But I also believe some are not, a true car owner doesn't just register as member and make a single post of complaints and that's it, no follow up no history of purchase/previous postings. Some even has no idea of what kind of car, he/she is discrediting. Well TL does outsell many brands and the most consumer wanted.(Tall puppy syndrome)
I am not going to suggest anything (I maybe working for acura, one might say lol), just use your common sense and a more thorough inspection before buying a car. Do not hesitate to test/try/push/pull any part of the car (careful, dont break any) that might cause a rattle/squeak. I didnt do any inspection back then myself but luck was on my side.
Anyway problem may/can occur to any brand, chrysler, BMW, Pontiac, Infiniti, Lexus etc. you name it.
I also have a rattle in the dash but I don't think I would want the dash replaced.
We have 10,000 mile on the six speed with nav and it is primarily my wife's car. We both still enjoy driving the car even with some of the annoyances that have been noted.
Appreciate you guys comment!
Another problem which I discovered--even following a couple of test drives--was that my right leg was unfomfortable leaning on the console (I'm 6'2"). I WOULD buy the car again though, as it's a real treasure chest of great features.
Check all legitimate complaint especially on websites like NHTSA. You can look for complaints such as transmission failure etc.
Eventhough my car doesnt vibrate, but I have some experiences with my old Honda Civic 87 with bigger wheels and low profile tires. It did improve it's handling but also its very easy to make the car vibrate. If you overinflate them, you would find annoying vibration especially with front tires. My remedy was to reduce the pressure on them then its okay. Hope this help!
Any experience out there on this set up?
I bought my TL04 three months ago and yesterday when I was driving a stone hit on my windshield glass and now I have a spider crack on my new TL. I do have a 500$ deductible glass coverage on my TL but the crack is not big enough that my insurance will cover it. Does anyone have any better suggestions of how I can fix this up? Does anyone know of any glues that I can use to avoid the crack getting bigger or any other solutions to this issue?
Sujeet.
I would be interested to know if this works.
Thanks a lot!
the other good thing was that my insurance company also said that they would cover it and send me to a glass company and now it looks great, cannot even see where it had cracked and it also gave me a state inspection guarantee for life!
-S.
two returns for tire balancing. I don't believe its the car but the Bridgestone's they are using
as OEM. I'll bet if I put on another brand such
as Michelin which was the OEM tire up until O3
the vibration problem would go away but I am not going to do it with my nickel. Problem with the 04's has been a flat spot on the tire. If it is a suspension problem than Acura better come up with a fix very fast or they will be getting bushels of lemons.
Complain to dealer
Call acura National file a complaint
Go to website NHTSA file a complaint
Maybe Acura will get wise and admit there is a problem with the 2004 tl tires since they no longer put them on the 2005 with NAV.
BTW...seems like Tire Rack has the best price $930 total..
What's the time interval between TL's 'internal' HI/LOW cycles?
I think I am going to pull the trigger on the snow tires...
Just had my 04 in to the shop, they realigned the motor mounts, balanced the tires [bridgestones] and adjusted the transmission cellinoid. The vibrations or I call it more of a shudder improved about 60%. Will have to try the new tires next. I will talk to my dealer in regards to an exchange. Let me know how you do.
vin
They told me they are not allowed to repair it until this factory rep shows up or decides that he doesn't need to see it.
Anybody else have any similar problems or an oil leak with the TL 05?
