Cabover Camper Chat
vince5vince5 Member Posts: 5
Hey, of all the speciality issues on this board
there was no mention of campers. I am a happy Lance
owner and would like to trade info about
truck/camper issues.
I'm going to the dealer today to order a 2000
Silverado 2500 4x4 LB Reg cab, is anyone using a
new Chevy to carry a camper? How about an
aftermarket rear stabilizer bar since Chevy is too
lame to offer one?
Vince
«13456710
  • mledtjemledtje Member Posts: 1,123
    I have a small popup camper (12-1300lbs) on a 99 Silverado 4x4. I had to add AirLifts to get the truck back to level.
    The 'Firm Ride' shocks were too soft, so I bought some Z71 shocks. Still not enough so I've ordered Bilsteins.
    With my lightwieght and short camper, the wieght shift isn't too bad. But, I want better so I'm going by the shop after work to talk about a Hellwig bar and get the price.
    It seems strange to have to modify the suspension so much while still within GM load limits.
    Oh well, I'm happy with all other aspects of the truck.
    Mike
  • haulinhaulin Member Posts: 17
    Just got my Y2K 3/4 ton Sierra to haul my 8ft cabover around. Truck gets wired up Saturday. I got my truck with the 2nd battery, dealer says he can wire it in so camper runs off of 2-12V. No more problems with furnace fan speed (I hope)! Have been thinking of the airbags to keep the load level. Have the tow package and suspension, a bit stiff when empty, we'll see how it handles the load this weekend. Has anyone added swaybars yet?
  • wesley1wesley1 Member Posts: 17
    Congrads on the Sierra, I love mine. Got a question for you. I don't have the factory second battery and have been wondering where they stuffed it? Can't really see room without moving the fender brace or something. I need to put one in for my snow plow. Did you get the 6.0L engine? Thanks
  • tcfitztcfitz Member Posts: 4
    We just bought a 99 Silverado 1/2-ton 2wd xcab, & plan to put a camper on in the next 2 yrs. What experiences have folks had with hardside vs poptops, from both liveability and driveability perspectives? Camper dealer support? Etc.? Only have about 1200 miles on the truck, luv it so far, will post how things are going on other topics. Thanks!
    Be careful of the weight you put on your truck. Your truck has a max load capacity of 1935lbs. And that is for a base model, no options. By the time you add V8, AC, etc. you probably have not more than 1700lbs available. A full tank of gas is 150lbs (1550lbs left).Subtract two passengers and gear and you are down to 1200lbs.
    Now try and find a camper that weighs 1200lbs or less when ready to go.
    I can only think of a couple of soft sided campers that will weigh that little.
    I have a Phoenix pop-up camper that is supposed to be 1298lbs ready to go. With my wife (130lbs) myself (180lbs) full of gas and water our truck weighed 6500lbs. Our GVWR is 6400lbs. And we started with a max payload of 2035lbs. Since your payload is less you may have trouble.
    However the camper has worked quite well for us. It did take 4-5 days to work the bugs out of the camper and to make it mosquito proof. I've heard complaints about most campers from people I've talked to.
    We now have about 15K miles and 42 nights camping on/in the camper. There is enough room for the two of us. The heater was a godsend on mid-20's nights. Hotwater is ok, but not needed so much. A refrig (vs. icebox) makes longer campouts a real treat.
    If you buy a pop-up camper, make sure the top is easy to put up and down. Ours is too heavy for my wife to lift up. Either visit the factory and put the top up and down or find a customer in your area that will let you try his.
    A camper will make your truck more top heavy and it will tend to sway side to side more with a camper on it. Hardsides more so than soft sides. Hardside campers have more weight up high (cabinets, etc) while softsides have only the soft side up high.
    My reccomendation today would be 4 Wheel Campers in Woodland, CA: http://www.fourwheelcampers.com/
    Good luck,
    Mike
  • vince4vince4 Member Posts: 1,268
    I have a hard side Lance and love the simplicity and security of the hard side but it is heavy and tall. The bigest problem I've had trying to squeeze into tight places (off-road) is the height. For some reason they don't trim those trail trees very often!
    P.S. I talked with a very satisfied popup owner in a campground and he said he had a real problem with mold on the canvas portion. Said they had to clean it quite often and it keeps coming back.
    tcfitz
    I had a 1800 lb cabover on a 1970 1/2T Dodge. Wow was that a thrill. Leannnn in the corners and brake early and hard. I added springs and a sway bar which helped but it was just overloaded. I'm sure the modern trucks are better but choose something light.
