Cabover Camper Chat
I believe the two Phoenix campers with toilets have waste water storage. How much, I don't know. You would have to call and ask them.
Our camper is a 'Warrior' model. We had it made 4" narrower, and the front overhang is cut in half both vertically and lengthwise. On the website, the view of the warrior shows a couch to the rear of the bed. Our camper has the couch, but the bed pulls out and is over the couch. When the be is not in use we can push the bed forward into the overhang and have unobstructed use of the couch. It works for us, we full use of the living space, full size bed, and only 1/2 the overhang. We actually had them duplicate the dimensions of the 4Wheel Camper.
We have had some mildew in the camper flexible sides. None during the summer/fall, but now that winter is here we have it. I will just keep cleaning it regularly with a mild bleach solution.
I have taken some pictures of our truck. When I go home I will download them, then email to myself here at work. Then I will see if I can figure out how to add them into a posting. If not, I will take you up on your offer to put them on you website Vince.
I'll be back on Monday.
Mike
www.duedall.fit.edu/bbff/
Click on Picture Gallery and then Click on Trucks & Slide-in Campers. The one that looks close to mine belongs to Brian Aut. My truck is black, not grey, and it is a V-10, not a PSD. My camper has green trim instead of maroon and it's a 99 model. Overall though, it looks pretty close. Same size and model of truck and camper.
promised but getting closer!
I thought about sending one of my pics to that guy but I'm not sure Chevys are allowed! I'd certainly be outnumbered by all the Fords.
We have the best powder snow skiing I have seen in New England in 10 years. No avalanches, great downhill and ski touring.
Those with interests in poptops might check out sunliteinc.com. The company has changed the design of their 10 foot pop top, putting the bath on the same side as the sink, I see, but otherwise it is like our 10 footer. After completing several week canoe trips during which we have lived in our tent we arrive back at our truck camper and it seems like a mansion - all the comforts of home. The sunlite is probably not as strong as the aluminum framed 4 wheel campers and we have encountered problems in keeping the plumbing connections to the blackwater tank tight. We hope that these problems have now been overcome - time and the next rough stretch of two track will tell.
Has anyone ever done anything like this?
What I need to know is, which is better air bags or helper springs? Also are after market helper springs about the same thing as what comes with the camper package, or are the factory springs better?
Thanks for any help
John
My wife said I can post them in her AOL and then put the address in a message. But, not tonight, we have to get our taxes done.
So maybe Wednesday we can get the pictures on AOL and Thursday I can post here.
Wish me luck,
Mike
The helper springs and rear stabilizer bar are going to get you more support for the load. However, they are not likely to totally resolve the rear end squat issue. The airbags should do that. The airbags will level you out and stiffen you up a little to eliminate some of the side to side movement. They should also improve safety since, by leveling the vehicle out, more of the weight is shifted to the front end, which is how the truck was meant to handle at it's peak efficiency. This should maximize handling and braking performance. My truck does not squat noticably, but I know I'm sitting a little back. That's why I'm considering airbags.
If you're running over GVWR or over the rear axle ratio, I definitely be looking at the springs and rear stabilizer bar. I don't think the air bags are substitute for those if you are over the max. I run over the max and feel the truck handles the load great, but I have the camper package, so I have the auxilliary springs and rear stabilizer bar. Like I said, I'm probably going to add air bags this year and replace the shocks with Rancho 9000 adjustables next year. I consider the airbags and shocks optional since I feel comfortable with the camper package. Still, I don't have any problems continuing to add things that will improve safety and performance. Just my $.02.
Second item is the rear stabilizer bar. It's a must. I suggest you buy the factory bar and mounts from the dealer. It's more expensive but it's done right once and you never have to think about it again. Otherwise Hellwig is probably a good source and certainly cheaper. I assume you have a front bar already, I think virtually all vehicles come with one.
Shocks are last. Some of us have upgraded and some are living with stock. Wait and see how it is for awhile before deciding. I'm leaning toward the Ranchos because of the adjustability. I don't want any stiffer unloaded ride. Otherwise Bilstein is probably best.
