Mazda3 (5-door) v. Mazda6 Hatch v. Mazda6 Wagon...
Here is the new place to discuss the Mazda3 5-door vs. the Mazda6 hatchback. Since the subject has come up in other discussions here, I thought it might make for a new topic of discussion. Thanks for your participation!
Revka
Host of Hatchbacks & Wagons
Revka
/direct/view/.ef213a8
Revka
It seems the Mazda3 5-door might be a stretch from the Mazda6 wagon, imo. Or have you, or others here, seriously considered the Mazda3 5-door vs Mazda6 wagon? ;-)
Revka
The 6 hatch will almost certainly cost much more than the 6 wagon. It also will have many more standard features, if it is marketed at all as it is in Europe and the rest of the world.
The 6 hatch is to be marketed as an upscale, sporty vehicle. The wagon will be far more utilitarian. Everything I have read indicates this will be the case in North America as well.
The 6 wagon will be far more competitively priced vs. the 3 Hatch. There will be people shopping both. Few, if any, will cross shop the 6 hatch and the 3 hatch.
The word hatch, when used to apply to the Mazda3, is merely attempting not to use the dreaded, downscale wagon word.
The 6wagon will be too large to compare it to a 3wagon.
Nice job on starting this topic though.
Dinu
Dinu
But then again I never claimed to be normal.
If someone wants a V6 though then the Mazda3 obviously would be out. Also the Mazda6 wagon may look better than the Mazda3. The Mazda6 hatchback looks almost like the sedan and that is a very good looking car so no problem in the looks department there.
After this whole rust thing though I'm starting to think the built in Japan thing might be worth something afterall. Also overall build quality is suppose to be noticeably better on Japanese built versions compared to NA built versions. Also the engines in the Mazda3 are built in Japan while the 4-cyl in the NA Mazda6 is built in Mexico. Possibility for quality control problems? This rust thing is making me paranoid.
I have a friend at work who has a 6 sedan. It seems like quite a leap forward from another friend's 626. However, the Fordies may have begun to plague him - he is having check-engine-light trouble.
As for built in Japan vs. built in the US, my dad's 2003 Accord was built in Ohio is is put together Really Well. I'll probably also be cross shopping the Accord sedan (bring back the wangon!) as well as the Prius.
I'll just have to wait and see these in person and the available option pkgs. It's gotta be cheap too ;-)
If my '91 Merc Capri turbo won't make it till then, still considering Focus ZX5, Protege 5, Elantra GT hatch...
That's not true: cargo capacity rear backseat up/down (litres):
Mazda3 Hatch: 300/635
Mazda6 Hatch: 492/1661
Mazda6 Wagon: 505/1712
Bruno
This would make it a larger cargo area than the Matrix has.
In outside volume, the Mazda3 hatch is larger than the Pro5 and similar in total volume to the Aerio, Impreza and Matrix, which have total cargo volumes between 1500 L and 1700 L. So the Mazda3 really should have a total cargo volume similar to those (rear seats down).
So those Euro spec numbers (300L/635L) are incredibly low. They must be using a different measurement methodology than we use in NA.
Mazda3 Hatch: 10.6/22.4
Mazda6 Hatch: 17.4/58.7
Mazda6 Wagon: 17.8/60.5
But like somebody pointed out, these are the Euro measurements and may not be the same as how we do it on our side of the ocean. They don't look right to me and I will wait for the official North American measurements.
The 3 hatch's rear deck is raised for a flatter cargo floor when seats are folded. & there's another layer of secret compartment underneath. The sedan doesn't & has a lower trunk floor.
Maybe the 6 hatch & wagon got a similar difference.
However, in NA, most mfrs rate cargo volume up to the roof. Mazda played honestly to begin with on the P5's rating and got beat about the head in the market 'cause almost everyone rates cargo as stuffed up to the headliner. They switched to this method later to provide more comparable measurements.
If you measure up to the level of the back seat, then it would make sense that the 6 hatchback and wagon would have similar numbers. Measuring up to the roof would be different.
johncline:"The 6 hatch will almost certainly cost much more than the 6 wagon. It also will have many more standard features, if it is marketed at all as it is in Europe and the rest of the world." That may be true, but from audi8q's post on the 6 board, the wagon will be only available as a V6, whereas the hatch will be 50% 4-cyl, so the cheapest option might be a 4-cyl hatch.
The hatchback should be lighter, so the 4-cyl hatch will give you better mileage with similar performance as the 6-cyl wagon. At least with the stickshift. And I think MOST of the time, the hatch will be just as utilitarian as a wagon would be. I guess on a long trip, with people in the back seat and a huge box or a lot of luggage, you'd need the wagon.
http://groups.msn.com/BrunoLuong/ustrimsandprices.msnw
OK, the Mazda3 stays on my list for now. Do you think the BP5 is still as pictured in your photo for the US? I'm thinking Strato Blue with BP5 interior. Is Strato Blue 27E as you listed or 25E as it shows at:
http://www.mazda.de/drive/mazda3/mazda3_farben.asp?modelname=2.0l- - +Sport+To
Canada must have a different system but Mazda not offering side air bags on the Mazda3 in the USA is total suicide. Even the Hyundai Accent, which starts at $9999, has standard side air bags.
AND HOPEFULLY NO RUST.
Maybe they can import one for me. 23Z please.
just my .02
3 reasons:
1. Hofu plant II (where the Atenza/Mazda6 is produced) is currently overcapacity.
2. Hofu II doesn't build V6 Mazda6's (the V6 is exclusive to N. America)
3. Importing Mazda6's from Japan while Flat Rock still has capacity completely undermines the Flat Rock plant.
Dinu
So, can you predict which one I'll be getting?
Dinu
I guess I'll take a chill pill and relax: I check mazda.ca daily to see when the configurator comes online
Dinu
well, i was considering the 6 hb, but i was disappointed when they didn't release it in the U.S. in MY2003. when i heard about and saw the 3 hb and pretty much stopped thinking about the 6 hb. coming from an integra, i prefer a small, nimble car anyway. and less expensive to boot.
Dinu
It really is a bargain, you're right. Now I'm really curious at how the seats are: material type, quality, etc... I'm not too fond on the blue as you know but the red is pretty good. Guess I'll have to get the Velocity Red one then instead of Winning Blue or Titanium. They're all nice colours anyway
Dinu
Are they planning on building the Mazda3 anywhere else?
Dinu