    I want to put Air Lift bags on the rear of my 2000 Silverado (if I ever get it). I see Camping World and Performance Products sells these. Does anyone have experience with Air Lift or Firestone?
    I've put Air Lifts on my 1/2 ton 4x4 Silverado. Its about 4 hours work with some drilling on the frame. I modified the mounts to move the airbag back about 1 1/2 inches.
    The Air Lifts will keep the truck level with a load on it.
    With 10 psi in them they don't seem to affect the empty ride.
  • jraskejraske Member Posts: 131
    I am planing on buying a Ford super duty V-10
    F 350 with dual wheels.
    Has anyone ever had any experience with loading
    a cab over camper on a truck with dual wheels?
    Does the dual wheels present a problem when
    backing between the jacks.
    The camper the camper will be a 10ft self contained model.Has any one had any problems with hualing a camper of this size with a one ton truck?
  • grizzly1grizzly1 Member Posts: 111
    haulin.... What size camper do you have? Do you know the dry weight. When I get my Silverado, I will be installing the Air Lift or Firestone air bags. I own a 10 1/2' lance, with a dry weight of approx. 2400 lbs, so I feel the air bags are in order. My friend hauled the same camper on a 3/4 chevy, 2wd, extended cab, & he had the air bags, & swore by them. My truck ( if I ever get it) is a 3/4,LB, ext. cab, 4x4, 410, LS, with all the goodies. Let me know how it carriers your camper.
    Gary-
    haulin - I agree, I'm tired of my headlights lighting up the trees rather than the road. I'm going to go with the air bags. I also hope to get some side-to-side correction and a little leveling adjustment in the campground.
    Does anyone have a recommendation on shocks? From what I've read on other topics the stock shocks aren't so great.
    One thing I very much recommend is a rear stabilizer bar. I added one to an old truck and it really helped the side to side rocking. Anyone who knows a good aftermarket source for a 2000 Silverado bar please speak up.
    haulin, obviously you don't live in California. We can't get the aux battery because they use that space to load more smog gear on the motor. What a drag. Well, I've squeezed a second batt in a Dodge and Ford so I think I can do it again when my Chevy arrives.
    Grizzly: I just have a little guy, 8 1/2 foot, 1850 lbs dry. I love the Lance models, not quite enough justification for the funds though. Your truck sounds very close to mine. I see JCWhitney has bags for about $188, roughly $250 more if you want an in-line compressor and in cab switch. I have yet to hear a bad thing about them. Has anyone ever installed them before? How tough are they? One guy I talked to was told the Firestones are superior quality, about the same price. I don't know if that is true or not. I saw a stabilizer bar in there too. Don't know how far I'll go with the extra stuff, I have to run out of money sometime! BTW, I put in a Line-X liner over the rails. Looks good, some scuffing after running my camper in and out over the weekend. Even scuffed up, it will probably exceed my expectations as I originally wasn't going to put one in at all.
    haulin, the air bags that JC Whitney sells are the Firestone ones, the model is Ride Rite (5000lb per set). You can see them on the Firestone web page, I don't have the name but I found it with a search engine. Firestone sells them for $284.
    I was just looking at those. Since I have been known to get dirty from time to time, I wonder how well that bellows design holds up to crunching with mud, rocks, [non-permissible content removed], etc, between the bellows. I would think you might punch a hole in it under compression. Does anyone hav a feel for this? Are the units pretty tough?
    I wouldn't worry about that much. That rubber has to be tough to handle 100psi + load and I doubt much could get caught in that small space anyway. My decision now is to buy Firestone or Air Lift. The Air Lift set runs about $250 at Camping World or Performance Products. It looks very much like the Firestone bag, I wonder if Air Lift actually makes them or just rebrands the Firestones. I'm leaning toward Firestone because they are the major player in big truck air suspension and also because JC Whitney sells them so cheap. Next is to decide who's compressor kit to buy. Do you really need that tank that Firestone sells?
    If anyone is interested I got the model number for the Air Lift super duty air bags for a 99 3/4 ton: #57245. Don't know about Firestone yet.
    I also got the rear sway bar model from Hellwig: #7634. This is for a lb reg cab 4wd but I suspect it is the same for any 3/4T.
