Advanced Course in Hybrid Engineering
I agree, I think the original poster just allocated the share borne by the 100lb battery to be 200watts as a fraction of total losses at speed assuming the 'Prius I' total weight was 2950lbs (1340kg).
But let's say you bring an '03 Prius and its 540kJ of kinetic energy down to rest in 4 seconds. You would have to remove 135kJ per second. With the 201v battery that represents a current of 675 amps. The battery controller will only allow 50 amps of charging current. So if you want to recapture all that energy you better slow down in about 52 seconds ! You see why I am against the battery idea ?
The battery is quite large just for storing KE even if you had allowed a 300% manufacturing margin.
6.5Ah is 23400 amp-secs, which multiplied by 201v = 4.7MJ.
Why is the battery so big ? Well, you are going to pull 100 amp during full bore acceleration (21kw) which is the 16C rate. In comparison cranking 500 amps out of your car's 72AH lead acid is about 7C . As heavy as that HV battery is, it takes quite a bit of stress in the Prius - and you think it should be smaller ?
I've already suggested the use of a dynamic braking resistor. But there are other options on board Prius. One idea is that, having cut the fuel to the engine then taking MG1 up to 10,000rpm to keep the engine revs high while the car slows, a kind of enhanced engine braking.
Then again, in summer whenever your foot comes off the accelerator, while moving, the inverter for the A/C compressor ( 2kw ? ) could be made to turn on full. Providing this temporary overide of the cabin thermostat (done transparently in the software) would be a good use of existing hardware and with hypermiling techniques has potential for recouping quite a bit of energy in the hot season ! Don't laugh, you've just seen the math.
Devsienna seems to have answered your other questions, tpe, guess I can go early :-)
T2
Out of curiosity: have you looked into how the math work out for ultracapacitors? In this case, the charge doesn't persist as long, but the weight is much less, and potentially the next "go" after the "stop" can be largely supplies by the stored energy from braking.
New Li-ion battery chemistries allow for much faster charge/discharge rates (A123 Systems, Altair Nanotechnologies). These batteries are also in the neighborhood of 1 kWh per 10 kg. So even with the packaging they should be significantly lighter than 100 lbs. This should be good news for hybrids.
I thought that one of the problems with diesel hybrids is the engine's inability to shutdown and startup quickly, e.g. at stoplights. While that doesn't really amount to hybrid technology it is a gas saving technique that most hybrids employ. Is this a problem that's been solved?
Other studies have shown that there is a fuel saving. In the case of the Prius the engine is spun up to approximately 1000 RPM. Once oil pressure is established fuel and ignition are supplied. It's not like starting an engine in the regular way.
The EPA city mpg rating is grossly overstated for hybrids. They plan on addressing this in a year or two. I think you will see something like a 42 city mpg rating for the Prius. Still very good but someone that expected 60 was probably disappointed.
Power density is the most important parameter to Toyota.
The earlier model of Prius had 38 7.2v cellpacks of 800w/kg power capability. When the the newer Prismatic cells became available with 1300w/kg they were able to trim the number of cell packs down to 28, at least that is my take.
Since both types of cellpacks weighed in around 1050 gms, and both had energy storage of 46Wh/kg this meant the lighter '03 battery also stored less energy, but its ampacity was much greater which was the major interest to Toyota. On paper this computes to 180 amps, up from 110amp. In practice a maximum of 100 amps seems to be used.
I was just on the Maxwell.com Ultracap site browsing their interesting products with 10Kw/kg power densities but they didn't give the weight of their 650F 2.7v , for example, so I couldn't compute how many amps they could deliver. Of course if it weighed 1kg then 4000amps, but then what is the ESR ? I am not sure I trust their 10kw/kg figure just yet - they are holding too much back. A scalability issue perhaps.
see yhoo prius_stuff #1071,#1165 and #17142 for ultras and regen they could be useful posts, but posts like #1068 refer to the earlier Prius which I think we should keep out of Edmunds to deal with the latest technology here. Also they are not so warm to non owners cluttering their site with speculative postings, these days. Never mind that talk of plunking down $12000 for an EEstor Li-ion, doesn't seem to phase them at all! Buying a Prius is on my horizon but I want the 'right' technology. Small engine, lightweight and no HV battery. In a few words my Prius has to be quick, simple and cheap. A pure series hybrid. I see the HSD as heavy and complicated right now. And rather expensive too I might add.
T2
For the nano cell if we choose a more conservative 2000W/Kg that would infer about a 300 amp charge which would get you a regenerative stop of 60mph to rest in roughly 8 seconds. More interesting just 25kg could provide 50kw for acceleration which should definitely impact engine size needed. Right now, if I may remind you, Prius has 28Hp/76Hp battery/ICE ratio. Toyota doesn't have a smaller engine than the 1.5litre which would work well with this powerful a battery.
As other posters have observed the car companies aren't seeming to follow this mantra, we'll all just be sitting ducks when the next spike in oil price occurs. The Prius is going to maintain its sales but I believe there is interest in a vehicle size below that. This battery could certainly change the dynamic if it became available.
The fast plug-in charge of a 100Wh/Kg battery at the 2000w/Kg level would take 100*3600/2000 or 180 secs with a 50kw supply for 25Kg. For BEV enthusiasts the best charger for this system would probably be another nano battery on permanent trickle charge.
I did notice Altair included footnotes regarding "forwardlooking statements" - Safe Harbour language.
