My wife recently left the Aviator at the Phoenix airport for the day in a large, multi-story parking garage. She flew to Las Vegas in the morning and returned that same evening. Upon leaving the parking garage, she noticed that the Nav system had lost it's location . . . about 25 miles away from where she actually was. In the 20 mile drive home, the Nav system never regained its proper position, though there was heavier cloud cover than is typical for Phoenix. The following day, we continued to have variable cloud cover with scattered thunder showers, and the Nav system still did not regain its proper location, prompting me to use the recalibration menu to manually reset the position. However, the very next day (today actually), we're still having scattered thunder showers and variable to thick cloudiness, and the Nav system once again lost its location late in the day (my wife reports that it was fine this morning on her way in to work).
The Nav system had up until this point worked as well as could be expected, despite the fact that the maps are woefully out-of-date for the Phoenix metro area. I called Nav Tech (the map suppliers for this system) and confirmed I have the latest mapping software load (2003 ver. 1). I was told that Nav Tech knows that the Phoenix has undergone considerable development in the last few years and that they haven't been able to keep up with the changes, but that they intend to improve their coverage in the near future. Unfortunately, the Nav Tech phone rep could not offer any assistance with the GPS aspect of the Navigation System.
Has anyone else with the Optional Navigation System noticed any problems with the ability of the GPS to track you during inclement weather or keep track of your location after parking in a large parking garage? Our Nav system has been a pain in the butt this week . . . thank goodness we're in Phoenix where it rains very infrequently.
I know you have to have line of sight, and the parking garage would have hidden the car from any satellites. But, it should have re-acquired as soon as you got in the clear again. Clouds don't usually cause this in my experience. I think you have a malfunctioning GPS.
I have not had the issue described above, but I can confirm that the system is incredibly slow to re-acquire satellites when it has been out of use for a few days. It has taken up to 30 minutes in my case. This compares with about 45 seconds to 1 minute with my Garmin unit is my Yukon.
I recall that I read that the GPS antenna is in the front dash area in the Aviator and not on top of the vehicle. This location would greatly impair its ability to quickly acquire the satellites.
The dead-reckoning of the system works very well for me, however.
My wife reports that even through this morning's commute, the Nav System is still lost. We had pretty significant rainfall last night, and the cloud cover was still pretty heavy at our house when we left this morning. In the 20 mile (~30 minute commute), the Nav system wasn't able to acquire enough satellites to "find" itself. I can understand the nav system losing satellite reception when in a parking garage, but I would have thought the dead-reckoning functionality would have been able to compensate. Right now, the nav system thinks it's about 25 miles away from where it actually is.
The weather system is clearing out as I type this, so we'll be back to our usual clear skies shortly. I would like to wait and see how long it takes the nav system to reacquire the satellites and recalibrate itself before doing it manually myself, but if it takes more than an hour, I'll be contacting my service manager once again.
I've had my Aviator only 6 weeks. I had it only three days when the transmission went out in the middle of nowhere in Montana. A new tranny was installed. Then earlier this week the check transmission light went on again and the tranny got sluggish, so it's off to the dealer again. So far my car has been out of service for 15 days out of the six weeks. I've only put 1700 miles on it while logging almost 1500 miles on rentals. At least this time I got a Town Car. The first time I got a Ford minivan. Anyone else hear of this being a chronic problem?
This won't make you feel any better, but I have never heard of that transmission having early failure. It's been unusually dependable in all applications. Damn the luck, huh?
We have 30,000 miles on ours, nary a hiccup, and we tow with ours too. It's the second smoothest transmission we've ever had.
Clark - That sounds very unusual, especially for the replacement transmission to be problematic too. However, I did hear of one or two people report failed transmissions on the very early 2000 Lincoln LS, which has a similar transmission. Overall, though, this transmission is pretty reliable, and both my 2000 LS and 2004 Aviator are very smooth operators.