    Latest update: you CAN get the Silverado auxillary battery with California smog equipment. The info on KBB and others may have been correct but not now. Even my dealer had the combination rejected by the computer but on further investigation found it was okay. So now I get to buy the parts ($+) and put it in myself.
    raske, I have a 10 1/2' Lance cabover camper, & I had a friend with a 1 ton Dodge, dully, to help me move it. Unfortunately, it would'nt work. It seems to me, the blocks I had the jacks resting on, were protruding out beyond the edge of the jacks, about 3 inches, therefor, the wheels would not fit between the blocks. I ended up moving it with a 3/4 t chevy. By the way, whats the dry weight on your camper? Mine is 2400 lbs, & it was hauled around on a 3/4 ton, LB, extended cab, with no problem. Your camper will be a piece of cake for your 1 ton. Let us know how it comes together.
    You have to get the swing out brackets for the front 2 jacks, only way it will fit. Then I don't suppose it would be a problem but I don't have any first hand experience. Are you buying a dually just for the camper? If so think hard. The F350 will have no trouble with a 10' camper with single wheels and when you take the camper off you have a vehicle that's easy to drive. Dualies are sooo wide I would think they would be a pain to live with.
    From the way you talk Gary the dually would have worked if your blocks had been set differntly or if it wasent sitting on blocks at all.
    Vince, as far as the duals are concerned i want them mostly for looks, but they should also add to the stabilty of the truck when the camper is loaded.
    Does any one else have any comments on duallys as far as loading campers and driving go ?
    Vince, I don't have the swing out jacks, & yes that could had been the problem. Now that I think about it, I remember my friend with the dully truck, mention something about swing out jacks. I'ts been awhile since we tried to move the camper with his truck. raske, I've talked to several people with duallys, & far as the stability, dually is far better. according to them. Makes since. Call your camper dealer, to find out about the loading of your camper with dually. Let us know.
    There is no doubt the dually is better when the camper is on. You can also handle a bigger, heavier camper. For me the issue is when the camper is off.
    You can see a picture of camper/dually at
    www.lancecampers.com.
  • rick63rick63 Member Posts: 10
    I recently purchased a full up, dare I use the term "heavy duty" Dakota, V8 and the works, has a 2000# payload capacity but unfortunately only around 45" or so between the wheel wells, I'm finding this dimension my biggest obstacle in finding a camper. I have two question for all you experienced campers, I have only found 1 mfg. of campers for this truck, Slumber Queen, includes a toilet on this model, Does anyone know what other mfgs. make a camper that will fit this truck, not impressed with the soft sides I have seen????? Next question is do those air cushion bladders help with the stability of the vehicle or with the weight carrying capacity, or both ?????
    2000lb payload capacity is pushing it for a camper, especially one that is self contained. You'll find the 2000# is a base model. If you have a v-8, AC, PW or any other options it will reduce the available payload.
    Lets say AC and V-8 reduce the payload by 200#. Now you have 1800lbs. Subtract a driver and a passenger = 1500lbs. Subtract some gear, food, clothes, water = 1300lbs. Put gas in the truck and your available payload = 1150#. I'll bet your camper weighs a bunch more than that.
    Go and weigh your truck with passengers and gas. You won't have 2000# available. Probably less than 1500#. Now find a camper to fit your available payload.
    Good luck!
    I have a 2000# payload and a 1200# camper. With gear, gas, water, myself (170) and my wife (120) we are 100# over GVWR.
    Mike
    Has anyone had any problems with breaking on a steep grade carrying there camper. Heating up, break fade, & so on. We've got some rather steep grades here in the Sierras. Thanx for any comments.
    Grizzly1,
    I live in CA and spend a fair amount of time in the mountains. I'm running a 99 Silverado 1/2 4x4 with a pop-up camper. We've weighed it on cert. scales and it is 6500lbs loaded. Max GVWR is 6400lbs. I've never even thought about the brakes until you asked.
    I guess the brakes are good enough that they didn't enough need a 2nd thought.
    I do have a manual trans, and I downshift when in the mountains, and probably downshift again when on steep hills. But I have never had a moments concern about the brakes. 4 wheel disks and ABS are reassuring.
