Cabover Camper Chat
145679
  • vince4vince4 Member Posts: 1,268
    For everyone in California, I recommend this book:
    California Camping
    by Tom Stienstra
    It is a very complete, concise resource. I think once or twice in 10 years I found a campground not included. He gives info on facilities, directions (usually good), cost (usually wrong), open periods, and contact phone numbers. He also describes the general area briefly.
    You can find it at amazon.com, camping stores, and book stores.
    Mike, I bet the campground is chained or gated. I've seen that in snow areas before. I'm interested in going however I like to get a jump and leave Friday afternoon or evening if possible. If it's a far location then stay the night along the way. What do you think.
  • mcollins2mcollins2 Member Posts: 24
    John - I have the tork lift tie downs on my 00 Silv 2500 SB Ext Cab. They work great! The fronts are very strong (have a 45 degree support arm for strength) and mounted to existing holes in the frame. The rears are made to bolt to tork lifts hitch, three 1/2" bolts on each side. I installed a Reese Titan hitch on the truck, and there was a hole that lined up (required enlarging though).
    When mounting the fronts you have to drill the hole for the support arm length. I marked the hole with the support arm out as far as I could (for more strength, but still inside the truck exterior) and left about 3/4-1" clearance for the horizontal arm to truck exterior.
    I clamped the rear mount to the hitch side plates and marked for the same 3/4-1" clearance. Then drilled the 3 holes on each side. The rears don't have the 45 degree support arms but are still very strong.
    I use the Happijac turnbuckle springs on all four mounts. I have the CA-TBS springs with the TBH-24 long threaded Hooks. The rears are perfect length. The fronts required 3-4 links of chain (supplied with the Tork lift mounts) to make the required length.
    Had one problem; one of the front mounts was only tack welded. I had it welded locally. Apparently the quality checks at Tork Lift aren't that great. Check yours before mounting. Mine all looked fine a first glace; all painted.
    Good luck,
    Mike2
  • stabburstabbur Member Posts: 75
    If you are lucky it is amazing what you can get away with. Several years ago in February before buying our camper we rented a motor home in Great Falls Montana and drove around that area. We made arrangements to park it at Mammoth and take the snow coach into Yellowstone for some ski touring.
    I had planned to hook up the motor home to electric when we left it for a few days, but that was not feasible and the Park Service had just prohibited the use of generators while unoccupied RVs were left in the lot because one had just burned up. With reservations on the snow cat and a rushed departure there was no time for a pipe drain or a trip to get antifreeze. We turned on the furnace and locked the door.
    Four days later when we returned the aux battery for the furnace was long gone and everything in the RV was frozen solid. We got the engine started, then the generator, and microwaved the frozen oranges and potatoes so we could have something to eat. All the plastic pipe was frozen and the water tank under the bed was a one huge chunk of ice. I hadn't even left the water heater going while we were skiing and it was frozen, too. With the furnace and vehicle heater going it took forever to get the interior comfortable.
    We left cabinet doors open, fearing the worst, but one by one the pipes thawed out without leaking. The water heater didn't even leak. We were left with that huge ice cube in the water tank. My daughter rigged a tube of rolled up magazines and duct tape that she ran from the furnace grate to the door under the bed and after a night of the hot air blast, it thawed too. No leaks anywhere. Took it back to the rental place with no comments. Now if I had owned it, there would have been 50 gallons of water soaking everything.
  • BrutusBrutus Member Posts: 1,113
    Sounds like you got lucky with the freeze up. This is the first time I have winterized my camper. Although I'm sure I did everything alright, there will still be some nervousness until I dewinterize it. Winterization of my camper is pretty easy. There is a tube that I stick into the jug of antifreeze and then I start turning on faucets.
    More than likely, the reason it took so long to warm up the camper was that propane doesn't like to be cold for extended periods. My camper had been sitting in temps of -25 to -38 degrees for 48 hours once. The heater worked, but my propane generator would not crank. After letting the heat run on the battery for about six hours, the interior temp was still only about 55, but the propane was obviously warming up. My Bigfoot camper is rated to -40 and the heater is a 25,000 BTU, so even though it was -25 or so outside, it wasn't the insulation or heater. It was simply cold propane. I've heard of people wrapping their propane tanks when they don't plan to keep their heaters running for 24+ hours, but want to get immediate heat when they return.
