2000 Chevy Silverado vibration
1246710
  • tuckyboy1tuckyboy1 Member Posts: 36
    Have you considered the lemon law? Sorry to hear about your troubles.
  • jed1894jed1894 Member Posts: 337
    Yes I've considered Lemon Law, and I'm giving the dealer one more shot at it (transmission). I've already started file with GM. If transmission not the problem, they'll have (by law) one more time; they'll probably put new wheels or tires and that'll be it. They'll probably fix with tranny or different brand of tires. If that doesn't fix it, there's nothing else to try.
  • edd4edd4 Member Posts: 22
    No Vibrations. 1500 4X4 reg cab, long bed, auto, aluminum wheels, Goodyear tires.
  • samrabbitsamrabbit Member Posts: 23
    It is now ninteen days in dealers service department with lateral vibration problem for me. Have no idea what is left to try but fairly certain I am not alone on wondering exactly what is causing the problem. GM Techs are fully involved in trying to solve this problem. Just wish it was not my 2000 Silverado being used as the proverbial "guinea pig". Oh yeah, this is a 5.3/automatic/3.73 posi/long bed/regular cab/Z-71 with Firestone..wait Goodyear... no wait Michelin tires on it now...oops went back to Firestone tires again.
    Have they considered new transmission yet? Sounds like that's all left to do....
  • quadrunner500quadrunner500 Member Posts: 2,721
    Have almost the same truck as you, 5.3L/auto/4.10, eaton locker, long bed, reg cab/Z71 with Firestone and factory aluminum rims.
    No vibrations yet, 17,400 miles. Have not even balanced wheels, but have rotated once without balancing. Still great!
  • sabot1sabot1 Member Posts: 28
    Howdy All,
    I've been tracking the problems you have all been listing for about 7 months. You all have been reporting the same problems over and over again. There are five basic problems since the Silverado/Sierra line started and some new developments in the last few months. These problems have been reported by both Chevy and GMC owners.
    1) Launch stutter- loud bang and/or lurching, then bed chatter felt when starting at a light or stop that goes away after a short distance. Reportedly caused by excessive torque lifting the right rear wheel off the road then dropping it back down. The change in drive line angle causes the u-joint to bind and unbind until the inertia of the vehicle allows the suspension to return to normal position. FIXES to date- replace rear springs, rebend rear springs, stiffen rear springs, add another leaf to rear springs. Seems to work most of the time but not in all cases.
    2) Low speed shimmy in front end- Caused by a number of things- Bad tires, wrong hubs B8 instead of the required B9, possibly the pressure sensitive steering mechanism. Fixes to date- rotate tires, realign tires, rebalance tires, replace tires, replace hubs-races-bearings, adjust steering preload (not an official fix but does work according to scraw in OK). Replacing the tires works for about 200 miles. All other fixes except adjusting the preload and replacing the hubs DO NOT WORK but will be tried before you ever see a new part (part of the procedure).
    3) Low speed vibration (30-45 mph)- caused by a bad program for auto trans owners. GM will flash your chip to update shift points. This appears to solve the problem in MOST but not all cases.
    4) High Speed vibration (60-70 mph)- This problem seems limited to any 2wd design Silverado/Sierra that has a 3.42 diff. Every engine trans combo and every body design reg, ext cab SB & LB have this problem. 4wd models with 3.42 do not report this as a fleet problem. cause unknown, it is suspected to be a drive line problem dealing with balance of the drive shaft and the angles of the u-joints. The problem is a by product of harmonic resonance in the drive line that reaches destructive amplitude at highway speed (fancy way of saying you can feel and see it at 60-70 mph). This problem manifests itself as a visible bed vibration, then a bed and cab vibration (usually being reported as a vibrating seat), then a bed, cab, and violent shake that makes the truck unsafe to drive. NO solution to this problem has been found and has not been officially recognized by GM as a "problem". Fixes attempted involve anything and everything you can do to a tire and wheel (DOES NOT SOLVE THE PROBLEM). Replacing the bushings between body and frame, adding more springs to the rear end. Balancing the drive shafts, shimming the diff (as long as it remains a 3.42) DO NOT SOLVE THE PROBLEM. Changing the diff to 3.08 or 4.11 DOES solve the problem as does replacing the trans (it appears)
    I can't tell from this BB what percentage of new Silverado/Sierras are having this problem. Based on the lack of response you all seem to be getting from GM, I suspect the percentage to be low 5-10%. If that is the case, it is not in GM's best interest, financially, to solve your problems at this time. It would cost more in lost sales to stop the line, research the problem, and recall and repair all the trucks than to lose a few customers or buy back a few trucks. I get the impression that this is a much larger problem (30-35%). I'm staying away from the Silverado until GM shows interest in solving these problems. GM's appearnt lack of concern bothers me because I like the Silverado and would have bought one months ago if these problems had been addressed in a more timely manner.
