Tailgate lamp for pickups ?
Has anyone seen these.... or more importantly does anyone own a truck with one ? I have a 2003 dodge ram and recently saw a 2004 Ram with a tailgate lamp (or so it looked). I'm guessing this was a custom job, but figured I'd come to Edmunds and ask the experts. . . . if it's an aftermarket add on i'm very interested in buying one, however I'm even more curious as to how you would install and run the wires for something like this. If anyone has one let me know
Thanks in advance!
Thanks in advance!
There is a product called line of fire and its a brake light that you mount under the tailgate and it is a brake light. It runs the length of the tailgate
http://www.premiermotoring.net/cgi-bin/webc.cgi/st_main.html?cati- d=1130
The picture that shows the bar with the wiring attached fairly clearly reveals that the wiring connects with a standard flat four wire plug.
The wire looks to be long enough to reach back to behind the center of the bumper where the trailer connector is likely to be found hiding.
You would disconnect it there. Easier than removing the tailgate.
Thanks a lot!
