Misfire
I have an 03' Mustang GT and I have had a misfire on Cylinder 4 according to the computer code from the dealer. It happens when I get on it, and at a high RPM it will all of a sudden chug, and when I let off the gas it seems to return to normal. The problem has occurred three times and the service engine soon light comes on. The dealer can not seem to fix the problem. Has anyone else had this problem?? Also, is this misfire doing damage to the engine?
Excuse me, please, no offense, but that is really pathetic performance from your dealer.
Okay, let's back up. What DID he do for your car?
New plug wires or plugs or what, other than to reset the light?
We'd need to know what was tried before suggesting anything.
Thanks for your reply. I am frustrated myself. Part of my problem is I do not know much about cars so I am not a good advocate for myself when I am at the dealer. I can not problem solve with them and I do not have the first clue about what they should be doing!! Therefore I am here trying to arm myself with some information so next time I go back, I am better equipped to make sure they fix it right.
The fist time on 7-18-03 they fixed the coil and assembly on cylinder 4, they said it was bad and cause the misfire. On 7-28-03 they said that Ford had put a new program out on a buletain board because other people were having this problem and they re programed the computer, (PCM Calib level), I have no idea what that means, that is what it says on my repair ticket. This last time, I brought the car to my local Mustang shop and they ran the computer and the code ( I saw it myself) said misfire on Cylinder 4 again, so I brought it to the dealer and they ran the codes and it must have reset at the mustang shop because the code they got at the dealer, at least what they told me, was they only got the crankshaft sensor failure code. They informed me that this may have caused the misfire. So, I left thinking it was only a matter of time before this light comes on again.
I do not know what the rev limiter is, however, I can gues that when you hit redline, it triggers something, perhaps that is what happened to me the other day and not a misfire? How would one know the difference between a misfire and rev limiter kicking in?
The light has not come on, however, I suspect it is only a matter of time. When the light does come on and I go back to the dealer, what would you suggest?
Thanks again!!
Mike
I have redlined the car before and now that I think about it, I think I can tell the difference between the two. The misfire is a more severe drop in power and as the rpm's start to scream all of a sudden it seems as if the car is going to just stall and a chug sound as if the car was gasping for air to stay alive, the rev limiter is a lot less dramatic. I am not certain, but I do not think that this was the rev limiter. Based on the info above, what do you think?
Oh yeah, I also meant to tell you guys that I have a few mods on the car, however, my dealer does not think they are related to the misfire. I have a Basani X pipe, Ford racing gears 3:73, a cold air induction kit and steeda pulleys. Since I have a few mods, I have to go to the one dealer who will overlook them and not black ball me from having work done under the warranty. The dealer happens to be a 50 minute drive. At least they will work with me!!
If this misfire only occurs at high revs, it very well could be the limiter--which does tend to be dramatic, if I recall correctly (I try never to redline borrowed cars).
Thanks again for your thoughts on this matter. I have not tried to induce the misfire, however I will try to do as you suggested. Any other advice? Is the misfire going to damage the engine or other parts. If the problem does re occur, and the light goes on, what would you suggest?
If it re-occurs, and the previous repairs did not fix it, then obviously the problem is "further downstream" in the diagnostic chain.
Often, especially with today's complex cars, mechanics fix the symptom but not the primary cause. This is why it comes back time after time.
