Ford 5.0L 6cyl good or bad?
I am looking into purchasing a used F-150. For
some reason, I think that I would enjoy having the
inline 6 that Ford used to offer with a 5-speed.
Anyone have any comments, negative or positive?
Thanks for any input!
PJB
PJB
Nothing wrong, but my new chevy 4.8 V8 has more power, gets better fuel econ. Just hope it turns out to be as reliable as the old 4.9 ford.
BTW the 225 will run forever, truly bulletproof with appopriate maintenance, but truly gutless.
Bottom line, the 4.9 engine is a very good engine.
There is a little knocking on first start-up, but it goes away when it warms up.
I highly recommend this engine.
My brother-in-law had a 2 wd with the same engine and tranny he used to pull a heavy trailer loaded with a grain bin to be assembled, as well as acetylene and oxygen torches, welders, tools, and three men in the cab. He said it would pull anything he could load on the trailer, it just wouldn't stop it.
I wish Ford would go back to that engine. If they did I would be inclined to trade trucks. Otherwise, I'll probably just keep going with the one I have.
I get critical because I've owned both. Actually--I still own them. I have two 90 I-6s and bought two 98s with the 4.2 for light shingling. Have yet to notice any "Blowing up motors". LOL!!
Don't get me wrong, the straight six was a great motor--probably better than the 305 and 302 for small eights but the 4.2 is newer and benefits from better tech. Sometimes change is needed.
The problem with this board is that no one seems to quote any facts and instead project myths.
Torque numbers almost identical of the 5.0 V8
90' Bronco, 140,000 miles, used for towing, hard work, daily driver, HAVEN"T SPENT ANY MONEY ON NONE ROUTINE MAINTNENCE!!!, doesnt' burn any oil or anything, have heard similiar stories
guy I know had 230,000 before it started burning oil!
IT gets great gas milege
bearing. These motors will go to knocking like crazy if you pull the front timing chain cover.
Thanks dshem
I would say don't do it! Your truck is not the heavy duty model (GAVWAR 8600-8800) and with the weight that you're talking about, you heading for Over-loads-ville.
Rich
Great motor to run around empty, poor motor to tow with.
Torque tows-not hp. The I-6 is a decent tower comparable to the 302 and 305 in torque. Same as Escort? Hardly. Your Escort was probably closer to 80hp.
And my diesel always pulled better close to its HP peak, not near its torque peak.
The twin cam Escort motor makes about the same HP as a 300 I-6, albiet at a much higher rpm.
This whole torque thing has confused folks for years. HP = Torque * rpm/~5200. Can't have one without the other.
How broad an rpm range the engine makes a specific HP can give a good measure of towing capacity, and undoubtedly, the 300 would out-tow the escort motor, but still pales in comparison to any modern V8.
Final point - 300 makes a good run around empty motor, as a pickup truck running down the interstate needs only 60hp to maintain speed. If one tows, and needs to either accelerate or maintain a large load, you need lots of HP.
The twin-cam motor of the Escort may have a "statistical" equivalent of the 300 but could probably pull half as much. By the time the Escort reached it's hp height, the rpms would be killing the little motor. The Escort lacks the low power to even begin to pull any significant weight that the 300 could. (Unless you blew the clutch) Sometimes, there is no substitute for cubic inches.
Did I claim the I-6 was a great tower? No. However, it can do more than "running empty". I yanked 4,500 lbs back in the 80's on trips to my childhoos home in Luck, NC. Camper being towed with motorcycle in the bed and going up the smoky mountains. It didn't shift much--now would the then-current 351 be better? Sure-but the I-6 performed a little better than any twin-cam Escort motor could.
The 4.8L has a slower peak piston speed at 4 grand than the diesel at 2800 rpm.
HP is the right measure, it's how they rate OTR diesels, ships, .... The peak torque reading just gives one another point along the HP curve, best to compare actual plots of the entire HP curve.
Sorry about my fervor, but one of our local female motorcycle racers has a f150 with the 300 and simply can't climb the 7% grades coming up the hill into Flagstaff (7,000') worth a dang.
"The 4.8L has a slower peak piston speed at 4 grand than the diesel at 2800 rpm."
The rpm is the measure of the speed the engine is turning the crankshaft so how does the 4.8 have a slower piston speed? Isn't the piston an integral part of the rpm speed of the overall motor? Or is it that way because the 7.3 you list is a six while the 4.8 is an eight?
Needless to say any further, but you have confused me. I need answers!!
I bought this truck used, and it has a chrome step bumper on the rear that I thought was probably for show, so I was about to buy a receiver hitch to go on it, when my oldest son, who drove it through high school, told me before I did that to take a look at the towing capacity stamped in that bumper. I did, and it is rated at 10,000 pounds, so obviously the mechanic that owned it before I did planned to use it like a truck.
Keep in mind this engine was built as a truck engine and used in a variety of trucks, from the F-150 up, including trucks used for hauling some pretty good loads. I believe someone in an earlier post mentioned he worked for a lumber yard or something, and they had several with it in them. The secret of towing capacity is the gearing. I once heard it said you can move a freight train with a washing machine motor with the proper gearing. Now it may not move it fast, but it would move it.
Personally, I wish Ford would produce more of the old inline sixes for their trucks. My truck is an '82 with a lot of miles on it, but I will drive it until the wheels fall off because of that engine and the fact I can't get another one.
Yah, my lawn mower would probably pull any of your trailers, geared properly, but I'd be in the way of everybody.
HP at the RPM you are running is what measures towing capacity.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
Pickups Topic 2465, Ford Super Duty forum.
Pickups Topic 2511, Ford F-Series, pre-99 models questions/concerns).
In addition, use the Topic Search, find other Ford pickup topics throughout Town Hall.... Thanks for your participation. ;-)
Pocahontas,
Edmunds.com/Host