The weather has now cleared in Phoenix, and I have access to the Aviator, so I'm off to test out the Nav System again . . .
Aaaarg! I've spent the past 90 minutes playing/fiddling with this stupid Nav System and it just isn't cooperating. The skies are CRYSTAL clear, so there shouldn't be a problem reacquiring the satellites, right? I spent 60 minutes just driving around my neighborhood after repositioning the vehicle location on my home and getting it pointed in the right direction (using the 'Position' soft button in the recalibration menu). The GPS icon would display intermittently for a few minutes at a time (indicating that there aren't enough acquired satellites to track the vehicle) and then turn off, only to turn on again moments later.
Further, the dead reckoning functionality isn't helping either . . . as I'm driving through the neighborhood, the map and my indicated position is clearly lagging my actual position on the road. I had to return home to reset my position once again per the procedure discussed above, and then used the 'Distance' soft button in the recalibration menu. Unfortunately, the Owners Manual doesn't give much detail on how this button works, only that the button will remain highligted until the recalibration is complete. Well, I sat in the car with the engine running for approximately 30 minutes, and the button remained highlighted the entire time and never seemed to complete. The manual gives no indication of how long this step should take, but I would think that 30 minutes is ample time.
If this problem doesn't correct itself by the end of the weekend, it's back to the dealer again come Monday. My wife is PO'd, and I'm not that far behind myself.
As a matter of fact, someone on the LS discussion board mentioned the same thing Sunday morning. As simple as it sounds, I hadn't thought of doing that until after I had read the post! Thanks for the suggestion though.
Unfortunately, it didn't work. :-(
What I find REALLY weird, though, is that my wife and I drove the Aviator south to the town of Casa Grande, which is about 35 miles south of the Phoenix metro area. When we left town, the poor Nav system had us going in the COMPLETE OPPOSITE direction. Once we got about 20 miles south of Phoenix, the satellite icon went out, and all of a sudden it started tracking us correctly. Of course, this only lasted until we got to approximately the same place on the road on our way home, and the satellite icon returned, and the Nav system once again got lost before we got home.
My wife reports intermittent, at best, tracking on drive about the Phoenix, Scottsdale, and Tempe area today, though it did work at some point during the day. I have already scheduled another service visit with my dealer for Wednesday. My wife had called late last week indicating we were having trouble with it, so it wasn't a complete shock that I called to schedule an appointment today.
I've only heard of one other Nav system complaint, and that had to do with the screen losing it's display sharpness, but I've heard nothing similar to what I've been experiencing. This has been a most frustrating new car experience to say the least, but so far, I'm still confident this will be a good performing vehicle. Gas mileage has been between 15 and 16 in mixed driving, and we've seen 18 to 19 in steady highway cruising at 75-80 mph, and better when cruising at 55 mph (too slow for these parts).
Well, all maps forNorth America are on one DVD. Granted, you can change between about a dozen different regions, but I've already checked to make sure I've set my region as the default. Further, the Nav System tracked fine for the first three weeks we had the vehicle. The trouble didn't begin until the vehicle was parked in a multi-story parking garagge . . .
What's troubling me is the fact that the satellite icon is almost always present now, and that's the indication that no satellite signal is present or being read by the unit. Unless the Phoenix metro area has been blocked out by the GPS gods (yeah, right) then something's gone wrong with the receiver/antenna. Perhaps a loose wiring connection . . .
Well, the computer can't understand me at all. I'm not sure if it's the Minnesota accent or what, but it just keeps telling me it can't recognize the command. I usually end up cussing at it and just pushing whatever button I wanted. Pretty much a useless feature.
It turns out that I had a defective gyroscope. A new one has been ordered and is expected tomorrow. Infant mortality of an electronic device. It would not be fair to blame this one on Lincoln, as it is an integral part of the Nav system made by Denso. It would be a problem just as likely to occur in a Lexus navigation system . . . lucky me. At least my dealer found the trouble right away.
