99 1500 Dodge Quad Cab 4x4
I know that isn't what you asked for, but thought I would warn you of the transmission problems in case you didn't know. One friend of mine has a 96 model Ram Extended Cab with 360 and he constantly complains of 10 mpg gas mileage, he has 80k miles on the truck now and has had 10 sets of front brake pads on it and he is an older driver that does not drive hard. Those are the two biggest complaints I hear besides cosmetics and asthetics that are pure preferences.
I have also had the truck in several times for movement in the steering column. Dealer is yet to resolve this problem, but I will not let up on them until they do. From some of the other posts I have read, the steering system has been a weak link in the truck. The September issue of Popular Mechanics berated the Ram for the same steering column problems. Read for yourself. I also read where Dodge made some changes to the steering system for the 2000 model year. Maybe I should have waited, but I couldn't pass up the $1000 rebate. I have the 5.2l (318 c.i.) engine. I get between 12 & 13 mpg in mixed driving. The 5.9l (360 c.i.) is actually rated 1 mpg higher in the city rating. Go figure!
I drove all three (Chevy, Dodge, and Ford) before I bought the 99 Quad. Ford was out from the get-go because I banged my knee on the dashboard when I climbed in the truck. Sorry Ford, but reserve the wrap-around dash for passenger cars. The Chevy was a nice truck, but the price was not right. Also, the chevy does not sit as high as the Dodge. I am 6'-5" tall, and I cannot stand having to fall into a vehicle. GM's plastic dashboard components look pretty cheap too.
I guess what I am trying to say is that you can find something wrong with each truck and something great with each truck. Drive all three. Pick the one you like the most. Buy it.
Have fun.
I traded my 95 GMC in on the truck after my transmission failed at 52K with no towing and light hauling. I had replaced all the U joints, and then the tranny went with every synchro, gear and guide shot to hell. I rebuilt what I could and traded it in. In fact I could not buy a tail shaft with reverse gear as the suppliers all said it was on "intergalactic back order" for around 90 days.
I like the look of the Fords. But they remodeled after the Dodge and I would not trust a Ford engine if I had to. On top of that I was always a diehard GMC truck buyer. I dont care either for the use of materials in GMC interiors nor for the redesigned look. I always liked the 88-92 look and love the GM motors. But Dodge put it all together. 4 doors, a rebate, good price, nice style and interior.
But being a conservative CYA kind of guy I bought the extended warranty out to 75K and if the tranny goes then Chrysler will pay to fix it.
I too have noticed poor gas mileage but its a truck. If you want good gas mielage buy a Honda !
Before I bought my truck I spoke to a guy I know with a 97 1500 Extended Cab, 4x4 with a trailer package. He tows boats, and sleds as well as off roads for hunting, hauls his quad and jet skis and drives a ton for work. He has around 70K on the truck with no visits to the dealer ever expect for the intial free oil change and scheduled maintenance. Not a problem, squeek, rattle or clunk. Testimony to me that the truck was good.
Good thing you bought an extended warranty. Most people I know that have bought Dodges wished they had one when all the problems started.
Take care.
I have erred however. I should have extended the warranty even further as I drive too many miles and will burn through my extension to 75K long before I am interested in a trade.
PLACED AT 35,000 MILES (MY FORD FI50 SB ATE ROTERS AND PADS) THE TRANSMISSION HAS WORKED FINE FOR THE LAST 50,000 MILES AND YES I DO ALL THE MAINTANED THAT IS RECOMENDED BY DODGE!!! BOTH TRUCKS WERE TO TOW A 27 FT FOUNTAIN POWER BOAT AND THE DODGE
DOES BETTER THAN THE FORD (FORD DID FIX EVERY THING UNDER WARRANTY BUT TOOK FOR EVER AND THEIR PADES LASTED APX 7,000 MILES ) WHILE MY DODGE HAS NOT BEEN WITHOUT PROBLEMS IT IS THE BEST I HAVE EVER OWNED BAR NONE AND THE SERVICE AT (WEXFORD DODGE HAS ALWAYS BEEN VERY GOOD) WOULD I BUY ANOTHER
YOU BET YOUR LIFE I WILL. THANK YOU BILL NEWCOMB
AND THE GUYS IN SERVICE
ANY QUESTIONS E-MAIL (ME) BIGBADWOOD@YAHOO.COM
The real equalizer is price. Only you can decide. Sounds like a fun problem to have.
Let me know if you want to move to the mileage topic.
Bob
Rob.
--TomC
Borla Exhaust
Performance chip
I've already done:
Tonneau
265 tires (Cooper Discover)
Tried changing grades of fuel
I WON'T TRY FUEL ADDITIVES
I knew going into this truck that fuel economy didn't even enter into the equation, but a little improvement wouldn't hurt.
Any ideas?
to.P.S, There is a new and old Message board there both great! http://www.abhunter.com/
and http://www.abhunter.com/wwwboard/wwwboard.html
Hope you all enjoy,Bob
on it.
It gets 14-15 mpg hwy, I don't drive
enough city to care about that mileage.
The ONLY problem I have is a squeal that
sounds like it is coming from the rear axle/brake
area. It only occurs below 10 mph and is intermittent. The dealer could not isolate it
and was in the process of locating some type
of noise isolator,(his words, not mine)
and the noise of course went away and has only
re-occured twice in the last 4000 miles.
The noise had started at about 3,000 miles and continued to about 6,000 miles.
The noise sounds like metal to metal rubbing
similar to brake pads that are worn to the rivet
level. I had an independent mechanic also check
it out but he had no luck.
Other then that I have no complaints, so if
anyone else has had a similar problem I would
appreciate any feedback.
As far as gas mileage goes, it seems my Dodge is like all the others (10-13 combined). I didn't really want the 360 engine and in my opinion, the dealer loaded up all the trucks on the lot with 360's to make more money on this option. So far I really like this truck. My last 7 vehicles were Dodge or Plymouth products and I've always been happy with them. The body style of the Sport really catches the looks going down the road.
it is unwieldy to manage, and difficult to use for "newbies". There is entirely TOO much topic duplication, so I will be doing some SERIOUS topic consolidation in the next few weeks, getting us down to not more than 2-3 topics per vehicle type, and ultimately down to 200 topics or less.
THIS weeks consolidation candidates are: F-150's, Silverado's, Dakota's, and Dakota Crew/Quad cabs.
In that vein, please consolidate this Dakota Crew/Quad Cab topic to Dodge Dakota Crew Cab - II and continue these discussions there.
Front Porch Philosopher
