Visitor Agreement.
My original intention in buying these things was to bring it back to unloaded ride height for headlight aim etc. But my truck sits quite high in the back w/o load so I'm not sure if I need to go all that way. Do you notice any headlight aim problems?
Truck didn't squat much at all (had several people watching and they all were shocked). I did have about 20-25 psi in the Airlifts to begin with and went up to about 50 psi with the camper load.
Truck handling seems fine, engine and transmission strong, brakes work great. I did notice some leaning on the turns. Vince your right, I need a stabilizer bar for sure. Let me know how yours works. I do have the Z85 HD Suspension Pkg. I tried the tow/haul mode and I like it.
The Lance 820 sticker shows 2773 lbs wet (39Gal Water, 40 lb LPG, 5cuft ice) but this is for a standard config, i.e. no options.
I had the torklift front tiedown welded today. The guy did a great job for only $5. I'm back in action!!
How do I locate a scale or weigh station? I wonder what to look up in the yellow pages to find one in the area?
Mike2
Places with scales: highway patrol weigh stations, rock yards, the dump. Mike L had his weighed I think, where Mike? I'm surprised Lance doesn't give you a final number with installed options. Did the dealer install some? If not I would call Lance and ask. Are you sure that sticker isn't an "as built" weight?
The Lance didn't give a as-built weight. They did give the wet weight of 2773 and a list of options with their weights. Air 100, Side Awning 51, Elec Jacks 40, Fiberglass 60, Oven 24, Gen 118, Gen Ready 30, Mattress 46, Storm Windows 24, Decor Pkg 20, Conv Pkg 20, Weather Pkg 20, Std Cab -80.
I have everything except Side Awning, Oven, Storm Windows, Std Cab. That totals to: 454 lbs. Grand total of 3227 lbs. Sure glad I have the elec Jacks!! The new Lances have a wireless remote control for the Jacks; with a camper switch enabling the remote for 10 minutes.
I need to get to a scale soon!
Mike2
Since my camper is on most of the time, I adjusted the headlights with the camper on. I rarely drive at night, except here in town where the streetlights reduce the need for headlights, so I have them too low without the camper. If I need to travel at night minus the camper, I will adjust them; it only takes a couple of minutes.
I weighed my outfit a couple of times. Once at a grain elevator. I weighed front, both and rear. Then again, in Canada and the midwest there are scales mounted to the side of the road at turnouts. I guess the highway patrol uses them for random inspections and the rest of the time they are available for public use. The two scales gave me the same numbers, so it must be accurate.
3100 F and 3400 R for a total of 6500 lbs on a 6400 lb GVWR. Gives me several hundred pounds under the axle ratings. I'd worry if I exceeded the axle rating. Having a bearing fail in the middle of nowhere is not my idea of fun.
Brutus, I never considered adding the camper shocks to my camper. You're right, its too light to need it. My point was that older trucks had flexible frames, even when empty! And they needed the help when a camper was added. And the new 3/4 ton may not need it because the new frames are much stronger than the old ones. In my dad's old camper, you could see the camper sway several inches at the front and the camper shocks really helped.
Later,
Mike L
I'm going to try to take some pictures of it over the holiday. I've got a 10 day break from work, so I am going to put it on. The camper and truck won't be at their best appearance-wise. It is winter up here, so they won't be the cleanest looking and they definitely won't be waxed. The camper was clean when I stored it, but we've had some snow (not enough in my opinion). I haven't fiddled around with a website yet, but I'm pretty sure I found a site to post some pictures on. I'll let you know when and if I get them on the web.
Chances are you may choose to get the airbags in the future. By not getting them right away, you can have a good before & after feel for the ride of the truck. The reason I am getting the airbags is so the truck will sit with the camper on like it does without it on. Even though I'm satisfied with the ride now, I think the truck will handle better if it sits the way it was designed. Weight distribution and braking factors should be optimized.
Make sure the Lance dealer knows that you have a Ford Supeduty so that he will include the platform with the installation. You absolutely need a platform. The cabs of the Superduties are higher. The cabover part of the camper will clear the cab, but there is not adequate clearance for some bumps you may encounter. My platform is basically 2x4s and plywood, but the dealer did a real nice job of putting it together. I get no movement of the camper or the platform when driving.