    I only included the big 4 after I indicated 5.
    5) Spring squeel- caused by the front and sometimes rear springs rubbing on the spring housing brace. Fix- bend, cut, twist, reshape, the brace to allow for 1/2 inch more room.
    6) [New] steering wheel clunk- caused by another substandard part, fix GM will replace you steering column with a new one (expect a long wait, nationally backordered)
  • trucks4metrucks4me Member Posts: 42
    Look at #174. This is a 4wd and a 373 rear. Many 4wd and 2500's have this problem, go back and read the posts.
    Trucks4me,
    "Seems" some other models are having vibration problems as well. 4wd models are not subject to the same considerations as the 2wd because 4wd don't have the 2 piece drive shaft and the angles to diffs are different by design. '99 Silverado/Sierra had a problem with bad tires and it appears from your's and other's reports that the '00 are having a similar problem. It could be that the speculation about the transmission applies in your case. I'm waiting to see how the trany change out works. I suspect it won't make a difference as the castings and machining are held to very close tollerances. Using cast gears and other new techniques inside the trany may be a cause for vibration that is transmitted down the drive shaft. Bad program for numerical control machine tools, incorrect tollerance in a clamp, or bad quality control for transmission internal parts could all contribute to a vibration along the drive train. There are no vibration damping bushings or connections, internal to the drive line, from the trany to the wheel. Bad tires would only compound the problem. The fact that you feel it on a 4wd indicates that the 2wd/3.42/2 piece driveshaft/u-joint angle theory may only be a part of the problem.
  • shfarmshfarm Member Posts: 1
    I have a 2000 GMC 3/4 ton on order and I too have been following these posts closely for about 4 months. I have come to the same conclusions you have stated. I think the vibration problem at high speeds is a 1/2 problem, although some 3/4 have it, but for a different reason I believe. The trans in 1/2's is different than the trans in the 3/4's. When people have their 1/2 ton transmission replaced the vibration problem is elimated. Therefore I believe there is a problem in the 1/2 trans. I have read posts on pacific audio that dealers have extra transmissions sent from gm for 1/2's but gm won't let them install them because of the expense. This is out of a dealers mouth. It's all a matter of money, you hit the nail on the head.
    Well I got my new transmission for my 2000 Silverado today. Guess what? Vibration gone. However, the first set of tires they put on also changed the vibration to a different speed and ran pretty good for about 200 miles and then it was back worst than before.
    I had the launch shutter also (not real bad) and the new tranny seems to have fixed the problem.
    One interesting point: Seems like when I go around a curve, it seems to have high pitched vibration in steering wheel. That has to be the tires, right? Any suggestions.
    Anyway, I've only drove it 20 miles (at night) with new tranny and my conclusions may be premature about vibration. The vibration was definitely cured at 70-75 mph. Haven't checked any higher yet.
    Furthermore, the tranny was not ordered and installed until I had all the other things first (new tires, wheels, driveshaft, driveline angle adjustment, six(6) balancing jobs, etc.) Now it runs smooth except corners.....and I'll just have to live with that I guess.
    By-the-way.....the new transmission was different that the one they took off. I don't know exactly what the difference was, but it required new tools the dealer did not have in stock to install. They had to go buy some tool (some kind of wrench I think). It also had all the new up-to-date information from GM (it came from GM) according to dealer.
    Too soon to tell.....will advise after a few miles...
    Jed1894,
    Glad to hear your new trany stopped the vibration. I could speculate on a bunch of possible reasons it works but thats all it would be. Good new is that GM did have a fix for you. Hopefully they will retro this into all the 1500's having the problem and not make everyone go through the entire ordeal of unsuccessful repairs and endless tire rotations/balancing. Good luck. I'm curious to see if this lasts.
  • scott138scott138 Member Posts: 1
    Just took delivery on a 2000 LS Z71 5300 with 3:73 locking rear. This vehicle has 900 miles now and absolutely no hint of vibration at any speed. I do have unusual shift feel from 1st to 2nd on light acceleration. Dealer says nothing wrong.I will be going back with it for this. Except for trans shifting issue this truck exceeds my expectations and again has no vibration of any kind at any speed up to 95 mph. I am thrilled with this truck.
