Visitor Agreement.
Vince - My battery is a 78A-84. The 7YR or the 84(month) is the warranty. I'm not sure if there is a difference in the 78 and 78A. Noticed the longer warranty battery 78-7YR has slightly better specs than the 5YR or 6YR on reserve capacity (120 min vs 100,110 respectively). Also has larger C.C.A (who cares for second battery). Since it is too difficult to get a deep cycle battery (10.9 X 7.0 X 7.3), I got the 78A-84 for the extra capacity. The cost was $81.
Mike2
On 99's you turn on the key and wait until the lights stop changing and pump the gas 5 times. On the 00's you only step on the gas 3 times.
Hope this works for you.
Mike
As far as the back is concerned this guy I went to is talking about being able to connect to my hitch from the sides. The only cabover I've had before was on a Dodge Dakota and i had stake pocket mounting on that, so I'm not real sure of the best way to go with my 00 F350.
Thanks for any help.
John
99 F-350SD SC Lariat 4x4 dually V-10 auto 4.30 l/s
99 Bigfoot 3000 10'11"
See the frame mounts at www.torklift.com and the bed mounts at www.happijac.com.
One other thing I was wondering about is if the frame mount system shows much when not in use?I know that seems like a petty concern, but on a new truck I would hate to have big ugly camper mounts sticking out.
Thanks for the information.
John
The frame mounts are in two parts. One part stays mounted to the frame at all times. The other part is about an 18 inch piece of steal that has the chain on it. This part slides into the part attached to the frame and is secured by a wingnut and locking washer. This part is always removed when the camper is on the truck. When it is removed, you cannot see the frame mounts.
I got lazy (and we had some subzero temps) so I didn't get the camper on over the break. Eventually, I'll get some pictures.....
but I was wondering about the receiver part that stays on the truck, do those parts show much?
since I also have a Superduty I am going to need that platform also. How is your's made?
John
Does anyone have any experience with these brands? Are there others I should be considering?
I have yet to meet a Lance or Bigfoot owner who was dissatisfied with their purchase. They appear to be a step above when it comes to quality, although they tend to be a step above in price also. Bigfoot campers are made in Canada. The number of dealers in the US are limited, and those dealers tend to know it. That makes it harder to negotiate a good price. If you can travel to pick it up, you can get a good price.
Keep in mind that just because Lance and Bigfoot are considered by many to be the highest quality, that certainly does not mean that the others are low quality. There are alot of good campers to choose from in a variety of different price ranges. A good site for camper questions can be found at www.happycampers.net. Click on "Chat". You can do a site search using keywords such as "Northern Lite" or "Lance" or "Bigfoot" or "Feetwood". You can also create a new thread.
The dually is best if you are going to leave the camper on most of the time. No doubt it is more stable. But a singley will do the job just fine too and not be so wide when the camper is off. I never considered a dually because I use my truck for a daily driver without the camper and don't want to deal with a truck that's as wide as my camper.
I don't know Northern Lite but I have a Lance and am happy with it. If you want less weight you need to go with their Lite series. But then you give up a bunch of goodies so you may not be content for 10-20 years with that choice. On that truck a few hundred more pounds won't be a big deal. It sounds like the Bigfoot has a great cold weather package, Lance also has one but I don't know if it's as good. One thing going for Lance is resale value and ease. All camper shoppers know the name and it's very popular on the used market so you can sell one quick. They are expensive when buying new though. I looked at a 9.5' model last year and they wanted $17k.
As I've mentioned before, I exceed the GVWR of my truck even with the duallys, so my camper (10'11" Bigfoot 3000) would not be recommended for a single rear wheel truck. I see the Bigfoot 2500 models on SRW trucks all the time. No doubt they are over their GVWR, but they are at least 500 pounds lighter than my camper. I weighed in one time last summer, loaded for a trip including two full propane tanks, 30 gallons of water and 38 gallons of gasoline and I topped the scales a little over 11,700 with me in the truck.
The diesel weighs more so it does reduce the payload. The good news is that the majority of your camper weight is on the rear axle, while the majority of your diesel weight is on the front axle, so you're more than likely not exceeding the GAWR of either axle. I know someone who has the same camper as I do and carries it on a Superduty with the diesel and 4.10. He gets about 5mpg better than I get with the V-10 and 4.30.
