Visitor Agreement.
The Impala barely fits in my mothers garage as is!
I also hope they don't make it so big that it is bulky and not easy to fling around.
I just rented a Malibu Classic, the old style, and while the seat are horrendous and the steering kinda funky this car can fly. Its surprsingly fast, handles bumps very well, and is easy to drive.
However, due to interior design and poor seat comfort I think Chevy is better off killing the Classic and letting people rent the current model.
However, prior to buying this car, I test drove three others and two of the three had some wind noise. So, I guess it just depends on the particular car.
Interestingly, I also test drove a Buick Lucerne and it had some slight but not particularly onerous wind noise. The remainder of the overall cabin noise at cruising speeds was about the same as the Impala which I ended up buying.
Make sure you test more than one car and buy the one with the lowest wind noise.
Chevy has the car for 2 days and decides nothing is wrong and fixes nothing.
2 days for an oil change and nothing else.
Im not a happy camper and I believe I will be buying a mazda 3, not a cobalt.
Silicone Grease will do a real good job of conditioning rubber, without causing any damage. I'm sure that the combination of softening the seals with silicone, and letting them get good and hot, helped form them to the metal better, and seems to have helped seal the car up nicely.
The car was built in May of this year and could be the last of the 06 run.I wonder if GM reads these forums and came up with fixes or did I just get lucky?
2006 Impala SS
Sport Red Metallic
Every Option
I have read posts in these forums regarding the clicking dash that appeared to have been written by someone in the maintenance or quality control fields at Chevy or GM so I think at least SOME of what we write about is getting through.
Aside from that, a lot of us complained about the Bose stereos here and at the dealers and corporate phone lines. I think the key is to let them know in force that we want issues addressed. Along with that comes the responsibility to be fair and reasonable. So far, it seems the participants in this forum get that and so does GM. Some of the dealerships/service reps may still need some work, though.
Good to hear you are happy with your new SS. I love mine as well.
what state did u purchase your vehicle in, when i was at the dealer getting survice there was someone there getting an ss same color and everything and i was wondering if it was you....small world!
The retailer sold me a 4-way car end #30503 and told me to hook up this wiring color to color on my Impala, but unfortunately I was unsuccessful in locating these wires. Can someone help me with this wiring please? thank You!
Do you know of any fixes or TSB's?
Hopefully Chevy has corrected on their 2007 Impalas many of the issues that people are having with their 2006 cars.
The value is a relationship of how many times the tire rotates in a mile to how many times the sensor (old type spedo cable) rotates for a mile. It's done by gearing, 5, 6, 7, 8 gears on the output shaft of the transmisssion and 15, 16, 17, 18, 19, 20 or 21 teeth on the sensor.
Tire rotation per mile is multiplied by the final drive ratio times the gear on the ouptut shaft divided by the teeth of the sensor gear.
The trick is to get that mathmatical number to come as close to 1000 (one thousand) as possible with 4% being an accepted error factor.
Russ
According to my service manager there is nothing wrong with the car, even things I know are wrong with the car. They are minor things, such as the parking brake not holding the car very well, but when I brought the car in for this, the TSB on the clacking engine noise, and wind noise, they did absolutely nothing.
Oh, they did scratch the heck out the side of the previously pristine Impala. Luckily they did not just deny it, they managed to buff most of it out, but I was major pissed!
Your proper tire pressure will be listed on the inside of the drivers door, in the door jam somewhere.
I love my car too. Other than the remote range issue and my annoyance with the A/C defaulting to recirc, I have no complaints either.
It's probably the most photographed road trip.
I think it's next Tuesday they'll do the next part. (Yeah, I don't usually watch but the driving and the pop gossip stories caught my attention.
http://www.alldata.com/tsb/General-Motors/1155711600000_1157007600000_06-07-30-0- 18/index.html
Does anyone know how to tighten the bolts holding the front of the seat rails/tracks down to the floor? They do not have exposed heads (the back bolts do) and I need to try and tighten my driver's side right seat rail at the front of the rail. My seat is creaking horribly when I lean back into the seat. If I hold the seat bottom down and then lean into the seatback, the creaking stops leading me to believe the rail needs to be tightened.
The dealer tried to fix the issue by lubing the seat rails. Yeah, that was a brilliant attempt.
Any help would be greatly appreciated.
However, Edmunds says that all 2006 Impalas have Onstar. Since it's not on the mirror, is it accessible through some other control mechanism?