    Sabot1: Yea, I'm hoping this new tranny will fix problem; time will tell I guess. The past vibration is gone....however, I'm so paranoid now I feel everything that moves. Another interesting point: every heard of "matched" balancing. Apparently it's some kind of tire balancing whereby all tires stay mounted on the vehicle. Dealer did not have equipment, only standard, everyday tire balancer. Although my truck is now smoother than it's every been, he is going to recommend to a larger dealer that I have a "matched" balance done to completely balance the tires. Apparently that system balances tires, hubs, wheels, all together somehow.
    Another dealer told me about some $8000 tire balancer GM is making all the local dealers buy. He said 99/00 are so sensitive that this new balancer is needed to accurately balance the tires. I don't know, do you?
    Scott138: that's very good news.....don't read any more! just kidding...... Good luck
  • kingfishguskingfishgus Member Posts: 112
    I'm still vibrating as before but some less since they changed tires. Would one of you guys that has their transmission changed please post here with a part number or bulleting number so I can educate my service manager.
    I got a new tranny, but I don't know if a part number or bulletin exist. They tried everything else until one day the service manager said that was all that was left to do. He made the decision before he called GM. He called GM in front of me and gave no number, other than my tech. assistance number. I'm going back for rear window in a few days and I'll ask service guy then.
    HOWEVER.....I'm not convinced 100% that the new tranny fixed the problem. I still have to drive on highway (this weekend) to make sure problem is solved. Another thing: don't expect the vibration to be completely gone with new tranny. I still have high pitched vibration due to super-sensitive steering system or un-balanced tires. The vibration is not nearly as bad as before so the new tranny problem cured the big problem. My dealer does not have modern tire balancer, so he's sending me to another dealer with high-tech machine to balance the tires completely.
    Another point: remember the guy who posted the information on the steering wheel pump, or something like that. If the tires are not properly balanced, the super-sensitive steering system with react.....per service rep.
    By-the-way....to ease my mind, I drove six (6) other trucks on the lot.....all had some kind of vibration or shakes....my truck drove the best.
    Anyway....I'll try to find the bulletin number, etc. for you....
    The good tire balancer should make a difference, assuming they swap some tires if needed. It puts something like 700lbs of downward pressure on the tire and wheel to simulate it being on a vehicle. Only problem is what are we going to do when we need a new set of tires. I can't see a tire dealership swapping set after set of tires although I'm pondering a theory that this is a harmonic problem that is just amplified by anything in the drivetrain being out of balance (tires, wheels, driveshaft, internal trans parts, maybe something in the steering, etc.) If I go with that assumption, it seems more likely that the actual real fix would be something like changing the isolation of the cab to frame, or adding some additional crossmembers to stop the frame vibration/pitch or some other non traditional fix. I can't believe Chevy is not on top of this if they are trying at all. I hope they aren't just pushing the problem off to the various dealers mechanics hoping someone will find something. Chances of that happening are unlikely. They can find stuff like tires out of balance etc. but any design or harmonic problem is not going to be fixed by swapping the parts they have available, or using diagnostic tools available to them. I wonder what happend with the guy that the dealer/service rep had put vibration sensors on his truck to try to isolate the problem. I don't remember if he posted here or on another forum.
    I am still waiting for my truck. I apologize, but did not want to garbage out this discussion with a lot of extra posts. GM tech guys swear it is the tires based on the vibration readings my truck is giving them. Main source of vibration coming from rear end from sensor mounted above yoke. Readings of 7+. Maximum acceptable is reading no greater than 5. Not sure of scale but if like a Richter Scale there would be a whole lot of shaking going on to go outside of acceptable range. Service Manager is sifting through sets of tires to get four that meets the specifications set forth by GM Tech on the famous Match Balancing Machine. The acceptable reading for this is 12 or less. Have two so far. One with a reading of 13 and second tire with reading of 4.
    Hoping to get two more good acceptable tires today from two additional sets ordered today. Service has spent an incredible amount of time and energy on my truck. Match balancing takes time to complete. I believe if this does not change vibration with these tires on then the service manager is going to declare the end of the road for this baby. this is the 27th day in the shop working on my truck. I will look back someday and probably laugh about this but right now I am not smilin' at all. Seriously considering ordering a 2500 series to replace this truck either way. I too am worried if this fixes the vibration, what happens when the tires wear out again. No warranty left and no one willing to spend that much time finding four perfect tires. Is GM gonna take care of us then? I wonder.