  • jraskejraske Member Posts: 131
    Mike I don't know what to expect when I get my mounts, I talked to a Torx lift rep, and was told they would come in pieces and have to be bolted together rather than being welded, I have a brochure that shows them being welded like you mentioned, when I asked about the pic, he said they weren't like that. Is it because yours are several years old? and they have had a design change? Maybe they are different for Ford Super Duty Trucks I should get mine this week and find out then.
    John
    John, I bought mine less than 1 month ago. I was the first to use them on 3/4 ton SB Chevy. They don't look anything like their pics. As I said mine bolted together but had some welded pieces that mount to the truck (most of the welds were to made to go around interfering metal on the truck). The directions that came with the mount didn't match either. The directions indicated that I needed to move the parking brake cable; mine fit perfect without moving. Check your welds when they come in; one piece was only tack welded and broke right away when I put tension on the spring turnbuckles.
    Mike2
  • mledtjemledtje Member Posts: 1,123
    Vince,
    This campground is 'closed' from 9-30 on. However, we stayed there in early October and it was not gated. The campgrounds near Hume Lake were locked but not these little ones. My fallback is Azalea campground near Grant Grove, it is supposed to be open all year, and it is not too bad. Both are near 6500' feet and should have snow after this last weekend.
    Certainly you can camp with us. It is always nice to have company, help if you get stuck or break down. But, we are not the best of traveling companions. We travel the speed limit, stop early for meals, etc. We don't travel after dark unless absolutely neccesary. A late morning start is 7 am for us. We are usually asleep by 8:30 and up by 5 (sometimes on weekends we sleep in until 6). I know from your posting times that you are more of a nightowl. If you still want to camp, bs, hike, etc. with us, we would like to have you join us.
    If you want to leave early (Fri) and meet somewhere, let me know.
    I ordered Tom's campground guide from REI. I should have it this week. Thanks for the suggestion.
    Mike
    Mike, I've been in Phoenix for 4 days and just got back. Lovely weather, 70 degrees and sunny.
    I'll e-mail you about the trip, no need to clutter the public board.
    Vince - How you been. Send me the e-mail too; I am planning a trip to Phoenix this yr (frm Fl).
    Did you get your battery yet. Wondering about the clearance on the posts. Or are you cutting them off. I was worried about that. I've had good performance with the Delco. Hope I don't have to replace it too often.
    Mike2
  • grizzly1grizzly1 Member Posts: 111
    Mike, Vince, How is everyone doing? I guess I was a little disapointed not being able to get my camper loaded the first time. I did keep my cool though. A long story short, I got the damn thing loaded. My wife & I that is. The first time I tried it, I stayed in the truck, & had a friend guide me. WRONG! The second time my wife & I did it, the difference being, I got out of the truck quite often to see for myself what I had to do. The ground not being level didn't help matters, but persistence paid off. Took it for a test drive, only to find out how top heavy it is. I had my air lifts at 65#, & 65 in my tires. What do you run? Power was not a problem. Guess you get use to it being top heavy, but I'm not sure I want to deal with that. Another thing is , when we get to camp we like to go places, not just sit in camp, & I know for sure, I wouldn't be unloading & loading each time. We love the camper, but we still may sell it & get a small fiver, (20/23'). We would then have use of the truck at camp. I know we would be somewhat restricted on where we could take it, but the Lance also has a height problem in some areas. Isn't this something, have a nice Lance camper & not sure if I want to keep it. If it were a little smaller, like a 9.5, or maybe even a pop-up, I might stay with it. Mike, have you looked at the four wheel campers in Woodland? Vince, does the sway bar make much of a difference? By the way, I love my truck,& have had no problems at this time. More miles will tell. I better get off here..sorry about the length. Will write some more later.
    Gary-
    The trip I referred to is a snow camping trip Mike L and I are talking about doing. My Phoenix trip was for work, a multi-day party/training/team building for a new division. The weather was great, lots of nice sun with some clouds. It was unusually warm even for Phoenix according to the locals.
    I haven't bought the battery yet. If you've been reading the posts you know I think the Optima deep cycle will fit with the bracket in place. It's also a superior battery but rather expensive. The best I've found on the web is $169 including shipping. List is $170 I think. I thought I should call a few local places first before ordering on the web. I'll let you know how it fits.
    Welcome back. Glad to hear you finally got the camper on even if it was somewhat difficult. I guess we all have our tolerance limits but as I've said, with practice it should be mostly painless. They are top-heavy, you have to get used to that and adjust your driving style. Our trucks are a little on the mushy side so they ride better empty, and that adds to the problem. The sway bar is very much needed and will help but will not eliminate the tilt. Better shocks would help too.
