Hydrogen Fuel Cell Cars
Strange but true. And PETA is not the only environmental group blocking wind generation. For much of 2007, a company wanted to put in a 'wind farm' here in Montana. Certain groups of "environmentalists" fought it. The company tried to compromise by reducing the number of windmills by almost half. They were still met with conflict so the fall of 2007, they pulled out and took their project to California. One of the main arguments was that the windmills didn't 'look good' and "wrecked the look of the environment". I guess a coal-fired electric plant looks better.
There are over 100 planned coal-fired electric plants on the drawing board in the United States and if other energy sources are not created, they will be built (actually, they probably will be built anyway because of the energy demands of our country's populous). If people are concerned about pollution from vehicles, they should read into the coal-fired power plants for a real wake-up call on mass-pollution.
As for electric, I think Nukes are the way to go, as far as environment they are pretty clean, and we really haven't had any meltdowns at all.
-mike
The main problem is there is not enough raw material to run that many nuclear power plants. If all the coal powerplants were somehow immediately replaced with with nuclear, the raw material would be spent in a few years. Though I did recently read about new technology that gets more energy out of the raw materials, so technology might stretch that out, but it's not a renewable resource and has a finite supply. Definitely not the ingredients of a long term solution.
-mike
Ever hear of a breeder reactor? Sufficient fuel is NOT a limiting factor in nuclear power.
Yes, nuclear would be, and is, a great short term solution, but my other point was that there is a finite supply. We would be exchanging one finite natural resource (dead dinosaurs) for another (a mined product). I agree with the switch. It's the best non-coal choice we currently have. I was just pointing out it is not a good long term solution because of the finite supply. It is not a renewable resource like solar, wind, water turbine, etc. So regarding nuclear, maybe the "Don't worry. It will never run out" attitude isn't the best. I seem to recall when people thought we'd never run out of oil either and now we've long sinced peaked globally and are on the decline (though a lot of people don't seem to want to accept that either).
-mike
http://www.energyempire.com/hafc.html
-mike
Said the salesman..
Please provide any test results from a recognized test lab. Otherwise, this is clearly a scam. None of the text in the web site makes any engineering sense.
I'm looking at one of these to test out on my 1990 240sx that has 250k miles. I figure if it blows up, then nothing lost.
-mike
Motorsports and Modifications Host
MODERATOR /ADMINISTRATOR
Review your vehicle
What better way to attract customers? No way to test anything at a show. It's simple-provide us with external test lab results, or be considered a scam.
There are 2000 dealers and distrubuters under them
Now it's clearer - it's a scam combined with multi-level marketing - genius!
http://water4gas.com/2books.htm?hop=br58com
I just built 2 HAFC's out of (2) 1 quart mason jars (coiled stainless steel wire and Distilled water w/ baking soda) installed them in my 99 Lincoln continentel . I was getting 21.6 mpg, according to the average mpg display. I am going to monitor the mpg for the next month to see if there is any difference.
But I think it is going to be better, because the display on the dash is now reading 27.2 mpg and climbing every time I drive the car at a constant 60-65 mpg. I am very skeptical of this, but I have to try it. It used be a steady 21.6 mpg.
I realize it takes energy to crack the hydrogen from the water (1.2 amps at 12 VDC) , and the energy comes from the battery. But the energy that is stored in the battery has to come from the gererator, which uses energy from the engine. So the energy depleted from the engine turning the alternator is producing that energy.
My question is: Why am I getting 5 more mpg (and climbing) than I was before I installed these 2 mason jars (with distilled water and baking soda that have 2 stainless steel electrodes immersed in the water). It must be magic!!
Some possibe reasons:
1-You're driving carefully, getting better mileage in spite of useless device
2-You aren't, you're just advertising
3-It's magic!
AS a heavy commuter I am looking for a way to save on my gas bill.
-mike
-mike
1. Does it contain previous scams? YES Your system (and I think you're selling this stuff, right?) has several elements (magnets, etc.) previously proven to be worthless scams.
2. Does it use meaningless mumbo-jumbo to appear legitimate? YES What is 'hho' that you keep talking about? Water? Why not say so? Of course, water's no benefit to an engine or combustion, is it?
3. Does it seem to be too good to be true? BIG YES You guys went too far, claiming doubling mileage, etc. That set off every BS meter on the planet. If it actually did this, it would be worth tens of billions of dollars to every car make on the planet, and the EPA and DOE would be beating down your door for information. You would seem to hold the keys to the world's energy crisis. Nobel Prize material, even! Any of this happening?
-mike
We shall see come spring if I actually go through with this on my 1990 240sx. As I said I will report back with a detailed log of milage etc.
-mike
-mike
The researchers then switched the fuel injection process to the PICC Modification and ran the engine under the exact same conditions for another hour. Now, the engine used only 2 pounds of fuel instead of 18 — an increase in efficiency of 9x. In other words, the vehicle traveling at 65 mph up a 30 degree incline for an hour would have obtained almost 200 mpg! When they shut off the engine, the researchers reported that it coasted on the plasma for another two minutes.
For more info go to 2xmpg.info
Isn't this blatant advertising? Something not allowed?
On the other hand, if coffeedrunk would like to set up a blog on his CarSpace page about this, that's perfectly fine. Then you can all go there and comennt on it without running into the forum rules.
That would be fine. All this falls more under "Gas saving gadgets and gizmos" anyway, nothing to do with hydrogen fuel cells.
I put a small 1 qt mason jar w/ 2 stainless electrodes connected to the battery thru a sw.I had distilled water in it and baking soda (about 3 tablespoons). a 3/8" tube was installed between the top of the jar and a hole drilled in the plenum between the air filter and intake manifold.
After 3 full tanks of gas and normal driving, I have only had a 3 mpg increase, not the 6 that the dashboard display was indicating. I am working on my next HAFC,(hydrogen assist fuel cell) to produce 3 times the volume (cfm) of gas that the current one produces, and it will also have lye instead of baking soda. I'm hoping for better results, and will be installing a PICC on my Taurus next.
“The BMW Hydrogen 7’s emissions were only a fraction of SULEV level, making it one of the lowest emitting combustion engine vehicles that have been manufactured,” said Thomas Wallner, a mechanical engineer who leads Argonne’s hydrogen vehicle testing activities. “Moreover, the car’s engine actively cleans the air. Argonne’s testing shows that the Hydrogen 7’s 12-cylinder engine actually shows emissions levels that, for certain components, are cleaner than the ambient air that comes into the car’s engine.”
It was not an easy task to measure the Hydrogen 7’s emissions. “A gross polluter is easy to measure, but the cleaner the car the harder it is to test,” said Don Hillebrand, director of Argonne’s Center for Transportation Research. “Most labs test at the SULEV level. Argonne’s vehicle testing facilities are unique in that they are ab
p.s. - I think BMW has the right idea, IC instead of the yet-to-be-proved economic fuel cells.
There are no forums for "hydrogen cars" so I guess this was still the place for it, even with the lack of a fuel cell system.
