That's why we have choices.
I didn't say the CTS was necessarily better. I said the BTS and Zephyr are more similar products. The CTS is bigger, RWD and offers a V8...like the lameduck LS does.
Choices are good. That's another thing that turned me off of Acura (I know - this isn't the Acura forum). I don't like their current move of "all or nothing." I could have, but didn't want to, spend as much $$ as the TL was asking. Perhaps if they had stuck to the "basic" model and saved the high output motor, the bluetooth-enabled radio, upgraded suspension, etc. for a Type-S variant, they might have had my business. Choices are good.
Also what do you guys think of this article:
Lincoln Zephyr Sales Surpass Targets, Win Back Import Buyers
(DEARBORN, MI) FusionUnleashed.com - Sales of the new Lincoln Zephyr are soaring.
"They're hotter than a firecracker," said John Moroni, owner of Westgate Lincoln Mercury of Lombard, Ill., near Chicago. "We can't keep them in stock. Every one we get is sold."
Zephyr sales are surpassing company expectations.
http://www.fusionunleashed.com/index.php?categoryid=9&p2_articleid=91
What Ford won't do is produce the concept car body, stop making it in "dune pearl" for the geezers and stop dealers from installing landau tops on them.
Don't see any TL's with Landau tops in an old fogey brown color with pinstripes. Give up Lincoln. I was going to give you a shot but you're just too old in image at this point. Produce the concept exterior with 20 inch rims and I'll come right over.
Here is a good review of the Zephr
http://www.theautochannel.com/news/2006/04/09/003548.html
What will you be driving when YOU are a "geezer". Hopefully you will make it to the "geezer" part of the lifecycle. If you dont like the car or image that is fine, but dont degrade the people that do. The "geezers" you speak about are the reason that you can pick and choose as you do and enjoy life in the America
:mad:
#754 of 1052 HP by akirby United States of America Feb 09, 2006 (1:06 pm)
Bookmark | Reply | E-mail Msg
Why are you guys assuming the final engine will only put out 250 hp? Remember the current 3.0L? It was rated at a wimpy 210 hp in the pre-production literature, but ended up at 221 hp by the time it hit production. Remember the Ford GT? Rated at 500 but actually hit 550 in production. The Mustang GT is advertised at 300 hp but tests are showing it's really putting out around 320. I think the 2007 models will actually be advertised at 320.
Actual output will be at least 260, maybe higher. On top of that it will be PZEV compliant which the competition can't match. It should also have a better torque curve.
When the final numbers are released and real world test results are available and it seems underpowered THEN you can gripe about it. Right now I think it's much ado about nothing.
After all, those product planners know best, right?
BTW; I'm still waiting for that list of cars that have been renamed 6 months after introduction.
I'll give you that the MTZ should do a lot better (if the production is there) with 265 hp and AWD option. But adding some knockout styling as well could make a huge difference. But that's not realistically possible for years.
Maybe the MKX will take off like the Navigator originally did. After all, the Nav wasn't that much different visually from its Ford counterpart. Lincoln needs a "winner" to get more people into its showrooms. One hot model can boost sales of other models sometimes.
This is exactly what ford needs right now. Its cars needs this kind of power. Now the question is, will ford take the 3.5, and put it in the fusion/Milan with 250/260 or so horses?
This would be awesome. GM's 3.6 can apparently do up to 270, but 265 is not far off. Although toyota does still lead, its only with the lexuz 3.5 with 300hp. That's okay b/c at 265, I'm sure ford will sooner or later add Direct Injection and knock everyone out of the market.
This is a really good sign for Ford, and for the future of US Mfg in general. I truly hope ford keeps the qualit together and meybe America still has some fight left in her.
Next step, of course, is to shift production back to the US... but 1 step at a time.
That is SO true! Same on Websites. We buy the cars, not the assembly line workers or the CEOs. Iacocca started this trend back in the 80's, with his "I did it my way" ads,and they sold. But hell, you wouldn't WANT to show the K-cars, you're better off selling Iacocca, and he knew it.
I agree, but that doesn't happen overnight. The Zephyr has only been out for 6 months. It won't overtake the market leaders that quickly no matter what it looks like or how fast it goes. The Lexus ES350 is a 3rd or 4th generation car that's been around since 1992. Let's see what happens with the 2007 improvements before we pass judgement.