The dealer provided my wife with a Sable loaner.
As far as voice commands go, I believe the commands given and the system response is highly dependent upon which mode the system is currently in. You have to be in destination mode to get the system to respond to the "Home" command. I use the voice commands to change between the various audio modes, and it works well for that. However, I agree that there seems to be a significant learning curve with when and which commands are most useful.
I just got my aviator back last night from the transmission repair. Drove it this morning and the transmission quit working again, the car wouldn't move. So it's back to the dealer for the third time in the last 6 weeks, at least they hadn't even had time to return the town car, so I have that again. I have a meeting with the Ford rep next week. Any suggestions on what I should say or ask for?
Per the dealer invoice outlining the repair, both the Head Unit, and the Navigation module were replaced. From what the service adviser told me, the Navigation module was a $2,000.00 part!
I drove it briefly last night, and unfortunately, the icon indicating insufficient satellite communication was illuminated the entire time, though the vehicle was tracking properly. While my wife was out driving today, and the system ONCE AGAIN GOT LOST and incorrectly displayed the vehicle position about 5 miles away from where it actually was. Looks like another dealer visit is in our (near) future . . .
The Navigation System is hopelessly lost again. We'll be bringing it back to the dealer once again tomorrow morning. Our 45 day old Aviator has been in the shop a total of 8 days . . . not good. I'm beginning to suspect a wiring harness issue, as the all the pertinent Nav modules have been replaced to no avail. >:/
On 2/3/04, I took my 2003 Lincoln Aviator to the Dealer in Virginia Beach, VA for 15,000 miles service, transmission shifting up intermittently, roaring noise in the rear of the vehicle intermittently, and a play in the steering wheel.
The vehicle was serviced for the 15,000 miles but the service representative told me that the other repair would take time and that it was safe to drive the vehicle as is and bring it back another time. I agreed and got back the vehicle.
On Friday 2/27/04, the play in the steering wheel became worse and the driver side rear window would not go up or down, so I called the service Rep who advised me to bring the vehicle in on Monday 3/1/04. They provided me a cheap Mercury Sable for transportation while my Aviator is being repaired.
On Wednesday3/3/04, they informed me that the left rear window switch was defective and replaced but they could not obtain the steering shaft from Ford Motor Company to replace the defective one from my car. They ordered it with an estimated time of reception 3/5/04.
They suggested that it was safe to drive my Aviator and that I could pick it up and they would call me when they received the part. I told them that I preferred them to keep the vehicle and perform the appropriate repair. They agreed to do so and promised me to have the vehicle ready by 3/5/04 in the afternoon or early Monday 3/8/04.
On Monday 3/8/04, no one called, so on Tuesday 3/9/04 I went to the dealership and spoke to the service manager and his boss. They promised to have the repair done by Friday 3/12/04 or at the latest Monday 3/15/04. Today, 3/15/04 nobody called. I am thinking of seeing my lawyer but before I do so, I am asking anyone out there some input. Please Help
Don't call your lawyer yet. That will just put up a wall. I recommend polite persistance. It works best in the long run. For the rest of the gang, the whine in the rear end is resolved. New parts should be available in April.- I know personally how disappointing it is to have repeating problems.. Be persistant and polite. Our dealers don't build 'em you know.
The Service Adviser told my wife that he has 5 other clients with Navigation system problems, so we're not alone. He didn't specify which vehicles were affected, but he did mention that one was a Navigator. We've got a Ford Taurus loaner until the Aviator gets fixed. A new antenna and cable have been ordered, and a specialist (i.e., a non-dealership employed technician) was brought in to address this issue. I'm counting the days, though my wife and I haven't specifically mentioned this to the dealership.
I heard production was stopped until the new differentials come in sometime in April. Do you have a build date on yours? I don't think any have been made in March.
