Chevrolet Malibu: Problems & Solutions
1484951535471
    gonogogonogo Member Posts: 879
    Called my dealer, no reflashes done. He set up an appointment to look into it.
    Thanks e2helper, I mentioned a factory guy for more leverage, hope you don't mind. :)
    oldster1oldster1 Member Posts: 9
    Yes, I am referring to the exhaust system---pipes, converter, muffler etc
    e2helpere2helper Member Posts: 1,002
    NP but based on kurt's comments above although this calibration has solved some complaints (rough idle and transmission shifting) it looks like there might still be some hard starting under certain conditions :(
    I agree that you likely have the latest calibration - actually you are probably one of the first to receive it - from the customer clinic you attended in April 2004.
    Regading the comment on gauges if it only happened one time I don't think have any suggestion on what to check. If it happens again also keep an eye on your "PRNDL" which shows gear you are in and odometer to see if they are affected. The first would likely not indicate a gear and the second would show "ERROR" if the condition lasted long enough (a few seconds). A lot of information to the instrument cluster comes over a serial data link and so if it is something external to the instrument cluster those functions also would be affected.
    kurtamaxxguykurtamaxxguy Member Posts: 677
    thanks, e2, for things to look for. I hope the connections for that serial interface are well sealed!
    The maxx is not the first car I've had with the lukewarm restart problem.
    My '83 toyota camry had the same problem (had fuel injection), and my '82 Honda Accord would boil its miserable 3 barrel carb dry when parked while hot (Honda refused to do anything about it).
    On other hand, my '96 Geo Prism rarely had this problem.
    And the calibration did help the idle, BTW. Now if I can only get the dealer to figure out how to properly set the steering gear preload....
    redmaxxredmaxx Member Posts: 627
    I too have hard start problems, but mine are different. There is no rhyme or reason, it just has a hard time sometimes. Since the calibration, it has never failed to start, but when it has trouble it takes about 2-3x as long cranking and when it finally starts it sputters to life.
    04bu04bu Member Posts: 16
    Two days ago I was merging onto the freeway and once again had no directional. Left, right or hazard lights which I quickly checked. By the time I got fully into traffic they were back.
    I'm getting tired of Chevrolet sending me dealership performance questionaires asking me what I think of the dealership performance and not what I think of their car.
    puhrincepuhrince Member Posts: 8
    just to let u know that the part finally came in..from a supplier in mexico..it took 8 weeks but hey its a big relief - Chevrolet is compensating by covering by future oil changes/maintenance for 25,000 miles.
    chevylovychevylovy Member Posts: 1
    Are those cars the bomb or what. Has anybody had any problems with this car and how does it ride?
    maxxolivermaxxoliver Member Posts: 78
    My daughter bought one and loves it. She says it is the best car (next to mine of course.) She got a granite blue one with the chrome sport package. It rides really nice is comfortable and the mileage is great. She drives a 70 mile round trip 3 days and 40 mile round trip 2 days plus and gets 27 to 30 mpg. I have driven it and it is a nice ride. The price is good too.
    79377937 Member Posts: 390
    I have also had the same problem and regard it as a safety hazard with potentially serious consequences. I still insist that these random problems have all got a common cause and should be investigated by GM.
    mdennishmdennish Member Posts: 16
    i have also recieved 3 surveys from gm re: my purchasing experiences from the dealership and not one concerning the actual car! i want gm to ask me what they could do to make this a better car or how to keep me interested in buying another maxx,
    legacy2005legacy2005 Member Posts: 3
    pretty much what the topic says. i have a 2000 malibu that i use as my beater car. but for the last couple of weeks the only way i can start the car is if i have my foot on the gas. ive checked fuel pressure and spark, and both are good. any ideas on what is going on?
    Check the fuel filter. Fuel pressure can still be good but volume of fuel delivery might be low.
    ill give it a check
    sean74sean74 Member Posts: 18
    The milage of my 2005 malibu LS is only ~1,500 miles.
    However I can hear scratching noise when I press brake.
    My old car had this problem. The mechanic said that was due to the dirty brake pad. I don't know what's wrong
    with my new malibu. I don't think I need have a new brake
    pad. But the noise is annoying. Thanks in advance for your advice.
    firemanjackfiremanjack Member Posts: 123
    I have an '05 Maxx with the 3.5 and it turns 2000 RPM at 70 MPH..in overdrive(4th gear)..I know that's low...but that's what it has always been...A serene high speed vehicle, that gets exceptional highway mileage(32-34)...It must have a numerically high final axle ratio.. Am I alone in this? Jack
    i checked the fuel filter and it wasnt plugged up. i threw a new one on just in case. but the car is still having the same problem. not to sure why i would have to have the gas pedal all the way down just to start the car.