I'm sure you would adapt to the dually however parking spaces etc. don't adapt to it. So some portion of adapting is simply not doing what you could otherwise do. For me, it is very different driving with and without the camper. In one case I choose my next move carefully and often just have to be more patient, in the other case I don't need to give it much thought and drive almost the same as in my small car. We have terminal bumper-to-bumper traffic here so being a bit smaller is often handy. But I use the truck for a daily driver. If you won't then pick what's right for the camper you really want.
Sorry, I couldn't resist.
Mike L
Thanks also for the reminder about adding in the weight of the diesel engine in my weight calculations. I had completely overlooked that.
I will probably buy the Northern Lite, but first I need to find a different truck, since my current truck isn't camper-capable. I'm looking for a used F350 diesel (or possibly Ram 3500) with a manual transmission.
Since they don't have a place to check out dealer invoice cost like you can with cars, it's really hard to figure out what is a fair price. A lady on another website was trying to sell a fairly new Bigfoot that seemed to be just like mine. She was asking almost $30,000. I bought mine for $22,600 installed, including construction of the platform. I added the $2,500 generator, so I was out the door for $25,100. Her's included the generator also, but the fact that she was asking $5,000 more for a used unit than I paid for mine new shows that there is a lot of room to negotiate. Out-of-State dealers are more than happy to give you price quotes over the phone and might even offer you a better deal than the locals since they know they need to entice you to drive up and pick it up.
Since you leave the camper on all the time the popup is great. I prefer the luxury of the bigger unit and the use of my truck when it's off. The only advantage of the popup I envy is the ability to go off-road.
For anyone buying a new camper, absolutely for sure definitely get this option if it's offered. It's an important safety feature as well as a convenience.
I'll definitely be checking out that lower window. I still foresee significant blind spots. My truck also sits up pretty high, so I doubt I would see a car sitting directly behind me.
Anything else I should know about my camper? I can't believe I never thought about the window. I'm still learning new stuff all the time. Although I picked it up last January, I really only used it from May through Labor Day. Of course, I did use it just about every weekend. This year, I plan to get out earlier and stay out later, maybe even do some winter camping. I should be able to winterize it for the season around the middle to the end of April.
Thanks for window tip Vince......
Actually being able to see people (especially kids) while backing is why I consider the window a required safety item. I don't open the slider or anything, I can see out in the rear view mirror just fine.
Does anyone have any opinion or knowledge about the suitability of campers for off road use on a 4x4? I'm especially wondering whether there is a strong disadvantage or advantage to either wood frame (Lance) construction as opposed to molded fiberglass (Northern Lite, Bigfoot).
I know a pop-up would be best for this, but I need a camper that I can also use as a mobile office (for writing). I don't want to raise and lower it all the time.
I'm not talking about serious four wheeling on challenging trails. I have a Jeep CJ for that. But I do want to be able to travel long distances on very rough unpaved roads. The two conditions that concern me most are washboard surfaces that continually pound the vehicle, and deep ruts that may put extreme twisting pressures on the camper.
Thanks in advance!
Photo 1 - This photo is of the rear left mount. It was hard to get a photo of the rear mounts that would show you exactly how it is attached. You can see a little hole in the left side. That's for the bolt that you put in after you have slid in the second part of the mount. You line up the bolt holes in both pieces and then secure it with a locking washer and wing nut.
Photo 2 - This is a shot from the rear of the truck. As you can tell, I had the truck running and warming up. It is less than 10 degrees and snowing right now. The point of this photo was to show that the mounts do not extend out from under the truck without the slide-in parts attached, so you can't see them unless you look under the truck and you won't be bumping your shins on them.
Photo 3 - This is a photo of the front mount on the driver's side. I was sitting right in front of the rear tires when I took it. As you can tell, the front frame mount is very well secured since the front tie-down takes the brunt of the pressure of the camper. The cord hanging down is my light cord. It goes up through a hole in the bed. If I pull the cord in the bed, the slack will take up and you wouldn't see it.
Photo 4 - This is the front left on the passenger side, also taken while sitting directly in front of the rear dually.
Truck 1 - This photo was taken in September. After I came in this afternoon, I realized that I hadn't a taken a photo that would show that the mounts don't show so I included it. This is of the front driver's side.
Truck 2 - Ditto for this photo except it's a rear view.
If you travel slow and have a strong nerve I guess you could do quite a lot with a camper on. I just feel too nervous to push it. One problem I have run into (literally!) is low branches. The tall camper on a tall truck requires more clearance than any other vehicle traveling those trails so you could be stopped cold.
