255/85's on Stock 2500 Rims..99 and up
stoutporter
Member Posts: 13
The time has almost come....the best tires I have owned (F-stones...even though everybody cried 4 years ago about them due too watching too much television) are almost ready to be replaced....74K on them...and want new ones before winter.
the 245/75's always were kinda small for a 2500, but I really didn't care. They did the job. I am looking at 255/85's and I remember years past people put these on their 2500 rims and had no problems....or did they?....I don't remember.
Anyone that has done this, please tell me your goods or bads...and what brand worked or didn't work for you. I remember Kelly's were a popular brand. I also know it's limited as to what is offered in the same rating of a tire as the current 245's.
I don't want to hear about 1500's, as they have different wheels...nor do I want advice on aftermarket wheels, as I don't want those either.
Any input is great..
This is for Chevy and GMC trucks....99 and up...2500..NON HD..4WD
- Porter
- Porter
Tom
I know some have done the 285 route on 2500 rims, but I think the 7" rim is not really designed for that tire. What kind of miles does that truck have on the tires?..(I see you say "just put"...so I guess not many)
Thanks for your input.
- Porter
Every tire manufacture calls for at least a 7.5 inch wheel when installing a 285 75 16 tire.
I have 285's on stock 1500 wheels, but think that this size on 6.5 inch wheels would be a mistake.
This is way more than most people want to know about tires - per tire rack web site.
Rim Width Range
Because tires have flexible sidewalls, a single tire size will fit on a variety of rim widths. A tire's rim width range identifies the narrowest to the widest rim widths that the tire is designed to fit. The width of the rim will influence the width of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim. NOTE: Because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.
The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
For example: a tire in the P205/60R15 size is measured on a 6.0" wide wheel and this size tire has an approved rim width range from 5.5" to 7.5" wide. The tire has a section width of 8.23" (209mm) when mounted on a 6.0" wide wheel. If that tire were mounted on all of the rims within its range, the tire's approximate section width would change as follows:
Difference from
Measuring Rim Rim
Width Approximate Tire
section width
0.5" narrower 5.5" 8.03"
Measuring Rim 6.0" 8.23"
0.5" wider 6.5" 8.43"
1.0" wider 7.0" 8.63"
1.5" wider 7.5" 8.83"
Because of the different wheel widths used in the above example, there is a 8/10" projected difference in tire section width when comparing a tire mounted on the narrowest rim to the widest rim within its range. This may affect fenderwell and frame clearances when selecting optional aftermarket wheel and tire packages
Additionally, some vehicle manufacturers and tire companies have permitted rim widths that are not within the tire's original approved rim width range. For example: BMW has combined 235/40R17 sized tires on 17x7.5" rims (which are 0.5" less than the narrowest 8.0" wide rim listed for the size) on certain M3 models; and Chevrolet has combined P255/50R16 sized tires on optional 16x9.5" rims (which are 0.5" wider than the 9.0" wide rim now listed for the size) on certain Corvette models. While these applications have received the approval of the vehicle and tire manufacturers, staying within the approved rim width range helps assure that the tire's internal stresses are within its design parameters.
Measuring Rim Width
The measuring rim width is the industry standardized rim width upon which the tire must be mounted in order to confirm it meets its dimensional targets. Because the width of the rim will influence the width of the tire, a standard rim width for every tire size is assigned and must be used. This standardized measuring rim width allows all of the tires produced around the world to meet the same dimensional standards and therefore, be equivalent with regards to their physical size. The measuring rim width is sometimes referred to as the tire's "design rim width".
Tom
Thanks for the insight.....I do know you can put all kinds of tires on these rims...305's etc.....but it's the long term wear I am concerned about...
I may just go 245/75 again....they did me well.
...and no 1500 talk here Ryan......1500KD (Kid Duty) topics are available if you need be......LOL
N-joy
- Porter
With 255s you won't feel any difference.
I got rid of those firestones at 30k. Two of them were loosing big pieces of tread out of the center.They did grip the road a little better than the Goodyear Wrangler AT/S that I have on it now.
Also change that cabin filter yet? haha
These 'Stones have wore, rode, handled great....so great I didn't want to replace them..
If anything, it will be the 255/85's instead of the 245/75's.....
I still have a few months......like to have them before deer waitin' season..
Thanks for the input.....
....where are the 255 guys who put them on 2500 Rims 2-3 years ago!?
N-joy
- Porter