    I usually just go see the sites with the camper on. It's a little cumbersome but not a real problem. You have to get it road worthy every day which is a bit of a hassle but the trade-off is that you have your home wherever you go. That's handy when you want to change clothes, make lunch, take a nap etc. Since I have a dog it is also a place I can leave her when I go places she can't. Sometimes I drop it in camp if I want the truck empty but not often. Probably the only reason would be to go off-road.
    Get out and use it whenever possible to give it a fair chance before you decide to sell.
    Nice to hear from you. I agree far as driving around with the camper on. It is nice to have your home with you, just in case you want to stay where your at. My other rig was like that.. I always had everything with me. Oh, I like it here, I think we will just stay. I am going to give it another chance.. it such a nice camper. I hate to give it up. I feel the loading of the camper will be much easier, now that I know what to look for. Have you replaced your shocks? What after market shocks would you install? Did Hellwig get there act together on the sway bar for our trucks, or do you still have to jury rig it? Any problems with the truck? How much air in your Air lifts, & tires when loaded? I'll let you know what I decide.
    Gary-
    I remember the first time I drove my truck with the camper on. I couldn't imagine driving regularly with all that weight on top. The good news was that I had 2,000 hwy miles before I got home. A few hundred miles into the trip and I barely knew it was up there. I had a similar adjustment when I first drove the dually truck, albeit, on a smaller scale.
    I have found that it is usually convenient to see the sites with the camper on. In the past, we would leave camp and head to the fishing spot or the clam digging area. The need to eat often dictated when we headed back to camp or it necessitated packing food to bring with us. With the camper on the truck, we had our kitchen with us, not to mention our bathroom.
    Slide-ins definitely aren't for everyone. If you don't anticipate eventually having toys to tow behind (snowmachines, boats, 4 wheelers), conventional or fifth wheels are often the better choice. You definitely have more room since your living space doesn't have to fit in the bed of the truck. A small conventional or fiver can usually get into many of the same places a hard side pickup camper can.
    You're not going to do too much serious off-roading with a hardside camper on. The height and weight issues will be limitations. When my camper is on, my height clearance is around 11.5 feet. I'm scraping some branches getting into my tighter, off-the-beaten path camping places. I just drive slow and check for tree sap once I'm stopped. If you're going to be doing any serious off-roading, I think the pop-up slide-in would be very hard to beat.
    One more thing.....
    The loading and unloading gets easier also as you get more experience. I load and unload by myself, often loading after work and unloading on a lunch hour the day after I return from a trip. I've got it down to about 45 minutes to load and 35 to unload. When loading, I'm usually backing up a few inches, hopping out to look, jumping back in, turning the wheel a little, backing up a few inches and repeating the process. It's not unusual for me to have to pull all the way out and make another run at it, but like I said, the entire process usually is finished in 45 minutes or less.
    Thanks for some feed back. All points well taken. I guess I'll just have to get out & do along test drive. My camper is actually lighter than the newer Lances, even the smaller ones. I know it's a matter of adjusting your driving habits, & knowing your limitations on where you can & can't go. As far as the loading, that will come with practice. The second time, it took me approx. 45min. total. Not too bad. I do need some after-market mirrors though. Not being able to see behind you is the pits. Is anyone familiar with the mirrors that attach to your existing stock mirrors. They show them in the Trailer Life magazine on page 118 in the Feb. issue. They look as if they might do the job. I don't think I'll be doing a lot of 4 wheeling, but with a pop up your not as top heavy. Have you ever seen the Alaskan camper. A bit pricey, & not much to look at, but built very well for a pop up hard side camper. At this time, we're going to give our Lance another shot. It helps to talk to other cab over camper owners. Thanks again for any input.
    Gary-
    No I still have the factory non-firm ride shocks. They are a bit overwhelmed with the camper on but not so bad that I'm going to run out and change them. The Edelbrock (sp?) shocks are tempting, they say they react differently to body lean vs. bumps. I'm dubious because often "automatic" devices don't work as advertised. Rancho makes a manually adjustable shock with 5 positions you select by turning a knob or something. That sounds good to me since I only need two modes: no load and camper on. However those shocks are not gas pressure types, does anyone think that matters much? Gas was introduced to improve handling in cars, I bet it doesn't matter in a big oafy truck.
    The Hellwig bar could stand a design modification to make it less stupid but it does fit with a little effort. I don't know if they have fixed it by this time. I did complain and they seemed interested. If you care you could call Robert and ask, I can give you his number. If you intended on keeping the camper you really should install someone's stabilizer bar. Take the truck to a suspension shop and let them suggest something.
