Visitor Agreement.
Think you should have your dealer check to see if it's functioning correctly; I have an LTD and once I set the temp on auto, I don't touch it again, regardless of the temp outside, whether it's summer or winter.
While Maxima is a nice looking car, think you made the right choice, too. I had considered Nissan but saw their resale values - far below Toyota. Same thing holds true with Infiniti vs Lexus.
zekeman1
I am only interested in Toyota factory installed... not after market systems.
Does anyone know if this can be done? Thanks!
zekeman1
At least the actual manufacturer knows to advise you to lower rear winddows during the early part of your drive to help exhaust the hot atmosphere.
Since the blower motor being turned on is delayed until the A/C builds enough cooling capacity the best procedure to use in this circumstance is to immediately turn the blower to MAX manually, then over-ride the system airflow intake mode into fresh, and then once the majority of the Hot(ter) cabin atmosphere is exhausted simply touch "auto".
If you don't get it, you can live without it just like you had previously, but if you want it, get it at the time of purchase.
This is like transmission choice of manual or automatic or paint color. If you change your mind, it's more practical to sell the car and buy a new one than to change out the parts needed to undo your original mistake.
However, there are a few portable nav units that can be used completely wirelessly for several hours on battery power so there would be no dangling wires, but they would need to be recharged (or batteries replaced) after use if you choose not to keep it plugged into a power port while in use.
In the manual, on page 226, it states;" when you set the temp selector setting at about the middle in automatic operation,"I am not sure what the middle means. I never checked the upper and lower limits. What happens if you don't set it at the middle?
That being said NipponDenso, Denso US, actually has a US patent pertaining to their method of airflow distribution within the passenger cabin. Their A/C plenum, air distribution management, is setup such that heated airflow is only routed to the lower portions of the car, and cooled airflow to upper portions.
So anytime the cabin atmosphere is at or very near the temperature setpoint, the airflow from the upper airflow outlets, dash, etc, will be as much as 20F cooler than will footwell airflow in the very same circumstance, setpoint, etc.
Since they take no accounting of radiant heating effect to the human body, only using the cabin's atmospheric temperature for feedback to the HVAC control loop, the system will quite often remain in cooling mode, all airflow or the majority thereof, from the dash or dash/footwell combined.
If you find the cool dry airflow to your face and upper body discomforting it will be up to your to switch the system to strickly heating, footwell only, airflow mode.
Has anyone else seen/heard this?
I have brought mine back 2 times already for servicing. The first time they shortened the springs, 2nd time they bent the bar that goes across the moonroof.
Still rattles sometimes. I was told to bring it back when I can duplicate the rattle so they can figure out whats going on.
My rattles are and I dont necessarily have the time to bring it in when I get a rattle. When I do have time, they dont...
We need more people to speak up about problems and perhaps make it into a service bulletin and let toyota know that we deserve to have a rattle free car for all the money that we paid for it!!!
Lets hear from more rattlers!
The second rattle is most likely from the moonroof/sunroof. Mine is so tight that it's like a guitar string and hums when its plucked (ie hit a bump in the road).
Bring the car back to the dealer and see if they can duplicate the sound. More than likely its the moonroof.
Good luck, let us know how it all worked out.
You forgot to mention "perfected" enough.
I have absolutely no objections, problems, with the VSC (PSM), trac, ba, etc, as implemented in my 2001 Porsche C4. It gives me just enough time to react myself and "crank" in the corrective action before it steps in to prevent loss of control.
Actually I can say the same thing about these new electronic aspects of my RX300, we can't all be mentally "on our toes" constantly so its really nice to have someone or something, watching your "back".
Toyota and Lexus have already discovered that the yaw sensor signal can be used to dynamically remove engine torque from the front to prevent loss of directional control. I have little doubt that the next move will be to disable ABS unless the yaw sensor indicates loss of directional control is threatened.
