How to Choose a Truck
                    I'm planning on moving this summer. And I usually do a lot of renovations and yard work when I first move in, and then ever once and a while I buy a new tree or something else for my yard or house. I have a few trucks in mind. They are the Toyota Tacoma, Ford F-150 Heritage, and the Toyota Tundra. Does anyone have better ideas? And I want to keep it under 25,000.
Carry on!
Be prepared for a lot of widespread opinions setzer!!
PF Flyer
All trucks have their strong and weak points. Most common are size vs. capacity. When you talk about weekend Home Depot runs or hauling dirt/mulch/gravel are you talking about 5 or 6 bags of Quikcrete and a small scoop of mulch (approximately 500 lbs.) or are you talking about 10 bags of Quikcrete and a large scoop of mulch? If the former, then the Taco should do just fine. If it's the latter, then you should stick with the 1/2 tons.
Just my $.02 worth.
Also if you are planning on a bed full of mulch or dirt on a regular basis, a full size truck would be a better choice.
These light utility vehicles come with many names: Ranger, Colorado, Dakota, Canyon, Mazda B-Series, Nissan Frontier, and Toyota Tacoma.
REAL pickups have F-150, F-250, F-350, Silverado 1500 (2500 HD, 3500), Ram 1500, Ram Heavy Duty, GMC Sierra 1500 (HD 2500,3500), Titan, or Tundra prominently displayed.
For any serious towing or hauling, the half-tons just can't successfully perform the task whether they be from Ford, Chevrolet, Dodge, Nissan, or Toyota.
I have owned little "toys" (1975 Nissan/ Datsun pickup, 1991 Toyota pickup, and 1985 Ford Ranger.
I now have a 1993 Ford F-150 Extd Cab LWB 4X4 which is a REAL truck.
Those little toys can haul a small load of manure, light weight bulky items from Home Depot, etc. Titan and Tundra ads try to deceive people into thinking they can do serious towing.
DON'T BELIEVE that crap. A close friend towed a 35' Jayco 5th wheeler with his Chevy Silverado 1500 for a year before he realized he needed a more substantial truck. He then got a Ford F-250 Extd Cab with 460 CID V8 and said he did not hold up traffic on hills any more.
True, the Ford F-250 burns much more gas while just driving around town than did the Chevy 350 V8 but got the same towing the 5th wheeler. The Ford F-250 got the same mileage empty it did while towing a heavy load.
Titan and Tundra are NOT satisfactory for heavy loads. Nissan and Toyota build fine passenger vehicles but have not yet built a viable truck for work. If 95 % of the usage is just hauling people, go with the Titan or Tundra if you want the Japanese label but if the truck will be used for jobs where work is involved, forget them.
My need now is for a small pickup that is easy on fuel and fun to drive around town. But on a clear day it's time to pull the pontoon to the lake. I am guessing the total package is not more than 3200 lbs. not including the truck doing the pull. I live in east central Florida so it's really flat towing except when we get to the boat launch. My big concern is extricating the loaded trailer from relitively steep wet ramps.
Will the 4cyl pull the load or should I locate a 6cyl. for the overall job I've defined. I have already decided on 4wd just to avoid rear tire spin on those wet areas.
I am assuming the boat trailer doesn't have brakes on it. I seriously doubt the Taco's brakes have a sufficient heat sink to prevent them from overheating during a "slight" panic stop, much less a full blown panic stop. If you have, or put, brakes on the boat trailer, then you might be ok here. The next thing to consider is the trucks suspension. Is the Taco's suspension heavy enough to handle that boat? The truck needs to be able to control that load under all circumstances. If the truck is too light, then the trailer will push it all over the road and will even cause it to jack-knife in a moderate avoidance manuever, causing a wreck. The next is the wheelbase. If your looking at a regular cab short bed, then I'd say no. The wheelbase is too short for that big of a trailer. If your looking at the model with the longest wheelbase - I don't know what combination Toyota offers, whether it is a crew cab long bed or just an extended cab - it may be long enough. The reason I mention wheelbase is based partly on personal experience, but mainly on the experiences of several people in my area of the country back in the late 70's and early 80's. I have towed an approximate 5,000lb trailer with a regular cab short bed truck and the same trailer with a regular cab long bed truck, both GMC 1/2 tons. The drive was more comfortable in the longer wheelbase truck. The trailer wanted to push the shorter wheelbase truck around when I would try to slow down. Back in the 70's and 80's, people were taking Jeep CJ's and putting V-8's in them. Then something would come up and they would hook a, for instance, 16' flatbed trailer to them to carry wood or whatever they needed. Well, you know how it is if you have towed very much, someone would pull out in front of them. When they hit the brakes, the Jeep would jack-knife and several were killed. I didn't know any of them personally, but my brother-in-law did.
