Dual Exhaust for Silverado
Other trucks (makes) you can order with dual
exhaust from the factory. The "Real Thing". I
have been told that Chevy doesn't offer that. It
seems kind of strange that others would. Has
anyone ordered a truck with dual exhaust from the
manifold? I wonder if the salesman is blowing
smoke?!?!?!? If there are any salesman on this
sight, could you let me know for sure.
I will be ordering my truck within the next two
weeks. Thanks.
Gary
weeks. Thanks.
Gary
I don't think that ford or dodge offer duel exhaust from factory.The dealers have them put on by muffler shop. The ones i've seen were just split after muffler. Thats been a few years.
Richard
If the truck has a problem and the problem for instance is possibly exhaust related, GM will insist the exhaust be put back to oem specs before they will go further in diagnosis.
I know this first hand. Happened to me and won't happen again. Wait until the oem warranty is over before adding those aftermarket items unless you don't mind a possible repair out of pocket.
are put on from the converter back? Good thing
nothing ever happened to my Dodge. I am ordering a Silverado in a few weeks. I was
wanting to have it put on but maybe I won't now. I
have just heard that if you have dual exhaust from the manifold, it will increase horsepower and give better gas mileage. I had dual exhaust
on my Dodge from the converter back, so it
sounded nice but didn't improve power or gas
mileage.
Thanks for the info.
Gary
Is there a huge muffler with two inlets and one outlet? I changed my '98 to a free flowing muffler with dual-in/dual-out pipes. The Vortec 350 sounds great with it.
-powerisfun
the Y pipe then couldn't I get it all the way
back without messing up the warranty or be any
work that is done within 36,000 miles? I would just have to get two mufflers right? I can't
imagine that they would make me take it off prior to doing any work on the exhaust system. Keeping
in mind I know that they wouldn't do anything to
the driver side portion. What problem could
having dual exhaust cause to the exhaust system
that would cause them to say they wouldn't cover
it until I took it off or I would have to pay
for repairs. Or is it just another way to make an extra buck?!?!?!?
Gary
-powerisfun
Exactly what powerisfun stated, I had an exhaust leak on mine and since they couldn't easily find it, they (GM) insisted I go back to stock before they would do anything further and I only had a catback, not a true dual. They also are much more stringent on emission related items than anything else because they are so highly scrutinized and regulated by the EPA and all.
My opinion.
bad! I had it taken off. It just made a loud
obnoxious sound. It was loud inside the cab and
drounded out the radio. The say it will help give
it more power......yeah right, it is isntalled
behind the catallilic converter. How can it! So
don't fall for it. I would just get the dual
pipes itself.
Good luck!
Mineke and they both said that in order for it to
help gas mileage or give more power, it would have
to be dual from the manifold. They said anything
installed behind the cat would not do anything
but sound better. I'm not sure who to believe but
I can tell you that mine didn't get any better
gas mileage after I had the flow master installed.
You might investigate it a little more before
wasting your money.
Let me know what you find out.
If you are looking for increased performance, a catback will actually lose lowend torque, more so if you install headers at the same time. This is because you have caused an imbalance where exhaust flow exceeds intake. So...increase the intake...airaid, Granatelli MAF...now gas mileage may increase...not mine..cause I somehow started to drive a little faster...
Start messing with the carb/air cleaner and GM will make a stink when you go for service work, anything engine related will be blamed on your "performance" modifications. I am spending over $27k on my truck and would not even consider putting dual exhaust on during the warranty. At best you will look/sound cool, at worst you will be hung with additonal cost that will be for not when you need to get service work done.
In order for the dealer to void your warrenty in regards to putting an aftermarket exhaust system on, they have to prove that the system was the cause of the problem. In my opinion, your best bet when changing the exhaust system, is to go with a aftermarket system that comes in a complete kit. Most of these systems are 50 state emissions legal and have been tested on the vehicles they are for.
it is unwieldy to manage, and difficult to use for "newbies". There is entirely TOO much topic duplication, so I will be doing some SERIOUS topic consolidation in the next few weeks, getting us down to not more than 2-3 topics per vehicle type, and ultimately down to 200 topics or less.
THIS weeks consolidation candidates are: F-150's, Silverado's, Dakota's, and Dakota Crew/Quad cabs.
In that vein, please consolidate this Silverado topic to Chevy Silverado - Continued IX and continue these discussions there.
Front Porch Philosopher