    I was referring to tcb70's comment about his terrible gas mileage. He has the 4cyl. Ecotec powered Malibu and so have I. If I remember correctly, at 70mph the rpm's on my car are about 2200 which is still pretty good for a 4cyl.
    I once took the car up to 90mph on a Nevada highway - 80mph speed limit - and it seemed as if it could have gone higher before I slacked off. I think the engine has enough power to satisfy most people.
    I know that a carburated car when flooded would only start if you pushed the gas pedal all the way down. I don't know if that applies to fuel injected cars though. Maybe for some reason or another your car is flooding. Maybe your air filter is clogged?
    04 Malibu 3.5 turns 1900 at 70 Mph, the sedan is 3.05 ratio and the Maxx is 3.29.
    paopao Member Posts: 1,867
    just did SC to VA and back..on one tank of gas if got almost 37 MPG>..after manual calculation it was about 35 MPG with the V6...as the DIC usually runs about 1.5-2.0 higher.....so not bad at interstate speed of 75.....ran over 50K in my Maxx on this road trip and love it still!!!
    beedublubeedublu Member Posts: 236
    No, you're not alone. That's pretty much what I get with my 04 Maxx LS. :)
    I thought it was the other way around. When we had a 1980s Sentra, I was told not to hold the gas pedal down before starting it as this would flood it. Sure enough, if I did, it was flooded.
    In fuel injected cars, holding down the gas pedal signals the PCM to cut all fuel to the engine. This is in the event that it gets flooded. Try it on the Malibu. The car will not start with the pedal to the floor.
    What I meant was if a carburated car had ALREADY been flooded for some reason or another, you could usually get it going by flooring the gas pedal and holding it there until the engine started.
    When starting a computer controlled fuel injected engine, the gas pedal should not be touched.
    The problem with the car under discussion is that it ONLY starts when the pedal is floored and it is a 2000 fuel injected Malibu. So we have a paradox here.
    imidazol97imidazol97 Member Posts: 27,155
    It's been my understanding that on a computer controlled car when the gas pedal is floored during cranking that stops gas flow--just like clearing out over-choking with a carburetor.
    What happens if you open the throttle halfway before you crank her at all?
    That's how it should work but if you look at the thread of this discussion and in particular, post# 2615, you will see that something funny is going on here. It would seem to me as if the engine is getting too much fuel despite the computer control. It is also possible that the injectors are leaking causing flooding of the engine and that is why flooring the gas pedal allows it to start. I don't know. It's always difficult to diagnose problems from afar. I don't know at what point of the gas pedal travel the computer switches off the fuel.
    The owner of this question about starting problems should post it in
    pgilbert, "Got a Quick, Technical Question?" #2152, 7 Nov 2005 1:07 pm
    There's a mechanic there and others who may be able to help.
    am definitely seeing these in my '04 maxx now. First was just after starting and the ignition key returning to "run" position when all the gauges went dead for a split second (just the gauges - the instrument lights stayed on).
    Second was when doing a remote start, and putting the key in the ignition - as soon as I turned the key to "RUN" the engine stopped running! Had to restart again.
    Does this sound like the ignition switch is faulty?
    suecsuec Member Posts: 2
    I am new to this forum, but couldn't agree more with the comment about Chevrolet wanting dealership performance feedback but no feedback on the actual car. Bad move on their part! I have a 2004 Malibu LS and have also had problems with my steering column and a thumping noise, primarily when I turn left. The steering column was replaced once while the car was still under warranty (I currently have 46,260 miles on the car and it is not quite 2 years old). I have taken the car back to the dealership twice and have been told that the thump is just a "flaw in the design of the Malibu." I'm not satisfied with this answer, but don't want to keep having the steering column replaced, especially if Chevy won't pay for it.
    I've also HATE the headrests. Can they replace them at no charge or am I out of luck because of the warranty issue?
    I think its variable. By trial and error, I was able to press half-way down on my pedal and it took the engine longer to start, and it seemed harder to start, but it may have been coincidence.
    cwesleygcwesleyg Member Posts: 64
    You should test fuses out of th panel.
    "My '05 Maxx makes a lot of popping and crinkling noise from the manifold thru the converter and tailpipe assembly when it is shut off and cooling down. This I can understand and accept. However mine makes the same noises when there is any change in sheet metal temp due to different operating conditions; such as when idling at a light, pulling a hill, coasting down a hill etc. Needless to say it is extremely annoying. Has anyone else had the problem and what was the fix?