So I have rambled on for so long, but it just kills me to see someone struggling down the road with too large of a trailer coupled to too small of a tow vehicle. You are really wanting the best of both worlds, good fuel mileage with decent towing capabilities. I doubt you'll find it. I don't know your particular situation, but if it were me, I'd buy that 4 banger Taco for use as my daily driver and an older 1/2 ton to pull the boat. It might cost just a little extra in insurance, but you'll get that back in the fuel mileage of the Taco.
I do agree with mullins87 and a bigger full-size (even with a six) would be much safer. Another alternative would be a used T100 4X4.
I tow a 5200 (wet) camping trailer with my Tundra.
Both trucks look great, drive great, and are at comparable prices. Which would tend to last? Any suggestions would be very appreciated! We like both trucks but worry that the 2500 is way too big for our needs.
I have the 2003 F150 Super Crew. It is a great all around truck while also being able to cary 6 people (which I do about once a week). Gas milage with the 5.4 is 18 on the highway, 15 around town. With winter my combined average has dropped to about 15 mpg.
It sounds like the Chevy is more truck than you need. The HD with an 8.1 is set up for serous hauling.
As for which will last? All I can say is I had Camry that had a number of problems. My F-150 had a couple of minor things that the dealer fixed on the first service. 2nd service in the next month will be just oil and tire rotation.
Full-size
Extended Cab (I have 2 kids & another on the way)
Prefer Automatic transmission
Price range $3000-7000, ideally
I'm thinking of a Chevy, GMC, or Ford at this point. I won't tow much (an occasional tow of a boat or light trailer load), and I expect to have to buy one with over 100k on it. I want something that will last me and that wears well. What are your suggestions? Pros and cons to different models?
Thanks for helping a new guy!
What do you plan to use the truck for? Do you plan to have your whole family in it? I have a family member with three kids. They take two vehicles.
I'd like to have the option to put the whole family in if we are going camping or somewhere that I'd rather take a truck than the minivan.
As I continue to look around, I'm leaning to the 1997-1999 era of Chevy/GMC trucks with a 3rd door, but I'll be looking at over 100k still to get in my budget. I'd still like to hear everyones thoughts. Thanks for your help!
For family driving, we have a 2003 Camry LE. So the proposed truck would be used mostly for commuting to work, 18 miles one way, trips to Home Depot (I love home improvement projects, room for a 4x8 sheet is paramount), and any solo errands. Typically it would be just me in the truck, or maybe our oldest child who is three.
Looking at the trucks, the standard S-10's, Tacoma, etc just visually look too small and low to be safe, and none have Good ratings at IIHS.ORG. The F-150's and Tundras, etc seem large, but some do have Good ratings at IIHS.ORG.
Another question is cab size. I'd probably either do the base size, or something extended a bit to toss junk in the back, but definitely not the four-door types.
My biggest question though, is going from FWD to either RWD or AWD. I have driven RWD a bit in the past and seem to recall that I always had a hard time accelerating in the snow. I live in NE Ohio by the way. There are plenty of trucks in NE Ohio that are only RWD, so I'm sure that with some brain retraining, I can learn what I can and cannot do with a truck. I guess my question is would buying a AWD truck help the truck feel more like the FWD vehicles that I'm used to?
Please feel free to try to read between the lines and to answer the questions that I haven't asked yet.
You ought to try to go for an extended cab 2door. It's just too uncomfortable in a reg cab: can't move the seat back, can't toss stuff there.
I don't know who makes an AWD truck. If you forsee problems with 2WD driving, get yourself a 4WD and you'll be all good to go. My 4WD Taco (stock at the time) did extremely well in snowstorms of CO.
You'll get used to RWD, don't worry.
My pickup rankings:
1)F150- cannot be beaten; Ford will last the longest of the domestics
2)Titan- is just as good as it is said to be
3)Ram- Big Hemi power and revived interior, with space
4)Tundra- the interior is very refined, but not like the Ford
5) Silverado- Why spend 40,000 on a Sierra denali for an average interior?
I know these facts firsthand, because I bought a new f150 last sunday, and testdrove each model, plus the colorado (which was better than the full-size silverado) 2-3 times, with different variations.
I am predicting that without major improvements, GMC and Chrysler sales will SIGNIFICANTLY diminish, below many german and japanese models. Mercedes might also go down with chrysler.
I've gotten informations from the "FWD vs. RWD vs. AWD" board that basically tells me that 4WD/AWD is nice, but don't expect it to make the truck handle more like a FWD.
So with this information, I won't spend the extra money on 4WD/AWD, but I'll look for a taller RWD with an extended cab. Years ago, just out of college, I bought a used S-10 and kept it for less than a year. The stick was ok, but I couldn't stand the lack of AC, sliding around on the bench seat, little room for junk to float around, and crashing my right elbow into the rear window whenever I started driving in reverse. I'll make sure I don't have these issues again!
