1999 2WD GMC Shocks
ok it's been well over a half a year, many trips
to two dealers, gmc puts the same shock on the 2wd
six as the 5.3L 8, at over 300lbs more weight,and
I can't get any one at gm to put a heavy dudy shock
on the front of my pickup, It has been bouncing
the tires like basket balls for 6 thousand miles,
push down on the front end and it bounces 4 to 5
times, the local tire shop said its the shocks,
they are too light weight, help me if you can i
have a short bed 2wd reg cab sport truck, with a
5.3L v8.
5.3L v8.
didn't show up till 2100 miles, if I was on the ball like obyone, you bet I would have just replaced the shocks, If I needed any warrenty work done I could just put the old [new] shocks back on. thanks sixaxe
sixaxe.
about my truck, I guess you only get one set of
cheep replacement tires per customer, good luck
obyone, sixaxe
and if he can't do anything to buy the truck back.
six.
E-mail Address(es):
cac@gmc.com
there are two tire recalls on the 1999 gm trucks
I had to get them to call general tire, you would think that a gm factory rep would know all about the trucks he is in charge of fixing. six
So I have to wait for the GM rep to return from vacation on Jan 4 to get a decision on getting another set of NON-General tires. Good luck on resolving your tire problem!!
If you go the Michelin's web site http://michelin.tireselector.com/
you will find that basically three tires will fit the Silverado (there might be more). The 255/70R16 is the OEM replacement. They also offer the 265 and the 275 as tires that will also fit the Silverado as upgrades. Good luck with your new set of tires. One last thing, I have been reading posts on some of the chrome steel rims being out of round. If you do have the chrome rims like I do, you may want to have them checked out at the same time or prior to mounting the new tires.
the only aurgument is that it is inherent to that truck as a caritoristic, not found on others. Just don't mention the General tires. You'll pay 700 dollars for a lawyer and then they get you tires. good luck sixaxe
good luck
obyone
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
