A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Oranu
___The Honda uses a completely different CVT then the Toyota/Ford uses. The Prius I, II, and Escape’s CVT are far more bullet proof imho. In any case, the HH and RXh are going to use the same design CVT as the Prius’ and Escape and I see no other way that the Camry would be Hybridized with something other then an HSD unit which will use the same/similar CVT.
___Good question as to whether the 06 Camry’s V6 or its I4 will be HSD equipped. I would prefer the PZEV based I4 that was atkinsonized as it would give it a nice kick and improve upon its FE in both highway and city envelopes. The issue is if Toyota is going to fall for this performance at all costs scenario that Honda is following with the new Accord Hybrid. Maybe Toyota will offer both an Atkinsonized I4 w/ HSD as a high FE Camry and a hopped up V6 based Camry w/ HSD as the performance version? Wouldn’t that be neat ;-)
___Good Luck
___Wayne R. Gerdes
Toyota tried different hybrid designs like
Prius-I (1 motor)
Estima Minivan (2 motors)
Crown (Mild hybrid which just shuts/starts the vehicle)
and finally arrived in
HSD (Hybrid Synergy Drive) which contains a
motor, battery and transmission as 1 unit.
They intend to deploy HSD in HH, RX400 and
Camry also. But whether it will go in V6 or V4 or both,
we dont know at this point of time.
But it seems that the battery suppliers could not cope
up with the demand and that is what is forcing Toyota
to put this in expensive low-volume vehicles.
Recently Sanyo has joined with Bosch to increase the
battery production and this may have a big impact on
the type of models.
Goodluck
Yesterday I found a dealer who had one available now and was selling at MSRP. The dealer is Crystal Toyota in Greenbrook New Jersey
I now own a new 2005 Prius tideland pearl with the BC option.
The experience there was very good.
I paid $26,780 for the car. Besides the BC option it has a few accessories (rear bumper Applique, carpet floor mats and cargo mat,and cargo net).
WOW what a car. I just want to drive even if I have no place to go!
Maybe Toyota is going broke selling the Prius for less than it costs to build them :-)
2005 Millennium Silver/Burgundy
$540 Delivery, Processing and handling fee
$20875 MSRP Base
$5065 Package #6 (BC)
$262 Preferred Accessory Package (Z1)
$59 Wheel locks (WL)
$65 Rear Bumper Applique (EF)
Didn't place an order for those last three but...
Total MSRP vehicle price...$26866
At purchase...
$399 "Processing fee for consumer services"
$817.95 VA Title tax
$53.73 "Dealer business license tax"
$10 Purchaser on-line systems filing fee
$49.50 License and title
Total, out the door price ... $28196.18
The "smallish" 12 volt battery is only there because many automotive accessories only operate at 12 volts.
1) my local dealer jacked the price up more than $1000 over MSRP, didn't get color wanted nor navigation system;
2) other dealers seem to be in similar situation;
3) the transmission is not a Continuously Variable Transmisson --a gem-- similar to the one on my 2004 Honda Civic hybrid, but is, instead. a 5 speed autotrans.
So, now I wonder if I should go through the same wait for Toyota's version, supposedly a 2006 model (arriving for sale when--September 2005? December 2005? ??--) ...
...And, if I wait, what will actually be built? Hence my pleasure with your information. I will be glad if you will continue to inform me (and others) as you get more information from your source.
Oranu
In the Prius the ICE has nothing to do with directly charging the 12V battery. There is no analog to an alternator on the Prius.
The ICE runs the generator(s) which provide High Voltage to the HV Circuit side of the house where the Traction Battery lives. In turn, the power from the big battery is coverted to 12V to power the Auxilliary Circuits, and charge the 12V battery.
The only real purpose of the 12V battery is to 'boot up' the car when it's started (power up the computers enough to bring the big battery circuit online), and to keep minimal power to things like the alarms and door entry circuits.
The actual 'starting' of the ICE is done by the big battery through one of the Motor/Generators. So, there's also no 'starter' on the Prius to worry about.
When the car is running, the big battery is always in the loop on the auxilliary circuits, and is supplying all the headlight, audio, etc. power. (and also charging the 12V battery).
