Explorer motor rattle
I own a 99 Ford Explorer that has a rattle in the motor. It has the old style push rod 4.0L V6. It is noticeable at an idle, and also on the freeway, at times can be really loud. when on the freeway the noise sounds like a pinging sound (usually caused by to low of octane gas). I have been told by the dealer that this noise is carbon knock and is caused by carbon build up in the combustion chamber. They have no solution to the problem except to decarbon the combustion chamber which is only a temporary fix. I have had another mechanic clean the MAF sensor and that has not helped either. The Dealer has shown me a TSB from ford saying that this motor must be run over 3000 RPM everyday to keep this from happening. Running the motor over that is definetley not a problem for me. I would appreciate any help I can get.
not what you want. use the recommended octane. brand to brand, the only major difference comes from those refineries that have already overhauled to meet the 2006 EPA no-sulfur requirements. sulfur and carbon are both elements, and sulfur from ClogCo gas is not going to turn into carbon. not without excessive focussed ionizing radiation, that is, to cause radio-sulfur to decay into carbon (that is, not without being put in an H-bomb.)
I think you might have very noisy injectors or an exhaust leak or...???
Does this engine use a timing chain or belt?
Besides, if he has this noise at idle, octane is not his problem. There is no load on the engine at idle, so pre-ignition really can't happen.
Perhaps his highway speed noises are octane related but not his idle noises. He has to look at injectors, noisy lifters, things like that. I can't recall if this engine is chain driven or not, but that would be another good bet.
And yes this engine is chain driven
If you have some clatter at idle, you should definitely put an ear to your timing chain, and if you DON'T have post-ignition (engine run on) I would rather doubt you have excessive carbon build up.
If you are pinging loudly at freeway speeds, I think you have an engine management problem, with some sensor that controls engine timing; also, pinging and a loose timing chain have a relationship worth exploring.
So far, I think this car is being mis-diagnosed. If there were more data I might change my opinion, but given what's on the board, that's what I think right now.
That "pinging" by the way, is actually the internal parts of your engine rattling around like a chicken grabbed by a terrier. In extreme cases, the actual cylinder walls of the block will flex. Typical damage from severe pinging is a hole through the top of the piston.
Heavy and sustained pinging is very dangerous...a light and brief ping now and then is not.