    Mike
    Mike, I'm glad to see you don't have any problems with breaking on grades. I too down shift with my present camper van. 1980 3/4 long wheel base, auto, 400 V8. Bought it new, & it still looks new, & runs great. I have on order, a 2k 3/4 LS extended cab, LB, 4x4, & all the goodies. Sure wish it would get here.Back to the breaks... How is the compression on the newer vehicles, far as down shifting & holding you back, like on the older vehicles. I was a bit concerned because my Lance camper, 10 1/2', has a dry weight of 2400lbs. I know if your on your breaks too long on a hill, they can get hot & begin to fade. This happened on my van one time on a long winding grade, but I was able to get it to stop, & let the breaks cool, then proceed to the bottom. Exciting! I,ve never experienced all ABS, like on the new Silverado. I'm hopping my camper is'nt too much weight for my truck. I know it will carry it, but safety on hills is my concern. Thanx for any feed back.
    grizzly, don't worry about the brakes on the Silverado. Chevy finally fixed that issue and I think we will be in good shape (I also have 2500 on order and 9.5' Lance). The Chevy brakes are better than the 89 3/4 ton Ford I have now and it has no problem with braking even in very demanding situations -- with one exception.
    I had the brakes completly fail after extreme use due to old brake fluid (bought the truck used). Brake fluid absorbs water very redily and under extreme use the fluid in the caliper will get so hot the water "boils" and fills the piston area with gas rather than liquid. Result = NO BRAKES! I didn't realize this was such a real threat until it happened to me. The moral of the story: CHANGE YOUR BRAKE FLUID EVERY FEW YEARS! I now use a synthetic which has a higher boiling point.
    grizzly1,
    The new engines have about the same engine braking as the old ones, except:
    They are generally smaller (6L vs 7.4L, etc.)
    They are turn slower (1800rpm cruise vs 3000rpm)
    If you downshift enough to bring the revs up to 3-4000 then you have good engine braking.
    Your 3/4 ton truck will have bigger beefier brakes than my 1/2 ton. Assuming you have an 8600lb version, you will not be above max GVWR. Staying below GVWR means you have more margin on your brakes, tires, suspension, etc.
    Good Luck,
    Mike
    I've had the Lance for 3 years and a different brand for several years before that. The Lance is on a 3/4 ton Ford with Hellwig add-on leaf springs and a rear sway bar. It handles pretty good and is stable. I'm going to put air bags on my new Chevy (build date this week!!!!) for two reasons: leveling and unloaded ride. A problem I have now is when the camper is on the headlights point above the road so I get a good view of the trees rather than the road and I'm blinding other drivers which I know because they flash at me. But when you look at the truck it's only a little low in the back, it really doesn't take much. Also my camper is a little heavier on the driver's side so the truck leans to the left a little. I'm getting an on-board compressor with the dual guages so I can adjust side-to-side as well as front-to-rear. I hope to get a little adjustment for level in the campground as well. The second reason is so when I take the camper off I can let the air out and the truck rides smoother.
    I've traveled thousands of miles with the camper and love it. It gives you so much freedom when traveling, you always have a place to stay and can still fit almost anywhere a car can. I've dropped the camper in the campground but usually I don't. It's a bit of a hassle to secure everything for day trips but when you are out all day you have your food, clothes, etc. with you which is very handy. I might drop it more often if I had electric jacks. If you want to go off-road then definitely leave the camper behind.
    Sorry for the long post, just felt like blabing.
    I'm glad you did so much blabbing. The reason I ask so many questions, is that I haven't had the opportunity to use my camper, since I don't have my truck yet. Your comments are appreciated. I also don't have the electric jacks, so I know I wouldn't be unloading, unless I was going to be in one spot for a week or so, but my wife & I like to move around a lot. The reason I have my camper before the truck, is I got the buy of a life time on this Lance. Couldn't pass it up! So then, I ordered a Silverado to go with the camper. What ever works, right? It's nice to just go about anywhere with the truck/camper combination. We like to camp in some out of the way places, so size of our camping rig is important. A 30' fifth wheel just wouldn't cut it. Do you notice a big drop in mph with the camper on? Do you happen to know your dry weight? Glad to see you have a build date. I called this A.M, & still no build date. Soon, I hope. Keep us posted on the truck.
    That's great that you got such a good deal. Have you ever owned a camper before? I'm assuming not. I'm happy to go on and on about campers, I just think they're great. Certainly tight on space but still comfortable. You get all the benefits of an RV with little of the downside. I generally leave mine in the driveway so I can use the truck. Once you get good at the on/off process it doesn't take long, about 1/2 hr.
