Problems with Goodyear tires
Me, I have had Good Year ATs and was nothing but pleased, both performance and price.
- Tim
By the way I did not get firestones again because they did not have them in the size I wanted.
Bridgestones have been used ever since, and tires have no longer been something to think about.
Lariat1. I'd print out all this conversations stuff, type Goodyear a really nice letter and see if they will do any customer satisfaction stuff for you.
Sorry, I own their stock. I want them to be world class. They got kicked off the DJIA last summer and their stock dropped to 1/3. Suspect they would like to return to their previous glory. Maybe they will help you out.
After considerable heated discussion, they finally gave me the Michelins I wanted to begin with. The Goodyears had only about 15,000 miles on them by that time and they weren't fit to put on a junkyard truck. I'll never own Goodyears again.
In my opinion, Goodyear does not care about quality, only quantity production. They put defective tires on the market and leave it up to the consumer to battle the problems. Not a good way to become a world class company.
My impression of Goodyear is that they aim to produce tires for the vehicle that is used as a commuter-mobile, and they are probably very good at doing so - good value, good wear etc.
However, by trying to meet that narrow sector of the market, they often have problems when their products are used by more 'entusiastic' drivers - just my experience.
On the '99 SD the tread depth is running 7 to 9 and has almost 40K miles. The tires are Firestones 265-75R 16 E. Maybe I'll get 60K???
My experience is that Goodyear makes the best tires in the world and I don't own any GY stock.
If that is how to describe GM, there must not be words bad enough to describe Ford. I now tell people that I used to like Ford until I owned one. I have had much better luck with GM than Ford. I have probably had more problems with my one Super Duty truck, than all my GMs put together.
I have also had very good luck with Goodyear. I had an 87 Z28 with the Goodyear Eagle GT's and I would get 45K out of the fronts and 90K out of the back tires. I never rotated the tires at all, so if you believe the theory that rotating extends the overall life I might have gotten 80K on each tire. I personally think the potential downfalls (like wearing all tires quicker with a bad front end alignment, etc.) outweighs the benefit of rotation. The Goodyears on my truck now still look brand new with 10K miles, so I can't imagine them wearing out at 20K, and expect they will last as long as the Z28's. I will rotate the truck's, but only because it is a 4X4.
The only thing about Goodyear that impresses me is their blimp...;)
Went to the Michelin dealer, he told me my front end was good and no aligment was needed, got four Michelins and went 80,000 miles I did not even rotated the tires like I was supoused too, just bougth four new Michelins and I feel like the old ones could have gone another 10,000, perfect even wear, the extra money one pays for the tires is well worth it, superb ride and grip and the long life more than makes the extra money.
Talk with people without LS diff's, and you'll find that they don't understand why you're whining about tire wear -- since they don't have it.
Also like Goodyears!
BFG doesn't make tires any more. They sold their tier business to Michelin in '86.
Rich
My experience,
I think performance comes with competition changes. I think mfr want to make them top sellers wihout the testing required. At the moment I have BGFS on my wrangler. No problems. I read your letters and I cringe. Now I'm undecided on my next set of tires. Perhaps generic kelly tires?
Goodyear doesn't make a LT 265 x 75 R 16 in laod range E.
Rich
bowhuntwi2,
The LR D tires are good to 3000 pounds at 65 PSI. The LR E tires are good to 3415 pounds at 80 PSI. I don't know what you're driving but you would be hard pressed to max out the tires at 6000 pounds before maxing out the axle.
Rich
Had some BFG all terrains in same tire size on a 88 Full size bronco and they hydorplaned VERY bad. I think the tread has changed on them though, or mabye I saw the new line similar to them, but they looked worth trying. The old BFG's didn't have channels to let the water move sideways out from under the tread. These others I saw recently had the channels and looked more "water on pavement" friendly though the mud performance probably suffers.
Isn't the convention for you to never use a patched tire as the spare because you will never know if the patch failed or had a slow leak until it is too late (ie. when you go to use it because one of you non-patched tires just blew out). Get my drift.
If you've come across this discussion and would like to continue this subject, please feel free to open a new discussion on our Maintenance & Repair Message Board.
In addition, here's another active tire discussion from Maintenance & Repair that you might find helpful: Tires.
Thanks for your participation. ;-)
Pocahontas
Pickups Message Board