Lexus has just developed something called VDIM (don't know exactly what the acronym is) that supposedly senses an impending collision and will disable and modify all kinds of things prior to 'impact'. Except, of course, the computer may have a little trouble determining whether this impact is really imminent or, for that matter, exists at all. Recent test of the GS, had a high speed lane change type of manuever (600' slalom) - the car's ability thru the change was limited because the 'computer' thought the traffic pylons used for the closed course were an impending collision. And, I think, that there is some widely held misconceptions that somehow VSC and/or other systems are true replacements for some driving common sense and driving ability.
But, also of concern to me is "Who" from the land of supreme beings is going to make these decisions for us - hopefully, not the same lawyers who wrote our owner's manuals or! They might just outlaw fine machines like that Porsche of yours.
This is very, very annoying, and to be honest, I'm starting to see why some people prefer Japan-built Lexus. I haven't heard of anyone complaining about this type of quality problem in GS or LS.
I am a long time Toyota owner and can say with qualification that Toyotas have always been very well screwed together and have not rattled. In comparison, my 2005 Avalon has developed more rattles and has more problems than any of the previous 10 Toyota products I had, including both those made in Japan and in Kentucky. This does not bode well for longevity. Toyota has let quality slip BIG TIME with the new Avalon, there is no question about that. To make matters worse - try contact Toyota Corporate or a dealer and see the kind of response you get.
Based on all of the above, I would consider myself a former loyal customer. I am slinking away towards other manufacturers showrooms as the end of my wife's Sienna lease approaches... Have decided it will definitely NOT be replaced by another Toyota product.
What a pity. The new Avalon could have been a segment buster like the LS400 was, but I think it is an also-ran as far as quality is concerned. They may be flying out the door now, but as they start falling apart in a couple of years, people will start to realize that Toyotas aint Toyotas anymore...
"....true replacements for some driving common sense and driving ability."
How many "common" drivers have even experienced the many and varied circumstances required to have "true" driving ability and/or "driving common sense"?
Were you to ask ten "John Q. Public" licensed drivers how they would react in an overstearing skid how many of them would tell you that the proper reaction would be to get off the gas and stear into the skid??
My bet would be on NONE.
And that will only be corrected once we start training drivers how to react instinctively in anomalous situations. Situations that are life threatening but may only happen to "common" drivers once in a lifetime. No pun intended.
What we need is driving simulators designed along the lines of the ones we use today for flight simulation.
I might agree with you that remote starters are not the most fuel-efficient and environmentally friendly feature of a vehicle. However, we're starting down a slippery slope here that ends in a ditch where no one can justify the "wastefulness" of a 5 passenger automobile that has 268 HP and does 0-60 in 6.9 seconds. None of us "needs" a Toyota AVALON simply to get from point A to point B -- a PRIUS will do just fine.
Now, I'm off the hook here because I'm going to buy an Avalon to replace my 12 year old SUBURBAN whose features and cargo capacity I no longer need. I figure I should get FREE remote starter just for my environmental "good deed"!
(Let the games begin....)
tstrick - drive safely and enjoy your Avalon, you are entitled to at least that much!
Now you have a split second at 60 or 70 mph to react - most of us would jerk the steering to avoid it, the same thing they are doing testing on a slalom course. Now that Lexus I'm talkling about, would, on its own accord, apply brakes, cut throttle, and actually slow the steering.
Is that really what you what your car to do for you?
I wouldn't want any computer logic interfering with the controls in this situation, especially considering that Toyota can't even get the auto transmission logic right.
I am not comfortable with the degree of over-automation the car manufacturers seem intent on imposing on us.
Perhaps I misinterpret this as indicating that at least one Avalon driver considers himself to be in the top 0.1% of all drivers?
I do understand that virtually all road users surveyed claim that they are 'better than average'...which may explain why traffic carnage keeps pace with the safety oriented vehicle developments now provided by Avalon and other models. Fast and aggressive tailgaters and lane-swappers, sharing space with frequent road-rage practitioners, now make many trips akin to the bumper-car experience at the carnival.
And yes, driving ability would be one of those ego kind of things - you would have a lot of trouble getting anybody to admit being even 'average' never mind 'bad'. I would guess that if we did do something smart like as wwest suggests, use an driving simulator to qualify a driver's ability to handle specific situations - we would also lose a majority of the drivers on the road!