I've got the Supercab 4x4 dually and 4.30 axle ratio. I get 11.5-12 hwy empty and 8.5-9 with the camper. I can get close to 10 with the camper on flat hwys if I keep the speed at 55mph. Normally, I'm driving in the low to mid 60s and the hwys are not flat. The 2000 V-10s seem to be getting a little better mpg, despite having more hp and torque. If you get the 3.73s, your empty mpg should be 1-2mpg better. I'm not sure that you will do much better with the camper. Your camper will be about 1,000 pounds lighter, but the CC vs the SC probably adds about 400 pounds or so. If you have the 2x4 vs the 4x4, that will also make you a little lighter.
Also what type of tie down set up do you have?
Thanx John
My tiedowns are mounted to the frame on all four corners. The part of tie-down that stays on the truck is bolted directly to the frame. Another piece with the chain attached can be removed when the camper is not on, so the tie-down mounts are not visible when the camper is not on unless you get down and look under the truck. With my setup, nothing is attached to the bed, with the exception of the power cord. My power cord comes up through a small hole in the bed near the front of the bed on the driver's side. I like the setup. I was taking it on and off quite a bit during the summer. It would take me about 45 minutes to load and 35 to unload.
Mike2
It is the same size as the truck battery, group 78, I have the p/n at home and will post it later. Exide makes a group 78 but I don't know about deep cycle.
I'm just going to order it from the dealer but I haven't got around to it yet.
It's too bad you are having so much trouble fitting the camper. Is it an old one? I thought those built in the last 10 years would fit any truck. The 4 inch gap and taking off the bumper both suck, I wouldn't do either. It sounds like the Ford is the way to go. The platform will help the tank clear the bumper so it should fit fine.
What brand and size camper do you have?
Mike2
It will fit, just not as easy to do.
The camper is a 10 foot Sunlite pop up with a full bath.
I looked at the Super Duty Ford yesterday, and it now has a 60 inch wide bed at the rear of the tapered box. So what the General started several years ago has now spread to all of the big three.
The salesman at Ford is checking out utility boxes to go on a Superduty 350 cab/chassis for me. Probably too pricy but it might work. He has previously sold me three trucks and wants to help. The Dodge guy tried a highball deal that really turned me off but straightened out when I told him what his original invoice was on the used truck. The more I look at the new vehicles, the better my'95 seems.
I don't want to remove that bracket. It seems like an important structural component. If you are willing to remove it then you can fit any battery in that location and your problem is solved. I'll order the battery after the holidays and let you know.
It's been fun on this discussion group, and I look forward to picking up again next year!
Everybody have a Merry Christmas and a safe New Year celebration.
I hope you all have a joyous and prosperous 2000.
Best Regards,
Mike L
I called Intersate Battery and talked with a good guy. They do make it but it is a dual terminal version. This should work if the top terminals miss the bracket. Otherwise they could be hacksawed off. He also gave me a few other numbers.
C78DTXHD 120 min, 725 cca, dual terminal
10 5/16 x 6 7/8 x 7 13/16 (L x W x H)
C75DTXHD 100 min, 525 cca, dual terminal
9 1/2 x 7 1/4 x 8 3/8
C74XHD 130 min, 575 cca, side terminal
10 1/4 x 7 1/4 x 8 3/8
It looks like only the 78 is short enough. Now I have to find a local dealer and get a price. These guys sell to gas stations etc. and the price tends to be high.
Have a safe trip Mike, & a fantastic holiday. Vince, sounds like the tolerances on your camper are a bit more forgiving than mine. That extra 2" on mine sure makes a difference. I'll figure it out in due time. You too have a wounderful holiday. Merry Christmas everyone!
Gary-
Gary-
Mike
Truck only: Front 3460, Rear 2340, Total 5800
Both: Front 3520, Rear 5430, Total 8950
Oh well, didn't make GVWR (8600) but OK on Front (4410) and Rear (6000).
