Towing and Overdrive
2»
  • warfishwarfish Member Posts: 117
    My new tires are load range E, rated for 3045 lbs at 80 lbs pressure, almost the same as the Michelins were. I also just had the rear end lowered and softened at a spring shop and now it's just great.
    obyone: Sorry for the confusion. The tires came with the truck from Dodge so I don't think they were Sears cheapos.
  • markbuckmarkbuck Member Posts: 1,021
    C range = 6ply 50psi
    D range = 8ply 65psi
    E range = 10ply 80psi
  • rrichfrrichf Member Posts: 211
    warfish,
    Now I understand what you're saying about RPM and REAL MPH. The tires are bigger and therefore it takes less engine revolutions to go a mile. Makes perfect sense, but alas the speedometer reads 'slow' for your real speed.
    Rich
    rrichf,
    Right, except I went the other way, to smaller tires. That makes my speedo read about 2.5 mph fast and I think there is enough variation in a normal speedo to make this not worth worrying about.
  • bob332bob332 Member Posts: 137
    Keep posting and this towing topic should continue. I like and prefer bigger tires--no big deal with the speedometer--just keep in mind that you have done it and allow for the difference. Problem might be when someone else drives the truck. The Silverado tow/haul mode will be better for a lot of jobs and especially for towing a fifth wheel. Bob
  • mahimahimahimahi Member Posts: 497
    The formula for the difference in the Speedo is: (New Tire Diameter/Original Tire Diameter)X Indicated Speed = Actual Speed with NEW Tires.
    Example: (32.5"/27") X 55MPH = 66.2MPH
    Here's the formula for the change in highway performance:
    (Original Tire Diameter/ New Tire Diameter) X RPM@MPH = New RPM @ Actual MPH
    Example: (27"/32.5")X 2400RPM = 1985RPM 55MPH with the NEW tires
    I got these from Tire Rack
  • meredithmeredith Member Posts: 575
    After 30 or more days of inactivity....
    this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
    Front Porch Philosopher
