1990 Grand Caravan stalls
shelleybabee
Member Posts: 5
I need help! I am at wits end on my caravan. My van stalls, at 1st it was a few times a month & it would restart with no problem. Now it wont make it all of the way out of my driveway. I have taken it to several shops and have also had home mechanic work done but no one can figure out what the problem is. BTW, it's a 1990 Dodge Grand Caravan 3.3 liter V6.
In the last month I have had several diagnostics run on it but nothing is stored in the computer. I have replaced:
air filter
fuel filter
camshaft sensor
crankshaft sensor
MAP sensor
battery terminals & cables
automatic idle speed motor
Fuel pump works & fuel pressure is normal, charging system comes up normal, no shorts have been found, passed compression test, all cylinders/pistons/spark plugs & wires fire normal.
I don't know what else to check & I'm close to running out of time/patience & money. ANY help or suggestions would be appreciated. Thanks
air filter
fuel filter
camshaft sensor
crankshaft sensor
MAP sensor
This is the most common problem for that symptom but it could always be a number of other things like IAC, TPS or a serious vacuum leak. Try the cleaning and see what happens.
I spent the day at this web site reading on the Caravan and after reading a few other entries I'm beginning to wonder if the ac compressor is playing a part in the stalling ?? I have read that other then the tranny people seem to have problems with brakes & ac..which I have had no problem with to date. I run my ac 24/7...even most winter days ( I live in sunny California ) and it runs ice cold.....hmmm
Thanks for any & all input
I don't know exactly what you meant by adjusting the throttle body but if you mess with that base idle screw, I hope you know how to do it. It's a pretty technical adjustment.
Now you say the tach goes screwy. That is an indication of losing you primary ignition signal. I don't know the the details of you engine (dist..DIS..etc),. also, we don't know if we are also losing injector pulse or not. In order to find out the van will have to be run with a spark tester and a noid like attached and observed when the stall occurs. This knowledge will point you in the right direction. An ignition only loss would point toward coil or ignition module. If injector pulse is dropping also look at things like crank sensor (DIS) or dist pick up (dist engines). They supply reference for both. Sometimes the ECM supplies power supply to both coil and injectors. This could also be an issue. Monitoring fuel pressure would also be a good idea. Bottom line is you have many possibilities and you need to gather a lot more symptom info.
for instance I have adjusted and cleaned the throttle body & the cables
What I had meant by that is that the throttle cable had come loose so I had that adjust (yes with the base idle screw) & I had the throttle body itself cleaned with cleaner & brush to make sure it wasn't sticking.
As for the engine itself it is DIS and I have had the fuel pressure checked but while idling not as it stalled so I will have that checked again, thank you. Also I had the coil checked but again not as it stalled, only during as it idled so I will have that checked will it idles until it has actually stalled to see if that reading comes up different. 1 mechanic I took it to suggested that it might be the ignition switch but he said that there is no way to check it, I would need to replace it & then see if it helped. It had sounded to me like he was just trying to take more of my money.
Thanks desi I will try what you have suggested.
That is what we refer to as "throwing parts at it" Believe me, a good tech doesn't operate that way. This is what makes it so hard with intermittent problems. You HAVE to duplicate the problem and it has to be when you are monitoring the vitals so you see what gave out first. I deal with problems like this every day and it's tough. You can't guess, you HAVE to confirm what's actually happening. That's why I said to monitor spark, injector pulse and fuel pressure. You have to know what every one did as it stalled. Everything will test good if the problem is not occuring.
Back to that base idle statement.
If you really did mess with the base idle screw, it could be a lot of you problem. That is a critical adjustment and has to be set exactly as the instructions say. If that is set incorrectly, it will cause the idle controls to get totally confused and either stall or "hunt". You should NEVER touch the base idle screw on a computer controlled car. It is NOT for idle speed.
You said that the base idle screw was not for idle speed but you did not say what it was for...now I must admit that you've peaked my curiousity..lol
One thing to look for if you suspect the ignition switch is to watch for dash gauges and accessories to die at the same time. If your accessories and lights stay on, it's not likely the ignition switch. It may be a little more complicated than your going to be able to handle.
I haven't taken it to the shop, am afraid it's going to cost big bucks I trying my best before anything,I replace
air filter
spark plugs
spark plugs wires
Without any luck.
any body experience this problem
CHECK ENGINE CODES flashes 1155 please help