    I've learned to really enjoy off-season camping and the camper lets me do that with no worries. So it rains a little, who cares! Just go inside and get warm. I usually get plenty of nice weather in the day and have a good time without the crowds. I live in northern CA and we have a great network of campgrounds in wildly varing terrain but we also have zillions of people so things get crowded in the summer.
    To answer your questions, my camper weighs 2200 lbs with water & propane but no gear. And yes I do notice a mpg drop but I don't track it much. I probably get about 9-10mpg with it on and 13 with it off. I have a 5L Ford and it's really working with the camper on, also I can't run in overdrive so the rpm is quite high. I expect to get about 10mpg with the Chevy but have plenty of power (which I don't now). The killer with campers is the frontal area, that's one area trailers have us beat.
    I'll be happy to blab on about what I've learned with two campers on two different trucks. As far as your new rig goes I'll mention what I think is most important. I'm doing all these things.
    First get good tie downs. I use HappyJack (I think that's right) turnbuckles, they are the most popular. They have a spring inside to absorb some shocks and are quite strong and stable. And don't even think about using the brackets that mount in the stake pockets of the truck.
    Second, add a rear stabilizer bar. GM is stupid on this one, I can't imagine why they don't offer one. Anyway I'm ordering the Hellwig bar soon.
    Third, I'm adding Air Lift Super Duty air bags to the rear. They're kind of expensive at $250 and $170 for an on-board compressor but I think worth it. I really don't know how the Chevy will do without some sort of overload assistance but remember, we are loading the truck to the rated maximum so why shouldn't it sag a little. A drooping rear end is ugly, unstable, and a problem with the headlights. A less flexible but cheaper alternative is Hellwig overload leaf springs, I think about $150.
    Fourth, add a second battery under the hood. Your camper has a battery but I recommend another one under the hood connected in parallel with the camper battery via a relay. Use only deep cycle batteries for each. By using the relay all three batteries charge when the engine is on but the truck battery is isolated when the engine is off. This way you can stay in one place longer and not have to worry about using lights and the heater. GM offers an auxillary battery option but if you try to add that to your order now it may delay it. I found out the hard way that it's available in CA even though they originally said not. Anyway it's not a big deal to add if you're into working on cars, otherwise you could buy the parts and have someone do it. I ordered all the parts from the dealer and it cost about $160 without the battery. So I have the parts but no truck!
    Enough for now.
    Your right... Haven't owned a cabover camper before, but have been camping with my other rig in northern Ca. for many of years. Our favorite area is the Sierra Buttes, outside of Graeagle, Plumas county. Do you know where that is? We do a lot of hiking & fishing. Dozens of lakes. Off season is the best time, no crowds. We were hopping to get the truck sooner so we could get it set up for camping, & test it out at the Buttes. We're going to take it to Mike Ferguson in Paradise, the Lance dealer, to get it set up. Would you let me know the order number on the Hellwig sway bar when you order? I will be going with the air bags also. The person that helped me move my camper had a 3/4 HD ford, with over loads, & he said they worked fine when your loaded, but hold on to your hat when empty. Said it rode like a Sherman tank in a rock quarry. Air bags are the only way. Might install some after market shocks later. The 36mm shocks that come with the Z85 will do for now. I ask for the battery also, & I was told it was not available in Ca.. Now I'll have to do what your doing. My camper is a couple of hundred lbs. heavier than yours, plus I have an awning & air conditioner. More weight. Glad they come with 10 ply tires. If you don't mind me asking, what part of northern Ca. are you from. We're in the Gold country, (foot hills)Grass Valley area. What are some good spots to camp in your area? Here you have some parts for an aux. battery hook up, & no truck, & I have a camper, & no truck, but the BEST is yet to come. By the way, are you going to put any kind of a liner in your truck? I'm thinking of Line-X or Rhino. Not sure yet. Keep us posted. Thanx again for the info..
    By the way, which model Lance do you have? I have a lot of opinions on that topic too. I looked at the new models and really like mine better except for a few things. I have a 91 Squire 4000 which is 9.5 feet. I wouldn't buy a Squire if I had the choice because I'm into bells & whistles but I bought it used so couldn't be so picky.
