Acura RDX
1333436383955
    I agree with you on the intrusion of the noise, though not on the quality. I confess to having little experience with turbos, but I found the reduced whine from the RDX preferable to the higher pitched noise from others.
    The RDX actually reminded me of the Murano I drove a few years back. It's been too long to make a direct comparison, but the Murano's VQ has a raspy and coarse engine note. Under hard acceleration, the RDX's K23 was similar.
  • upstatedocupstatedoc Member Posts: 710
    These guys obviously push this car farther than any owner would. That dyno reading is insane, 260-270 hp in awd mode, no wonder the RDX seemed like it was quicker than my 05' TL (w/ no torque steer).
  • c_hunterc_hunter Member Posts: 4,487
    You can tell this is no sports car by all the tire howling! Whether or not the RDX handles well, I'd be embarassed to make all that racket! I can push my S2K much harder than that and not hear a peep from the tires...
    If you watch the "underbody analysis" video, there are a lot of neat details -- it's worth a look. The narrator is no engineer though. Almost every time he labels his comments with "we'd like to see", it seemed like he was clueless about real-world engineering design...
    Well, they disconnected the rear driveshaft because they were on a 2-wheel dyno, so they didn't get realistic data. They really should have taken a litle extra time to locate a 4-wheel dyno (they are commonly used in the Subaru/Mitsu tuner scene). Without a true AWD reading, we have no idea what kind of losses exist in the rear drive system (about the best you can say is their numbers are optimistic). They measured 215HP at the front wheels, but real world is probably another 10-15HP down from that when driving all wheels.
    They seemed surprised at the minor difference with exhaust removed, but that's not surprising at all for a turbo motor -- the pressure drop across the turbo is significantly more than what you get from exhaust losses. The diminishing boost at higher RPM is also standard practice, in order to improve durability/reliability -- nothing surprising about that either. I suppose these Honda-guys are just not real familiar with turbos or AWD...
  • biscuit1941biscuit1941 Member Posts: 31
    I live in boontoolies, so do not have access to dealer except for rare trips to the "big cities." I currently have a pilot (lease) that I choose over highlander because of interior (read driver) room. The Pilot fits me perfect, but RDX data sounds interesting for my next car.
    How does the driver shoulder/leg/headroom compare to Pilot/MDX?
    Is the RDX in a smaller class? :confuse:
  • marleybarrmarleybarr Member Posts: 334
    Does the RDX have a sealed drive line system, or is regular service, i. e., grease jobs required like on the Lexus series?
    Yes, the RDX is smaller and the cockpit is much snugger than Pilot/MDX (which is not surprising since it's a much smaller vehicle). The RDX is similar to my Subaru Outback, which has always felt smaller than the Camry/Accord based platforms (which include Highlander/Pilot respectively).
    I don't know about the 07 CR-V/RDX pair, but in the past generations, the CR-V was based on the Civic platform.
    That tire howling may have been a "directors" enhancement (microphone within a wheelwell) so the audience would know (think..??) the turns were being taken "tightly".
  • robertsmxrobertsmx Member Posts: 5,525
    The idea wasn't to guess overall loss, it was to see how much the engine might be making, and based on their observation, RDX's motor seems to be underrated with 240 HP. That was the point being made. They all are aware that with AWD (all wheels engaged), greater losses are to be expected.
    And no, RDX is not to be confused for a sports car, not with those all-season and high profile rubber. The focus was more on handling, and it certainly appears to be quite impressive for the vehicle that it is.
  • bellorushabellorusha Member Posts: 10
    Did any body played with LCD on tech package? I see that they different in size (base-6.5" and tech -8") is there difference in use?
    Does the tech package LCD can show something else then GPS? like (what i dream about) Xm radio: Station NAme, Song Title, Singer and etc., mp3 information, AC info? Tech package has a sub display with on line, and all info I describe showing over there, but can it be displayed on main LCD? I just do not need GPS and hate to see GPS all the time.
    I went for another test drive today, and have a few more observations to share.
    The engine noise some people are asking about is definitely from the turbo. It's more of a petite "swish" than the "whoosh" I hear in my Outback XT, but it's there. I don't find it annoying at all -- I like the sound, and it's better than the whine you get with many turbo motors.
