Visitor Agreement.
Ford V10 275 HP 410 Ft Pounds
Dodge V10 310 HP 450 Ft Pounds(10 less of each for rwd 2500)
and as I have said before remember that the Dodge came out in 1994 the Ford in '98.
Ford = 310 H.P. 425 lbs. torque.
Dodge = -10 in California also.
Yeah you Ford30/Dodge20....run home to mommy, eh? .....pretty lame to claim Chevy copied anything from Dodge....
You and Truck Trend should compare apples to apples. sure the F350 will outpull the Silvo 2500, the Silverado 2500 biggest engine is 50 cubes smaller than the 2500's.
You are comparing Ford's biggest engine to Chevy's medium engine.
either use GM's 454 or Fords 5.4 for comparisons. otherwise, its hooey.
Chevy's HD line is in transition stages right now...and will soon be one line....instead of 2.
- Tim
You're still comparing the wrong ones!! The 2500 Silverado is LIGHT DUTY! biggest available engine is 6.0. Chevy makes a different 3/4 ton. The C/K.
At the time of your quoted argument, it was possible to get a C/K series truck (NOT SILVERADO) and get 454 or 6.5 diesel in 3/4 ton.
THAT would have been a fair comparison.
In September, the NEW GM heavy duties will be out. 3/4 and one ton trucks will get the 6.0 as a base engine, with upgrades to 8.1 gas, and 6.6 diesel. THESE trucks will be equal to the Ford you quoted.
Most manufacturers now have very little diff between their heavy duty 3/4 and one ton trucks. frames are the same. but, you get totally different springs, different hubs, different tires. including Ford. thats a big difference to me. if not to you, thats fine.
I realize that, but Dodge is just being lazy. If they wanted kick Ford's into the netherworld when it comes it current engines they could and its another of my personal beliefs, that they will in the blink of an eye. The fact is that GM is behind the times, Ford is much better, but Dodge is the only manufacture who can among other things call their engines something that carries the weight of history like Magnum while others talk about nonsence like "Triton" and "Vortech". When you hear that name your mind goes not to engines, but the largest and most succesful and innovative Gunmaker in the history of the the world.
Smith & Wesson
As far as the torque of the Chevy trucks (5.3l), the new model Silverados only show the peak points. That does not at all mean that it has no torque until the peak. The torque curve is only about 15 lbs less than Ford (5.4l) at 1,200 rpm all the way to its peak at 4000 rpm. Flatter torque curve is more useful throughout the rpm range. The torque curve is higher than dodge up to about 2,200 rpm where Dodge starts to move up toward it's peak. I know a guy (here we go with the "I know a guy stories") who has a 2000 Ram with 5.9l, 3:55 gear diff. That thing has "sufficient" power below 55 mph, but get it out on the highway and it is constantly downshifting on the slightest hills, especially with cruise set. My Silverado never downshifts on the same hills with the cruise set. Tells me that HP "does" make a difference when towing at certain speeds and rpm.
Not saying any are better than the other. Depends on what you use it for. But the myth of the Silverados being undertorqued is just that, pure myth.
Been drinking? Where was your argument going? Are you stating that the "name" of the engine is of utmost importance when comparing them?? LOL!
BTW: Your argument of S&W is just as lame as your defense of Dodge. Ruger makes stronger guns and they don't sell out to Clinton and Brady.....
The test will be re-done with the new 8.1, I'm sure, and Ford better have something to compete or they'll be in trouble.
Lastly, the axles(Dana) hubs 8 lug, brakes etc. are the same on the Super Duties. The Silly 3/4 and 1 ton designations(I call them silly because both trucks will carry over 1 1/2 tons) are for spring rates(GVW) and dually configurations which are available on "1 ton" and not "3/4" ton trucks. The single rear wheel is also available on the 1 ton and I think some different cab/bed variation separate the two. Otherwise they are the same trucks.
Hence the thicker top straps on Rugers. Sorry guys, but I love my Smiths. Let the banter resume......
Modv
I understand what you're saying, and we just look at it differently. Maybe i've just heaped you in with everyone else that instantly compared the 6.0 to the v10, because thats whats out right now. when the 6.0 came out, everyone forgot about the 454, even though THAT IS Chevy's big block right now.
GM has been planning the 4.8 -> 5.3 -> 6.0 -> 8.1 engine progression for years. right now the 454 goes in the last spot.
if you want to discount that fact, then it slopes the field heavily in your favor, cuz 6.0 isn't meant to do big block work.
Oh, and I will pit my lameduck one ton with 350 and 4.10 gears against any other truck. with midsize v-8 or course.
Varmints beware!
S&W is a fine gun maker owned by scared Brits which are giving a true disservice to all makers. I sold my last smith yesterday. I want no part of them.
Second, I follow Jeff Cooper's beliefs that if left with only one double-action, it would be a Ruger. They may be cast(not all) but that frame is still overkill which I admittedly like the looks of.
Sorry folks....back to the subject!
Roc
Not selling my S&W 586 revolver, no matter what Cooper says. It's a tack driver with the best trigger in shooting. Was sorry to hear they are foreign owned. It figures.
Harry
Later: 220
But they also said that GMC Sierra pickup would be getting the 6.0! C-series. Apparently, that means the half ton. But said nothing about Chevrolet.
My opinion: GMC sales have not been boosted by the new model like Chevrolets were. looks like they are going to offer the 6.0 into GMC to get some sales boosted. offering in GMC only shouldn't hurt their CAFE too much since Chevy outsells GMC about 5 to 1 right now. Looks like marketing/sales trick.
- Tim
- Tim
Only problem is that front end grill on the GMC...almost as ugly as a Ford 150.
Trucks are not for performance...
- Tim
Drove a friend's '00 Camaro SS. Felt like I was sitting in a coffin. Plus passenger legroom was nonexistant with large bulge on floor for catalytic converter. Also drove another friend's '00 Vette...If I had to drive a coffin...this would be the one.
If the T/A had better seats....my wife would have one in the garage..
GRRRRRRR
I was going to mention the vette...but we are talking a different ballpark of moooolah there.
- Tim
Once raced and won against an older vette, while towing my motorcycle. The 350 LT1 was the genuine article.
- Tim
I love the F-Body.....but if I'm going to sit in a hole....it's gonna be a Vette.
...Course a WS-6 on the side might make you forget about the hole effect??
- Tim
- Tim
LOL
- Tim
What we do for love.....(least I think that's what is it??)
- Tim