    At least your close to some great camping. Kirkwood is on 88. I've never camped in that area since I grew up on the north west side of Tahoe, so consequently I camped in the Truckee & Buttes area.I lived in the Tahoe City area since the early 50's, (the good old days)to the late 80's, then moved to GV. The Tuffliner & the rubber mat may not be a bad way to go if one doesn't want the Rhino. I sure don't want the camper sliding around. Speaking of the camper, mine is a 1988 Lance 580, 10.5, with all the bells & whistles. Has the queen size bed also. The air & awning were brand new, used only once, ( they had them put on just before we bought it) & as far as the camper, we bought it from our neighbors who only used it a week each year. Absolutely spotless. The only thing it doesn't have is a microwave, YET. We have all the paper work that came with it, including the 1988 Lance brochure, & the sales receipt. It's like we just bought it off the showroom floor. Anyway, would you send me the parts # on the batt.. I talked to my fleet dealer this am, & he said only the diesel can you get the aux. batt. option when ordering, in Ca.. Are you going to put on the sway bar yourself? Are they hard to do, or would I need a mechanic? I've got some mechanical abilities, but by no means an expert. Well thanx again Vince, I'll do the E-mail next time. Have a great week end. Where's my truck????????????
    Thanx for the info. on bars. The price sounds right. Are you putting your bar on also? Sounds like youv'e been to some really nice places. Alaska/north Canada, sounds great. How do you find the time to go to all these places. Lot of vacation, or retirement. What ever works. Thanx again.
    Argggg, bad timing! I just ordered the bar today from Hekethorn. Their quoted price is $144 but he matched the JC Whitney price of $135 for me. Oh well only $15 lost. Thanks for the info though. Please post the results after you put it on.
    The $33 cable goes from the starter (heavy +12V) to the RELAY, not the battery. This is how the aux battery charges only when the relay is energized.
    One area of your camper that may not be in such great shape is the roof. RV books say you should do roof maintenance every year. I think that's a little much but it is important to strip off all the old joint sealer and reapply new every now and then. The sealer goes around all the vent flashing, along the roof edges, etc. where ever there is any joint. I've been putting off doing mine but I have seen that the old factory applied sealer is 100% cracked and useless. You may want to ask the Paradise dealer when you bring it in.
    It looks like I'll be stuck with ordering the parts as well, & installing it, or having it installed. What ever it takes. Sales people will tell you anything to pacify you. Not my favorite people. How nice you got your camper/truck set up at one time. Instant camping. Great! I'll let you know when all mine comes together. Going to call again Monday am for the build date. Looks like you'll be up & running long before I will. You know, I've yet to see a 2k, 3/4 extcb, 4x4, LB. Not one! Far as that goe's, not even a 99. Let me know what you think when you get your sway bar, far as installation. Do you do any camping in the heart of the winter. Most of the places we go to, are under 10' of snow. Do you think I'll have to install extension mirrors, or will the stock ones due for hauling the camper? Think I'll go to Camping World tomorrow, & do some snooping around.
    You may want to wait on the battery installation until you try your rig a few times. If you expect to stay places with power then you absolutely don't need it. Even without AC the camper's battery should be fine for weekends. Where the duals really help is when you stay in one spot more than a few days without driving. Also cold winter camping requires a lot of heater which consumes power. Did your neighbor replace the battery recently? Since they had an air cond. they must stay at places with power so the batt may be pretty old.
    Did you order an extended cab? I thought is was reg. cab as mine is. I ordered the camper mirrors so I hope those are adequate and I don't have to add any mirror. Did you order those? If not then you will definitely need to add some extension mirrors.
    I've camped in the snow only a little, usually not on purpose. With my one wheel drive truck it makes be nervous. Most campgrounds at altitude are closed in the winter so I end up at the coast or local places if I don't have much time. The Santa Cruz coastal range is near here and has some beautiful spots in the redwoods open year round. Have you been to Death Valley? The winter is the only time to go unless you like 120 deg heat.