    Forgot to mention, the tires coming as original equipment from factory are reading 20 + on the match balancer. I bought a set of Michelin tires and they too were well above a reading of 20 + range. Is it the tires? I do not know. But if the tire manufacturers can not consistently hit the ideal number then why is GM releasing these trucks from the production line with out of spec tires on them. This sounds like a quality control problem to me.
    Well guys and girls, the new transmission didn't fix the problem. Matter-of-fact, it made it worst. I reported a couple of days that my new transmission fix the vibration problem. Well it did correct the low speed (0-65) growl/vibration. However, it now has a constant vibration from 75 and up. Although different than before, now the vibration is high pitched. Before, the steering wheel jumped about 1/2 inch. Now it vibrates real fast (if that makes sense).
    Anyway, it now feels like the tires. I have Goodyears (2nd set) and chrome wheels. I'm convinced (again) that if it's not something major, it's the tires and/or wheels.
    I'm writing the Lemon Law letter tonight and mailing it tomor. I've had enough of this truck. Ironically, the only thing the dealer hasn't tried it switching to Alum. wheels and trying another brand of tires. Just switching with another truck on the lot makes a lot of sense to me, but they haven't tried that (?).
    Bottom line.....in my case....it wasn't the transmission. Any suggestions or comments welcomed.......
    Also, anyone know what driveline angle should be: anyone have the correct measurements. They shimmed my driveshaft on an earlier date: two (2) shimms on each side. They didn't take out with new transmission ?......Thanks
    The vibration I described above as "constant" was incorrect. The vibration will come and go at speeds above 70 MPH. Tires and Wheels?
    Jed...just sent you e mail prior to reading your update. I am truly sorry transmission did not work, because it is all that is left to do on my truck now. Dealer was able to install four match balanced tires within specs on my truck. The vibration monitor went from a 7 down to a 2. Drove truck home and I was a happy camper. It was a pleasure to drive my truck. Over the weekend I have put two hundred freeway miles on the truck. The vibration is still there and getting worse the more I drive it. Coming home from Nashville tonight it was becoming irritating to drive at freeway speed of 70 mph. I am taking the truck back to dealer in the morning. I have no idea what to do now.
  • chevy4mechevy4me Member Posts: 203
    Has anyone had or heard of a gear change from 3.42 to either a 3.73 or 4.10? Does this help with the vibration problem? I actually shopped for a truck that had the 3.42 rear to get better mileage, now I wish I had gone 3.73. I have 1500 ext. cab 5.3L 3.42
    That might help with the launch shudder, or driveline growl.
    The front end shaking is from the rack and pinion steering box on 2wd trucks. Someone needs to try a steering dampener.
    I'm going to another dealer, as recommended by me dealer, on Thursday for fance tire balancing attempt. Other tech. says new machine (what ever that may be) will tell if tires, wheels are bad.
    Got letter for buyback typed and will mail Thursday if problem not resolved.
    I guess every time I need a tire balancing job, I'll have to pay $$$$$ for fancy machine?
  • jeffthrojeffthro Member Posts: 35
    I'm sorry guys, I too have had enoooooough of this nagging mid speed and highway speed vibration. I am in day 14 of 40 day arbitration process to hopefully swap/buyout.
    I just don't have the time or sanity for much more of this.
    Jeff
  • lutdaddylutdaddy Member Posts: 10
    I have a 2000 LT...does anyone notice a vibration at start-up? I notice it sometimes, and it goes away after I accelerate. Please post if you have noticed similar problems.
    Lutdaddy: Are you talking about launch shutter or when you're stopped? Launch shutter in these trucks is a common problem, but can be correct and/or fixed. The take off vibration is also common and I don't know if the cure is the same for launch shutter. If you have a 99 or 00 built before Apr/99, there is a TSB on the problem, I think.
    However, my truck still has small shutter/vibration when I start, but it goes away. I also have a new tranmission and all the other fixes that suppose to have fixed the shutter, but it's still there.
    Another cure may be re-flashing the PCM......ask dealer about that one.
    Good luck. John
    Lutdaddy If you have lauch shutter (truck has to moving to feel vibation) on take off, it usually means the the drive shaft if binding. The S-10's had the same problem when they put on 2 piece drive shafts a few years back. leaf springs have correct some of the problems, I heard, on some 99 models. They tried shimming my drive shaft, but it didn't really help much. Good luck
    Thanks for the responses. My shudder is after I shift to reverse or drive, but before I start moving. When I accelerate a little and get going, it stops. What should I say when I take it to the dealer?
