Visitor Agreement.
In choosing the replacement car, I test drove the V-8 Lucerne . It seemed sluggish to me, by comparison with the Aurora. I test drove the 6 cylinder STS. It also seemed sluggish by comparison.
In my test drive, I found that the DTS Performance model put me back in my seat when I accelerated, and I could effortlessly pass cars going 70 miles per hour. I felt a significant increase in peppiness.
That has been my continuing experience for the past 20 months
One thing that I found with my Aurora was that the engine seemed to "breathe" better above 3000 RPMs. My Seville did not have a noticable improvement as the engine speed increased.
Your performance DTS is a bit quicker than the base model, and will give you the impression of greater performance in any particular gear. But, at 6000 RPM's the 3.11 axle will be going at a faster speed in any gear than the 3.71:1 axle ratio. My Seville could do about 90 MPH in second gear. I think that the DTS performance can do about 80 or so. My SRX will only do about 65 MPH in second, but I still have four gears left.
I took to a Schwab tire store today and they felt I could rotate at any time, they said the tires were wearing well and didn't see any urgency about doing it
at the moment. In the real world how often is enough?? If never rotated how much sooner would the tires wear out? I'm just trying to get a general idea on this based on fact finding and the experience of other DTS owners. Last important bit of information is that living in a small community I rarely have to slam on my brakes or brake hard and often let the car coasts to a very slow speed before using the brakes.
All suggestions appreciated.
As far as mileage, I routinely get 24-25 mpg. My wife took it to Charlotte a few weeks ago and even with a little stop and go driving, the DIC indicated 25.9 mpg when she pulled into the garage.
For the power and handling plus reasonably good mileage, I think that the performance model is very underrated.
Larry
The first one, with 32000 miles burned in my garage fire and was almost a year old.
Bought the second new one for a Christmas present in Dec 2006. It now has 30,000 miles on it.
I have had very little trouble out of either one of them. My Air Conditioned seat quit working and the dealer replaced the seat mudule while I was getting an oil change.
The trunk mounted tail light was cracked.... replaced while getting another oil change.
Had them check the NAV unit once for a strange glitch.
Battery died after sitting in my garage for over a week with the radar detector left on and the cell phone charger plugged in. I don't think THAT was Cadillacs fault.
Called OnStar... 5 minutes later my dealer called and said the service truck was on the way. Ten minutes later... service truck was here. Jumped started with no problem. He replaced the battery anyway.
It has been at the dealer a couple more times for real minor stuff. They always give me a new car to drive. Usually a Lux ll DTS.
All in all... VERY LITTLE trouble with a total of over 60,000 miles on the two DTS Performance Sedans.
I have one question to the forum...
Why do most people think that the Performance Sedan with the Magnetic Ride, ride SOFTER than the regular DTS?
My experience has been the exact opposite. The Magnetic Ride is quite a bit FIRMER than the regular DTS. I have driven SEVERAL of them, both before I bought my first Performance Sedan and several time when it has been at the dealer.
The regular DTS has a much more smooth, soft and floaty ride. It also does not seem as CONNECTED to the road as the Performance Sedan.
Texas Jim
I was urging my folks to look into a year-old DTS, but I think I'll hold off on that now. They have 42,000 completely problem free miles in their run-around-town car (a Civic EX); your DTS would be unacceptable.
I agree with you about the rough roads. It does smooth them out a lot.
I know it is not a SPORTS SEDAN. If I had wanted one of those, I would not have bought a big DTS.
I like big comfortable cars. I don't like one that beats me up on trips. I have had my share of THOSE.
But that said... it is not too shabby for it's size and weight in the handling department.
Texas Jim
I am also real particular about ANYTHING that I percieve as wrong with my car. If I think something is wrong... it goes back to the dealer.
I have been very happy with the two DTS Performance Sedans.
I find that my current SRX to handle much better than the Seville did, and I do not find the ride overly hard on long trips. I do have an optional sport package with lower profile tires (50's) on all four wheels. I think that on your DTS the ride would be harder without the magnetic shocks.