Weights included hitch, camper tiedowns, airlifts, 3/8 tank fuel/water, full LPG, wiring, extra radio, carpet and rubber bedliners, one person.
Guess I have to keep my king of overload title?
Mike
My camper is a Squire 4000 9.4 which is basically a 9 1/2 foot version. It weighs about 2300 lbs. The longer units are nice because more room is always good but I prefer this compromise between exterior and interior size. Mine also has a pop out rear section for the bathroom on the driver's side. It's no problem, there is still plenty of room for loading. Since the other side is straight all the way I just look at the driver's side when backing the last 50% and know the other side has lots of room.
I don't think the factory mud flaps work with the flares we have. For the photo, the only way I know is to put it on a personal web page. Your ISP likely offers free web space and it's pretty easy to set up. If you want to e-mail me your pictures I can post them on my page for all to see.
I got 9.6 mpg with mostly freeway at about 70 mph. I bet it would go up by 1 mpg at 55 mph, not that I'll ever find out.
The air bags need 75 psi to get it back to unloaded height. It looks kind of stupid like that though because the rear is so high. I lowered it closer to level in the daytime but ran it up to 75 at night so the lights would be aimed correctly. The on-board compressor is quite handy. I also let all the air out once to help level when parked.
The stock non-firm ride shocks are about maxed out with this load. It's okay but it is a little floaty and I feel bumps in the steering wheel more than when unloaded. Better shocks are in my future but not for awhile. I really don't want to make the unloaded ride worse. The side-to-side sway is not bad. It isn't even noticeable if you drive gently without sharp movements. I suppose better shocks would help this too.
So that's my report if anyone is interested.
Averaged 9.8 mpg doing 70 on freeway and a lot of 5 mph backcountry sightseeing.
Had 60psi in front and 80psi in rear tires. May go to 50 or 55 in front also. Had 75 psi in the AirLifts. Didn't adjust any air pressures this trip ( no compressor ). Side sway isn't bad at all without a stabilizer bar. Would like better shocks though. I have the firm ride shocks on mine but think adjustable shocks would help some.
Handling with the Lance 820 was very good. Really like the Torklift tie downs with the spring happi jack turnbuckles on all four. Tried all the equipment. Used the refrig on DC, AC, and LPG at different times. Fired up the generator to run the AC and microwave for lunch at Captiva Beach; really works great! At most campsites I just lowered the rear elec Jacks to stabilize the rig when jumping around!
My dog loved the trip. Just say "lets go camping" and she's ready to go! Next trip to Oscar Scherer State Park in Osprey FL this Sunday for a few days.
Mike2
Anyone out there with a second battery factory installation (Silverado) that can help us? Maybe there is some other "special" bracket used in place of the original one.
Mike2
I have a factory installed second battery in my GMC 2500 EC 4X4. How can I help?
Mike2
Happy '00
The truck comes with a bracket on each side. The tray for the aux battery sits directly under the bracket on the passenger side and so the available height for the aux battery is limited to about 7 1/2 inches. What we are wondering is how the factory deals with this. Do they remove the bracket, use a different one, or use a shorter battery? If you could compare the brackets on each side of the truck you can tell if they have used a special one on the aux battery side. If so it would need to bend up very near the 2 big bolts holding it to the fender.
Thanks for your help, you are our best and only hope for the answer because the dealers can't handle such detailed questions. One more item, you listed the battery as a 78-6yr and Mike said 78-7yr, is this a typo? Or maybe the answer?
And off to Death Valley. We had great weather - 70's in the daytime, 40's at night, 20's in the higher elevations.
We went in through the south. Through Ballarat and Indian Ranch Road (some interesting canyons to explore here), and in through Wildrose Canyon. Drove up to Aguerebery Point to overlook the Valley. Then down to Furnace Creek and find a nice campsite at Texas Springs. Beautiful, clear nights - you can easily see the Milky Way.
Next morning we went down the Westside Road and up in to Hanaupah Canyon. 9 miles of 4wd trail and it takes about 1 1/2 hours to get to the end. And our truck is the wider than most vehicles to pass this way, so we get to push the brush back on both sides at the same time.