The shocks aren't a problem when they are worn out I'll probably replace them with the Rancho 9000.
Any recommendations for the air bags?
Thanks again.
John
I took advantage of a 15% off sale at Performance Products to buy both. Then the price was not bad but they tend to have high prices otherwise. Also, don't consider anything but the heavy duty "5000lb" bags (which can lift 4000lbs by the way!). Here are some web sites.
http://www.airliftcompany.com/
http://www.firestoneindustrial.com/rvlt.htm
Sorry its taken me so long to get back to you about the camper. I wanted to keep the number of options down, but with the 4wheel camper just about everything is an option. I ordered the roof rack and jacks and I added my own battery. After talking to RVer it always seams like somthing is broken on their RVs and I didn't want to end up with that.
This thing just sits in the bed of the truck and there are 4 eye bolts that are bolted into the floor of the bed. No happy jacks here. I have an 99 F250SD to carry it. So I really don't have any kind of loading problems with the truck. The ride of the truck really didn't change too much.
If the Cal Expo is the show in Sac. Ca. they did go there a few years ago I don't know if they go every year. If your near Sac, Woodlawn is just a few miles (10-20) north on I5.
As for mold I haven't had any problem yet. This camper is very tight so when I use it I usally open the roof vent a little and open one of the access pannels (the ones that let you get to the mounting hardware). This lets air flow inside the camper. Also during the day I open up the window a little bit when I am driving around. Someone told me to use this stuff called 303 protectant on the vinyl, this should keep the mold away. I haven't tried it yet so I don't know if it really works.
I have used the camper several times, so far our biggest camping trip was up the Calif. coast to OR the we cut east to Crater Lake NP. We spent several days there then drove up to Bend OR. On the way back we stopped at Lava Beds NP. With our truck this was an easy trip.
Joe
Thanks for steering me to another info spot !!!
jraske,
I have the airlift bags on my 93 F250HD with a camper package and it made all the difference in the world. I didn't get them right away after buying my Lance 10'1 camper but after having them installed, I was so pleased. I got so much more road control. I didn't do the inside compressor but I am considering it for my 00 F350. I like the convenience of controlling the pressure from the cab. I will have to look into vince4's suggestion of Performance Products for online compressor. Just my $.03 worth !!!
Have to wait and see.
john
I'll admit, I never would have thought of a cow mat! Do you think they make them 8 feet long?
Any scratches or chips in the paint will allow rust to start and spread.
I have lifted up rubber mats and found moisture even after months of dry California summer.
Maybe a carpet, or one of the open mats made from cut up car tires would breath enough to allow that area to dry.
Vince, my camper sits directly on the bed with only a few paint blemishes after 20,000 rough miles. And I have not had to tighten my mounts. Maybe these new GM frames don't twist like older frames did?
Mike
I have .jpg photos, and I will paste one per message so I don't have a single huge message that bogs down your modem.
I hope the next message will be a picture.
Mike
Later,
Mike
I added electric jacks to my Lance two years ago. To me, it was well worth it. I had hydraulic jacks and one of them started to leak. I also found the hydraulics a little tricky to work with. The electrics are much easier and quicker. It cost me over $1000 to add them. It was cheaper as an option on the camper but I didn't do it at the time because I was trying to cut expenses. I did have my camper already wired for electric jacks (a Lance option) when I bought the camper so the process of wiring the jacks was basically simple. The holes on the attaching plate had to be drilled in order to attach the new jacks but that was about it. I had the dealer install them. I don't remember what they charged me for installation.
Tempting...
http://members.home.net/vofm/FRONT.JPG
http://members.home.net/vofm/LDNHI.JPG
http://members.home.net/vofm/LRDN.JPG
http://members.home.net/vofm/LFDN.JPG
http://members.home.net/vofm/LFUP.JPG
http://members.home.net/vofm/LRUP.JPG
http://members.home.net/vofm/RFUPHI.JPG
http://members.home.net/vofm/RTUPHI.JPG
http://members.home.net/vofm/INSIDE.JPG
http://members.home.net/vofm/KITCHEN.JPG
http://members.home.net/vofm/SPOTMRR2.JPG
If I didn't have a slider my dog wouldn't be happy. How else could she stick her head through for goodies?