    Thanks for your post about the steering shaft. Burt Chevrolet in Denver replaced it without question, is aware of a problem with the old shaft, carries the re-designed part in stock.
    And it works great!
    Well, the problem that I was having was that you could feel vibration from 0-10mph or so when taking off so that sounds different from what you have. The springs and shackes are mean to address an angle problem from driveshaft to rearend, presumably in the alignment of the rear universal. Others have noted the vibration is worse if you add weight to the bed or are towing a trailer (because of tongue weight). I don't believe I have seen any posts about a shudder while sitting still.
    I have my truck back. Finally after 28 days in the shop. The final outcome for now is it is in the tires for the lateral vibration problem. I have put 400 miles on the truck since installing an acceptable set of tires. The condition at 65 mph is better. There is a whole lot of shaking going on at 70 mph, but not enough to trip the vibration scale to not acceptable. I believe the lateral vibration is a "harmonic" generating from the frame. Possible also is wind catching in the box. Has anyone tried driving with tail gate down to change the vibration of their truck? I did and the vibration was different, but not the same as when tailgate is up. Considering taking off the tailgate protector next to see if that changes the vibration.
    I'm still wondering if the frame is the culprit, either vibrating or out of alignment, bent, etc. There were some bent frame worries/posts sometime last year that I saw somewhere. I wonder if it would be worthwhile to get the whole vehicle alignment checked by a good body shop with state of the art alignment equipment. See if the rear end is pointing the right direction etc??
    Just something else for us to worry about.
    Whatever the problem is, I have to believe Chevy knows what it is but won't fix because of the cost involved. With so many trucks having the problem they have to know. Better for them to fess up and fix it rather than get into the lawsuits that will come up later which, no doubt, will bring it to the publics eye and force them to fix the trucks anyway.
    Hey Chevy, how about being responsible for a change. People do appreciate honesty even though it seems to be lacking in many folks of late.
    Sorry, I'll get off my soapbox now.
    Guess everyone's heard my vibration problems and what GM has done to attempt to correct (new tranny, drive shaft, angle adjustement, 2 sets of tires, balancing, shims, etc.) the problem. Get this:
    After the new tranny didn't do the trick, the dealer sent me to another dealer with some $14,000 tire balancing machine....state of art stuff. Well I get there with a vibration at 73 and above and leave with vibration at all speeds and a steering wheel jumping/shaking. It drove 100% better before I took it. The new dealer tried to give my some BS reason the steering wheel was jumping after I took it in (bushings) and said that GM was going to recall the 99/00 trucks to correct the problem. Everything he was saying was total BS.
    Anyway, being completely confused and mad, I went to tire dealer on the 2 hour trip home. At my own expense and without telling the tire dealer what I had gone through, I asked him to simply balance my tires. I explained what it was doing and took him on test ride. After about 20 minutes he took me into garage and showed me why he thought my truck was vibrating. Two (2) of my chrome/steels were so warped it wasn't funny. Very noticable on the standard tire balancer. I also had two (2) Goodyear tires that were also defective and would not balance out.
    The tire man told me that it was amazing that the truck wasn't shaking/vibrating worst because of the bad tires and wheels.
    Bottom line: this was the first non-GM people to work on my truck and found the problem in 20 minutes (or at least another problem). Anyway, I then went to the post office and mailed my Lemon Law letter requesting repurchase.
    Oh yea,,,,,dealer said, when I showed him paper work (that I paid for) about problem, offered to order new chrome wheels and more Goodyear tires. That will be third set.
    What a joke! John
  • croctcroct Member Posts: 26
    My 2000 silverado 1/2 ton standard cab. long bed
    vibrates bad at 65 mph and up. Its only got 277
    miles on it.Should I report to dealer or direct
    to GM ? Looks like no easy fix , and possibly
    several visits to dealer`s repair shop in my future.. I`m looking for advise from anyone who has been able to win out in this unfortunate situation.
    My own little test at 65mph on up I`ve noticed that vibration much worse on cocrete hiway compared to asphalt hiway , Is this the case with any other 2000 silverado owners? Could this rule out drive shaft or transmission as being my problem?