Because the 12V battery has so few responsibilities, it's smaller than normal. It's also a dry cell battery that doesn't out-gas as much as a normal auto battery.
Because it's small, the 12V battery can't power the auxilliary circuits for long by itself. That's why it runs down quickly. However, if you leave the car on, the ICE will only run when the big battery gets low, and the big battery can power those circuits for quite a while if that's the only thing it's doing.
Because it's non-standard, the OEM Prius 12V is more expensive than the average auto battery, but on most Prius sites you can find instructions for replacing it with an alternative for about the same cost as a normal battery.
update: the service advisor told me yesterday that the tech isn't finished checking the car. it's no problem for me since they gave me a rental, and i always tell the advisor to take their time with the car so that it is fixed and working/running properly. i'll try to provide details on what they did when i get the car back...hopefully today.
also, they gave me a corolla as the rental. smaller interior (i knew that already) but what really bothers me is the smaller driver and passengers seats. definitely not as comfortable as the prius.
another question: why is a dry cell battery used and not a regular (fluid filled) battery?
1 Start Button Push without Brakes puts you in Aux Mode burning only the 12V battery. You certainly shouldn't count on a lot of radio time with that.
2 Start Button Pushes without Brakes brings the Big Battery online. It will help keep the 12V circuit alive for a much longer time. You can run lights and A/C and other stuff in that setting too. But, it will also run down both batteries eventually, and it's very hard on the HV Battery to run it down too far. It also takes a special Toyota Charger to attempt to recover it.
Full IGN ON (Start Button with Brake) is probably the way to go. If the battery has juice, the ICE won't run. If the battery gets low, the ICE will automatically come on just long enough to charge it back up and prevent damage. You can sit around forever in that mode as long as your fuel holds out (probably days).
As far as the 12V battery construction, it's not really truely dry cell like a D battery, it's a gel cell as I recall (might be saturated plate but I don't think so).
It's generally called 'dry' because it's designed not to ever require water.
It also has a higher energy density, less outgassing, and won't spill or leak as easily.
Since it's inside the passenger compartment the gas/spill/leak issues are good to consider.
Since weight is inversely proportional to fuel economy, higher energy density is good.
Low maintenance is always good.
The downside of that kind of battery is that overcharging can force enough of the little available liquid out to harm the battery. But, since the Prius has so much brainpower, some of it is devoted to managing the charge state/cycle of the 12V just like it is to the HV battery, so overcharging isn't an issue, unless you do it yourself with a badly applied trickle charger or something.
Good information. That explains the $300 replacement charge for the 12V battery that one poster had. Gel cells are more expensive than conventional sealed lead acid batteries.
Happy holidays to Sylvia and everyone!
I have two questions:
1) If the 12V batt were replaced with a premium batt, say a Sear's DieHard or equiv, would it last longer than OEM? I know the weight difference would be greater, physical size in the batt compartment and exposure to possible hydrogen gas, but would make any sense?
2) I have the Pkg 9 and I've noticed that the rear windshield wiper doesn't flip up all the way like the front wipers do. Is there any way to "free up" the mechanism so window cleaning could be improved?
Rich
12/18/04: checked for codes on OBD2 no codes stored. checked with OBD 1 found T/M code stating that there's a low power supply.
charged battery and rechecked monday a.m. 12/20/04
12/20/04:
vehicle dash lights came on but not the ready light.
multi-display also not on. display came on when jumper hooked on when turning power on.
display was reading transmiss park lock mechanism abnormal. also there was no ready light and no shift indicator squared on shift.
checked for code found P3102 in HV ECM information code 581. transmission EMC malfunction.
also found C2300 ACT actuator malfunction.
C2318 low voltage error in transverse ECM.
checked HEV fuse 13.9 volts (good) resecured fuse.
turned on power switch vehicle now has ready indicator light on. cleared codes and rechecked ok.
fully charged auxillary battery. vehicle stop and starts ok.
i'm sorry for this long post. but i figure it might be helpful information for someone. i am happy to have the car back. many thanks again to all who have sent replies regarding my problem. i've learned quite a bit more about the car.
MERRY CHRISTMAS and SEASON'S GREETINGS TO ALL
I was not really ready to make a car purchase, but really wanted to take one out for a drive. I stopped in the following weekend, only to find that there were 2 Prii on the lot (a 2004, and a 2005).
