Tonneau covers: What type to choose?
                    I am planning to buy a tonneau cover for my new
2000 Nissan Frontier and am curious if anyone can
offer some advice on what type to buy. I know they
make them in Fiberglass, and roll-up Vinyl. Which
holds up better and is easier to store.
The big advantage of a vinyl cover (besides price) is that is can be easily rolled up to get full use of the pickup bed. I've had an aluminum cap on a pickup before and it was a pain to take on and off so I could help people move.
I've gotten a new vinyl cover that work much better in the cold. Yesterday I rolled up my cover to haul some firewood - I won't have any problem rolling it back today. It's a Berlin cover that I got from Northeast truck caps. The vinyl is slightly looser than the Extang, and the latches over the tailgate are on springs, which allow them to move in a couple of inches for easier snapping in cold weather. The only thing that I don't like about the cover is the clamps - they are designed for a cap. They slip too easily - they don't work as nearly well as the Extang clamps. I also think the clamps on my camper attached a lot tighter than these. I'm on the lookout for a new set of clamps that attach tighter.
I also must admit that I have not seen super cold weather up here in the Northeast. It appears that this is going to be a snowless if not poopy winter.
Whatever you do, do not use Armor All on the vinyl, it will shrink it. The installation instructions warns about this.
Roll top looks good and functions well. It can freeze up IU'm told if ice gets caught in the track, but it's not a big problem. The downside is that it takes up cargo area in the front of the bed for the roll canister.
The fiberglas lid has no cold weather problems. To use the whole bed you must remove the lid (4 clamps) and find some able bodies to help lift it off. They are not particularly light, but they lock and are removeable if you are so inclined. Prices about $600-$850.
If you are keeping the truck more than two years don't buy the soft top unless you know that the cold will not be a factor for you.
That's not my opinion, scientific fact but I won't go into all the details unless people really want me to, because when I did so on a previous topic some months ago we all went off at a tangent for a week.
The A.R.E. doesn't lock the tailgate, but the rear lip does prevent the tailgate from opening.
A.R.E. build their lift mechanisms with a combination of gas shock and steel hinge. This might not look as attractive as most other applications which use gas shock only, but is a lot beeter for your truck.
The gas shock only, used by most all the other companies puts a lot of strain on your truck bed - now I know this sounds a little off, but the physics are correct. As previously noted on this topic these lids are heavy - close to 100lbs. If you have only two shocks then all the stress of lifting and holding that weight is being passed down the shock and into your truck bed (actually into the tonneau frame, but this amounts to the same thing because it is bolted to the truck to prevent movement). In addition the direction of this force moves as the shock angle, and consequently the weight distribution, changes. Now I know that pick ups are built sturdy, but problems can arise when the force is applied in ways different to what the design is intended for - which is what happens, it is a twisting force.
I don't have figures for how often problems really occur, but I can understand that the potential exists. Given that I frequently lift and lower my tonneau I wasn't prepared to take the risk.
Sorry if that wasa bit technical, but I hope it made some sense.
As far as locking is concerned, you are right. The locks actually fit the end of the frame, but with the tonneau lowered and locked the tailgate cannot be dropped and so your bags should be secure. I am not sure how secure the arrangement is against a determined thief, but an opportunist would be put off.
Bookitty
P.S. The original hinge failed because it was too light, and the dealer called me and made arrangements to replace it with a beefier hinge at no cost to me.
My only complaint with the cover I got is that it won't just roll up out of the way,if you want to take it off you have to take it all the way off.You can drive with the cover on and the tailgate open,and I have even driven with 2X4's sticking up out over the tailgate with just the back of the cover off,but the sides need to be attached.This cover is made by Saddleman I think(can't remember I've had it almost 2 years).I don't use anything special on it(just soap and water)and it still looks good.I bought it at Western Auto for about 200$
Roll-up Cover? In Minneapolis, dealers claim that it is the best soft cover for a cold climate.
In '99, I purshased a new GMC Sierra. Went to order the Century, but was told the delay would be 10 weeks.
Went to another dealer and ordered an A.R.E. with a 5 week delay. Am I ever glad I got the A.R.E. The lift arm supports aid the gas shocks to make lifting the cover a breeze. (By the way, it's the hinge that takes the majority of the stress when you lift the tonneau. The lift arm supports distribute the weight of the tonneau away from the hinge.)
Both the Century and the A.R.E. are designed with a rear downturn to capture the top of the tailgate. This prevents the tailgate from being opened with the lid down. When the cover is locked, in effect, so is the tailgate. The lock on the A.R.E. is on the rear vertical surface and has a palm type lever that is painted to match the body color.
The Century had a piece of black vinyl trim that went around the entire lid's edge. The A.R.E. has a piece of trim that is body color. Looks so much better. Some lids have no edging at all.
The A.R.E. is designed with the lines of the hood for a specific vehicle. So instead of looking like a flat piece of fiberglas laying on the truck's bed, it looks more integral with the design of the truck. I weigh over 300 pounds and have stood on my A.R.E. to wax the top of the cab without causing any damage to its looks or its function.
I paid a little more for the A.R.E. (about $680 vs. $660). My wife as a GMC Sonoma High Rider and we just ordered an A.R.E. for hers.
Sorry for the long post.
The cover locks to the unlocked tailgate, but makes the tailgate more difficult to open/steal.
I chose the manual operation, but a remote operation is an option.
Protecta?
I have searched the net and can not locate the
Protecta company which manufactures the bedliner
mats. I want the Protecta Heavy heavyweight Bedmat for the Dakota QuadCab and have been unable to determine if there is one even made yet. I do not want the standard Protecta bedmat.
ton·neau (tah-noh, tuh-noh)(couldn't reproduce the characters)
n., pl. ton·neaus.
The rear seating compartment of an early type of automobile.
Cheers
robert
My father in law has the roll up one you are talking about. There is an aluminum track that the cross members slide/roll on, and the outer edges have velcro to attach to the top sides of the bed. The back has a locking mechanism which flattens the cover out nicely. I dont know how much it cost, but I thought it was very quick to open and close. No security though.
Supposedly the GM cover is lockable. I have also heard the dealer can install a locking tailgate mechanism?
I just bought a 2000 F150 SC and am looking for a tonneau cover. I have used toppers before but they are limiting. For those of you who have the Pace-Edwards or the Roll-n-Lock, are they waterproof? How strong are the covers? Can they hold up 200 lbs.? I like the concept but I need to keep the bed dry. I am also considering a hard lid, probably an A.R.E.
Thanks for the advice and I'll keep you posted on my choice.
I like the rolling cover concept though. You can buy a locking mechanism for the tailgate to work with you keyless entry from Pace Edwards also. That way your bed is more like a trunk.
I elected to order the factory tonneau cover from GM on my new Silverado for price reasons only...If I order it from the factory it is $200, from aftermarket the same cover is $700. That also elimated the $800+ for a fiberglass lid!
Bill
I live in Phoenix, Arizona and am also concerned about the vinyl covering on the V-series during the hot summer months.
Randy
just my experiences,
robert
I have a ATV & didn't want a hard cover, also the hard cover is about $1000+. That's too much money to pay for a hard tonneau cover.
There is no snaps on this cover. Also, since it was installed on a new truck - the warranty is the same as the truck warranty (3 years).
rcoos
I have had it for approximately 1 year now and it is still in showroom condition with absolutely no problems.
They have a dealer locator on their site.