    I noticed you are running 65 psi in the rear tires with the camper on. That's under inflated with such a load, you should run 80 psi for sure. It's always better to be high than low. I bumped the fronts up to 60 just for general principals but it does make the bumps sharper. Based on the weight measurements Mike2 made I think leaving the front at 50 is fine. He measured front and rear axle weights with and without the camper. The front weight only went up a few hundred pounds. Anyway GM specs 50 and that must be for a full load.
    The air bags take 75 psi to bring the truck back to no-load height, which has the back end sticking up a bit. I try to drive with about 55 in the day so the truck is level and bump it up to 75 at night so the lights shine on the road. It's easy since I have the on-board compressor.
    On the loading issue, I usually get the truck backed up on the first try and almost never need to get out until it's all the way back. I'm not saying that to brag, rather to give you some hope for the future. My camper is an easy fit with all the wide stuff on only the driver's side which really helps. Maybe your camper is different since it's a few years older. I have pictures of mine now which I'll post shortly.
    Brutus, e-mail me a picture of your rig when you get one and I'll put it on my web page.
    Well I finally bought a battery. I ended up with the Optima D750U deep cycle. It is only 7" high but will still not fit under the bracket so I just removed the bracket. It does mount down using the standard GM method which is nice.
    These batteries are expensive but use a superior construction technique. The best price I found on-line was $169 delivered. I called two local battery shops, the first one quoted $169 and the second $140. Guess where I bought it.
    It fit fine and the GM side terminal cables worked great.
    Have you ever thought about air shocks? they can do a great job in improving your ride with the camper on.I used them when I had a cab over on my Dodge Dakota, they made the truck ride level and gave it a firmer ride kind of like the Rancho 9000
    shocks you mentioned. Something that might help with your loading problems also might be electric camper jacks, if you don't already have them. I hear they are real nice you just push a button to raise or lower your camper, you can raise or lower the whole thing at one time, or just the front or back, or each corner from a remote control. I have the hydraulic type now but I hope to get the electric type latter on.
    What ever you do give your camper a chance, I bet you will love it after a little while.
    John
    I too will not run right out & change my shocks, but if I were a full timer with my Lance, I would probably go with the Rancho 9000. The Lance dealer in Paradise recommend the 9000. I've heard good things from others as well. I think I'll check out some suspension shops in Sacramento, see what they have to say about sway bars. The Hotch kiss would be nice, but a bit pricey. Anyone out there have Hotch kiss? Once I get loaded up again, I need to clean the fresh water tank, since it's been sitting for so long. Has anyone had to do this? Vince, if I get a photo of the truck & camper, maybe you could put it on your web page. No electric jacks here, but I can live with that, at least for now. It takes as long to jack it up, as it does to load it. I probably keep it closer to the ground than necessary. Vince, are you able to get to your spare tire with the camper on? I didn't pay any attention. To change a tire, I would think an after market jack would be in order. Can hardly wait to load it up again.
    Gary-
    Vince, thanks for the offer. I had hoped to get the camper on this winter, but chances are that I will now wait until Spring. I've also got to go out and buy a digital camera. The company decided to send our digital camera out to a very remote "fly-in" location with our Forester. I guess they wouldn't have understood if I lobbied to keep it here in town because I might need it for personal use.
    I see mirrors on a lot of the Trailer Life test vehicles that appear to have a brace that runs from the mirror to the bottom of the door. My guess is that it is a stability issue. I've heard of some after market mirrors that vibrate too much and become ineffective.
    I opted not to replace shocks right away either. My plan is to run this year with the existing shocks and then get some Rancho 9000 shocks next Spring (2001). My truck has about 27,000 miles on it right now, so I should be over 40,000 by then. I figure I will feel that I got enough use out of the stock shocks. I'm still thinking about airbags for this year, as long as I am confident they will be effective with duallys.
    I've seen the Alaskan Campers. They are pricey, and the certainly don't have all of the amenities of the hard sides. Still, if you head off the beaten path, they are hard to beat. I'm pretty sure the website is www.alaskancampers.com.
    Gary, I have never flushed my water tank. I keep thinking I should run some bleach water through to kill any nastys but haven't gotten to it. I don't drink the tank water anyway because it tasted bad from the garden hose to start with. I have a table/shelf above the sink that a 2.5 gal jug from the grocery store sits on nicely. It's convenient to use because it has a spigot, then for travel I just set it in the sink.