T2
This battery is available, somewhat. Altairnano has a $750,000 order for their battery packs from Phoenix Motorcars. They've already delivered at least one 35 kWh pack and its installed in an SUV that's currently making the rounds at the alternative energy shows. My understanding is they are contracted to deliver 10 of these packs by year end. Not exactly high volume. Some company with a lot of manufacturing capacity needs to pay Altairnano a licensing fee and start churning these things out.
You mean compared to the 72Ahr battery in your car ?
But that oldtech commodity battery weighs but 50lbs and holds just 0.9 kwh and costs a hundred dollars.
Why, if you made one twice as heavy it'd store 1.8 kwh and set you back a whopping two hundred bucks.
Why on earth would you do that when for $2000+ you could pick up one of those hi fallutin' NiMHs with 1.3 kwh ?
Don't take me seriously. It's Friday.
I'm just fooling around, that's all !
T2
On one of your previous posts you gave the altairnano battery 2000W/kg. I think that their claimed 4000W/kg has been demonstrated so you can go with that. This type of technology allows for a stupidly fast series hybrid that has no more than a 80 kg battery pack. There's guys like Richard Branson, founder of Virgin Airlines, donating 1 billion dollars to green causes. If I was in his position I would contract to build a high performance series hybrid with the Altairnano battery coupled with a highly efficient diesel generator. I don't think it would be that expensive.
Even has MATH equations.....how nerdy !!! :shades:
A tale of two hybrids
Oh, this just in - Magna International, an auto supplier like Delphi but unlike Delphi not in chapter 11, just announced it is looking to partner with three equity firms to takeover Chrysler in order to protect its order book. Didn't waste any time did they ?
Two thirds of their business is with the big three and with $2Bn in cash and $2Bn in reserves, I guess Magna can be a player. They might even pick this time to go after their rival so over at Delphi they better start putting broomhandles in those doors !
The posted article seems to be riddled with inaccuracies, starting with : -
"ICE: Internal Combustion Engine - The standard drivetrain of cars way back in the 20th Century."
History will no doubt recall the ICE as a prime mover.
The standard drivetrain of cars way back in the 20th century would of course include the ICE plus a clutching arrangement controlling a multistage gearbox.
Since the author is going to go on to describe systems which don't have some of those things mention of them should have been included at the get go.
I've learned that it is important to describe the architecture very accurately otherwise you can find yourself inadvertantly making statements that are BS.
Take the Prius, for instance, the writer omitted to point out that the transaxle that delivers power to the differential via two intermediary spindles is only 82% efficient. Account was taken of the losses in the PSD caused mainly by churning electrical power between MG1 and MG2 but what were those 95% transmissions ? I would also like to see those 95% efficient transmissions, sadly not on this planet charlie, a 1:1 ratio might be 95% but anything above 1:3 and you're looking at 93% and that's just for a single mesh.
Also the Power Split Device is actually a torque split device a more knowledgeable writer would have pointed out.
However the writer did conclude that the series hybrid may become the predominant architecture in the future. However I would have to take issue with his description of what a series hybrid is. There is more than one type you know. The writer's version is essentially an EV with a back up generator to provide enough energy to cruise. Let's say at 70mph, about 20Hp I suppose.
An entirely different direction which I have been refining over the past thirty years not including a couple of concentrated years on the internet suggests a unique version which rarely gets mention. In this version the battery and ICE roles are reversed. The prime mover would now be a powerful but small engine (600cc or less) driving a hi-speed generator at up to 12,000rpm when 100kw or 120Hp is needed for those short periods of extreme acceleration. This version would have no high voltage 'boutique' energy pack of expensive dubious chemistry either. The keynotes for this idea being simplicity, low mass and cost.
For replacement of the HV battery the existing 12v lead acid would be just slightly beefed up and equipped with a step up converter in order to perform the 'virtual HV battery' role. This would facilitate engine starting via the generator's feed_thru inverter and at other times allow low speed "electric only" operations to 10mph. 10mph since a single general purpose battery would not have the power capability to put out more than 1500W on a continuous basis.
T2
I will try and post a sane distillation of whats in my head!
....whilst I catch up on what Ive missed since my last visit here!
I know the major thing holding back all electric vehicles per se is battery technology, we can't get enough juice for the given size/weight to make an electric car go the distance we would want out of a family car (about 350 miles on a tank) I also know that even the latest li-poly batteries are prohibitively expensive, still take a while to charge and suffer from charge loss over time, ie they have some way to go before we reach the holy grail of a lossless, high concentration electrical energy store...
I also know that if we all made a slight change in our driving habits and if our workplaces would provide sockets for charging your car whilst at work and our respective governments help put in place the infastructure for charging your car at home(I live in an appartment without a garage, so running an extension cord out to the car would get me loads of more headache! ) we could all live with and love the current best of breed electric cars (tesla roadster is an example of the right technology, but, too expensive for most of us)
That said I also think a better more gradual change involves, hybrid cars that still run on petrol, but, eek out the most efficiency out of the fossil fuel and as a by product lower emissions drastically. Which brings me to the meat of my post, Ive posted some of this here before, but talked about a diesel engine powering a generator that charges an onboard battery and drives an electric motor that drives the wheels (a serial hybrid). I realise that by adding the conversion from fossil fuel to electricity and storing most if it in lossy battery then converting it back to motive power to the wheels involves quite a few losses of efficiency.
Ive been thinking about something said to me a while back be either toyolla2 or goodcrd ???, sorry folks if I've got this wrong it was a while back. It was essentially that of whther we need a large battery store at all!?
In essence the gasoline engine powers a generator that drives an electric motor directly... Lets talk efficency of such a setup, how much energy loss are we talking here?