Back on the Westside Road, we get a flat! Changing a flat on a dirt road is a new experience. Take the tire and $15 to the station in Furnace Creek for repairs. Back to Texas Springs for another beautiful night.
Next day we drove/hiked to the back of Golden Canyon. And then off to Racetrack. 27 miles of 4wd trail takes about 2 1/2 hours to get out there. It is a large, dry lake bed at about 3500-4000' elevation. At one end there are many large rocks up to 2'x2'x2' on the lake bed. And behind these rocks are trails where the rock has moved across the lakebed. Some trails are 2-300' long. One theory says the rocks move when it rains and the lakebed turns to mud and the wind blows 80+ mph. But, no one has every seen it happen.
It was getting late in the afternoon, so we found a spot and set up camp for the evening. After 5pm we did not see or hear anything moving. No cars, no critters, nothing! Very quiet. And very dark. The stars were brilliant!! We thought they were bright in Death Valley, up here was more so! When we woke up the next morning it was 34 in the camper (thank heaven for down). Probably 26-28 outside. Turned on the heater and got up 5 minutes later. 2 1/2 hours back to paved road and 8-9 hours more back home.
We could have used another 2 weeks, too much to see and do.
I'd say it's good to be back, but I am at work.
I'm only 5 numbers away from retirement (I got one).
Mike L
I don't believe any of the battery parts offer additional support over the base version. I (we) have the dubious advantage of intimate knowledge of both configurations. The battery tray you refer to is actually a replacement bracket for a smaller one in the base version. It uses the same mounting screws so doesn't provide any additional strength over the base bracket. The 3 screws you see going into the quarter panel fix a small L bracket used to support the end of the battery, or base, big bracket and to provide the stud for the coolant tank tab. Because the battery tray bracket doesn't mount directly to the quarter panel I don't believe it offers much to replace the loss of the upper bracket. I think I've pretty well beat this topic senseless but just to be sure I'll e-mail you a picture from the GM parts computer so you can have an idea of what's down there.
I do have one more question. Where does the battery negative cable attach to ground? From a different GM picture it appears to go somewhere on the engine. Mike2 where did you ground yours?
Thanks for all your help. I tried the parts manager with other aux battery questions and he had to call GM and still couldn't get a straight answer. I didn't have the courage to go back with this one.
AAA has a nice Death Valley map. I bought another map at the map store on Washington St in Santa Clara. Gotta have good maps.
Changing the tire was not a big problem, just dirty. You have to lay on the ground to get the spare in or out. I had to lay on the ground to locate the jack under the axle. The jack is not happy with dirt/dust/sand in it. (I still don't know how you will get your spare out with your camper on the truck)
Yes the truck gets scratches if you use it. But that is better than having 4x4 cause it looks cool. Trucks are meant to be used and to get scratched. It is still traumatic when it happens.
You can probably get out to these places faster than we did. We averaged 10 mph and everyone else seemed to average about 30+ mph. Of course, 2 of 6 SUV's that passed us had flats by the time they got to Racetrack. And our flat happened on a smooth stretch of the Westside Rd. when we were going 35 mph. It seems the front tire kicks up a rock and the rear hits it just right (wrong?) to get a puncture. I wouldn't mind leaving the camper behind and day tripping, but it does limit you a little. We were able to stop and camp where ever we were. If the camper were back at Texas Springs then we would have to head back there. But it would be nice to leave the weight when putting around. All the dirt areas in Death Valley are dangerous in rainy weather. Flash floods and washouts are common, even if the sun is shining where you are, the water floods down from the hills.
Vince, have you been in Death Valley before? I've been about 10 times. Still much to be seen and checked out. November to April seems to be the right time to go, but even in the middle of summer it is enjoyable.
Mike L
You may be right that GM just 86'd the brackett because it was in the way. Some serious thought and work went into the new design, but production types don't always consult the design team before they make modifications.
Tom
You say the middle of summer is enjoyable??? I actually like heat but draw the line at 120 degrees so I'll wait for winter.