As far as the wood frame, I think any good brand camper is going to hold up structurally. It's likely the small things and appliances that will show the wear.
If you read back in this topic, Mike L has a popup he uses for off-road and we have discussed the merits of both styles. You need to decide which is more important to you, convenience or versatility.
One other thing, how much space do you think is needed between the cab of the truck with cab running lights and the cab over part of the camper? Since I will need a platform to raise it up a few inches I want to get it right the first time around.
I went out yesterday and bought a used 93 Lance Squire that's 10.3ft long. This camper is great,
it looks just like new, The guy I bought it from is going to deliver it to me since my truck isn't set up for it yet.
I can't wait to see how my truck will handle the camper and boat together.
John
We don't have 4wd so we stay on two track at least. We did drive out over some tufa beds at a hot spring so we could get a level place to park for the night and I wondered if we would poke through. Came out OK. I worried about environmental impact but a few others had already done it at this remote site and I don't think we did any harm.
Avoiding tree limbs is a real plus. Also many pop tops are only 7 ft wide so when you are tipped to the side it is easier to get between narrow places in the trees.
How much room did you have for the aux battery?
I'm asking because I ran across a deep cycle battery that can be 6.8" high. Will that fit under the bracket?
It is an Optima battery, has no liquid and can be installed in any orientation. Laying on its side it is 10" x 7.8"x 6.8". 750CCA. A marine battery so it can be left for months without problems.
Failing that, I guess I would mount the battery in the bed of the truck under the right front corner of the camper. Lots of wasted space there.
Still undecided on the truck purchase.
Mike
The answer as I assume you read is to remove the bracket. This is GM's enlightened solution. I've gone out twice with just the brand new camper battery and it did fine so I haven't gotten back to this issue yet. I do want the second one though because it lets you not worry about having many lights on, or running the heater a lot in cold weather. I also used it to jump the truck when the battery failed in my last truck. Good peace of mind if you are out in the boonies.
If you do go for the new truck be sure to order this option. Maybe you could set a number goal to resolve the issue, like order a new truck when yours has 60k miles. Or maybe order a 2002 model year. I hear they are going to put alum heads on the 6.0 and boost the hp. I'm not sure which I'd rather have, cast iron or hp. I like both.
If I order a 2500 it will have the Aux Battery option. However, at this time nobody wants to take an order for a GMS price on this truck.
One dealer told me that 3/4 tons are so scarce they can sell them at list. Why would he want to waste a scarce allocation on a GMS deal?
I actually located a 3/4 ton 4x4 stick shift truck in CA. But, it is white, does not have the aux battery, aluminum wheels, fog lamps or the camper mirrors. $24K. I do like the truck I have, so I'm not ready to settle for less than I want (salesmen hate that). None of the dealers want to deal with a manual trans. Only one in CA is a GMC.
One of the features I really want to get on a new truck is the foldown center seat. I actually found one in a wrecking yard, but they wanted $1000 (yes, one thousand dollars) for it. I guess they wanted it more than I did.
Hey, it is starting to look like I can go snow camping next month. I was getting worried for a while. I put a new thermostat in the camper that I can set down to 35. Just enough to keep the water from freezing. Max is 75. Actually it is a standard thermostat adjusted 10 degrees.
We are looking forward to snow camping. We will probably have the place to ourselves again. If it is half as good as I think it will be, we will have a great time.
Later, I have to work now.
That $1000 seat is crazy. I bet they hold out for someone that really must have one, or possibly to sell to an insurance company. My dad's Blazer was stolen and recovered a few years ago and they trashed the seats. The insurance co. looked all over the country for used seats because the truck was several years old. It took awhile but they found some and probably paid a bunch.
You can have your 35 degree thermostat, eee gads that's cold! I'm happy to use the fuel to keep mine at 50-55 at night but it is noisy. Remember that 35 at the thermostat isn't 35 inside the cupboards where the plumbing is. Those are closer to the outside and are much cooler than the camper interior. You should probably use about 40 or so.
Where are you going to go? Do you know of any campgrounds that are open or do you just make your own?
When we were at Racetrack in Death Valley, it was 34 in the morning when we woke up. That lightweight down comforter works great!! Reach over and turn the heater on and wait a while to get up.
I don't think the water system will freeze at 32. First, it is contained and any pressure will lower the freezing point - ice expands and the pipe wont let it expand. And that lowers the freezing point substantially. Second, the plumbing is all plastic and it doesn't conduct heat very well. It will freeze, but probably not until it has been 25 or less for several hours. Keeping the thermostat at 35 should work, and we know we can sleep at that temp.