Im going to make some assumptions here: (these is just guess work)
Typical motor electricity to motive power efficiency: 85-90%
Typical generator motive to electricity efficiency: 80-90%
So a simple scenario where we replace the drive train (gearbox, clutch, drive shafts) with a generator coupled directly to our gasonline engine, which then powers a motor driving the wheels, would net us a lower estimate of about 68% of the engine output (85% * 80%).
With the original clutch/gearbox in place I know you lose some of the engine power too, what is this roughly, about 10-15%? Would this electric drivetrain be any lighter than the equivalent mechanical drive train(gearbox, clutch) I know drive shafts would be needed for the electric motor too, but with in wheel motors being talked about this too might not be needed!
How much loss in efficiency in using this electric drive train are we a talking about over the mechanical drive train? My of the top of the head guess would put it about 20%.
Now couldnt this be efficiency loss be made up in using a smaller lighter gasoline engine (3 cylinder, lean burn, 1-1.5 litre capacity if not smaller like a motorbike engine!) that has been tuned to run at a high rpm with turbo charging if necassary (would this be even needed!)?
Wouldnt focusing on a smaller lighter more efficient gasoline engine be the way to go. It wouldnt need to provide a wide power band, just a very small highly efficient band of power producing electricity to power the motor. (you could even include some ultracapicators that could soak up the excess electricity produced if the car is moving too slowly for amount of electrical power the gasoline engine/generator combo is producing and if you were to use regenarative braking, this could then be used to provide extra power to the motor when needed, or when restarting the gasoline engine if its been shutdown)
Another benefit over a standard ICE mechanical drive train setup would be the internal passenger cabin layout options provided by the space saving of not having a large engine/gearbox, drive shafts/tunnel to the rear wheels.
Sorry that this post is long, but, Im fascinated by all of this, should have been an engineer instead of the desk bound computer programmer that I am !!!!
Any ideas, criticism is welcome as is any kind soul that can point out any huge holes in my understanding or concept.
Its all gone very quiet on this board of late!
Secondly the sprocket speeds of 200 revs/min under consideration (for a bicycle) are also quite removed from the 200 revs/sec encountered with the induction motor in the SHEV. In this environment the chain speed with a 12" circumference drive sprocket would be around 200'/sec.
Of course as we know a motorcycle chain doesn't go anywhere near this velocity because primary gear reduction has already been accomplished inside its transmission.
And you responded
I can tell you from motorcycle experience that chain drive is more efficient than drive shafts for power transfer to the rear wheel, and more efficient than direct gearing for camshaft/crankshaft synchronization. But I don't know how this translates to automotive uses."
After spending this weekend studying a Haynes manual for the Kawasaki KZ400-550 series quad cyl motorcycles, I have to say I stand corrected about the use of chain at hi speeds ( > 10,000 RPM).
The primary drive internal to the engine, in Kawasaki's design does in fact include a Hy Vo chain with an approx 1:1 ratio driving the secondary shaft from the main crankshaft at speeds to 10500 RPM. However the reduction needed to the gearbox of 2.935 is accomplished by gearing in the following manner: From the secondary shaft a 26 tooth gear drives a 65 tooth gear on the clutch assembly.
You referred to the chain used in the "Final drive" for power transfer to the rear wheel from the gearbox external sprocket. Yes, this setup provides a 2.5 step down ratio to the wheel but with the more modest speeds of around 3500rpm at the drive sprocket.
And one other thing owing to the length of the chain back to the wheel on a motorcycle, geometry allows a good wrap on the sprockets at both ends.
Using a similar system for the 1 : 10 single stage reduction needed by the traction motor on that SHEV transaxle could be marginal since the wrap angle on the smaller sprocket would be significantly diminished due to the proximity of the two sprockets.
I did some calculations of the primary drive chain speed for the Kawasaki. The 23T sprocket on the crankshaft using 3/8" per link Hy Vo chain will have a 2.5" dia. pitch circle and rotating at 10500 RPM will yield a chain velocity of 7500ft/min or 90 mph !
The chain on the final drive to the wheel, for comparison, is driven by a 16 tooth sprocket that rotating at 3500 max rpm will yield only about a 30mph chain velocity.
T2
In the US most industrial inverters are run on 660vDC because diode input bridges on 3-phase 460vac will produce this voltage across the main bus. In Canada the powers that be because they generated so much electrical power looked into the future and advocated a 575vac system. Although the higher voltage would seem to allow savings with thinner copper conductors savings were nefarious at best. It certainly made equipment, switchgear etc, more expensive because of the smaller market in Canada to meet this new standard. It also did not forsee that the day of specifying large electric motors would be over.
Today the trend is towards multiple smaller machine drives simultaneously controlled through digital comm. links. Inside these smaller drives higher voltages have become more of a problem than a virtue. Low cost 575vac inverters available off-shelf, assuming they are not front ended with a 3-phase SCR half-bridge soft start, will have their IGBT devices working off an 800vDC bus. The problem is that these relatively new inverters have not been found to be as reliable as the established 460vac inverters used previously. It turns out that maybe, just maybe, 650vDC may turn out to be the sweet spot for silicon IGBT technology after all and that going forward, the use of voltages above 650vDC should be avoided if possible.
This was triggered by seeing a inverter die posted on the Yahoo prius_stuff board. There was a query on the terminations and I suggested to them that this would appear to be a SENSEFET fabrication on the internals of an IGBT !
There are donuts on two of the power leads, but sensefet outputs are likely to be much faster than current TXFMRS and may be a way that Toyota is making their circuits more secure. This will be probably be checked out soon. ORNL (Oak Ridge National Lab) also mislabeled the polarity on their pic.
I hope they don't make mistakes like that with other stuff they work on up there.