By the way was that your truck pictures on the beach with the chocolate lab?
http://members.home.net/vofm/chevy2.jpg
http://members.home.net/vofm/camper3.jpg
Will be picking up our new lance 1130 soon, and was wondering which type of bed liner to buy so as to minimize the campers movement. Our local farm center had the regular "truck mat" which was approximately 4' x8' x 3/8" thick. Also they had what they called a wash mat that is used in dairy farming. This mat was a softer rubber and had a hole pattern (honey combed) that would allow for drainage, so as to help keep the bottom of the camper drier. Any suggestions as to which would be best? Thanks
wheel a Phoenix but shipping made them too expensive.I have a ton of questions but will ask them over a period of time.Anyone else have this type of camper? Please e-mail any comments.
I have a Lance Squire 8000 myself so I can't offer any help with your brand of camper.
John
Either one would do the job just fine. It seems like most people just use a simple flat one.
What type of truck do you have?
-Blocking the roof vents with an insulator really helps keep the heat in. I went years without doing this and noticed a difference when I started. I use the fuzzy covered foam ones you can buy from the RV store for the small vents. For the big vent above the bed I've never been able to find one for sale. Lance now offers an insulated pad which sticks on with Velcro. That would be easy to make yourself.
-Make a similar cover for the big front window unless you are lucky enough to already have double pane there. I don't and the cold air hitting the bed is tremendous. In fact the entire front of the camper was covered with snow & ice except the window because MY heat was going out through the glass. You can buy insulating blanket material in bulk from the RV store. It has aluminum on each side and looks quilted. I'm going to make a cover soon.
-Be ready for lots of condensation from the metal window frames. The edges of the bed sheets got soaked on three sides. Next time I'll put a towel under some of the windows.
-All the roof vents were frozen shut after a good night of snow so don't plan on using them.
It was great though, I stayed nice and warm thanks to the heater, full propane tanks, and 2 batteries.
I read where some have trouble loading their campers---I may put runners in the bed like on a boat trailer to line the camper up in the same place each time.This should also keep the camper from "walking" in the truck. Anyone ever tried this?? THANKS.
If you camp where it is real cold, I've also heard about people putting insulating blankets around the propane tanks. Propane does not like to be real cold. As long as it's in use, it will stay plenty warm, and it should do fine if it's not in use for a days drive. One time, I was traveling in -25+ weather and didn't use the camper for 48 hours. The propane generator would not start. The heater worked, but it took several hours to get the temp up to where it was comfortable. My camper is rated to -40 (Bigfoot 3000 with thermal pane windows and no front window in the cabover), so it wasn't an insulation issue. It was just getting the propane to warm up and work effectively. The next day, we hit temps of 35 above zero and the generator cranked right up and the heater was at full force.
In retrospect, the issue can be easily resolved in the future. Don't let the camper sit for 48 hours without running the propane. If it was subzero with no signs of hitting warmer temps anytime soon, I'd make sure to crank the generator up every few hours when I stopped for fuel or food. I'd probably also consider those thermal blankets for the propane tanks.
I found boot in JC Whitney that tapers from 6" at the top to 3" at the bottom and is 30"wide and 23" tall. This boot is listed for a 73-79 Ford, but it fits my truck nicely.
The JC Whitney PN is: 10ND5699B.........$26.95
The blanket idea for the tanks is a good one. I bought several feet of the insulating material I mentioned above to line the propane and battery compartments. Of course I haven't done it but maybe some day. For now I'll use it to make my vent and window covers. Brutus I would think your camper would come with the compartments insulated. Did they not or is that just not enough in such cold weather? It only got down to 30ish on my trip, I've never been in -25 weather. I suppose all sorts of things could go wrong with my camper since it really isn't made for such cold. It would be interesting to find out. Especially if Brutus was along to invite me in from the cold!
this topic is being "frozen." Please continue these discussions in Topic 1637 Cabover Camper Chat - II.
Front Porch Philosopher