Still don't have details on repairing the PGV, but I wouldn't be surprised if it cost more than the Private Party value average condition of $742.
Ford offers Edge model, I believe, but I get lost in their model numbers.
As far as Chevy.....I wouldn't touch it with a 10-foot pole. I'm sure they offer something like a prerunner, but you'd have to find it on your own.
If you are going for a Toyota, you could wait until the summer. Current line of Tacomas is being updated with all-new look and engine, '05 Tacos will be bigger, with a 240hp engine, so you could buy '04 even cheaper than now.
On fixing the van, I skip all the horrid details, but the shop took over a week to get me a "good" estimate on the repairs and asked $$ for some suspension work. I never felt comfortable with their answers to my questions, so I had the vehicle towed to my house unrepaired (yes, I paid their stupid diagnostic/storage fee). The suspension looks fine to me, but it will need to be aligned. What surprised me when I looked under the van to see what the grumbling noises were, is that the exhaust pipe was chinked and pushed off it's center line by 10", and that something had pierced the muffler. I'm glad those professional took the time to give me a "good" estimate. Those #$@ never even looked at the van.
Long story short, looks like the van will be repairable and I should get it done before my buddy reclaims the keys to his Tacoma.
Thanks to everyone for the advice given. Had the van had a bit more damage, that Tacoma looks very nice. Not sure if I'd buy 2WD or 4WD, but I'll come back here and ask again if the situation arises.
How much does this pontoon boat and trailer weigh?
If you want a reliable truck, go for Tacoma single cab with an I4. 2WD or 4WD, doesn't matter. If it's under 20K, a 2WD will work fine. It'll be a lowrider, but it'll work, and I4 with manual transmission will work just fine.
Colorado is new, and might be too big. Knowing Chevy track record, I'd wait at least a year until Colorado has most of the bugs worked out. Tacoma, on the other hand, is a proven 10 year old design. The I4 engine in it has been in use by Toyota for over 10 years, and is bulletproof.
If you are going to go with V6 Tacoma, your gas milage will be 17-18mpg.
Seats: it seems that Toyota fixed this problem in later 2001+ models. I have a 2002, and have never had a problem, even on 17 hour drives.
Options: I got a 4x4 Tacoma (manual, V6) with SR5 and TRD packages. Then it also has sliding rear window and floormats. You don't need TRD, and you could just go with cheapest wheels (Steel) that they offer, and just upgrade your wheels later if you feel like it.
So, SR5 package is pretty much all you need.
Sandbag the rear axle and don't worry about buying TRD package b/c it has a locker: you will not need it unless you go offroad. Some people do find TRD suspension better than stock suspension (TRD is tuned for offroad), but it's completely personal matter. And you can always put different shocks on it, or even lift it up for less than $400.
My buddy was not amused when he returned from Hawaii to find my van inside his garage, instead of his Tacoma that he let me borrow for about 10 days!
The Tundra has more room in inches but not drastically bigger than the T-100. The Tundra tows more though.
Could anyone give me advice on whether to buy an 04' Super Crew F150 4x4 or 04' Double Cab Tundra 4x4? I am struggling here... They both seem like great trucks... I will not be towing a whole lot... maybe a sea doo or two, but that's about it! I am looking for a good deal, and I want to spend less than 30 grand on it! What do you think for the quality and durability... which would be better for me? At this moment i'm leaning more towards the Tundra!... any suggestions??? Thank you~
From my experience, there is always a buyer for the Toyota trucks. Even if the Toyota is slightly more than the Ford, go Toyota. No doubt!!
For a base SR5 4x4 Double Cab, you should absolutely be below $28k.
I am going to buy a truck. I am considerting Toyota Tacoma I4 2WD and Tundra V6 2WD (regular cab).
The specs of payload and towing of both trucks are 1500lb/3500lb and 1500lb/5000lb. So it seems that there is no big difference between them. But as Tundra is a full size truck, and it should have more payload.
I asked my friend, who has a Ranger I4. He told me that the actually payload of his Ranger I4 truck is under 700lb (also 1500lb in spec), otherwise the bed just sacks down, and he may damage the rear axles. Thus I wonder what are the actual payload of Tacoma and Tundra.
UCSC
I hauled several loads of furniture and wood in my Tundra and it never was a problem. I owned a 93 Truck with the 2.4 and I remember one time that I had 1600 lbs in it.
The only thing you have to deal with the Tundra is to watch for little cars beside you (blind spot) and it takes more gas.
Does a diesel perform better in extreme cold?
Do Chevy, GMC, and Dodge have drivetrain problems in sub zero temps?
Does anyone know about alternate fuels or Bio Deisel engines and power specs?
Thanks, Mr.Ski
Nortsr1
http://www.fordaxz.com./pdf/2005.SPORT.TRAC.OG.pdf