T2
Sensefet is a Motorola trademark name
link title
Hybrids are getting heavier, but they seem to bear their weight better than conventional vehicles when it comes to fuel efficiency, according to a recent study. In the study, the scientists found that the trend toward higher-performing hybrid-electric vehicles (HEVs) in the North American market is eroding the fuel consumption benefit of hybrid technology.
However, the gain in vehicle weight and power is not necessarily surprising or discouraging, as researchers Conor Reynolds and Milind Kandlikar explain. HEVs are new in the market and, as such, are diversifying from the compact cars that first appeared in 1999, such as the relatively light, low-power Honda Insight.
“In our analysis, we found that changes in weight and power affect HEVs differently than ICEVs [conventional internal combustion engine vehicles],” Reynolds explained to PhysOrg.com. “For example, we found that added weight doesn’t matter as much for hybrids as for conventional vehicles, a comparison that reinforces the fuel benefits of hybrid technology.”
The study by the University of British Columbia scientists is the first to account for all nine light-duty HEV models on the North American market in 2007 (a number expected to double in the next two to three years). While HEVs made up about 1.6% of the total vehicle sales in the U.S. in 2006, nearly 30% of these HEVs were SUVs. Further, HEV cars in the second generation hybrid wave (2004 and later model years) exhibit higher performance levels across the board: an overall 30% weight increase and 60% power increase.
POLITICAL SCIENTISTS that's who
T2
You wrote
" This is obviously leading to my personal theory that a series hybrid design with a small very efficient diesel engine running at a constant RPM turning a generator which charges up a battery/electric motor and all the associated regenerative braking/turning off when the battery is fully charged etc... would be the most efficient design. Lensman"
Let's see "small very efficient diesel engine running at a constant RPM turning a generator"
Operating strategy - Always to run at full rated power.
The difficulty with this approach is that you would have to specify the performance required of the drivetrain so that your diesel can be sized correctly.
"There can be no ideal. No technology is perfect, and you’ve to deal with compromises. It is all about getting the job done with simplicity and minimum overhead. robertsmx"
If we were to target a top speed of 100mph as they did with the Prius you will need to continuously rate your diesel for about 50Hp. It will need something like a 1.2L tdi to deliver that at 2400rpm most efficiently, but that engine will be a long way from the low cost single cylinder engine that you may have envisioned, more approaching a 3 or 4cyl. Perhaps an engine consisting of just one single cylinder of that same engine could deliver 12.5Hp and maintain 65mph on a level surface etc, etc.but you will need around 80kw of NiMH/Li-ion to get it up there in 10 secs and that energy source could weigh more than 115kgs (260lbs) roughly four times the capacity of the '04 NWH20 Prius.
If we selected the Prismatic cells from Prius, each 7.2v cell pack weighs 1040g and is rated @ 1300W/kg in that package and should be 180Amp capable. Toyota uses an electronic current limit of 100amps for longevity, let's do same. Each pack should be good for 720W. 80kw will need 115kgs worth. Four times more powerful than existing Prius pack although not necessarily four times the weight since some ancillary included hardware to support the battery will not need to be scaled up at the same rate.
100mph with a fully charged pack, but for how long can you go? Assume 50Hp is total needed then subtracting 12.5Hp diesel power requires additional continuous 37.5 Hp or 28Kw will be needed.
The Prismatics rated at 46Wh/kg means the 7.2v cell packs will rate at 6.5AHrs. But that's too much information. All we need to do is multiply the energy density by the amount of battery material we have and then divide that heap of energy by the required consumption rate. 46 x 115/ 28k = 0.1889hrs or 680 secs.
So there you have it. A compromise. You can have your ten minutes at maximum altitude then you're dropping from the sky. On the other hand Prius could do this all day and produce 50Hp at around 3300rpm. ( interpolating 76Hp for 5000rpm). [mg1= -3720rpm for Prius fans]
It's not such a depressing result however if there is indeed a market for people who would accept these limitations on an 80mpg car. Since very few people drive beyond 90mph it's always been a want rather than a need. Its always been difficult to limit top speeds in the past because taller gears and overdrive meant for fuel economy allowed manufacturers to offer speeds well beyond 100mph free of charge, after all it's the superior 0 to 60mph in the lower gears that you're basically after. Whether manufacturers can get away with ( i.e. maintain good sales) a car with excellent acceleration and throttle response second to none but with an "inverse time" specification on speeds above 65mph remains to be seen.
There are some other pros to the idea. A small engine will warm up sooner and become efficient after a mile rather than three miles or more. It's emission will also be better for the initial part of those trips as well. Tell me who doesn't make sure their car is well warmed up before submitting it for exhaust emission testing. It is difficult to put a dollar figure on that. But then I read a poster (maybe on Priuschat I can't remember) who reported that his mileage readout improved following a spell with a block heater and it seemed to have a useful effect whatever the weather. Half the time, of course, that will not be possible. I am particularly warm to the idea of being able to get the ice melted quickly in those remote parking lots because you have a few kilowatts electrically installed inside the heater vents.
Although I am dead set against diesels for a number of reasons on further reflection I can't deny there are could be some attractive benefits. Utilising the contents of the fuel tank by circulating the diesel fuel as a coolant through the engine could be one of them, naturally an oil cooler rad would be needed and the engine would have to have an automatic cutoff before a minimum tank level is reached. That is not a problem assuming there would still be some electrical miles left in the battery. Then I just thought, doesn't diesel have some decent lubrication properties ? How critical would it be to use fuel for lube on a 30lbs-ft 2400rpm 300cc diesel.? I know it's become illegal in some places to dispose of old engine oil in repair shop space heaters but after running through the engine this wouldn't be old oil at all. In fact this would be almost new oil ! I was looking at the DeltaHawk site regarding their twostroke aviation 160Hp diesel. They stated they won't be certifying their machine with oil cooling but isn't it implicit that two strokes lubricate wth their own fuel ? Enquiring minds wish to know.