Took the 2004 for a short spin - both on city streets and a short stint on the freeway. After finishing my drive, it was clear to see WHY there was such a waiting list for this car. There was plenty of room in the front and back, plenty of gadgets if you wanted them, and decent acceleration - all at a reasonable price. And contrary to what some posters have suggested, I had no problem getting the car up to 70.
Was the car as quick as my V6 Camry? No. Was the 4-cylinder as smooth as my V6? No. Having said that, if someone was out shopping for a 4-cylinder, mid-sized sedan (you know - the type that most people actually buy), I would easily consider this vehicle.
Anyway, just wanted to post my impressions.
Now on to the question -- this one for people who are actually driving the new Prius. Having just gotten hit with our first winter storm (snow plus a nice layer of ice -- ick), I was wondering how the car handles in typical winter driving? Any responses would be appreciated.
Happy motoring!
1. Because of the placement of not one but two drive motors there is more than ample weight on wheels for better traction.
2. Because of the slight bubble style of the Prius (creating great head & seating room) the car is a bit touchy in cross winds.
3. Questions as to winter rain, slush, and snow invading the electrics of this hybrid creating problems are (so far) unfounded.
4. Only downside I've noticed has been the heater system. This past week we've experienced our first sub-zero temps. The heater seemed to take a long time to get the interior of the car up to a comfortable range. I also noticed the (ICE) engine running considerably longer durations effecting MPG's.
In closing, I'd like to say that my Prius has been, by far, my most enjoyable car. I drive with a since of satisfaction that I only expected from a car of considerable higher costs.
I thought that my next car would have been a Beemer or a Mercedes but this amazing car sparked my interest when I test drove it not once but three times. Even my wife found favor in the car. I also would like to say that performance of this car is quite exceptional. This is a car of the future today.
I hope this helped in some small way.
Culliganman (Hybrids are here to stay)
P.S. Getting about 45 mpg's this winter
I was mostly wondering how traction was in snow/ice conditions. With its lighter weight, I had some concern that traction may not be the best. Thanks again!
excellant forum note and it covered several areas very well.Keep them coming as we wait delivery of our Prius next year.
If building Prius is expensive, then they can easily
increase the price with the current demand.
Toyota has designed a new battery that has only 28 modules
in Prius-II instead of 38 in the Prius-I and yet it gives
the same power. That is why they are able to price it the
same as Prius-I
Their objective is to prove that Hybrid does not cost much
and they have already increased the production from 76,000
originally planned to 130,000 this year and next year to
180,000.
For the US market, allocation has been increased from
47,000 in 2004 to 100,000 in 2005 and I hope this should
satisfy the demand. But if the oil price shoots up
again, then there will be another big wait.
America's oil
consumption has increased from 897 tons to 914 tons while the
production has decreased from 347 tons to 341 tons.
So hang on guys.
http://www.automedia.com/autoReviews/rts20031101tp/rts20031101tp.- asp?affid=
We're looking to purchase an '05 Prius. Do you have the APRs for Toyota Financial? Do you show what's the longest term (i.e. 60 months, 72 months, etc.) Also, we're in So. Cal. and want to know what to pay for the car. MSRP? Thanks.
http://www.edmunds.com/new/2005/toyota/prius/100454051/optionsres- ults.html?action=2&tid=edmunds.n.optionsresults.ntmv.2.1.Toyo- ta*
I got a rate of 5.9% for 60 months. The longest term they mentioned was 72 months. The APR will vary with your FICA score.
If you are really worried by it, you should arm yourself with ext warranty. 6yr/72K can be had for around $800. That would cover the screen and its related modules.
I had some company whose car was in the drive. As is typical, I went out - started the car - let it run for awhile hoping it would start melting the ice on the windshield.
With a Prius - does that actually work? Will the defroster continue to work since the car isn't moving (i.e., the engine isn't running?)
Again, any comments from current Prius owners would be appreciated.
And Happy New Year to all!
Given the size constraints it will be difficult to fit a larger 12v battery in the provided space in the classic Prius. Where is the 12v battery in the 2004+ model?
Windshield wiper heaters, Canada only.
Heated windshield, Canada only.