    For now I wont be putting in the aux. batt, until I get a feel for things. When I bought the camper, I installed a new marine batt & I also have a batt. charger to keep it up while not in use. I did order the extended cab, LB, LS, & since my camper is a extended cab also, I thought it best to have the extended cab on the truck, so it doesn't hang so far over the front of the truck. Might be too long for some people, I'm really not concerned about that. I will more than likely be getting a fifth wheel in the near future. Right now we want to enjoy what we have. Yes I've been going to Death Valley for the last 35 years. When we lived at Tahoe, we would go every spring to escape the clutches of winter. We would camp at Mesquite Springs up by Scotty's Castle, & also spend time at furnace creek, Texas Springs, & even had to spend a couple of days on the asphalt jungle. Besides absolutely loving the mountains since I was raised there, I'm also a desert rat. When we lived at Tahoe, I had a dune buggy, & we would go to a place called Sand mountain outside of Fallon Nevada, & just have a hell of a good time.When do you usually go to Death Valley? I lived in Palm Springs for a while, so I can honestly say, I DON'T like the triple digits. On the mirrors, I goofed & didn't order the camper mirrors. I guess I'll buy some after market ones you can take on & off. Any suggestions? Oh, & I haven't camped in Santa Cruz area either. I've heard there are some beautiful places. Maybe sometime.
    I've only been to Death Valley once. I'd like to go back with the new truck and drop the camper in the campground and drive some of those dirt roads to who knows where.
    For great redwood forests you are better off going to the Eureka area. The distance isn't so much different and you don't have to battle the crowds.
    The mirrors are a mixed bag. From the photos it looks like they did a nice job with the extendible mirrors however they are manual adjust and someone here said the passenger side mirror is flat. So if you mostly use the truck without the camper you may be better off with the regular ones. I really wish the camper mirrors were power, it's so handy on such a wide vehicle.
    Well good luck, let me know what the Lance dealer in Paradise does to your rig. If my truck was actually built last week the dealer should be getting an invoice in a few days. Now I have to figure out how to pay for the thing!
    You guys spend more time at your computer on weekends than I do. Actually, I don't turn on my computer nights or weekends. I log in before work and at lunchtime. However, I understand indoor activities with bad weather, its just that we finally got summer here.
    I expect to receive my sway bar this week, and I will install it this weekend. I'll let you know how the installation went and the effect it has on the truck. I'm not a pro, but I've managed to accumulate enough tools and experience to tackle almost any job (outside of the truck's computer). I think the sway bar will be easier than the Air Lifts that I put on; maybe about the same a changing shocks. I'll let you know.
    We get enough time off work because my wife and I have both held our jobs for over 25 yrs and get 6 weeks vacation each year. This year we used it all at once to go to Alaska.
    Fantastic! We were quite prepared for it to be exspensive, it was not. In the south (Anchorage/Denali/Kenia) it was a little high, in the north (Fairbanks/Dalton Hwy)it was cheap. Camping averaged $10. Scenery and wildlife far exceeded expectations. The sheer size of the place boggles the mind. The clarity of the air hides distances. In CA its a rare day to be able to 50 miles. In Alaska you can look acros a valley and no know if the mountains you see are 35 miles or 135 miles away. Nothing manmade to give scale and perspective to the view. Nothing like driving 400+ miles up a dirt/gravel road, through mostly empty country, to have to turn around and come back down the same road. Driving for hours without seeing anybody else. In case you can't tell, we enjoyed the trip, especially the northern part. We will go back.
    But there are a lot of other places we need to visit also. After all, my wife's only been in 44 of the lower 48 states (only 6 before she met me). We graduated from a motorcycle and tent camping to this 1/2 ton 4x4 with a pop-up camper. The thing seems huge to us and we can't imagine one of those big Lance campers. Our truck has a std cab and the front overhang is 5" high and not as long as the roof of the cab. The bed slides into the living space, and with the bed put away we have the full 8' available. Slide out the bed and we have a queen size bed. Close the top and we have less frontal area. We averaged 15mpg to and from Alaska. My parents used to have a big cabover camper, moved to a 5th wheel, and now to a tag trailer. I understand why some people like the big rigs, but we are really happy with our choice.
    Later,
    Mike
    I can see where the popup is a nice mix. The Lance is very nice with the added security and convenience of a hard side but it is huge and heavy. Going off road on anything but smoothish dirt really throws it around and the gas mileage sucks. But for on road I think I would still prefer the hard side. I've never had a popup so I don't have anything to compare with.
    Just found out Air Lift changed the part number for 99/00 Silverado 2500. It is 57245 per their web site but the factory says the correct number is 57250. Performance Products has a 15% off sale going until the 29th of this month. They sent me a post card, don't know if you really need it.
    Mike - I'm interested in your Air Lift installation. Are there any tips or problems you can pass on??