Lensman when I originally answered your post, at DIESEL HYBRIDS ? I hadn't read your post thoroughly before I entered my diatribe on optimal efficiency. Looking more closely, the case you propose sidesteps this 'optimal' issue somewhat with your small diesel by employing it only at full power. At constant speed and full torque there are no variable losses, of course, to cause departure from the optimal efficiency point. Running at full torque thus ensures that the fixed losses are always a small part of the throughput.
The question is now how often will this engine need to be started. Well with 12.5Hp or 9Kw and using the equation above
46WHrs x 115kg / 9kw = 0.587hrs. Lets assume bibberonage of from 90 % to 10 % SOC =0.47hrs or 28 minutes. Then the engine will run for 28 minutes minimum when triggered at the 10 % level. Depending on the power being used by the vehicle it could and probably will stay on for much longer than that.
Ideally you want it to stay on permanently as much as possible so the energy can go directly through to the traction motors and not churn through the battery a process which is only 80 % efficient.
The problem with this system as I see it, is that with appropriate gauging available to the driver, this car will start driving you. You'll know that out on the highway you will want to be draining the batter
T2
The biggest detractor from what you write is that the petrol/diesel engine would need to run for 28 mins or so to juice up the batteries from 10% to 90% charge. You mention having a 'force charge' button on the dash somewhere. I think this is a great idea actually, it puts the onus on the driver to decide whether they are arriving at somewhere where they could charge the batteries from the mains supply or use the onboard generator/engine combo to start charging the batteries beforehand. Appologies as this is going to go slightly off topic...This could be extended 'coolified'(tm)
Now the obvious question is what happens if you arrive at your destination without having force charged and with only 10% charge left in the batteries without means to plug in. Well you mention around you could get ~50hp from the 1.2L diesel engine in your example configuration. The engine could run immediately you set off again, and it would be feeding the electric motor directly, only charging the batteries when the motive force required from the motor falls (you've reached your cruising speed). I am again out of my depth here, but ok you would be limited to 50hp in this situation but could this work? I mean wouldnt 50hp be plenty enough from rest and up to 30-40mph, and then you'd only need what was it, 20hp to stay at 30-40mph...
I fully realise that the holy grail of all the serial hybrid would be a engine running on petrol/diesel that is of fundementally different design to extract the wasted ~60% from the fuel that current internal combustion engines give off in sound and in heating the atmosphere
Take a look at my post again, I think I suggested we are going to use one cylinder of a conventional 1.2L diesel to give 12.5Hp. This is 9kw. Meanwhile an 80kw capable NiMH battery will hold 4.5kwhrs whether we like it or not !
So at 9kw this will take roughly half an hour to charge, I said 28mins.
If you have 10% SOC, that would be worst case, in parking lot well that's more than enough to start engine. Let's do some math. you need to exit the lot straight onto a busy major hiway, worst case again. You need 100hp for 10 secs in your battery to get to speed fast. Your 12.5 Hp engine will put that in the battery in 80 secs. Can you see how I did that ?
Remember you only need a horsepower or two to mosey around the parking lot so you'll probably be ready to go as soon as you find the exit.
A word of caution, although this can be done doesn't mean it should be done. This battery would cost around $8000.
T2
Upon tearing apart a Toyota Prius—spanking new from the dealer—what strikes an engineer's eye is that this first parallel drive train gas/electric hybrid car is more like other modern vehicles than not. Ignore the large nickel-metal hydride battery tucked out of sight behind the rear seat; filter out the associated starter-motor-like heavy-gage high-voltage orange cables running along the frame to carry current to and from the electric traction motor for power and regenerative braking. Now you have a system that seems "conventional," despite the optimized hybrid-power-train architecture.
The Prius overall appears to follow the Toyota build philosophy: standard modules, bits and pieces--from electronics to doors and other components--that readily fit in place, enabling the same vehicle model to be built to the same quality standard anywhere in the world.
Like any modern vehicle, the Prius packs numerous electronic subsystems. Six, however, stood out: the inverter/converter, the user-interface/dash module, the engine control module, the navigation/display system, the airbag control module and the anti-skid system. The functionality, placement, electronic content and packaging of those subsystems represent the cutting edge not only in terms of technology but also in the context of reliability and power management.
From your comment in News and Views #268, I agree with you tch_titanium, this is not totally bad news to me either.
The Toyota concept of invoking a hybrid model differs from mine and I've always felt that they were going in the wrong direction with the HSD system despite its success.
I would say that somewhere in the mix of the two is the understanding that electric traction is involved but after that.....let me try and explain my side.
Generally the Hybrid is defined as the act of combining two different energy sources e.g. gasoline and NiMH battery for synergism.
And that's the HSD. In my mind, though, I have the term Hybrid defined as the act of the conversion of one energy source into another so that synergism will result.
My model does not require an HV battery as either a major storage element or as an element able to deliver major power. In the model I propose, a conventional sized lead acid 12v battery could deliver 900W of power to the HV bus which would suffice for the type of limited low speed mobility in forward and reverse most often required.
