Tonneau covers: What type to choose?
www.snugtop.com
Good luck and have a nice day...:o)
Roger
robert
Feedback?
I installed a Fold-a-Cover unit on my Dakota Quad Cab about two weeks ago, and have been very impressed with its versatility.
The TA (Total Access) unit cost $550, and I installed myself (with occasional help from the wife). Installation went smoothly, and the cover seems offer the best traits of both a soft tonneau and the single-piece hard-shell units.
The cover consists of four foam panels with black annodized, "pebblegrain" aluminum skins, connected together via sealed piano hinges.
Interesting that in the brief two weeks I've had it on the truck, it's already drawn the interest of a couple of "soft-cover" guys... One of them decided it was time to ditch the frozen fingers unsnapping and re-snapping his cover in the wintertime... He ordered a Fold-a-Cover, and will probably install this week.
If you'd like more info or photos of the unit in various postitions, let me know... I can shoot a few digitals and e-mail them.
Steve
Have a nice day everyone,......
Roger.
Sorry 'bout that
Roger.
Just my .02c
Cost for the P-E unit was $499 + $40 S&H for a short bed full size truck from truckaddons.com I think they also have a clamp on version that costs a little more.
Dean
On my last truck I had a Tekstyle soft cover and that was a nice low cost cover too.
Just my thoughts.
Andrew
Unlike rigid fiberglass covers, they don't get in the way if you need to haul something taller than the box of your truck.
The design sheds water/snow so you don't need to worry about wet cargo.
I have done a lot of mods to my truck. From my experience, I would order an item through an aftermarket parts house located in Louisiana, pay the UPS and still save over buying in Hawaii. An example. I ordered 4- edlebrock shocks from Shocks Warehouse. Paid $69.00 each + $10.00 each UPS. Ron's Performance Center in Mapunapuna wanted $99.00 each for the shocks and they had only one out of the four I needed.
I read your post in the Ford topic. Has your truck reached Chicago and started to make its way back to the west coast?
BTW, these wood grain sets could run upwards of $700 depending on how many pieces are included. After awhile though too many pieces can be excessive. My set included 13 pieces which included the dash, a/c vents, and door area where the window controls are. I thought it was maybe a little sparse but for $100 couldn't complain. Must have been decent cause the Shop Foreman at my dealership was impressed on the quality of the product and the price when he test drove with me.
Sorry for the long post....
just my .02
Hope this helps.
Putting the tonneau on was FAIRLY easy with two problem areas. 1.) The cross bows seemed to be too long, so I had to shave the ends down slightly. And 2.) what really concerns me is that the cover was very difficult to snap. The cover was straight out of the box and at first I had the snaps on one side on the top while the other side was on the bottom - no way! So I put both sides on the top (loosest setting), but the front and back were still on the tighter setting - no way! So I put the back on the looser setting - still no go. I then put all snapps on the loosest setting but still couldn't get the tarp snapped. I set an electric heater in the semi-enclosed bed and FINALLY got all the snaps fastened. Now if Extang claims to be the only tonneau that can be adjusted between summer and winter and we're not even to winter yet, I hate to think of having to unsnap/resnap my cover this winter. Sorry for the long post but if anyone can offer a suggestion as to what I may have been doing wrong I would appreciate it.
A.R.E. OWNERS: ARE has come out with an automatic lock for the tailgate/cover. Some modification to the handle assembly and run wires to the front kickpanel. WORKS GREAT WITH THE FACTORY REMOTE.
The kit works with both the lid and cap.
Randy
I am thinking of getting a Sierra or a Silverado and one option is the soft black tonneau cover. Have any of you had any experience with it? Would I be better off getting a cover from some where else?
Chet
I was just wondering if anyone would have an idea on how much mpg can improve with a cover on? I'm just looking for any guesses here. Also do the bug/wind deflectors help any with mpg?
Rick
GC
Dakota's Rock,
shawkwav
Spring bar is really just two long springs stuffed into the side channels - you put the tangs on the rear bar into the slots in the side channels and there is some resistance from the springs - it's actually a very tight fit, and it takes some rapping with the palm of your hand to get the bar in and out - but the springs do have the effect of adding tension to the rear bar and make the snaps easier to fasten.
Frame is black anodized aluminum - will show scratches where it has been nicked in transport or where you attach clamps/move clamps.
Purchased from netruckcap.com on line - $259. Took a full 10 days to get to me UPS.
Vinyl appears to be good quality with good liner inside.
I should have installed bed rail caps before installing the cover - I'll probably take it off and install them soon - probably ProCaps.
Likes: seems to be quite weather tight (except by tailgate as advertised - holes along sides of tailgate - not a tonneau issue), doesn't move around when driving. Opens/closes easily.
Dislikes: tonneau only opens about 30 degrees, so you have to unsnap front to get to items in front, black color shows dust and water spots very easily - used 303 protectant and cleaned up nicely, have not yet mastered the art of rolling up the bows and end rail in the vinyl cover and fastening at the bulkhead yet - takes a few times to get the hang of doing it quickly, I guess, but it does work and you lose about 6" of space at the front of the bed.
Torquing down clamps deforms thin sheet metal on Silverado rail - problem with all trucks nowadays, not tonneau problem - so use a bed rail cap to hide the deformation.
Overall assessment: worth the $259, I never haul anything with the truck, just a commuter vehicle, just wanted something to keep the bird droppings out of the bed - tired of cleaning/waxing the bed.
I will probably get a BegRug bedliner and a load bar of some sort to install at the rear of the box, since I use the bed like a trunk - actually seldom use it - bought the truck for comfort a big cab space, better ride quality, fuel economy, etc.
