Auto trans VS. Standard
and down while you (with the torque of that diesel) will want to have more control over the shifts. On hills, you may want to engine break, easier with manual. Another consideration - Ask what percentage of big rigs use autos and why that is - next to none.
Serious damage can occur if one doesn't have the skill of driving stick while towing. An auto can ease the greeness of a driver if towing infrequently.
There are big rigs out there with automatics. today's engineering has really raised the bar, and you can safely tow with automatics more so than you could a few years ago. the only issue is making sure you are geared correctly.
i think the Cummins in the Dodge is geared pretty darn good where it should never downshift.
I agree that the original poster is hauling some serious weight--where stick is better. However, since he asked the question, I doubt he's expierenced. Driving stick empty compared to towing 17g under the manual is a whole different ballgame.
cdean,
Does Mack still offer their autos? As I recall they were only five speeds......
Thanks again for all your input.
Does it have to be a Dodge?
- Tim
On the other hand they rate the engine at a little higher torque with the manual than the auto. This is on new models anyway. So you win some and loose some. I would think the auto is up to the job.
Its not so much the dodge I want its the cummins engine thats in it. Too bad I cant put the cummins in the Ford, in my opinion that would be the perfect truck: F450 with a cummins TD.
Robert.
The powerstroke is a close second.
And even though I am a GM fan...I will never say the current 6.5 GM diesel is great.
Now with the Duramax on the horizon and the Allison tranny behind it....
THAT will be the king combo...period.
You could wait for a used one of those....but you probably don't want to wait that long.
Good luck anyway.
- Tim
You are 101% right about the new Duramax, but I bet it's going to be a while before you can even buy a new one, I bet ever since they released the specs on the truck they already have so many sold orders that it's going to be a while before you can just go to a lot and pick and choose from what they have in stock. Remember when the Durango came out it was the same way, now every dealer has a handful of them.
Robert
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