Otherwise the model recognises that Stealth (electric only) driving and regeneration (when stopping and hill descending) are not essential unless you are building a conventional EV. The exergy of gasoline is such that hauling a 100lb battery around to save a few drops of gas does not impress me. As to the recapture of mechanical energy then the use of an electrical resistor mat to dissipate potential and kinetic energy as heat in order to reduce disc brake maintenance has much higher efficacy, as I see it, being cheaper, simpler, lighter and able to be of higher power rating than the absorptive NiMH system currently in vogue. e.g. Prius can absorb a maximum rate of 10kw and that is if the weather is warm and the battery temperature is up, I think you would agree that most moderate braking manoevres need an absorptive ability several times that.
You wrote :
Advances in silicon, magnetics, and other materials has been steady (much better than batteries) and I'd have to think that's where most of the improvements are going to continue to come from.
I second that and would add that a single cylinder performance engine such as found in Yamaha's WR450F with its 96x62mm oversquare design should be considered as a simpler prime mover to supercede the 1NZ-FXE four cylinder now in use.
Finally the use of the existing 50kw inverter but with a low cost induction motor geared directly to the differential gear of the transaxle would be far simpler and about twice as efficient. You would be looking at a 7% reducer loss versus an 18% estimated loss of the current transaxle multistage reducer.
T2
Solutions to electric vehicle propulsion have always been subject to wacky ideas. Even car companies like Mercedes Benz which was looking to fit thermoelectric generators on hot exhaust pipes ! Well I guess there was a government tax credit attached so why not let some guys play around ? As long as the outcome is unlikely to change the status quo.
All that is really needed is good applications of existing technology. For example when Toyota introduced liquid cooled heatsinks in the Prius I remember thinking that that in itself was fairly exotic technology to employ for a 50KW inverter. The largest single electronic drive I ever commissioned was 300KW (400Hp) and the SCR stack was forced air cooled, so from my standpoint I couldn't see why Toyota would ignore this more bulky but time proven method. In the event liquid cooling has shown that this is the way to go for automobile systems, their failure rate is a thousand times better than I would have predicted they would have received with an equivalent version that would have been air cooled.
The idea I proposed earlier, using a single cylinder 450cc engine has received no comments yet but it is a good suggestion for reducing the cost of hybrids. When the engine is fully decoupled from the wheels as in a series hybrid it provides a lot more options in the prime mover. Generally you want high speed because that reduces frame sizes for the same power, but exotic devices like gas turbines have to be precluded because they require expensive high temperature materials and don't perform efficiently at part load. A modern single cylinder design on the contrary may net you 60HP in a small light package and avoid all that, so the resulting hybrid vehicle could actually be lighter than one with a conventional four cylinder with clutch and manual transmission. Not forgetting that with this hybrid you can redline the engine at max torque from a very low speed until you reach your target roadspeed - can't do that with a stepped transmission manual or the auto kind nor can the Prius either until it reaches 50mph. So this 60Hp may behave more like it was 100HP in practice.
T2
That *might* be possible. The biggest problem with steam is that it takes awhile to get going, so to speak, and if you stop suddenly, a lot of heat might gp to waste. In the case if a hybrid, the electriv motor could move you at first when the steam was being accumulated, and after parked, the leftover steam could top off the batteries.
I've had much the same thought in regards to a stirling cycle engine, which is more efficient than steam.
BMW is developing a small steam engine driven by the heat of the exhaust, which then assists in driving the car. Supposedly, this increases both power and fuel economy by 15%.
You are talking about a series hybrid, right? Why would the gas turbine ever have to operate at part load?
My model does not require an HV battery as either a major storage element or as an element able to deliver major power. In the model I propose, a conventional sized lead acid 12v battery could deliver 900W of power to the HV bus which would suffice for starting and for the type of limited low speed mobility in forward and reverse most often required.
Our series hybrid models are quite different. You seem to be a battery storage type guy and I'm not. That means therefore my choice of prime mover will be operating at part load all the time except on steep inclines or when extreme acceleration is required.
T2
Not really. I do like performance and the beauty of EVs is that you can have both performace and efficiency. There's no way a 60 hp engine can deliver the type of performance that I'd be interested in unless it was able to charge a more powerful battery pack. I'm not talking about a huge battery, <100 kg would suffice if it was the new type of fast charge/discharge offered by Altairnano or A123 Systems. Yes carrying around this extra weight would detract somewhat from efficiency but if you can more effectively take advantage of regenerative braking then the extra you spent to accelerate the greater mass would be largely recovered. Also, unlike in your system, the engine that was charging this battery would only operate at its peak efficiency, which would further offset the hit taken by the added weight.
Interesting concept.
http://www.evworld.com/article.cfm?storyid=1277
http://www.velozzi.org/
And who pays for the energy lugging that battery round the streets ? And who wants to pay for the battery also ? I've been into that before on this forum, let's not go there.
Load levelling for peak efficiency. Talk of peak efficiency always raises a red flag with me. Like a product in a supermart with the word Gourmet on it. Expect to pay double. It's usually the same thing in a fancier box.
So now you've got me turning off my engine while I drain my battery to 10% SOC at which point my engine comes on at full bore ( for peak efficiency of course) to recharge it. I see you bought into this one.
Let me ask you some questions. Are you aware of the losses involved churning energy through a battery ? And are you oblivious to the problems of poor mileage experienced by HCH owners when temperatures drop to five degrees C ?
Sure the battery is in the cabin, but the car might be outdoors 24/7. Your 40 minute commute is not going to be long enough to thaw it out.
But its not all bad news. Here's a creed I can go with. It was in your EVWORLD article : -
The overriding design strategy for Velozzi is weight-savings and has its origins in high performance auto racing. He pointed out that the lighter the vehicle, the less energy it takes to move it.