I'm think seriously about waiting for the 2001's to come out. They may have some little improvements like the 2000's do (headlights switchable, programable door locks), and the new HD pickups should be available. Might reduce demand for 2500's. I actually like the sound of the new diesel engine, but the cost so much in $$ and weight. Ideally, the 5.3 with the HD 5-speed, but that is not available. So, 6.0 5-spd is my only real choice. My only real concern is with fuel economy.
But, I really like my current truck. Maybe, selling the camper (that we also like) and getting a 4 Wheel Camper that is lighter weight is the right solution.
http://www.optimabatteries.com/main.htm
What you really need to do is pull that seat out and modify it so the middle folds down. You may even be able to make a hinged top for it. It would be a fun project for which you have the ability and equipment. Then you would be happier until 2001. Waiting is a good idea because this is still a new model so they continue to make small improvements.
Are you interested in company next month?
Length: 10" 254 mm
Width: 6.8" 172.2 mm
Height: 7.8" 198.1 mm(height at the top of the terminals)
Minimum Weight: 43.8lb. 19.89kg
Terminal Configuration: SAE / BCI automotive and GM style side terminal (3/8" - 16 UNC - 2B, threaded nut).
Notice the height includes the terminals. I just measured my terminals and they are 3/4 inch so the battery is only 7" high! That will fit. I'll cut the terminals if I have to.
The construction method is impressive, I'm sold. Now to find the best price. By the way, if you are interested you could add one to your truck easily. Thanks for the idea.
To me the Torx lift is a better system.
Brutus, you never said what brand of frame mount you used. From your pics they look different then Torx lift.
Anybody else use the Torx lift brand? How do you like them?
Thanx John
Base on dealer trade in value it would only cost about $8-9000 to move from a 99 1/2 ton Base model truck to a 00 3/4 ton LS. If I sold my truck for near Blue Book it would be about $4-5000 to make the move.
And it costs almost nothing to do nothing. I actually looked at a 00 1/2 ton LS. $3-4000 less than the 3/4 ton. (after looking at the 3/4 ton LS I realized there are a lot of features on the LS that are not on the base model)
You may not realize it, but you guys are acting as a sounding board as I try to make a decision. Thanks for being there and listening and offering advice.
Mike
I don't mind company at all. Still don't know if we can get into the campground. Technically it is closed. But, I've talked to others who have camped there in the winter. As long as the road is passable and the gates aren't chained it should be OK. Lodgepole is a fallback.
I never thought we would have water at a snow camp. Even if it was there, it would be frozen. We use what we bring.
I had forgotten about Tom's book. I mean completely forgotten. Can you refresh my memory with the name? I would guess it is something you can buy at REI or ??
We are planning on going out on the 19th and returning on the 21st. That gives all day on the 19th to find a spot and get settled in. 20th is a play day. You know, wander around in the snow, get frostbite, retreat to the camper and indulge in some hot tea so you can repeat the frostbite. It has been so long since we have been in the snow, that we may not have as much fun as we expect.
Hopefully the weather cooperates that weekend, or we may wind up down in the central valley with the mountain roads impassable.
Mike
As far as the rear mounts, I'm pretty sure they are mounted to the frame and the bolt extends down through the hitch. I'll double check that for you also.
This dealer knew exactly what he was doing with the installation. They loaned me a car so I could go take a scenic drive up to the local ski resort and grab a bite to eat. The installation only took a couple of hours. That included construction of the platform for the bed, the wiring, and the frame mounts. I was pretty impressed.
The only thing that I was disappointed with concerning the installation was that he put on the wimpy stock turnbuckles. For those of you who do not know what I am talking about, I will take some pictures of the stock and new turnbuckles in the next few days and can e-mail them to anyone who is interested. I will also get the brand name. I just found out that our digital camera here at the office is getting sent out to a remote location with our Forester in a week or two.
As far as the website, I'm pushing for late March or early April. For starters, I have to get a digital camera or scanner. I will also be in a better position to update regularly if I wait until we get closer to the summer camping and fishing trip. The site will be very basic since I'm no web master, but it's something that I definitley plan to put together. Heck, it's free. Everybody should try to set one up. It's an inexpensive way to keep the relatives around the US up to date on what you're up to.
Feel free to ask stupid questions when you get to it.
