The I6 will be easily a 400,000 mile engine, the V6 is a 200,000 at best..
The '06 is your last chance to get the better engine IMHO... as for the 7spd.. sure it's better, but not enough to offset the loss of the I6.
- When I start up and place the car in reverse, it feels like th brakes are setting up or something . making nose almost like a chatter then they are fine .....
- The transmission delays going into drive first thing in the am or when I go from reverse to drive
- Coming to a stop, the transmission does not downshift smooth and it feels like the brakes are not going to stop the car ... It takes more pressure than it should ...... Otherwise a fantastic car .
Will be making an appointment to take it in shortly ........ Also, anyone have Satellite in their car in their car >>> If so, who installed it ........
Thank You
M
I'm sure this is your problem, Let me know if this helps
MODERATOR /ADMINISTRATOR
Review your vehicle
M
Frank
Currently driving an Audi A6 wagon, fully loaded. The thing I am most hooked on is Parktronic. I find I don't use the Nav so much- is cumbersome, although there have been a few times when it has been absolutely great to have. Am curious what people are thinking about the MBZ nav system: do you use it? One person mentioned the system had too many layers to easily enjoy. Others? Anyone using the Sirius satellite radio?
Also, my 4 day per week commute is 2 miles each way. Has me concerned. Thoughts? (I know, it SUCKS to only have a 5 minute drive to work in such a beautiful auto!!)
Does anyone else have strong pro or con feelings about the panorama roof? Upholstery color- does the lighter (stone) show dirt very quickly?
Thank you- I await your comments with anticipation!