The Performance sedan wasn't on my radar until YOU guys on the cadillacforums suggested I try driving one...and my impression was that it did ride softer than the Lux III, though "softer" may not be the correct word. A couple of possibilities:
1: All suspensions are a compromise and the standard Caddy must be firm enough at highway for control yet soft enough in town for comfort. So you aim somewhere in the middle, compromising on both ends. The Magnaride lessens the compromise. It can allow a softer in town ride because the shocks will add the appropriate firmness for highway driving. Don't know if that is actually true, but the concept of the variable shocks would allow that kind of set up.
2. When I drove the Lux III, I felt more wallowing, maybe a bit more shudder, when large suspension movements occurred. That was pretty much eliminated by the Magnaride. So though the suspension might be stiffer, it gave a much more controlled ride, which resulted in a smoother ride that was perceived as softer.
To me the Performance model was closer to what I expect of a "Cadillac ride" than the standard suspension. That, along with a more responsive transmission sold me. (The car is due in the next two weeks.....)
Vic10 (aka TulsaVic)
Newport BT
when purchased new. The electrical system in DTS is still quirky at times but runs as designed most of the time. I enjoy owning these two fine cars but may choose either a Toyota, Honda, or Nissan as my partner for Town Car in the future. I am amazed to see so many American flags on the Japanese cars, I have never owned a foreign car but my experience with this DTS (my Third Cadillac) tells me it's time to strongly consider a Japanese car. The new car warranty on my DTS runs until mid 2011 or I would be inclined to trade it sooner.
I'd have to disagree with you on the Town Car. Granted, my only driving experience with one was a week long rental last year. But for such a large luxury car I found it uncomfortable. The seats gave the first impression of being soft, but I swear I could feel a hard bottom after awhile. Hated the driving position--plenty of legroom but sitting almost Corvette style with legs straight out rather than like sitting in a chair (which is what my 300C is like). Adequate performance around town but poor performance on the highway. Soft but not very controlled suspension. And one of the biggest complaints: Mushy brake pedal. I had to come to a sudden stop and had a hard time doing so...until I realized the engine was racing: The brake pedal mushed down so far that I ended up depressing the accelerator at the same time. (Granted, it WAS a rental car....). Overall it was a bit too dated for my tastes. Though I suppose for what you get for the money, it's a steal....
My Lady friend likes it enough she going to order a 09 in september , Enjoy the ride
but I thought new quality controls by most manufacturers had improved upon this. I guess there could still be issues with first model years including Cadillac. I am reasonably satisfied with 2006 DTS but just have had bullet proof results with my Town Car. In addition (for me) the best part of my experience with T.C. has been the seats and interior comfort in general. One of the reasons I like the forums such as this is that owners can compare experiences and results and develop better insights in to the car owning experience. Of course this experience is enhanced when people like your self post their experiences with out trying to diminish the experiences
of other owners and posters at this forum. Thanks again!
There is no right or wrong in this so any and all opinions are appreciated to help me evaluate whether
I need this system.
In addition, my wife had a flat tire recently in a remote area. She merely pulled over, kept the car doors locked and called OnStar for Cadillac's Roadside Assistance. Such assistance was forthcoming within minutes. For this alone I would keep OnStar operational.
On Cadillac.forums, one of the CTS contributors told how he was going down this relatively remote road, took a turn too fast, and rolled his car. OnStar responded when the airbags went off. As a result, he said he'd never drive without it.
If you've never had an event when it was needed, then the yearly cost seems like a waste. But if you've needed it just once, you can probably justify it forever.
I have no personal experience YET (If my new DTS doesn't come today I'll attack someone....). Ask me in a year if I think it's worth it. Since the car doesn't have NAV, I'll probably get some use...though I NEVER get lost.....
I travel a lot and use it quite a bit.
It is real nice, when coming into a strange town, to just push the button and ask the nice OnStar lady where the nearest Holiday Inn is. She tells you how to get there and will give you the phone number. Sometimes I have had them make the reservation for me. All I have to do is check on.
After you get checked in, you need to eat... Push the button and ask her where the steakhouse (or whatever) is, and she tells you how to get there.