    I feel like the RDX is a bit weak off the line -- the combination of turbo lag and the relatively heavy curb weight work against forward progress at low RPMs. Once going it picks up just fine, but it lacks the low end "lunge "I am used to in my Outback XT.
    Handling and ride is very nice -- good balance between the two. I thought the front seats were excellent, but not as good as the ones in the Lexus RX350 I sat in a few minutes earlier (that is quite posh inside).
    The taupe interior seems a bit on the "cheap" side to me, but ebony looks fine. I saw a Silver/ebony model and it was real sharp -- exactly what I would choose. The Carbon/taupe model that I test drove just didn't look good. It had the optional 19" wheels, running boards, and the roof rack (the rack lists for $399, but the dealer tacked on $671 for the rack+install, which is obscene). Those options really emphasized the tall/stubby look of the RDX, and the overall effect was not good. About the only thing they could have done worse was tack on a vinyl landau roof!
    Craig
    Enjoyed reading your reviews, Craig. Why the 2nd drive? Where you at the dealer for service or something?
    RX seems so different to me in its mission, it's more Lexus ES than Lexus IS. Luxury, as opposed to Sport.
    X3 is pricey but don't forget the 4 years' free service plus the excellent resale value, in fact that's probably why lease rates are lower even with higher MSRP.
    varmint - did you switch VSA off? I think you waited so long for a test drive that you just got a bit too excited. :D
    I like the shaved bumpers and Acura's explanation about the lower plastic part, that makes fender benders less pricey to fix. We'll see if that holds up on the bumper basher tests CR and IIHS conducts.
    Dyno results were very good even for FWD. Loss is usually, what, 15-20% or so? So if it put down 215hp at the wheels then it's making at least 247hp. Interesting that on the road he felt it wasn't really pushing hard until 4000 rpm.
    I bet a manual trans would fix that plus the complaint about it not going to first above 28mph.
    -juice
  • bikerjohnbikerjohn Member Posts: 52
    I thought I would share with the group, the response I got from my local Acura dealer on the turbobash. All I wanted was to check out some more colors and go for a 2nd test drive. I wonder if Arnold will be there?
    "This is to acknowledge and thank you for your RSVP to our RDX turbobash party on this Wednesday, August 24. Our party will begin at 5:30 pm. In addition to the introduction of the all new 2007 RDX, you will have a chance to meet the elected officials from the City of Tustin and the State of
    California, members of Tustin Chamber of Commerce and enjoy a special performance by Miss Tustin and her court. Hors d'oeuvres will be served and valet parking will be provided.
    We look forward to seeing you at this wonderful event."
    Oops, looks like they made a mistake on the date. August 24th is a Thursday, not Wednesday. Hope all the officials show up on the right day!
  • jonnyinsacjonnyinsac Member Posts: 6
    I just took a trip from Sacramento to Gualala/The Sea Ranch on the Northern California coast. I was on the freeway from Sacramento to Petaluma, a two lane highway from Petaluma to Bodega Bay and up Highway 1 till I reached Gualala in Mendocino.
    Gas mileage on my 160 mile trip was 19.3 mpg. It takes about 3.5 hours to travel that distance. To my surprise on the way back (via the same route) I got 23.3 mpg and I wasn't trying to conserve.
    Overall the handling of the RDX was great on twisty roads. The car always had enough power no matter what hill I was on. Give it some gas and it would just go. I had my wife, two dogs and the back was full of luggage and two bar stools. I was impressed that it all fit.
    I also think the RDX is a blast to drive. I normally drive a 2005 4.4i BMW X5 (Sport Package with 19" rims) and I would prefer to drive the RDX as it feels much lighter on its feet, it is way less bumpy over rough roads and it is super zippy meaning it hauls. It feels like a car. By no means is it a drag racer from zero to 60, but it has plenty of power for around town.
    I do wish city gas mileage was better but if that were the case, I am sure it would have much less punch on the accelerator. For around town it is way too easy burn the gas but oh well... that is what makes it fun to drive.