    If not mistaken, Croct, Chevrolet offers 500 miles, satisfaction guarenteed on the 2000 Silverado. Go get your money back and quick. Before that sucker rolls up 501 miles. Check it out and do not look back. Then drive your replacement truck and make sure no vibration, before accepting. Thaey cannot all shake.
    Croct, sounds exactly like mine. If you can go back before the 500 miles mark like samrabbit said, you better jump on it. I went back at 700 miles (too late) and then the fun started. Now 6800 miles and still no fix and I've done everything. However,,,,,,if you read my previous post--I found out I had two warped rims and two bad Goodyear tires. What kind of wheels and tires you have?
    Also what month yours built? Look on driver side door for month and year....
    Don't let them BS you when you take it back.... I'm in process of trying to make GM buy mine back. Good luck,,,,,John
    Well,my tires are goodyears,my wheels are chrome.
    Are these chrome wheels or hub caps??? When you feel the inside edge it feels like two parts.
    ps; still 277 miles I'm not driving it till I make up my mind on turning it in or trying to get it fixed. I`m driving my 89 chev 1/2 ton 163000
    miles on it .Its` still a smooth shifting automatic and smooth ride. I was hopeing to get ten good years out of my new one, you know ???
    forgot to check the mnfr.date earlier, it`s sept,99
    Dealer told me truck had to have 500 miles before they would work on vibration. If you got it, get rid of it immediately. You may be able to find one on the same lot that is OK, but don't keep the one you have unless you want to spend the next few months taking it back repeatedly, then get shafted on the buyback which is based on the mileage.
  • white6white6 Member Posts: 588
    My 2K GMC Sierra SLE came with the aluminum wheels
    and Goodyear tires. It had no vibration initially,
    but developed the steering wheel shakes at about
    300 miles. I then put a new set of wheels and tires
    on (Chevy factory aluminum wheels and BFG Long
    Trail TA's, 245-75R16) and it did not change
    anything at all. I am convinced it is in the
    steering somewhere. I'm going to take it back to
    the dealer tomorrow and see what they do. I already
    talked to the service manager and he said he
    hasn't heard of this problem before. Yeah, right.
    Will post my results.
    I also have chrome wheels and Goodyear tires, at least I did have Goodyear tires until today. GM authorized change of tire brand but not to Alum. wheels unless I paid 200 per wheel (Fat chance). Anyway, I had two warped rims that was causing a shake/vibration.
    Now with 25 miles on it, it drives smooth with new General tires. Don't know how long it will last though. It has rode smooth before but then began to vibrate again after 100 miles or so.
    Suggestions: Have an independent tire person check your tires and wheels. And if know what to look for, ask to watch them balance the tires on the balancer. If you rims are warped, as was mine, you can see it there. You can also see if the tires are defective as well.
    According to my independent tire source, the Goodyear tires are worthless. He has replaced for other Chevy customers with Factory Goodyear tires because of rough/vibrating ride. Warped rims and bad tires apparently affect this new style truck in a hard way. The steering is very sensitive apparently.
    Another suggestion: if you can return it and walk away, do so. Chevy has a problem on their hands and apparently don't have a clue yet.
    By-the-way....I also had a new tranny, which seemed to have help the vibration problem. But my hopes are high that the warped rims were the real culprit and the problem is now cured....guess I'll know in a few hundred miles.....John
    Forgot to answer question about wheels you asked. The wheels are actually steel with chrome finish. The cap will unscrew (black nuts) and remove. Then you can get to lug nuts.
    The black cap nuts will loosen on their own, but will not come all the way off. You'll need to hand tighten occasionally. There is a fix but no TSB yet that I know of. Some guy posted a fix a while back but I forgot what it was. Good luck. John
    Are the General tires the Ameri*660AS, size P255/70R16? Just wondering cause I'm on my second set of Generals. Replaced all five about four weeks ago. The problem I had with the first set is also happening to the second set. Feathering on the edges due to lack of sidewall support. Feathering starts at about 400-500 miles. I'm working on getting a third set as of right now. I guess I'll keep replacing them until General gets tired of it. Good luck with your new set!!
    Just my luck! Yes they are. Unbelievable!.....Will this problem ever end for me? Seems like all tires they're putting on has some problem. Did the feathering cause any addition vibration, etc.
    What tire pressure you keep in General tires?
  • z28ls1z28ls1 Member Posts: 2
    Originally had no vibration problems, but now do. Seems to happen between about 60 and 80. Whole damn passenger side seat shakes. Should I even bother with my local dealer or should I go straight to GM?