Exactly ! So no 100kg battery for me. When you've unloaded a 4-cyl together with its clutch and transmission from the engine bay a genuine 60HP with a throttle response second to none won't seem so bad.
My whole thrust nowadays is to look for ways that hybrid costs may be reduced. Replacing the HV battery with a 'virtual battery', the elimination of the stepped transmission or mechanical CVT of questionable durability and the adoption of single cylinder 450cc engine technology are definitely on that path. They won't please everybody
but they will be an answer to the rather expensive, bloated HSD system now out there.
T2
We just differ on the source of that power.
My suggestion is about proven technology, successful application should be quick, simple and relatively inexpensive.
It's the now.
Energy storage systems of which you speak are not yet proven technology, development will be slow, difficult and expensive.
It's the then.
I will agree that there can be penetration of Battery Electric Vehicles into the market if they come suitably equipped with tunes, A/C and at a reasonable cost, this is not the 'Operation Hairshirt' crowd, I know that. But I question whether any car company has the will to do that today. And it is not encouraging when even advocates like yourself insist on raising the bar as you did somewhat when you preferenced in terms of 60+ HP versions. For that particular upmarket, I can't see vehicles to be available in the short term and they will be expensive unless, as they say, the alchemist shows up and soon.
Case in point, Ballard Power Systems with its fuel cell design, been in existence seems like forever and still not ready for primetime with consumers. Battery technology indeed is difficult.
Meanwhile I, on the other hand, propose a back to basics rethink.
Here's the amount of electric power we need - say 45KW (60 HP).
Here's the best way (small, lightweight, simple and lowest cost) to generate it - a brushless alternator at 10K+rpm.
And since the alternator is going to need a mechanical drive.
Here's one of the better ways (small, lightweight, simple and lower cost) to drive it - the 450cc big bore short stroke liquid cooled 4 valve single cylinder engine.
This is the horse I am betting on. Thanks, nice discussion
T2
You mention that people won't adopt EVs if they don't have the ammenities they've become accustomed to. I agree. But a 60 HP engine cannot provide the power that people have become accustomed to if this is your "prime mover" as you put it.
I used to live in San Diego and probably 4-6 times a year I'd make a road trip to Las Vegas with 2-3 friends. This involved about a 25 mile stretch of highway where you climb 4,000 feet in elevation where traffic is running around 75 mph. The 60 HP engine just wouldn't cut it. Granted this driving situation only took place a handful of times a year but its enough to make the vehicle less marketable. A larger battery pack could have supplemented the power on these occasions. Yeah the bulk of the time you'd be taking a mpg hit by carrying this weight around but you also take a mpg hit by carrying around the extra weight of an AC and even more of a hit when you use it. It comes down to what would be more marketable.
I wrote 'consider the 2006 Honda CRF450R engine which weighs in at 28.9Kg, its oversquare 96mm x 62mm single could probably put out around 60Hp @ 9000rpm for those short bursts of vehicular acceleration.' -citation needed.
I don't have dyno figures for this engine - morons ripped the pages out my library copy of Cycleworld. So for now let's extrapolate from the Honda CBR600RR which yields 118Hp from an inline 4cyl. Each of its 75mm pistons should develop 29.5Hp. At similar piston speed and piston dia. (squared) CF450R should be capable of 48.3Hp on paper. The cooling efficiency of a single is way better than a four so it may very well be capable of 60Hp. I'll do further research on this and get back later.
Notice another benefit of the series hybrid idea that could make this engine even lighter. Honda describes this particular engine having a dual sump design in order to separate clutch/gearbox contamination circulating into the engine lubrication. A crankshaft mounted alternator would of course not need this consideration. It has a 12:1 compression moving it towards diesel effcy also.
The piston speed limitation I would place at 18m/sec or 9000rpm with the 62mm stroke. Yes, I gun for speeds higher than 8000rpm because this reduces the size of the alternator needed for an equivalent power.
Re longevity, I agree no engine will survive 9 - 10 thousand RPMs for extended periods, but if we are looking at 8 seconds to 60mph a theoretical distance of only 117 yards will be covered before the engine will be returned to speeds of 3000 rpm or less for cruising.
T2
This vehicle said to have around the same internal dimensions as the Prius and intended to seat 4 rather than 5 passengers has a curb weight of 926lbs against 2,890lbs of the Prius. It achieves this by the extensive use of carbon fiber reinforced plastic. The 500cc flex fuel engine is part of a plug-in hybrid powertrain that weighs only one quarter of the equivalent system in a Prius using a lithium ion battery. The result is a vehicle with the possibility of traveling over 600 miles on a small four-gallon tank of fuel and achieving the acceleration performance that is equivalent to the Prius.
They don't explicitly announce this is a series hybrid and no photographs of the powertrain have been put up. Furthermore I don't know whether this is a single cylinder engine either and that is rather important for cost reduction.
If we can sidebar on this for a moment - intuition would tell us that a 850cc inline four engine, for example, probably involves as many components and machining operations as a 2.7L inline four. It is therefore reasonable to expect that the price delta between these engines in mass production may be quite small. It is a fact that Tuner shops notice a similar situation in the costing of crated V8 engines between 302 cu. inch and 454 cu. inch that are produced specifically for the aftermarket.
On the production line it's the reduction in number of cylinders that would seem to bring about significant cost savings. This might be the reason Toyota is about to replace the 2.4L inline four on the Camry with a new 2.7L engine. It occurred to me that this engine may come so close to 200Hp to discourage the 20% of buyers that have usually accepted the large price delta for the upgrade to the 3.5L V6. That they would have to move up to the Avalon to get the V6 would then make more sense. It further begs the question that in the horsepower race, just when is enough enough ?