    Was it uphill going, downhill coming back? :D
    That's a pretty big difference. Perhaps the ECU leaned out the fuel mix once it learned your driving style.
    -juice
    I was up the road getting my OB XT serviced, and conveniently, there are Acura and Lexus dealers down the block. Nothing new to test drive at the Subaru dealer, so I branched out a bit... I would consider the RDX for my next car, but right now it has a couple "utility" related shortfalls and the gas mileage is a bit low, so it's not a super-compelling vehicle to me. The Lexus RX hybrid, on the other hand, was sweet, but $47K is not realistic if I want to stay married!
    Craig
    There was more uphill on the way there but only on the last hour long stretch. Since that is Highway 1 that is possibly why it got such better mileage. I was at 22.6 mpg before I hit Interstate 80 where I saw the mileage jump to the final of 23.3 mpg, so I must have gotten better than the stated 23mpg on the highway doing 75 mpg. It was all flat.
    I assume you're using the car's trip computer to give you the mileage stats?
    Let us know what you measure at the pump, i.e. miles you travel/gallons used. Usually the trip computer is optimistic, at least from what I've observed.
    -juice
    And the pump is more accurate...!
    NOT...!
    Point of shut-off, pump-to-pump, station-to-station, seems totally random to me and accuracy will always be on the high side if human natures serves....
    They ALWAYS, within "tolerance", want to charge you for more than you pumped.
  • jrynnjrynn Member Posts: 162
    wwest,
    The NIST standard (adopted by the Weights & Measures departments of many states) requires that fuel delivery systems' deficiency be LESS than 5 fl.oz. per 10 gallons of fuel pumped. That's less than .0039062 of the total delivered volume/10 gallons.
    Despite your dim view of human nature and insinuation that service station owners routinely cheat customers, by manipulating gas pumps to deliver less than the indicated volume, albeit within "tolerances," ...
    if the fuel pump was tested and working within required tolerances, then the amount of gas the previous poster who noted an @4 mpg difference between his outbound trip and his return trip COULD NOT be explained by your theory.
  • carlitos92carlitos92 Member Posts: 458
    The bigger issue is when the pump decides the tank is "full." I admit that I don't know exactly how the pump shutoff works (pressure-related?) but even the same pump will not fill you up perfectly consistent every time... It's not a vendor cheat, just the tolerance of the machine that depends on a lot of different stuff - how the dispenser nozzle is seated in the inlet, among other things. It's probably splitting hairs, but going to the same gas station (even better, the same pump) every time will be a lot more accurate than a trip computer.
    So, when weights and measures shows up and tells the station manager:
    1. The customer is getting ~5 fl. oz of FREE gas for every 10 gallons pumped.
    2. For every 10 gallons pumped the customer is being shorted ~5 fl.oz.
    Which of those two will be more likely to get the station manager's attention?
    But I agree that the pump shut-off point would undoubtedly be the major "tolerance" issue.
  • vanhalenabevanhalenabe Member Posts: 20
    Hey everyone,
    Sorry for the long email, but I wanted to post my thoughts after seeing and recently driving the new RDX at the RDX Turbobash. I drove the car on Tuesday, August 22nd, at a Dallas dealership.
    I am currently in the market for a new, sporty SUV. My wife drives an Acura MDX owner and don't need another mid-size SUV with 3 row seating. 2 rows are fine, but I am looking for something with great performance and handling. My current car is a 2-door Mazda MX-6 with a 5-speed manual, and it is fun to drive. I just need a real backseat and some practicality with a growing family.
    The crossover SUV at the top of my list was the Infiniti FX35. Great handling vehicle and I LOVE the styling. However, the amount of features (at the price) left a lot to be desired.
    On paper, the RDX looked like a real winner. Even paying MSRP, it was cheaper than the FX (Sport & Touring package). For that price, it also came with a Navigation System, an iPod jack, Paddle Shifters, and a much better Stereo. The RDX looked pretty good, inside & out, from the brochure I had. We were also Acura owners, and had confidence the Acura brand.
    Unfortunately, I left the Acura dealership disappointed.