It can save you a lot of trouble and hassle.
I also used it one time when I locked myself out of the car and was 50 miles from the nearest town. The cost of a locksmith to come out that far probably paid for at least a years subscription. And I didn't have to wait a couple of hours to get the car unlocked.
I would rate my level of satisfaction at around a six with ten being highest. PLEASE NOTE, I have the same problem as you do with the radio and turn signal audio not coming on at ignition, this happens around once a month on average, I giggle the on off switch on the radio and this generally corrects the problem but for a car of this category it is disappointing to have an unresolvable glitch like this.
Based on my experience I will probably not by a first model year again unless I do more checking than I did
for this car. My warranty runs out in mid 2011 and will probably replace the car before the end of the new car warranty period.
I hope you will continue to update us on your progress and the resolution of it and if I can be of assistance please post here and I will certainly try in that I own the same model year. Best wishes and continue to go after what you paid for, a good quality luxury car.
This has happened several times in my '07 DTS with 12k miles. Happens so infrequently that I didn't expect the dealer to be able to duplicate the problem. Until a service bulletin appears, there's probably nothing that can be done. I assume this glitch isn't setting any codes in the BCM.
"True, with On-Star turn by turn you do not have to type your destination. That is the only advantage. Just before my free subscription expired I called for directions to a very well known destination just to test the system. At the same time I set up my built-in system for the same destination
I purposely passed the destination. On Star asked if I wanted new directions by reconnecting to an advisor. This would mean waiting for a down load of new directions.
Meanwhile the built-in system had already re-calculated and was redirecting me to my destination. Also, you can see an actual map to clarify where you are with the built-in system.
I will not be renewing On Star unless they lower their prices."
Additionally, someone made mention that ONSTAR would direct you to restaurants and hotels. The built in NAV does this also if you have those options turned on. The map actually shows such things as gas, hotels, restaurants, and medical facilities right on the map, but you do initially have to tell the system what you want displayed.
The built in NAV is extremely easy to set up and use.
The built in NAV system is by far, better than On Star. I have a small portable NAV system that I purchased ($150.00) for my truck that outperforms On Star.
Anyone know what I'm talking about or have the same issues?
It's not just old people that like this car.
I rented a DTS in Janauray. After driving a Camaro, Prius, and a Mustang (i actually liked the seats) I was horribly spoiled by the drive and comfort of the DTS.
I made a hasty decision in February and bought a Honda Accord Coupe 2008. The body style and such is amazing and the performance is good. The problem is the seats are extremely uncomfortable for rides longer than 30mins.
I'm also considering an STS.
Many thanks for your reply.
From my experience, I would recommend you install only the tires recommended by the dealer (and let them do it). By installing tires purchased elsewhere, I unknowingly gave Cadillac a "way out" excuse which allowed them to completely blow me off with the claim that I caused the problem myself by putting on non-factory tires.
Even though I ended up getting rid of my DTS (I just couldn't take the vibration anymore) I still have followed this issue all over the internet. It seems to be very common on these vehicles, yet completely unresolved for the 2007 and 2008 model years.
Good luck with your Caddy. Keep us posted.
I think it amazing that GM has not got a handle on this and the salesman told me there been a few cases that even with original equipment they lemon law the car
being through Lemon Law on Audi A6 i will tell you to get all paper work before you leave shop , if your entitle to loaner take it even if you take it home and park it
record dates and times on phone to gm or garage and
any comments made by tech or any rep, good luck , i hope that they can fix it and you don't have to do lemon law
My 2005 Town Car gets about 29.5 in highway driving. T.C. weighs about 400 lbs. more than DTS, has a slightly smaller engine but has more than enough power in most every driving situation. You would be wise to consider any of the brands and models you mention. Only problem with Lexus is the cost to value ratio. I think Town Car wins on that basis against almost any luxury auto. Test drive them all and pick the one that suits you best and let us know who gets your preference and choice. In the meantime I would be in no hurry to part with your 2003 Deville. Best wishes!
The ride is excellent, with no vibration, ever. I'd call this car the most trouble free car that I've ever had, and the most fun to drive.