    I think I can get to the spare tire with the camper on but I haven't tried it. My camper is 9.5' so it sticks out some but it doesn't drop down, it's flat from front to rear. This means the winch hole in the bumper is accessible, the only question is if the rod has to come in at an angle. Don't rely on the factory jack, it may not be able to handle the weight. Go out and buy a bottle jack, at least 4 tons. They sell for $20 or so, are small, and come in a nice plastic case that fits in the cab just fine. Well, in a regular cab anyway, I don't know what storage you have in the extended cab. You wouldn't believe what I have behind the seat in my truck: 2 tool boxes, bottle jack, compressor, ropes, big tarp, jumper cables, tool bag, spare hose, rain coat etc. Only things I'm missing are some basic spare parts. You can see I'm used to driving old trucks.
    If anyone wants to e-mail me a picture(s) I'll be happy to post them. Maybe we could start something here. I'm going to work on my new pics right now.
    I scanned in my Christmas/New Year pictures. This was the first time the camper was on the truck. The first two are in an orchard I lived in for a few days in Durham CA. The second two are at Pismo beach CA.
    http://members.home.net/vofm/camper1.jpg
    http://members.home.net/vofm/camper2.jpg
    http://members.home.net/vofm/camper3.jpg
    http://members.home.net/vofm/camper4.jpg
    Send me yours! (Snap shots by snail mail accepted too!).
  • anonymousanonymous Member Posts: 314
    Welcome back.
    Sorry to hear you had a trial loading your camper. I put mine back on this weekend. Took about 30 minutes to get properly lined up and under the camper. Of course, I wanted it loaded slightly to the passenger side so a couple of times I was trying to move the truck 1/2" or so. The tape idea that Vince and I talked about was helpfull.
    What we talked about was a line of tape down the center of the camper, and a matching line down the middle of the bed of the truck. While backing up slowly, sight down the middle of the truck tape and line up with the camper tape. Then stop every foot or so, get out and walk around and check.
    I thought my pop-up camper felt top heavy, and added heavy duty shocks (Bilsteins) and a sway bar (Hellwig - not recommended). Now it is not too bad. My 1/2 ton truck is right at the max GVWR and I run 45 psi in the tires and 50/40 in the Air Lifts (the drivers side is heavier and has more air).
    My dad ran a big camper for years, but finally gave up and bought a 5th wheel. Later he traded that for a tag-a-long trailer which he says is the best choice. He didn't like the cramped bedroom in the 5th wheel. But then he is 77, but he still loads up his camper and goes out 20 times a year. I hope I hold up that well.
    Yes, I have looked at the 4 Wheel Camper in Woodland. Go up and check them out yourself. I think they are one of the best made units out there. In retrospect, I probably should have gotten one, but the extra $2000+ was out of the question at the time. They are basic campers and will not be available with a water heater, shower or toilet (only porta-pottie). Our Phoenix was available with hot water and the outside shower for extended stays. I'm not unhappy with my camper now that the bags have been worked out, I just thing the 4 Wheel unit is better.
    MikeL
    Welcome back.
    MikeL
    The link I gave was bad. It is www.alaskancamper.com.
    When I dewinterize, I put a little bleach in the fresh water tank and fill the tank about 1/3 to 1/2 full and let it slosh around for a day or two while I'm driving before I fill it up for the first camping trip of the season.
    Nice photos Vince- makes me want to load up & head out. Yours looks just like mine, but only a foot longer. Soon as I get a photo, I'll send you one. Mike, I did use the tape trick the second time, & it definitely helped. Soon as we get some better weather, I'm going to load up & take it for a long spin. Might check out the 4 wheel campers this week end. Vince, the water jug sounds like a good idea. I've seen them in the store. Sounds like you have everything but the kitchen sink in your truck. Good thing the camper has the sink, or you might have that in your truck as well. LOL!! Sounds like you could put some of the items in the bed of the truck through the door openings in the camper. Going to pick up a jack this week end. Hope I never need it though. Going to be looking around for a good sway bar, & the shocks will come later. Let you know what I find.
    Thanks Brutus for the info.. Don't see to many Alaskans down in this neck of the woods.. I have seen a couple though.
    If you want standing room in the sleeping area, then a tag along is the way to go. Hope I can still be camping at his age. That's great!
    See you all later. Still trying to locate a good set of trailering mirrors.
    Gary-
  • pistoleropistolero Member Posts: 52
    I noticed both here and at Happycampers people with F-350 duallies mentioning bowed brackets and problems with bag failure on the Ride-rite air helper springs. I contacted Firestone and got an E-mail response stating that I should make sure the dealer gives me the right kit. Evidently some people, according to Firestone, have been sold kits made for F350 chassis trucks, which are different than the pickup model. Just thought I'd pass it on, would be interested to hear more from people with these installed on a dually.
