there is an aftermarket update available at http://www.redsautorehab.com/products.html
All 3 lines are about $100 and maybe 1 hour labor, shouldn't be more than $200 anywhere.
There is a TSB on these, many dealers will replace them at no cost under the 100K drivetrain warranty as well.
I was totally disapointed when I moved from a 2006 Tacoma that was getting 17 city and 23 hwy to my 2009 Silverado Crew Duramax. If I drive the truck like any other vehicle or my previous truck I get 14-15 city and 16-17 hwy. The best I can get out of my 2009 while milking the [non-permissible content removed] out of it and pissing everyone off around me is 16.5 city.
Previous truck was able to tow and get 12 while the new chevy gets 9.5? Gone are the days I could tow at 75 or 80 as well.
I think many of the claims here are exagerated or from older trucks with out the DPF system.
Anyone know how it is calculated now?
I like that our '06 Impala LS computer has both an instant mpg AND an average mpg display. Our '07 2500HD Duramax LTZ only has an average mpg display, but we get a gallons used display.
As a "detail oriented pain in the butt quality assurance professional", I can still accept the "close enough" readings. It all sort of falls into the "What is really important" category. If the factory displays aren't good enough, we have to decide how much it's worth to us and add big dollar aftermarket measuring gear.
I get real values from the spiral steno pad that lives in the truck. I record date, odometer, trip miles, $/gal, # gal, $ spent, brand, location, and misc notes at every event. Events are everything from fuel to light bulb replacements (bulbs don't get fuel information recorded). What do you expect, I am in the QA field.
Mostly, this has been of value to figure out when we went where.
Loving my 'Max.
We call it Max, and the outdated navigation system voice Maxine...
Rick in colorado
What's yours?
Ps in Jan the PU had 34K miles on it and 38800 now..
I liked to do it with my Ford Diesel to them darn bikers in yellow shirts that clog the roads.
I did put 265 tires on it but my fuel mileage dropped before that. Did you ever have a vibration issue with the 06's I had it back several times eventually they put new cab mounts on the truck, I think they used a softer mount to absorb the vibration?
want to stay running, acts like it's out of gas and actually died out on the highway. Tried changing the fuel filter and it didn't solve the problem, it died out again. Any ideas on what else to check?
Thanks again for your comment and any more are welcomed.
I just had the first real repair to it at 38K miles and still under warranty it was a new turbo... around town mileage back to 17+ and road 21mpg. Heated seats are nice in the winter. XM radio is hard to beat.
Good Luck
You need to put it on the computer and see what the error code is.
