Mine does feel a little "looser" but not terribly so. Almost 19k miles. Its a little over a year old.
My mechanic told me thats something he cant really fix, he said some brand new cars have this problem too. Please help in any way you can thanks!
thnx AnnoD
Last winter I had the car into the dealer for a few other things, they drove it and said they didn't see anything unusual for this model. Anyone else experience anything like this? Can this be the dreaded transmission "howl" that I'm reading about?
I havnt tried taking it in yet. I'll let you know what they say when I do.
I purchased an 04' on 12/21/04. We never made it off the lot, the heater did not work. Since then I've been to two service departments for a wind noise on the passenger side rear hatch and alignment of the hatch which was off by a little less than a 1/4". The techs can't find d the win whistle, but my mother-in-law heard it on an 11 hour trip to DC and she is hard on hearing in one ear (no joke). The steering column was replaced. The ignition key won't return to the run position when you star the car, the moon roof rattles in the vent position, the handle to lower the rear seat broke, the day time running light has a bad socket assembly which I found that the dealer claim the can't, after I told them what the problem is. Now for the good part. I found gold over spray under the clear coat on a black car. It is also the same side as the day time running lamp problem. They did re spray the hood under warranty. As of today I've been working with GM in the Business Service Section. The rep has been great, considering that the selling dealer took two weeks to get the warranty claims sent to her. I should have an answer on 12/14/05. Any feedback would be great.
RANDY
Also, wrt the transmission problem in the early '04 Maxxes; is it true that a bad trans can be detected by Vehicle VIN only? Or do you need to verify the transmission Julian date?
wrt transmission, I am very worried. If that goes out outside of warranty it will cost thousands of dollars to fix. The car is not worth that. What bothers me the most is the dealers won't give me a straight answer.
Am I misreading things, or does it seem Wagner and Lutz are more interested in shoving half-baked new models down our throats rather than getting them right? Serves me right for buying a first year car...never again. Which is a pity as the Maxx held great promise.
would think if chevy is having a lot of problems with the rack and pinion steering....sounds odd as I thought this electronic steering eliminated that......but again..no mechanic here..but regardless if the service departments are completing field reports and sending them back to GM...then we should see something....a base cause or issue....much like the steering column....that one was a NHTSA engineering review...but wasnt enough for a mandated recall apparently.....
BTW took the plunge or another first year Gm car..and picked up our 06 Pontiac Solstice two weeks ago...WOW is all we can say so far!!!
dated oct 24 2005 document id# 1716682
in short,it details the issue covering malibu/maxx 2004 thru 2006 and pontiac g6 2005 and 2006 models...
I quote"The root cause has been determined and corrective action in in the validation process" " At thsi time service parts are expected in the first quarter of 2006"
The service Mgr gave me a copy of the document and updated my service file to follow up with me on this matter sometime in feb when i would be due for my next service...
It looks to me the gm although being quite about this design problem will be able to fix it shortly...
Sorry about the rambling on and i hope this will be of use to all of us who are having this issue...thanks
thanks justamom1
Feel of the Steering has improved considerably - no more pops/steering kicks during low speed turns and the stick/drag at the center of the steering wheel position is gone. Unfortunately there is still a rattlyness about the front suspension over some rough roads, but I guess that's the way the Maxx is built.
The fix earned the Maxx a reward of a new set of Goodyear TripleTreads (TT). Initial impressions are the tires are not harsh, but a bit stiffer than the Bridgestone Invictas the car was wearing, so there is more road feel. The tires also seem to help traction and squeal less. Once the rain storms hit S. Calif I'll advise how the TT's handle in the rain.
After complaining over a year ago that my 04 Maxx LS would sometimes require me to practically stand on the brake pedal in order to disengage the cruise, I gradually learned to live with the problem. I wasn't taking too many long trips, so I didn't press the issue with the dealer.
Then, this fall, the cruise would occasionally quit for no reason. Other times, it would not engage unless I pressed the Set button 2 or 3 times. This problem disappeared for a while, but then it returned -- requiring me to press the button as many as 10 or 12 times.
That problem morphed into another one: The tap accelerate/decelerate function would quit working. If I pressed the "-" button to slow down, there would be no response. Ditto with the "+" button. The car would just keep going at the preset speed. (This is getting scary). Or, sometimes I'd press "+" or "-" and the cruise would just quit.
Now the cruise is completely dead. (Naturally, it died while I was on a 600 mile trip). What is going to be really aggravating about trying to get this fixed is that this erratic behavior shows up only after the car has been driven at least 100 miles or so. How will the dealer be able to duplicate the problem? Has anyone else had this same problem? :confuse:
Thanks in advance for any advice.
As a side note, a number of my Maxx's "push" switches like mirror controls now need much more pressure to make contact. I suspect the switch surfaces are oxidizing
I'd be happy to pay GM a little more for better connectors and switch surfaces within its vehicle wiring. Most Japanese cars already do this, and their electrical problems are far, far less than GMs'.
My first post here. After a serious accident which totalled my car (miraculously, I wasn't hurt), safety is high on my list for a new car. So I boght a malibu 2005 LT in a hurry mainly because of the IIHS ratings. But am now wondering if I made the right decision after researching more.