    Gary, when I was thinking about tow mirrors I most liked the brand that slipped over the entire length and back of the truck mirrors. They look the best and seem easy to install. I don't know if they stick out far enough for a full size camper though. Performance Products sells them for too much $ and Camping World also sells them. There are 2 small adds I recently saw in Trailer Life for add-ons. They use a metal bar that goes under or behind the existing mirrors. I'll post the www when I can.
    The GM "camper" mirrors are okay except they don't work well with campers. The passenger side is about flush with the camper side when fully extended. It's good enough because I stuck on a big wide-angle so I can see beside me but it would be much better if they made them to go out another 2 inches. The other problem with these mirrors in general is they slant up so you can't see the road in the far end of the mirror, just where you need it. I almost exclusively use the wide angle stick on for the right side. If I can ever buy a wide angle stick on that covers the entire mirror I will (passenger side camper mirror is flat). They sell these for the old style power mirrors. Then it would be like the factory power mirror.
    Vince, Thanks for the info.. I know for sure, I will get whatever mirror does the best job, even if I have to pay a little more. Cost a hell of a lot more to fix a camper from backing into a tree, rock or whatever, than spending a few $$$$$ on mirrors, not that I have $$$$ to burn. Like you said, being able to see the road as well as to the sides is most important. I noticed the scissor steps on your rig. Do they work well, & are they stable. I'll bet Fido loves the ocean. Where does he sleep? How far are you from the ocean? Takes me about 4hrs to get to Mendicino/Fort Bragg. Probably 1/2 hr or so longer with the camper. Kind of a winding road.
    Do you know if Mike posted any photos of his rig? Your truck & camper look really sharp Vince.
    The scissor steps work quite well. Since I ended up with a Squire (not a REAL Lance) I don't have a bumper and step on the camper. These are better anyway. They are stable and fine up to 250 pounds. They can be mounted permanently but I don't like them dangling there so I use the other way. They come with a bracket that mounts to the camper and allows the steps to be removed. I set them on the floor just inside the door for travel. If you ever buy some get the aluminum ones, not steel. They are twice the price but you'll be glad every time you lift them.
    My dog's name is Dusty. She's a 13 year old Chocolate Lab and she loves the camper. She's quite happy to spend hours just snoozing away when I'm off doing stuff. I have a foam cuddle bed that fits between the sink and fridge. After it gets dark she begs to go inside and go to bed for the night. She also rides back there when I'm driving. She preferred my old camper because she could lay up on the step and stick her head out the front window for hours on end. No way with the little step in a Lance. She has never liked the ocean much but she loves the beach because there are all sorts of disgusting things to eat. She is more a lake/creek dog.
    You see what happens when you get me started on dogs! It's worse than trucks.
    All this talk about mirrors got me wondering, do you have the telescoping TT mirrors on your truck? I understand the 99 SD don't have them. if not how do you see around your camper?
    I tried my camper on for the first time yesterday, and took it for a short ride, I love that PSD and it felt great with the duals.(both a first for me)I was disappointed with the mirrors, even with the telescoping feature it was hard to see out of the passenger side, not [non-permissible content removed] good as I had thought they would be.
    John
    Bet you expected pictures in this message. Sorry, but you have me motivated.
    Last year for Christmas I got my wife a digital camera. She has used it twice. This weekend I will dust it off and take some pictures (weather permitting) of the truck and camper. Don't expect nice scenery like in Vince's photos.
    My truck looks similar to Vince's truck, Charcoal Metallic, Std Cab, Longbed but with black fender flares and a much smaller camper.
    Unlike Vince, I am very happy with the camper mirrors on my truck. They extend out far enough to see down the side of the camper (80" wide) on both sides. I do wish they had a convex section on the passenger side where it is needed.
    Mike L
    The 99 trailer tow mirrors don't have the telescoping feature, but they are the same mirror otherwise. I just don't have the ability to retract them in when the camper is not on, so they are always extended. Personally, I think they look pretty good extended out with the duallys. Mine are power mirrors, which is a nice feature.
    As far as visibility, I guess I never expected to see directly behind me with the camper on. I use the passenger mirror to see what is in the lane next to me. I've always backed my trucks into parking spaces and other areas where I want to insure easy egress, so I'm pretty comfortable backing up, even with the camper on.