    First of all, the exterior look simply didn't do it for me. The "proportions" were off and so was the "stance". Hard to describe, but it just didn't look right to me. My wife didn't like it all.
    I was also disappointed with the interior. It looked good in pictures, but when you sit inside it feels a little cheaper than the Infiniti FX. Infiniti uses real aluminum for example. Flipping the 2nd row seats down was not as easy, as you have to first flip the lower half of the seat forward, before you can flip the seat back down. Otherwise, the 2nd row does not fold flat.
    The Stereo was great and the Nav with Traffic was cool. But the paddle shifters felt very cheap and plasticky to me -- like they would break easily.
    And to top it off, we got a "Brake Malfunction" warning message during the test drive. We were able to clear the message by turning the car on & off, but that was cause for concern. My wife and I are already wary of buying a car, ANY car, in its first year of production.
    The RDX is a brand new car from the ground up with a brand new engine, not an update of an existing car. When you check Edmunds, you will see that most cars (including Lexus) have more problems in their first year of production.
    But I was willing to take a chance on reliability, for the trade-off in extra features and gadgets. Ultimately, it was the mediocore exterior and interior styling that turned me off.
    Obviously, beauty is in the eye of the beholder and styling is very subjective. The dealership said they had sold 10 vehicles and had only delivered 2. Full price, MSRP. Plus a $595 "Protection Package". No room for discounting, and people are putting down deposits sight unseen. So, I have to admit this vehicle is popular out of the gate.
    But I can't get over the exterior and interior and am very disappointed. I wanted to like the RDX, but it has been crossed off my list.
  • phastphil1phastphil1 Member Posts: 24
    The nav screen can show audio screen info and trip computer as well a calendar and calculator screen.
    yet tried using the paddle shifters to downshift to use engine compression braking? With front wheel torque biasing I wonder if the RDX engine/transaxle control firmware will even let you do that.
    Or does it quickly move the bias to the rear and then downshift?
  • ts1234ts1234 Member Posts: 21
    Took a close up look of the RDX today, with all the hype and press the last two years I walked away disappointed.
    Ho Hum bland styling with inflated prices.
  • teledatageekteledatageek Member Posts: 23
    Interesting... I guess I should be careful what I wish for! My wife also drives an MDX (which used to be my car for two years). I got an FX35 in 2/05 and it's a great car. I've just been very unhappy with the crappy NAV system in the FX and so am thinking maybe the RDX should replace the FX. We'll see how my test drive goes.... But as someone else said, I could just get an external NAV.
    The other problem in my area is that the Acura dealer is 20 miles away, while every other dealer (including Infiniti) is within two miles from my office. Some weird rule about Honda and Acura dealerships being a certain distance apart apparently.
    Very good review, and I agree with most of your points. I like the exterior styling a lot from some angles, but from other angles it is downright ugly. The vehicle has an odd proportion that emphasizes a short length and tall height, so it looks squashed from some perspectives. Anything that emphasizes the height (such as the roof rack and running boards I saw installed on a dealer demo model) makes it worse.
    I am neutral on the interior, especially since it functions fine in my experience. The instrument cluster does look a bit cartoonish to me though. I thought the taupe interior looked plasticky, but black was better (perhaps the plasticky materials are less noticeable in black).
    Having to tumble the base of the rear seats before folding the seat backs is a hassle. I have had previous vehicles that were like this, and you lose valuable storage space in the rear seat footwells (good places for ski boots, hiking boots, small cooler, laptop case, etc). I never realized how much of a pain this was until my 05 Outback came with rear seatbacks that fold flat in a single step, with the seat base in place. It's a pity Acura couldn't do this on the RDX -- there is no reason not to.
    Craig
    Craig,
    Regarding the plasticky interior that I mentioned. That was specifically on the Taupe Interior. I normally don't like Black Interiors, but IMHO it looked better in the RDX.
    I also completely agree about the Running Boards. The Tech Model I drove was White Exterior\Taupe Interior and had Running Boards. The running boards really ruined the look.
    In the showroom they had a Black on Black model, with the 19" wheels that looked better. The black color tends to de-emphasize some of the odd angles and proportions of the car.