It seems that steering wheel can lock up causing loss of control of the vehicle. Especially on 2004 models. There are also several consumer complaints about the steering problems for 2005 models at www.mycarstats.com.
There was a post( msg #2780) about the clunking and poping issue which claimed that the issue is for malibu 2004 through 2006. Is this steering column clunking and popping? It seems that the steering failure often comes after clunking and popping noises in the steering column.
The problems with the car so far are:
1. wiper fluid does not come out when the car was right off the lot: fixed. Connector loose?
2. Brake pedal switch does not work: Fixed. connector loose.
The car was built on Aug. 2004 and has been sitting on the lot for a year. Could that be the reason that the connectors are loose?
3. It happened on one occastion: In a parking lot maneuver at very low speed. I noticed that the steering was heavy when the wheel is turned fully right. I could not reproduce it since.
Is there a TSB covering this? Would this lead to steering wheel lockup? You can tell I am a bit freaked out but I just don't feel safe after reading all these steering wheel lockup problems.
4. At highway speed, 120 km/h, 75 miles/h, I felt the gas pedal ( and probably the car) is vibrating. Some posts suggest that it could be flat spot on the tire. Would reblance the tire help?
The last 7 digits of my VIN is F139364, it is built in Aug, 2004. What issues this built may be prone to?
hhmax
My Maxx has been in the shop 6 times for this complaint most of the time they tell me that they "can not duplicate the problem". On my fourth visit the tech witnessed the problem but because it wasn't popping any codes on their dx equip. He said there was nothing he could do because according to their machine there was nothing to fix. He recommended that I not top off my gas when refueling because by doing so, over-fueling would cause the engine to shut down for safety reasons. Well that sounds great and safe but my car would present this problem whether I had just filled it up, had a half a tank of gas, or when I was low on fuel. It didn't seem to make a difference.
My 5th and 6th visit was at a new Chevy dealer. On the 5th I was told that they could not duplicate the problem and the 6th I spoke with the lead tech not only about my starting issue but also a steering issue (ticking and clunking noise). He turned the key and guess what, yup it cranked and cranked and cranked and eventually it started. His response was, " that's the way it was designed". He said that when the engine shuts off that there is a sensor, a crank position sensor, that needs to line up properly and if it doesn't the engine will keep turning until it lines this sensor up and then it will fire.
Well I understand what he is saying but it doesn't seem right to me that this would happen several times a month. Seems to be something wrong. So long story short still working on getting some answers. My bestfriends bought the same car the same day and they have the same problem. Anyone else having this problem with their Maxx?
Thanks for taking the time to read.
E2helper will probably mention there was one software update in early 2004. You may want to ask your dealer if you have the latest PCM update? Does not totally fix the problem but it is supposed to help...
hate to hear of these issues...and feel sympathetic for those with the hassles......but I do like this car.....and so far..knock on wood....as with any other car.....it is holding up well approaching its completion of second year of ownership with me....just my two cents worth
I've noted dramatic reduction in noise and clunking now that the rack/pinon has been replaced. Car drives almost as well as when brand new (before all those problems showed up). The new Goodyear TripleTreads do add a little harshness to the ride but make up for it with much better traction and braking.
"...but I do like this car..."
I like my car too. However, I'm losing confidence in it. I still haven't sold my '94 Sundance because I think I may NEED it yet.
If there is a real problem with the rack and pinion, then GM should just put out the lights and send everyone home because that is not new technology. I can tell you my first hybrid (or flying) car surely won't be from GM. Hopefully that next car won't be needed for eight more years.
Only about fourteen payments to go!
It's now within spec but due to a snow storm, road test could not be performed. Hopefully it was fixed. The dealer seemed to know what they are doing.
hhmax
The machine also can check the rim without the tire for runout--unevenness in roundness and the machine tells the technician where to put the tire on the rim to have the higher part of the tire fit to the lower part of the rim so that they can (partially) balance each other out.
Keith
The vibration definitely feels better especially the gas pedal to the point that I can live with. But the steering wheel vibration is still there. Now it can be felt at lower speed as well.
How do your malibus feel like at highway speed? Any vibration at all?
I didn't check if you're still low mileage, did the dealer check and trim the alignment?
I reread TSB. It says cross camber should be set to -0.50 to -0.75 degress to resolve left lead. My cross camber is +0.2 degrees. Cross camber is left camber reading minus right camber reading. Will have dealer check this again on next visit.
Recently I'm having issues with my 2004 New Style Malibu, the automatic start is going off by it self when I turn off the engine, can some one help with this issue?
Do you have remote starter option on your vehicle?
Is your vehicle a sedan body style and a very, very early build of 2004 model? Build month prior to Dec 2003? If you do you have the earliest 2004 Malibu I think I have come across on forum so far.
In any case take your vehicle to the dealer - they will likely replace the Remote Keyless Receiver (which most probably is the issue) and also fobs with revised parts. Remind them they can access module from trunk through a hole in rear shelf panel and don't have to remove rear seat and trim to get at module - service procedure was recently changed to reflect this and don't know how many dealers already figured this out on their own BTW your old fobs would still work with new module maybe you could get them to program them as well so you have a few spares although the newer ones have some improvements in them.
If they have a problem diagnosing tell them to look up document #1708401 in their Service Information system for troubleshooting assistance.