    Still, if it's questionable at all when I'm backing up, I jump out and take a good look behind me to make sure I know what's back there. Like Grizzly mentioned, fixing damaged campers is not cheap. It's certainly worth a few extra minutes of my time....and, if necessary, someone else's time that may be momentarily delayed while I take a quick look.
    When I picked up my camper last January, they had another Bigfoot camper in the shop that they were doing some pretty serious fiberglass repair on the upper right hand corner of the cabover area. I think it was a $2,000-$3,000 job. They said the guy forgot he had the camper on and only remember.......after his failed attempt to pull into the garage. Ouch! See, there is hope of getting use to the top heavy effect of the campers.
    I enjoyed seeing the photos. We also remove the steps and place them inside on the floor of our pop top for travel. I hold the steps down with a bungee attached to a screw eye placed in the floor on each side of the door right next to the wall where they are out of the way.
    One day while cruising at about 60mph we were passed by a car and a very worried looking passenger pointed to the rear of our truck. I stopped, and you guessed it, the steps had been dragging for about 5 miles! How could we be so dumb? We had stopped to look over the rapid called Lunch Counter on the Snake River and had used the steps to get food from the camper so we could eat it near the river. Forgot to put the steps inside and just drove off after lunch. Thank God they stayed on and hadn't flipped off into another vehicle.
    The aluminum cross piece at the bottom of the scissors was completely worn away on one corner but was easily grafted with another piece of stock aluminum.
    Since then whenever we remove the bungee and steps we place the bungee on the driver's seat. That way we are forced to remember the steps are down before we drive off.
    It was a good thing they didn't fall off. I've almost backed up with mine down a few times but luckily remembered. I try to always run through a little checklist in my mind before getting in the truck: steps up, fridge locked, water pump off, etc.
    It's good to relay our faux paus so everyone knows they are not alone. Sometimes the mistakes are obvious errors of forgetfulness but sometimes the mistakes are self inflicted. Hey, it seemed like a good idea at the time, but in retrospect it seems so obviously stupid we wonder how we ever could have thought it worked.
    For those of you who winterize, I had a friend who forgot to bypass his water heater before he added the antifreeze. He finally caught on that he was filling the hot water tank with anti-freeze on about the fourth gallon and still no antifreeze was showing up in the water spigots.
    Thanks for all the input on the mirrors. Now that I have all of these choices, I'm bound to find something that will work for it's intended purpose. Sounds like fido, I mean Dusty, has a pretty good life. Your best friend, I'm sure. He probably eats better than you! He probably has big ol steak bones buried all over the back yard. You can really get attached to a pet, whatever it may be. Hope Dusty is around a long time for you.
    I should have given you this website earlier:
    http://www.fourwheelcampers.com/
    They have a pretty informative site. But, they do not do specials.
    On the other hand, Phoenix will build whatever you want. It is more weight (800 lbs vs. 1200 lbs), but less money, and more time to fix the things that are made poorly.
    http://phoenixcampers.com/index.html
    Our Phoenix has worked well for us. We have about 20,000 miles on the camper, having slept in temps as low as 20 degrees and as high as 85 degrees. It has kept rain and snow and bugs out. The options all work, etc.
    Phoenix will build a unit with a toilet and shower. You can get things done that are not listed on the website - just ask.
    We saved by not having to pay CA sales tax or an installation fee as on the 4 Wheel model. The only downsides were - not being able to visit the factory prior to ordering, having to pickup the camper in Colorado, having to spend 2-3 weekends mosquito proofing the camper.
    I guess if you wanted to consider the Phoenix, you could come down and check out ours and I could show you what I had for problems and solutions.
    Good Luck,
    Mike L
    I have the brochure on the Phoenix, & it appears to be a decent camper. It offers more than the Four Wheel camper, & of course, most the items you need are optional. If I had the $$$$, I would go with the Alaskan.. Like the idea of the hard side pop-up. The Northstar is nice as well, but the options will drain your wallet. I guess there all pretty much the same as far as the options. I think for the $$$, the Phoenix offers the most. I'm kind of like Vince, I like the bells & whistles, BUT, I also like to pull off the road & explore, & a low profile camper is the way to go. The Alaskan is the heaviest of all low profile campers, but still far less than the hard sides. I will have to check out the RV show at Cal-Expo this spring.
    Gary-
    The Alaskans appear to be the superior pop-up, but like you said, you pay for it. The price is every bit as much as a hard side, and more expensive than many. If you look at the base equipment and then start adding options (many of which are standard on hard sides), the price quickly is in the $20,000 range. If money is no obstacle, and the conveniences a pop-up offers (lighter, lower profile, easier to handle, basically go anywhere the truck can go empty) is what you need, I doubt the Alaskan can be beat. Of course, price is usually a serious consideration.