    But the price for 19" chrome wheels & tires -- $4600. Ouch. I figured about 2 grand for the 19" wheel upgrade, but not $4600!
    At this point, it's back to trying to get a good deal on a 2006 FX35, even if I have to wait until 2007 models come out. I will give up the tech features of Acura for the sake of better styling and interior quality with Infiniti. Just my opinion, of course. There is no doubt that many people really like the RDX, judging by initial sales.
    Abe
    You didn't comment at all on the test drive, though. Was it quick? Did you sense lag? How was the steering? Light? Good feedback? How was the ride/handling balance?
    -juice
    Is it just me or has anyone else noticed that strickly manual shifting is becoming extinct, moreso with FWD vehicles than otherwise?
    I was looking forward to the new RAV4 having a stick shift so it could be a TOAD but....Automatics only!
    Yep, I have noticed that too. Can't even buy certain Subaru Legacy and Outback trim models with a 5-spd manual now, including some "GT" models. Hard to believe.
    Yep, no more Subaru Legacy GT wagons with a manual.
    No more CR-V manuals at all.
    -juice
    Here in St. Paul, Mn. the HONDA and ACURA dealers are not even 1 mile apart.
    Juice,
    You are correct -- I did not comment on the test drive because I did not get enough drive time to write a fair opinion.
    On the day of the Turbobash, there were other customers waiting to take test drives. Therefore, we were only allowed to "drive around the block". Seriously, the test drive was 1-2 miles and involved no freeways and no opportunities to accelerate hard.
    On top of that, it started to heavily rain as soon as our drive started. When I switched places with the salesperson, we literally had to go under a covered garage or we would have been soaking wet. It was raining HARD.
    I thought it would have been a good test, to see the AWD system and how it would respond in the rain. But the salesperson would not allow us to drive very far, as others were waiting. His manager even called during our drive, wondering where the car was.
    The ride was pretty smooth, but I thought the brakes were a little "smushy". Maybe because of the rain or the "brake system warning" light that came on during the test drive. I cannot form a fair opinion on acceleration, handling, or even noise -- I couldn't even hear the engine because of the rain hitting the windows so hard.
    Abe
  • ncstewartncstewart Member Posts: 6
    Showed up promptly at my local Acura dealer's Turbobash yesterday at 5:30 pm...and was surprised that nobody had arrived before me. I guess I thought there would be a lot of people there before me. There were trays of sandwiches, cheese, crackers, etc. and a wine/beer stand (which I thought was odd if people were going to be test driving!)
    A salesman accompanied me on the test drive -- loved the feel of the car but was disappointed by what I perceived as real hesistation from takeoff, particularly when I gunned it. Now I might be a bit biased as my daily driver is a 4.6L V8 Ford Explorer, but I had understood Acura had addressed turbo lag. Guess I need another test drive at some point.
    Apart from that, the sound system blew me away, the fit/finish is absolutely top-notch, and....well, it's my top contender for about a year from now when I can negotiate on price.
    Neil
  • rcizmercizme Member Posts: 16
    Keep in mind that vehicles with traction / stability control set "on" will have a "hesitation" when coming off the line. I guess the feature takes a moment to distribute power to the wheels in an effort to keep them from spinning? Turn off the feature and there is often a noticeable difference in takeoff response.
    It's turbo lag, plain and simple. There's not much chance of a turbo four-cylinder with an automatic spinning 18" wheels on a 4,000-lb car. UNLESS... you are really, really trying - and salespeople frown on that. :shades:
    Yeah, I agree the RDX has significant lag. And it's surprising since they use a variable nozzle turbo which should have alleviated this quite a bit. Even with the VNT, the RDX has noticeably more lag that the turbo-H4 in my Outback XT (and that does not employ VNT). So I was kind of disappointed about that aspect of the RDX. With the mediocre gas mileage and turbo lag, I find myself questioning the engine choice.
    Craig
    If, when, you suddenly go WOT and if the engine torque at that particular moment happens to be primarily to the front the stability/traction system may very well delay the onset of significant torque development by the engine to allow time to "reallocate" torque to the rear (drive both left and right rear clutches into full engagement) and thereby prevent incidents of loss of directional control due to front wheelspin.
