Failed Brakes, 2003 Suburban
Does anyone know of a problem with the 2003 Suburban braking system?
My Suburban has about 4K miles and yesterday with no warning, I had no brakes.
The car was towed to the dealership but I'm really afraid to drive it again.
Am I panicking too soon?
The mechanics of the braking system should not be effected by an ABS failure.
No braking on a new vehicle usually is a failure of the master cylinder.
Just how does it release a fluid applied brake.
The ABS system is comprised of computers and sensors which operate these parts that help prohibit a wheel or wheels from locking up. Limiting wheel lock allows the driver to have better control of the vehicle.
An ABS failure does not mean that the braking system is rendered obsolete. Only the ABS control of the system is down, not the actual braking system.
If the braking system fails, it is most likely caused by a mechanical failure and not an ABS failure.
The dealership said that a tiny amount of brake fluid leaked each time I stepped on the brake pedal...not enough to notice but over time the last six months the vehicle lost all the fluid.
That said, I told him I thought the computer should have given me some sort of warning before this...he agreed and said there had to be something defective in the ABS system as well.
I don't know enough about this but he said there is a back up system that would have stopped the car.
Does anyone know what he's taking about?
I will post the part but it was expensive...over $1,000.
The only way is to unseal the system - a mechanical failure!
Perhaps factual knowledge prevails over ignorance?
No. If you believe you are correct then so be it.
I am not going to debate this topic with you any longer.
Besides, what do I know? It's not like I work on these vehicles on a daily basis - right?
Seems to me you'd have a messy floor with a master cylinder that lost every bit of fluid.
The situations people continue to place their families in will never cease to amaze me. It takes less than 5 minutes to check all the fluids in my vehicle....I'll gladly invest that 5 minutes once or twice a week to make sure my family is safe.
I can hear the reponse - it shouldn't have lost fluid in the first 6,000 miles...that's right, it SHOULDN'T HAVE, but break-in periods are the MOST critical times to keep a watchful eye on your vehicle's vital fluids.
Thank God no one was hurt, and maybe the owner will be smarter next time.
Nothing wrong with that.