I did not intend that driving simulators be used to qualify (test?) a driver's ability.
My proposal was to use the driving simulator non-destructively to TEACH, and/or train drivers the proper reactions and procedures to use in anomalous circumstances.
alan,
Were you driving in D or S? I suggested a while ago that shifting into S seems to cure this kind of behavior. Have you tried it yet?
havalongavalon
If you look at pre 2005 Avalons you will see much better quality everywhere. The workmanship is not there with the outside body parts fit. The rear bumper plastic panel, where it meets the rear quarter panel at the wheelwell has an 1/8 in. gap. The otherside is perfect. ange1
I did not expect my '05 to quite be able to live up to the quality standards set by the 04s and earlier. The Av really was, after all, a heavily optioned and slightly stretched Camry. If that was all the 05 was, never would have bought it. The Av is a completely new car, engine, tranny and all and as such can not meet the same sort of quality standards set by a previous model built largely the same way for more than 10 years. Not even Toyota is going to be immune from new model teething problems. Acura has been experiencing the same problems with the TL ever since they moved that car away from being an upsized/upscale Accord. Detroit's problems in this regard are near legendary - read some user group comments for things like TLs, 300's, LaCrosses etc. - you will find the same sort of complaints that you find here.
I would also consider that anybody who is going to take the time to participate in one of these forums is a certifible car nut and/or extremely finicky about their cars (probably both). Not to excuse Toyota for whatever mistakes they have made with the new Avalon, but it occurs to me that maybe, just maybe, we are expecting too much.
Based on some of the rather picayune complaints that I've seen, I have to agree with you!
zekeman1
Maybe. But some have been really important, like the Great (1/16") Hood Gap Controversy of June 2005...
This was Toyota's response to my query regarding the transmission:
"We apologize for your dissatisfaction with the driving response.
The poor response you described typically surfaces either when the accelerator is depressed fully to the floor or when depressed an aggressive manner. The newer version has transitioned from a manual throttle linkage to an electronic throttle control system. The electronic throttle control monitors the everyday driving habits of the operator and then tailors itself to make the most efficient gearshifts. On rare occasions when the operator fully depresses the pedal or depresses the pedal in an aggressive manner, the system may experience a delay in determining how to make the optimal gearshift.
At this time Toyota has no plans to make changes to the shift characteristics of the transmission. To minimize this condition, we recommend trying a firm yet gradual application of the accelerator.
Your feedback is appreciated; it is through communications such as yours that we become aware of our customers' expectations and reactions. It also provides us with valuable insight when planning and developing future products and services to increase our customers' satisfaction."
Draw your own conclusions.
On the quality issue again. I can accept that a new car can have problems. What I don't accept is the dealers bad attitude and reluctance to remedy the problems and Toyota Corporate's indifference.
Toyota should back their products, stand behind their customers and try to correct the issues, not leave us hanging and orphaned after we leave the showroom.
Remember, we have paid for the warranty in the price of the car and we are at least entitled to a certain level of service and remedy, and should not be treated with contempt and considered a nuisance. Like HMO's, Toyota and the dealers try to avoid the cost of warranty repairs to maximize profits. Who loses?
A large man threw his door into my door in a parking lot, causing some major dents and ripple dents. It was under my insurance deductible, so I had to foot the bill. Problem was, after I got it fixed from the shop, the paint job was terrible. Had them rework the job, same deal -- this time the paint was shrinking and wrinkling and body line on the door was gone. At this point, I was totally fed up -- I had other body shops look at it and they're disgusted with the previous workmanship. To fix it would cost almost 2X the original price I paid. Some wouldn't even dare touch it for fear of what possible bad workmanship lies underneath. What a mess right? I'm letting a judge decide that... To be continued...
These electronic systems, perhaps unfortunately, are here to stay because without them many of those other 'safety' systems that everybody seems to want won't work. If Toyota does come up with some sort of new computer chip, or whatever, I will be in line to have it put in.