    Better than what Cadillac had to do with FWD and their NorthStar engine. Heavy, HEAVY dethrottling at WOT from a standing start to prevent loss of control by a bunch of slow reaction time old codgers, blue hairs.
    Maybe in some situations, but I still say that from idle, the mechanism that is preventing the "onset of signigicant torque development" is the fact that it's a small-displacement, low-compression four-cylinder engine. Honda/Acura had the right idea, but obviously the variable nozzle hasn't rid the RDX of all the turbo bugaboos. FWIW, the CX-7 with its direct injection and higher compression ratio hasn't solved the problem completely, either.
    At least in Subarus, the AWD system and stability control system reacts in a matter of milliseconds. I would expect the same in the RDX. Turbo lag is longer and more noticeable.
    I don't think an electronic system can hold back on engine torque/HP without either retarding spark or throttle (common methods for rev limiters) and that would definitely put a dent in the RPMs. I didn't detect any of that with the RDX. The RPMs were always going up smoothly, but the engine was noticeably weaker down low. It seems like classic turbo lag. It was normal easy driving, certainly not a situation where I would expect drastic intervention from AWD or stability control!
    But I guess whether it's turbo lag or the limitations of a FWD-biased drivetrain, we are noticing that the RDX is a little gutless down low. Surely something Acura could improve on. My wife's TSX is a bit weak down low, but the transition to higher RPMs is not so abrupt, hence you don't perceive an off/on power delivery like a turbo engine.
    Craig
    With DBW the firmware designers can do what they damn well please with the throttle valve regardless of your input.
    "With DBW the firmware designers can do what they damn well please with the throttle valve regardless of your input."
    I don't think anyone is disputing that. But what firmware designers can not do (and DID not do on the RDX) is completely overcome the physics of a small engine. I own two turbo four-cylinders right now, and have driven countless others in varying states of tune. Unless Acura purposely designed in hesitation from a standstill in the throttle map :confuse: (what the original post referred to), it's turbo lag that the RDX has. Is it a deal-breaker? Probably not - it's still a great CUV. But to pretend Acura got it perfect with the VNT on the first attempt is denial.
    -c92
    Yeah, that's my thinking as well. This implementation of the VNT is really not any better than other fixed geometry turbos I have owned/driven, and may actually be worse!
    Craig
    And it cannot, for certain, be the result of both...?
    Not by any means disputing turbo lag as a significant source of the "off the line" torque delay, but can we be sure some level of throttle delay isn't "hidden" in there somewhere?
    IMMHO it can be exceedingly dangerous to allow an unwitting owner (certainly enough of those available) to suddenly apply ~240 HP to just the front tires' contact patch when the ability to apportion some of that, a significantly high amount, to the rear tires is possible.
  • traveler7traveler7 Member Posts: 1
    I have driven Hondas for the past 10 years. My 2000 CRV SE stayed in the family with my daughter. The new CRV is not out til October. The Rav4s available seemed, well, like a Rav4. I wanted the same size as my CRV, but the Rav4 didn't seem worth the price and didn't have the features I wanted. I found the RDX on line, called the dealer, put my name on one and picked it up a week ago. Base model. Used the savings to extend the warranty to 100K and add mud flaps, side molding and pin stripe. First tank 22 mpg. Plan to drive it for the next 10 years.
    Okay, okay... so no, we can't be certain about how the Acura guys really set up their throttle map. But my point all along has been that there would be NO REASON to tinker with torque-apportioning when there "ain't no torque to be had." The power peak for the RDX is up at 6000 rpm, and the torque peak is up at 4500. When the light turns green and you push the "go" pedal, you are nowhere near needing to worry about full-rated power for a while, dim-witted driver or not.
    I have a chipped Jetta 1.8T (also DBW, but not with the OEM map anymore, obviously) that is unimpressive off the line, but then at 3000 rpm, it will smoke the tires through the first three gears. It's actually pretty funny, unless you are pulling out in front of a semi. ;)
    Congratulations on your new RDX! Please keep us posted on your experience. I am especially interested in more real-world reports on gas mileage.