We got our Aviator back from the dealer again today. This was the second visit to address a Navigation System that would get itself hopelessly lost. This time they replaced the GPS Antenna, which is located behind the instrument panel. We've had a Ford Taurus as a loaner for the past 3 days.
So far, the icon that indicates insufficient satellite communication has not illuminated. I certainly hope this takes care of it once and for all. The dealer has had this vehicle for 10 days out of the 47 days since we took it home.
My Aviator had a humming noise during acceleration. Dealer replaced the rear defferential two weeks ago, and the problem is solved. Now it's a perfect car, with no whining noise at all.
Yeah! Our Aviator has been to the airport parking garage twice more since the last repair, and it's been in yet a different multi-story parking garage, and the Nav System is working like expected.
Each time we enter a large parking structure, the icon that indicates insufficient satellite communication illuminates, but it disappears in only a few seconds after we exit. I'm satisfied that everything now works and we can finally fully enjoy our new Aviator.
I'm looking forward to the next time we can get out of town because I'd really like to take the Aviator down to Organ Pipe National Monument (near the Mexico border) and take the two scenic desert loops. We've had a rather moist winter (more like spring for most folks) and the desert flora should be spectacular. While these roads are far from an off-road challenge, the Aviator should smooth the road out considerably and the air conditioned seats will make the drive that much more pleasurable!
Have a 2004 Aviator, 2000 miles. From day one, I could feel a very slight vibration when we reached speeds above 50 or 60 mph. Vibration is constant and is not noticeable unless we are driving on an asphalt road.
Took the car in today for the first time. Mechanic said he felt it also but could not say were it is coming from. Suggested drive the car, with the vibration, for another couple of thousand miles. Said if it is a rear end problem like others have had, it will develop noise somewhere around 5000 miles. At that time Lincoln will replace the rear end.
Any suggestions as to what is causing the vibrations?
Most of the time, out of balance tires are the root cause of vibration. I would first have the tires balanced at a shop that uses a Hunter GSP 9700 Road Force Analyzer. This is a highly specialized tool used to diagnose tough wheel/tire balance problems. My Lincoln Dealer has 3 of these tools in their shop, and my local Discount Tire store has one as well, but it's worth paying a few bucks extra to have your tires checked on this machine to rid yourself of this type of problem.
This was the first thing I suggested to the mechanic ... his thoughts were that it wasn't a tire problem ... but ... I tend to feel like you ... check the tires out first and then if the problem is still there, try something else. Thanks for the input.
Isn't a common tool, and can often diagnose tire irregularities that typical tire balancing systems cannot.
In each of the last two sets of tires I've purchased, my Discount Tire store had to return 2 and 3 tires, respectively in order to get all four new tires to balance properly. These tires WOULD have balanced OK on the standard mounting/balancing equipment, but the Hunter 9700, by applying road force during the balancing operation, discovered tire irregularities . . . similar to what you would experience while driving.
It costs about $5.00 more per tire to have them balanced on the Hunter, but it's worth it to me.
I finally drove my Aviator 100 miles to my dealership to work on the list of noises that I had?see my post #1022?.the rear axle whine, the rear hatch styrofoam squeak, the grinding noise from the engine compartment, the loose seat, etc. I had discussed all the noises during my 10K service on 3/26 and brought the Aviator back to them 4/3.
When I arrived on 4/3, I was told that there is no fix for the seat problem. I had the tracks/rails replaced in November at the 5K service and the seat remained tight for about 30 days. I was now being told that all of the seats are loose if you have the seat close and perhaps I should try moving the seat back farther. To me this is really not an option because even if you can move the pedals you still need to reach the steering wheel!
They had the vehicle from 4/3 until 4/17 and they gave me their loaner Mercury Sable to drive.
The Sable?s accelerator pedal cable broke on my way to work 4/12, leaving me dead in a busy intersection. The Sable was towed to a Ford dealer about 30 miles away and I rented another car from Budget. Yesterday, I turned in the Budget car, got a ride to pick up the Sable, and drove the Sable 100 miles back to the Lincoln.
