Best 4x4 Pickup for bush (logging) Work?
a chevy man. 1500 LS Z71 pkg (good on highway and trails) with the P265 tires. I have an ext cab 4dr Z71 ls with the 5.3 (you can still get the 4.8 with everything) itll hold up well. You said u only need a small V-8 and the 1500 would probably suit u better than a 2500 because gas milage would be a heck of alot better. My only suggestion is drive them all i know my chevy is by far the most comfy truck out there.
Good luck
Ryan
Good luck
Ryan
BTW: Get the low gearing in the axle-4.10
LOL
- Tim
Ryan
I am going to get flamed for this but I would buy the 2001 Dodge Ram 1500. You stated you don't expect to carry heavy loads so you really do not have a requirement for a 3/4 ton and they are more expensive. The Ram has a solid front axle and offers more ground clearance. The 5.2 litre engine is good and will not cause you any problems. The five speed manual removes any transmission worries. Dodge has had problems with their 4 speed auto transmissions.
I don't like the IFS for serious off road work. you stated you have had problems with your 96 light duty Fords and they are still using the same front end. The new GM trucks are nice however they are built for the 95% of the population that thinks going off road is driving on the lawn. I take my truck off road but I take my time and I treat it with respect because if I break it I have to fix it. If someone else was paying the bills then it would be a whole different story. I hope this helps.
Randy
Ryan
Another thought, due to useage, would be to order an open differential and then install an aftermarket "locker". LOCK-RIGHT and DETROIT both make units for these trucks rear ends. Of course I probably don't have to tell you about swapping out tires to some BF Goodrichs' to increase sidewall strength to resist punctures. Good luck.....
The Chevy with 4.8 will by far give you the best gas mileage. it will probably be substantially better than the Dodge 5.2. Power would be a little better. I would suggest an automatic if possible. Automatics are so much easier to drive, and MUCH easier on the truck when in serious offroad conditions. been there, done that--if i had the choice, they can keep their stick shifts!!
Ryan
Yes, a stripped down 3/4 ton Super duty will be close in price, and would be a damn good truck. Fuel consumption would probably be the worst, thats probably the only downside to that option.
And we have been all talking about halftons. sorry to pick nits.
"And we have been all talking about halftons" GEEEZ a guy starts a topic, asks about a particular vehicle and YOU decide it's only about half tons.......Boy, we think highly of our selves don't we? LOL!!!!
Kodak moment
i have been a big believer in UNDERLOADING work trucks and have been rewarded many times over by using 2500's vs 1500's in my land surveying work ie 100k in 3yr work w/o any repairs! i don't abuse my trucks, but i sure don't baby them either
DHD79413
what did I miss!!??
- Tim
Ryan
It just ain't right.......
- Tim
I'm a raised Southern boy. We don't talk about such things!
(Although you better run if you hear banjoes!!)
LOL!
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