    Dealer ofcourse says this is normal---BS. "
    I'm having this "problem" as well... I figured it would stop as the car broke in, but it is as loud as ever w/ 5100 miles now. I drive my Maxx pretty hard, so I know I get it hot fast, but the noises do seem extreme. I still love this car though. I still look forward to the drive home...
    curious as to the thumping noise....I too have a slight one..but hardly noticeable....cant hear it until you sit in the passengers seat and going forward...disappears at highway speeds....51K on my car...original steering column ...Maxx LT here..18 months old here
    I can't describe it except to say it is a "thump" that you can hear and actually "feel" in the steering wheel when you turn (mostly only when I turn left). Mine started out hardly noticable, too, but seems to be getting worse. :cry:
    sgr5516sgr5516 Member Posts: 163
    I have a 2004 Maxx LS and have not had the thumping problem. I'm no expert, but problem may be caused by the steering gear pre-load adjustment. While the power assist is electric and built into the steering wheel, the steering gear is a standard manual rack and pinion system. There is TSB for this, but it says it only applies to GM Chevy dealers in Mexico. It's TSB 04-02-32-003, issued April 2004.
    The TSB says - Some customers may comment that while driving over certain rough road conditions, they hear a rattle noise from the front end of the vehicle. Some customers may also comment that they feel clunking in the steering wheel while hearing the noise. This condition is more likely to occur only when the vehicle is hot and will go away after the vehicle cools down.
    The fix is to remove and install a new plastic adjuster plug and retorque to spec.
    @60 MPH: 1800 RPMs
    @65 MPH: 1900 RPMs
    @70 MPH: 2050 RPMs
    @75 MPH: 2200 RPMs
    @80 MPH: 2350 RPMs
    @85 MPH: 2500 RPMs
    2004 Malibu Maxx 3.5L V6
    Note: to obtain these numbers I set the cruise control at these speeds on a level highway and held that speed for about a minute to ensure that the transmission was satisfied with its configuration (no TCC changes, etc).
    mine isnt in the steering wheel at all..that is smooth as glass still..at first thought it was a bearing but had that checked..and wasnt the problem..so will just live with it.....mine is so slight you can only notice it with the windows up...no fan and no radio going....just one of those little things you get to know about your car I guess
    some have simply turned the headrests around....out of warranty...dealer will probably not touch the issue...
    to be honest..I find them the most comfortable ones I have had in all my autos....they actually support the head vice the neck..and allow me to sit straight in the seat and rest my head back....Im not one to laid the seat back..and make it a lounge chair.....
    maxx4memaxx4me Member Posts: 1,340
    ...agreed. As for the steering, my squeeking noise has returned. As a result, I am not having any of the "parking lot jitters". It is nice not to sweat it knowing I have the warranty until 102,000 miles.
    YES, there is a Technical Service Bulletin (TSB)that is about replacing the headrests in the '04 (at least) Malibu. My dealer was unaware of it, and I was NOT charged for it. They took about a week to arrive. I hadn't realized that with the original headrests, I was sitting with my head tilted slightly forward. The replacements are better. Even though the fabric style doesn't match exactly. I have the LS interior and sedan headrests. But it's still better.
    mhelselmhelsel Member Posts: 11
    1st 3 months radio worked great. then it started, turned off radio, my wife gets in turn on the car and the radio comes on by it self with out turning it on! Sometimes XM,CD player, FM station, or while going down the road with the radio off. any one out there having this problem too? My dealers says its the two keys that that is causing that to happen, it remembers not!because it does not play what either one of are selections.
    Had same problem, my dealer said it was the calipers grabbing and lubricated the guide pins and the noise went away, but it is starting to comeback again.
    Have the dealer clean& lube the caliper guide pins and the noise will go away.
    I think we have seen this complaint before :(
    Dealer is incorrect, radio personalization is based on the last fob used to unlock door, not on the key itself.
    If radio settings are changing when driving down the road this is most likely a different issue - either with the Radio or BCM.
    I will think about this some more and post back - would you be willing to have the personalization feature turned off if that would address complaint? Dealer might be able to do that for you - although they might not know how to do this without help from their technical assistance center ;)
    mybooomybooo Member Posts: 92
    I have seen some talk about different key fobs holding different radio presets. Does anyone have details on this? What is this feature and what all does it do? I have an 05 Maxx LS, and was unaware of this feature. Any help would be great! THanks!
    Larry :-)
    prdmprdm Member Posts: 145
    e2helper knows better than I but I believe this option was deleted for '05 due to overwhelming confusion. We don't have it but neither do we have the CD changer option.
    Ok, thanks! I was trying our different fobs with no luck. We have the LS with the single cd. I am surprised at all the little features I keep coming across on the Maxx. Very nicely done! Thanks again for the info!
    Larry :-)
    2manypauls2manypauls Member Posts: 2
    Have 2005 Malibu LT,3500mi,2 mo old.3.5 V6.Problem with exaust heavy sulfur smell when hot.Dealer gave me loaner.2.5 days later could not duplicate problem,no codes ,if so engine service light would be on. GM said to dealer to break in & run 5 tanks of Mobil gas.This is the same dealer who when questioned, charged 5 qts oil when manual says 4qt with filter.Two GM mechanics in their own business says either lazy 02 sensor or computer in lean mode.