I missed my Aviator and was glad to be finally getting it back. The mechanic assured me that I would love my new quiet ride. I got in, started the engine and heard the grinding noise from the engine compartment. I went back into the dealership and spoke with the mechanic. He said that replacing the AC compressor usually gets rid of the noise and that it is just the reeds in the compressor making the noise. I said that I would not leave the Aviator now, but would bring it back another time. I drove off.
About a block from the dealership, these weird (new) noises started, the steering got stiff, the vehicle started pulling to one side, and the engine was sounding and behaving strangely. I was terrified! I turned on my flashers, bravely made a u-turn, and headed back to the dealership. I really did not think the vehicle would make it back, but it did.
The mechanic took it for a drive, then another mechanic joined him?The service rep. told me that the transfer case had IMPLODED and that the mechanic put the differential back together too tightly. They would have to keep the Aviator and order parts on Monday.
So I have this beautiful car that is totally trashed that I could never sell! Who is going to buy a car with loose seats, with an AC compressor that sounds like the engine is going to fall out, that has had the rear diff rebuilt, AND the transfer case rebuilt after a dealer-caused implosion! Any advice would be appreciated.
Bribery Too!
I also forgot to mention that the service rep said that he would top off my tank if I brought him the blank customer service survey from my November 5K visit!
Well, the grinding from the A/C is normal if the unit hasn't been used for a couple of days. You can go to the dealership, and start any car on the lot that has been idle for 48 hours, and upon engagement of the A/C, manually, or automatically, it will give you quite a noise, but then that's it. Why it does it, I don't know, but they have done this for years, and I've never had a compressor go bad on me yet. I don't think it's harmful, just a little embarrasing, maybe.
The seat track, sorry to remind you, but I told you there is no fix for that. You get used to it, or at least I did, and don't even notice it anymore.
The transfer case problem, now that's a bummer. But you don't have much choice but to make them see it through a fix it. Unless you have a lemon law that will force them to take the truck back with multiple issues, instead of a repeated one issue, you're gonna have to see it through. You may end up hating the truck, but you sure can't sell it this way, right?
I'm so sorry all this has gone wrong with your Aviator. I am at a loss to understand why, (although you are kinda picky, seat track and all...) Clearly, the rear axle whine is not satisfactory. This is the kind of stuff that can sour one on a brand for life. I wish you well.
I don't feel safe when the seat moves. What will the seat do in an accident? If it is working loose after only one month, what is going to happen in a head-on in a couple of years. I don't think I am picky, I was ready to settle with just getting rid of the rear-end whine and wait for the other components making noises to fail and then replace them.
I hope that is true about the AC, but you can't blame me for not trusting anything the service rep or mechanic tells me at this point-the rep even told me that the tire pressure monitoring system works by compressing a post between the tire and the rim, the post being "molded" into the actual tire and the next set of tires had to be exactly the same.....not a sensor and transmitter built into the valve stem. If YOU say it's normal for the AC compressor-I believe YOU because even there is no face behind your posts, your information over the past year gives you credibility.
Please don't take my "picky" designation negatively, you have every right! There are some things I'm horribly obsessive-compulsive about, like lights. EVERY light must work on my cars, EVERY time, or I can't rest! Lotsa people, that's not a priority with, but me, I gotta go get a replacement today, if a light is out, inside or out. So I understand what you're saying.
On the seat, I was thinking back to my first 97 Mountaineer. The seats in that car rocked upon acceration. It was a totally different thing than I think you're describing, which I'm also familiar with, but it bothered me lots. I even had the dealer (who was very accomodating) exchange a seat for a seat in another new Mountaineer, to see if it was better. It wasn't. I never liked that car, as a result, even though the darn thing was really bullet proof! That one design issue kept me from enjoying it.