    Money definitely is a consideration. I have looked at their used Alaskans also, but they can be quite expensive as well. I could offset the price by selling my Lance, but I'm not sure I want to do that at this time. I do need to find a GOOD sway bar though if I keep my Lance. Can't do any serious camping at this time, so I have time to investigate further.
    Gary-
    No serious camping around here. We had about a foot of snow on Sunday and Monday, mid 40s and 100+ mph winds yesterday and upper 30s with a rain/snow mix today.
    The Seward Hwy to the south had five avalanches on Monday and numerous ones since. It has been closed just south of town all week. Three other hwys (Dalton, Richardson, Old Glenn) also had intermittent closures on Monday because of avalanches.
    DOT had to pull their workers off the Seward Hwy a few times for fear of more avalanches. On Tuesday, a railroad employee operating a grader to clear one of the avalanches got caught in one himself and didn't survive. They got him out quick, so he didn't suffocate or freeze which is the usual culprit when people die in avalanches. He had a crushed pelvis and internal injuries. When snow can crush a grader cage and do that kind of damage, it just shows the devasting power of an avalanche.
    The weather has been wierd this winter. I prefer mid 20s for highs in the winter. We've had it pretty mild most of the winter. This is more like our weather at the end of March. Last year at this time, it was below zero. I'm not sure I would trade for that, but I fear this is only a Spring tease. Winter is not over just yet.
    With posts like that it makes me glad to be living in sunny calif, the weather here has been great warmer than normal in the low 80s kind of a spring tease also, I am sure it will cool of again
    before the real spring gets here.
    John
  • joejoe Member Posts: 16
    I see someone might be interested in the Four Wheel campers. I have own mine for 2 years so if you got any questions just ask away. In general I am happy with it. When I bought it I felt it was one of the better popup campers made, and from what I saw at the last RV show I think it still is. It does have some limits, so if you are into RV type camping it might not be right for you.
    Joe
    I can attest to the devastating power of an avalanche. I've been in a couple myself. The second one I was in, I was buried for about 25 min. ( seemed like an eternity) in a Tucker Sno-Cat while grooming the ski slopes at Alpine Meadows. I fortunately was wearing my seat belt that morning, so I remained in the cat as I was being tossed & thrown through the air, until I landed in a group of trees, upside down, my cab filled with snow, all the windows broken out, hydraulic fluid everywhere, & to top it off, I thought it was going to catch fire. My rig & I were totally buried. My friend was on a high knoll in another grooming machine, & he saw me grooming the trail one minute, & the next minute I was gone. He was totally freaked out.. more than me I believe. He & the ski patrol managed to find my cat, & dig down to find me in my cab, very shaken & bruised, but made it out alive. It's amazing what goes through your mind when you think you've met your maker. My cat wasn't in to good of shape either. My friend behind me in another cat was also buried. I've been in others, but this one was the worst. A VERY scary experience! Snow is not always soft & fluffy. The avalanches you've had up in your neck of the woods has been shown on our local news. Growing up in Tahoe, I can definitely relate.
    Joe, Thanks for lending your ear if I/we have any questions on the four wheel camper. Did you get a lot of options? How is it to load,& what kind of truck do you have? Maybe they will have them at Cal-Expo this year, so I can get a better look. Do you have any problems with mold on the canvas? Where have you traveled with it?
    Gary-
    Wow Gary that is quite a story. I guess you know about that "life flashing before my eyes" thing. I just read about the Alaska slides on the internet news. They got one highway opened up but expect more problems.
    I looked at the two web sites given above. It is clear that there are trade-offs in the selection of a camper. No doubt the popups have the external advantage but you really give up something to get it. I look at it like the popup is a very nice step up from tent camping, pretty similar to a popup tent trailer. You get all the most important needs met: heat, food, shelter etc. but quite minimum beyond that. The small water tank and lack of gray water tank would bother me. Maybe I'm wrong about the gray water but I didn't see a mention in the specs.
    On the other hand a nice hardside is like a scaled down RV. You have a small version of everything the big units have.
    With a nice modern truck it's not a big deal to haul around the heavy camper. The differentiating factor is off-road capability. If you think you'll want to go beyond dirt roads then the choice is clear. Or maybe you only want basic facilities. However short of that the big campers really provide a lot for the additional load.
    I just felt like sharing my thoughts to stir up the conversation a bit. Feel free to throw out other opinions.