The good news is over 40% of Zephyr buyers are conquests and they're shifting flex assembly line production from Fusions/Milans to more Zephyrs to meet market demand.
That's 306 hp in the IS350 but only 277 lb/ft or torque, and that's a very expensive engine. The ES350 is only producing 272 hp in the standard version.
If you're willing to use expensive components, do a lot of expensive R&D and use premium fuel you can get a lot of hp out of any modern engine. Look at the M3/M5 engines. But the cost goes up exponentially.
Exactly what does "L" do in these transmissions? Presumably it does different things at different speeds. Specifically, if I am driving down a mountain road at 45 MPH and want some engine braking, will "L" simply lock out overdrive or does it go lower? Does it keep downshifting if I slow down more? If I take off from a dead stop in "L" will it upshift at all - and to what gears? Does "L" upshift and downshift within the lower gear ranges - such as 1st through 5th - depending upon the speed and throttle position?
I reviewed the Zephyr manual and it didn't tell me much. Any idea where I can learn more about the functionality of the 6 speed automatic and it's D-L shifter? I will need to rent a Five-Hundred 6 speed and try it myself but any comments would be appreciated.
Conventional, even bland. Oh come on, Lexus is the greatest luxury car in the world. They've never been bland. I mean there cars have never looked like anybody else's car (Mercedes Benz). Lexus's designs have always been revolutionary I mean absolutely ground breaking in ever generation. How could you say that. OK, sarcasm off
PS
Just kidding
:P
So, ANT, what does my former Navigator now compete with? The Denali? You're conceding that the Escalade is better?
Having had both, I still don't think so, other than the hp, which is not relevant to most of us - the Navigator has plenty of power even if the Caddy will outrun it.
http://www.maximum-cars.com/Cars/CarPicDisplay.php?carnumber=632&pictureID=2&pic- index=1
What's the thinking behind Ford showing off prototypes that look so good and then either never making them (Adrenaline, Lightning, Continental, Mark X) or finally producing a car that is a pale caricature of what they teased us with, which only disappoints anyone who was paying attention.
How is it that other manufacturers can actually deliver what they promise?
Has anyone in Dearborn ever heard of "under-promise and over-deliver"?
In short, I need a push to trade in my ES for the Z.
It sounds like the MKZ might be tuned a bit more toward handling than the Zephyr.
There is nothing wrong with making a 1960's type of interrior scheme. I just think it worked better in the Navigator where they had more room to play with.
the 1995 Es Has nothing on the Zephyr/MKZ. If you wait for the MKZ you will be officially 2 light years ahead of your Lexus.
Even the production facility at which this car is built is more advanced that the 95 ES. The only 1 issue that i could see you have is quality. HOWEVER, the Zephyr of today probably has better quality than the Lexus of 12 years ago. I am sure this car is a good choice to replace your lexus. The sound system alone would be worth it.
That was one of the criticisms so it's a good sign they're reacting so quickly. Sounds like they're moving back to the Fusion suspension tuning - which has been praised in every review.
Well, I agree with half of your statement - the Ford side of it. But GM has too many car guys? Who, Lutz, yes, and remember originally he worked for Ford before going to Chrysler. Waggoner? Maybe. That's two. If they have so many car guys, why are their cars so pathetic looking for the most part? Especially inside!
What I don't see is a plethora of new models coming on line in the next couple years, like Chrysler and GM have confirmed. The 500 needs a total re-skin, not just s new front end. The Fairlane needs to be here ASAP. Why show it, when its introduction was not imminent? Nothing at all is proposed for Mercury. Lincoln plans are nebulous. Where is the creativity? The Edge looks good now, but the redesigns of competing models makes it look awfully conservative. What the heck??? Move, guys, or you're done.
Well, evidently, you have a different yardstick than I do. Because I don't agree that the styling has improved that much. Do you seriously think the Lucerne has an interior worthy of the Buick Flagship? I don't. Do you think the new Impala has a quality look to their dash? Cause I sure don't. Don't even get me stared on Pontiac... a line that should just go away, IMO. Cadillac is so bad on the interior quality, black flat plastic all over the place, it's not in the league with other cars in that price bracket. Plood and satin nickle plastic in lieu of chrome (ah, the old days) don't cut it for me. The interiors are the major gripe I have against the General. But, some people like 'em. They actually do.
