Visitor Agreement.
PEAT-MOSS
Just an opinion.
I have talked to many guys at jobs sites that have them on various trucks. They all complained about the leaks. Go through a car wash everything gets wet. Drive in rain everything gets wet. The dealer went back and resealed the front and sides and no help. I have side rails so the holes are covered. There are 2 holes in the front of the box that need to be sealed, but that didn't help either.
Now the dealer has added the TruXedo line and is goin to replace my Access at no extra charge. The TruXedo has a self adjusting tensioner so it will not flop around when you are on the highway. With Access you have to readjust for summer or winter as the cover tension does change.
He also says that the way the TruXedo is Velcro'd it has a better side seal. A lot of the water leaking in on the Access comes through the Velcro sides.
I am having the TruXedo installed nexr week and I will report back what I think of this cover.
I have an ARE cover on my 2K GMC Sierra with a NOMADIC “Glider“ Roof Rack . In my opinion the rack adds a bit of class to the cover and it very useful to carry a variety of things. The NOMADIC rack has special accessories which clamp directly to the basic rack. A bicycle rack is one option. This combination of ARE & NOMADIC is not cheap but it looks and works very well.
Ed
I have an ARE cover on my 2K GMC Sierra with a NOMADIC Glider Roof Rack . In my opinion the rack adds a bit of class to the cover and it very useful to carry a variety of things. The NOMADIC rack has special accessories which clamp directly to the basic rack. A bicycle rack is one option. This combination of ARE & NOMADIC is not cheap but it looks and works very well.
Ed
shiftless
Thanks for the info. That helps. I was hoping they would be strong enough to support the weight.
Does anyone have an answer if they have seen anything for carrying fishing rods and/or guns under the cover so they do not roll around in the bed, yet still allows you to store gear in the bed?
gatorfan1
On the GMC 2500 HD on order since Nov 13,2000, I plan to mount a SNUG LID made by SNUG TOP. SNUG Top is at 1711 Harbor Ave., Long Beach, CA. 90813 or SNUGTOP.COM. Keep on truckin.
Does anyone have any experience with this cover?
post here or email me direct... tomcrain@gulftel.com
Are all tonneau covers compatible with either bed liner? Can I use either style liner- and not have issues with the covers performance?
I think I want a soft tonneau cover but dot know if the type of bed liner be incomparable with the liner. Can you help?
Chris
Chris
Got one on my 99'GMC, Works good, sometimes a problem with snow,ice. Like useing the remote to open it.
Ordered a 01 2500HD GMC. If specialty covers arn't available. Have to check out Pace Edwards.
Just a note to anyone interested
I like it enough that I will be adding one to the 2nd Dakota I just ordered. Oh, they are painted at the factory to match your VIN. Perfect.
Oh yea, the address http://www.gemtopleer.com/gemtop/gtclassic.htm
I paid a little over 700 for mine installed. I have had it for 3 years now. I have never had a leak. My wife washes the truck and she uses a high pressure hose nozzle (I know bad, but she is willing to wash the truck so who am I to stop her) no leaks. It isn't flush as in below the surface like some. It sits right on the surface level. It has a rubber gasket all around. Sometimes it seal so tight opening it is like opening one of those flip top jars with a rubber seal. To install it it has several holes drilled. 6 holes along the side rail, 3 for the hinge and 3 for the strut bracket and 2 in the tailgate for the latch.
The top weighs about 100lbs. It does come off pretty easy. Unhook the struts put them in their slots, lay the top down slide it back a couple of inches then lift off. Just don't do like I did and take it off in the hot sun (ouch!!).
why i got a truck and traded in my car
up through the weather. thanks in advance for your help and replies
I recommend rail covers with no stake pocket holes (I used BAK brand) and an underail bedliner(I used Bed Rug). The disadvantage of the soft cover is that you cannot lock your gear, but you can get locking containers to go over/above the wheel wells to give you some locking storage. I just put some 2x8s in the lumber slots to create storage compartments. I don't plan on storing valuables in the bed - just want to keep stuff out of the elements when I am driving.
