Torque Lug Nuts to Avoid Brake Disk Warp ?
Does anyone out there TORQUE their lug nuts when they mount their wheels on the Solara ?
My super-ace mechanic brother-in-law says that you SHOULD do this (to manufacturer's specs) so that you don't warp the rotors
How much does a torque wrench run, anyway?
Do you mean how much torque? Mine have 450 ft. lbs and 650 ft lbs. Enough to break all the lug nuts with ease.
Or do you mean how much do they cost?
You can buy cheap junk for about $50 or you can buy a quality Ingersoll Rand air wrench for about $129
another way to get this result is to jam down lug nuts one by one. this gets to the funny result of the little centering conical section of the lug nut not going inside the wheel hole, but binding up on the outside of the hole on the rim's edge. first time you slip on pavement, you have a loose stud as the wheel reseats. good way to have lug nuts come loose and wheels fly off into the bushes, and a good way to break lugs. that kind of pressure is bound to warp hot, thin rotors.
in any event, it's something you have to watch for when tightening down a wheel. and why it's supposed to be done in a star pattern in two or three passes.
I just wonder how many people are aware of this and/or ensure that this is done when going in for service (i.e. tire rotation).
Even if you're using an air wrench, you should turn the lug nut on a few turns by hand and then use the air wrench. However, a lot of the gorillas as these discount tire places do all the turning with the air wrench. If the lug nut is cross threaded, the air wrench will still drive it on fine. The problem comes when you try to remove that lug nut and discover that its cross threaded.
This happened to me once. I immediately went out and bought a floor jack and now do my own tire rotations.
Also, a good torque wrench isn't cheap, and a cheap one isn't good.
So just tighten your wheels firmly by hand and don't over-caffeinate prior to installation.
It is heat that warps rotors, but if they are not tightened evenly, they expand unevenly. Tightening by hand in several stages, you will most likely be close enough. Using a power wrench, even with "Torque Sticks" may end up with uneven tightness if one i tightened before the rest are snugged.
A 50 to 250 pound foot Central Tools "click" type wrench wholesales for about $240. I buy mine through a wharehouse company.
Harry
Never seize is great stuff. Me myself and I prefer to install lugnuts dry.
Harry
Plus, if you have a flat in the middle of nowhere, and the previous time you had work done in your wheels the guy pounded the lug nuts with thee air wrench, you won't be able to get them off.
Do them with the provided wrench, and you should be fine...
My $0.02. G.
warning, danger, beware of possibility of personal injury when overstressing tools, never be put in a position where the tool could trap you against a firm object or could snap back and hit you, etc. and so on, voids lifetime tool warranties, support your local lawyer, and so it goes.
As they heat up and cool down, they expand and contract. If the lug nuts are not torqued the same, over time the expanding and contracting can cause the rotors to contract differently on portions of the rotor.
and if you do them one at a time, I guarantee you will NOT have one or more of the lug nuts centered in the hole of the wheel... where the taper at the end of the nut will not have entered the wheel to make a final centering adjustment... and those will loosen in just a few hours of driving. possibly even spin off into the weeds.
just two more ways to have uneven force against the rotor... and when it gets hot, it will expand wherever it can. if there are gaps between the wheel and the rotor... and there WILL BE sooner or later if all the nuts aren't snugged up the same... the rotor will be encouraged to distort.
It is when impacts are used when the most problems are caused.
In my opinion, if they install a rotor that can actually be bent by changing a spare tire with a lug wrench, then they are REALLY cutting the corners too thin in making the car. Reminds me of when GM expected Corvair owners to put just the right amount of air in front and rear tires (different pressures), accurate to within a pound or two, or face dire consequences--well, guess what?
I would think that the tire/rim going around a corner in the road at 45 mph would put more pressure on the studs than over tightening the wheel nuts would. Where am I going wrong here?
you don't have to warp 3/4-inch to make a shudderingly obvious difference, just a few thousandths of an inch (probably 10+ thousandths, but I don't gage rotors for flatness, but that seems a reasonable out-of-flatness to cause issues.)
Stamped metal is extremely succepptable to warpage, which is why some aftermarket replacements for vehicles like the Lumina are cast, machined rotors.
Understant that the hub of the rotor affects the braking surface. If you pull a bolt down, the face of the rotor flexes. As it heats and cools, it will set in a position.
Most often, this only happens when air wrenches are used. It can be corrected by having the rotors turned on the vehicle, but then again, if they are stamped rotors, then replacing them is the best option.
My personal opinion is that rotor thickness plays a large part in rotor life. That thickness can be achieved a number of different ways (design-wise) but I have seen some pathetic rotors on certain new cars. They seem more interested in making them look nice than in giving them durability.
Comparing aviation to automotive is like comparing apples to oranges.
There are alot of requirements in aviation.
Those requirements are not there in automotive.
Not everyone carries torque wrenches, but EVERY tire shop should have them. If nothing else for liability concerns.
I have torque wrenches that range from $150-$650 (1/4" dial to 3/4" 600 ft/lb.) and all of them are sent in every 6 months for re-cal.
If I pull a tire, I may use a torque wrench or a torque stick, but all lug nuts get torqued.
Now I would have thought that the discs had been warped. Not so - the rear drums were the culprits. I proved this by lightly pulling on the parking brake while rolling to a stop.
A new set of drums solved the problem. I also noticed that the cheaper drums were pressed out and were manufactured in a South American country. The story I got was that these countries buy the stamping dies cheaply from manufacturers after they go out of specification after so many operations.
So either the drums had become out-of-round or the mounting surface had become warped. Anyway, it beats the heck out me as to why it happened. For sure, the lugnuts were over tightened but I still can't fathom out the mechanics of the process taking place when nuts are over torqued.
I doubt they are selling production dies overseas. rather, we have some folks doing reverse engineering overseas from a sample, and their products are at best three stages removed from US production.
BTW, drums and rotors are cast metal in the case of every car I have ever bought. check 'em out for balance holes drilled in various odd places, a hallmark of casting parts that need to be balanced.
the parts you had malfunction were cheap cheat jobs.
After stamping out the drums are machined and you could clearly see where the the chuck of the lathe had gripped the outside of the drum. It's possible that at this point where the mounting for machining is critical, that any offset will be reflected in a wobbly or egg shaped drum.
No - there were no balance holes drilled in the stamped out drums.
No - the drums that got warped on my car were factory fitted drums and not cheap cheat jobs. There were balance holes and weights fitted to them - a sign that they were cast. I bought the car new in 1999.
good to see you weren't taken in by the scam.
Which brings to mind another thought. Any stamped out drum or brake disc must of necessity be softer than a casting. If you are going to stamp out a part the material has to be malleable hence softer.
A casting can be made of high carbon steel and a good brake drum or disc can crack if given a hard enough blow. You cannot stamp out a form made of high carbon steel. I suppose stamped discs and drums will just dent if given the same blow. Maybe that's why discs and drums don't last so long any more. They're too soft. I'm no expert on the subject so please correct me if I am wrong.