The seat track slippage that makes it move slightly forward and back on the track is something I've experienced in lots of Fords, Town Cars, 02 Mountaineer, etc., but it just kind of has been pushed out of my mind as an issue. Hope you can do the same, because other than welding the seat in one position, I don't think they have a fix for you.
Your A/C should not do that if you use the car, and or the Climate Control every day. If it does, you have a different issue.
And hell yes, why should you believe the service advisor! Even mine, whom I have used for 10 years, lies to me once in a while. I just shake my head.....
I have a noise in the cabin of 04 aviator that sounds like a door or the liftgate is not completely shut. it makes the noise when i cross railroad trcks or small ruts in the road. Sounds like the right rear side. have had to dealer several times.they replaced the rear shocks, but no help yet. any info would be appreciated.
You're sure your spare is locked down tight, and the jack too? If not that, I wonder if your rear A/C evaporator has come loose in the rear quarter panel? There's a lot of stuff hung in there behind that plastic panel, computer boxes, radio guts is in there too, I think. Maybe somebody put a coke bottle in there for you with a note in it from the factory? Hope not!
This is the type of annoying problem that I usually insist the service manager goes for a ride with me. Once he agrees the noise exists, then I tell him to keep the car and drive it, give me a loaner, and don't call me until it's found and fixed. Sometimes, it's taken a month, but they eventually find and fix it.
I love my aviator. I have the loose seat, but I keep it all the way back. So if I inquire I am sure they might say it is because I keep the seat all the way back. I have gotten accustomed to the loose seat with the previous continentals I have owned.After a few hundred thousand miles of lincoln driving you hardly notice it. As far as the heat ..I was told that the reason you get the cold air forced through is because they want to pump in fresh air as a safety issue. I forgot to ask if the heat is on the floor only position will cause me to suffocate. Some minor inconveniences. A telescpoing steering wheel would be nice as would a fore /aft adjustment on rear seats as well as heated rear seats.
HI, well with almost 11,000 miles on our 2003 Avaitor we have encountered numerous problems...mostly concerning fit and finish. Numerous squeaks and rattles in the interior (door panels, pillar post, headliner, steering column, rear hatch). Also, the side mirrors drive us crazy as they shake slightly at freeway speeds which makes it hard to focus on side traffic. The rear hatch was "fixed" by the dealer...they tweaked one side of the hatch so that it slams down on the tail lamp on one side and rides high on the other...but the problem persists. When the rear side door is opened it hits the back of the front door when car is parked on an angle (our driveway), resulting in chipped paint. Rear end whines but I see that many people have already posted regarding that. We're in So. Cal. so I can't comment on the HVAC problem. Steering wheel shakes when braking at freeway speeds, if I didn't know better I would think it had a bent rotor. Seats are just loose enough to be annoying, driver seat motor clunks. Dealer in Anaheim, Ca. won't fix anything...says mirror shaking is "normal". Upon picking it up after "repairs" we noticed the same noise problems, so we turned around immediatly and told them to come for a ride. They said a tech was not available but I finally got their oil-change guy to ride with us and confirm the noises, and to sign on the work order that he heard them. Service manager refused to acknowledge because the oil-change guy "isn't trained in that field". I guess they offer a class on sqeak and rattle detection!? We're not the kind of people who complain, but we are feeling a bit like suckers now that we've shelled out the $$$ and are stuck with all these problems. Has anyone else experienced these problems, or does anyone know a local Southern Ca. dealership that will take us seriously? It looks like we're headed towards invoking the Lemow Law.
" I was loaned an '03 continental during this time and ..."
Hey, cool. What do the '03s look like? Curious since they discontinued the Continental in 2002:>)
Sorry for the misinfo. Its wasnt a Continental that I was loaned it was a Towncar.
Here's a link that describes this tool
http://www.craigautometrics.com/huntergsp9700.htm
Bribery Too!