For those growing numbers more interested in fuel economy, however, when a 150mpg vehicle arrives with 0 to 60 in ten seconds I think there are going to be plenty of takers. In case there are still those who will equate this car with the 3-cyl 67Hp Insight it is well to consider that mated to a stepped transmission, albeit even with IMA assist, is a poor way to extract power from an engine. When available maximum power is limited to 67Hp, then when you need it, you must have that 67Hp right away and it must maintain continuously. It is not an acceptable system that allows vehicle acceleration only while the engine is struggling from the middle to the top of its power curve and then at which point you are forced to changeup and cause the the engine revs to sink back down to a lower power point to repeat the process all over again in the new gear. It is just poor efficacy to do this. That is what I have always been against.
Earlier posts #186, 188 and 195 have outlined different aspects of my design and it is encouraging to see that as far as engine capacity goes finally someone at Toyota 'gets it'.
T2
link title
One of the nice things about electric motors is that increased power does not equate to a reduction in efficiency. In fact small electric motors are typically less efficient than larger ones. The electric motor on the Tesla Roadster weighs about 70 lbs. So I don't think weight is much of an issue. Certainly driving 100 mph is going to use more energy than driving 70 mph. But for the person who chooses to drive 70 the fact that he has a more powerful motor than he needs will not result in an efficiency penalty. So you can have a confuration that appeals to the performance enthusiast as well as the person trying to use as little energy as possible.
MODERATOR /ADMINISTRATOR
Review your vehicle
Is there a site that provides simulation for RX 400H? I kmow there are a number of simulation for Prius hybrid in which you can see the relationship between road speed, engine speed, MG1 speed and MG2 speed.
I am particularly interested on the engine speed at 60 MPH if the MG1 is frozen to zero speed. In the prius simulation, the engine speed is 2500 RPM. I want to know the engine speed of RX 400H in the same situation.
Mark
I see also that Chrysler, not to be outdone, has gone this route of providing the wider camming authority of double VVt in the 4 cylinder engines of their current offerings of Caliber,Jeep Patriot, Compass, Sebring, Avenger and Journey.
At Toyota we know that the Corolla has already gotten the 1.8L 2ZR-FE. Wiki shows a third member, the 2.0L 3ZR-FE at 140 Hp, which could be a base engine for the Camry line as gas enters $5 territory. The Hybrid Camry could then become the power version for Camry replacing the V6. That would clarify the Avalon role to be the sole choice for a V6 sedan at the dealership.
It appears that all three engines share the same bore of 80.5mm which is up from the previous 75mm for the Prius. Normally piston bore is a good indicator of power for a given piston speed. In this case power varies between the three engines because of increasingly longer strokes while leaving red line max rpm almost the same for all three engines at 6000, 6000 and 5600rpm resp. , with power ranging from 124Hp to 140Hp. Since they have the same bore it is clear that Toyota gets the power via higher and higher piston speeds across the range afforded purely by increasingly longer strokes.
There must be cost savings in having the same bore size over a range of engines. Makes you wonder though how critical bore/stroke ratio can be in the final analysis ! That does prompt the question regarding a business plan that builds three engines which differ overall by only 16 Hp. Perhaps someone out there could enlighten us ?
The 1.8L 2ZR-FE double VVt-i is as mentioned the current Corolla engine and I can't see them using this in the Prius when the smaller 1.6L 1ZR-FE engine at the bottom of the "R" range is available. This smaller engine still outperforms the 1.5L 1NZ-FE by 20Hp. A 40Hp increase by the Corolla engine seems excessive even when reduced by Atkinson camming.
I have to assume they are going with the 1.6L 1ZR-FE. They may also slow it down to 5000rpm. The following estimations show the effect. This junior member of the "R" family has a much reduced stroke of 78.5mm compared to 87.4mm previously The Prius piston speed will now be 90% that of the previous engine because of the new shorter stroke. When you factor that in along with the larger bore you would expect a 3.5% increase in power with the 1.6L but you would be wrong. In this case double VVt- i appears to deliver almost 20Hp or 20% more power which is hard to understand.
On the torque side we would expect Atkinsonizing to cause a drop off of 25lbs-ft of torque so we might expect 90lbs-ft to come through this time instead of 82lbs-ft. It will be interesting to see how MG1 handles this. Either the PSD ratio will be increased speeding MG1 beyond 10000rpm or MG1 will be beefed up to handle the new torque.
T2
In the HSD system - at startup - at a standstill - there is a 10 sec delay designed into the running of the drive system. This I believe is called phase 0 in some discussions. The vehicle is READY if the driver chooses to drive immediately but if the vehicle remains stationary then nothing happens until the ICE kicks in - giving a boost to the traction battery.
My admittedly non-technical hypothesis is that MG1 draws some juice from the traction battery to get the ICE pumping and spinning without actually injecting any fuel into the cylinders. This to make the ICE ready to jump into action in an efficient state. If the vehicle doesn't actual go into drive mode then the ICE starts to pump fuel and generate power which goes to 'pay back' the juice borrowed initially.
After the ICE has paid back its debt it shuts down until needed.
How much of this is accurate? Thanks
The 10 second delay on the Prius system engine startup may be the coolant temperature bypass valve allowing hot fluid stored in the thermos reservoir to be circulated through the engine. When that has been accomplished it enables starting of the engine to proceed.
Why is it programmed to do this ? I can only guess that the assumption is that if the car is not going to be moved in electric mode after a reasonable time delay, all bets can be covered if the engine is pre-emptively 'prepped'.
T2
