Toyota Tacoma vs. Nissan Frontier
124»
  • cncmancncman Member Posts: 487
    don't know where you are getting you info that the frontier isn't even close, the 2.4l fromtier tows 3500lbs, has a 1400lb payload and there is only about 4-5tenths of a difference 0-60 between the two. The tacoma is a great truck it was my second choice after my frontier, I just liked that I could get the same quality in a bigger truck with a bigger bed with more features for less money.
  • webbdwebbd Member Posts: 176
    You're right about the nissan and reg cab models being close, but the tacoma's numbers are still better. 94 lbs more payload, equal towing, but acceleration between reg cabs is not only 4-5 tenths difference. The reg cab frontier ('00) is 2999 lbs. compared to 2580 for the tacoma. The tacoma has much more low end torque on its 4 cyl compared to the higher strung 2.4L from nissan which has a higher HP rating. Couple that with a difference of 419 lbs. between the two and account for the slickness of the tacoma's 5-speed trans. vs. the longer throw of Nissan's trans., and you have something like 1.5 sec. difference in the speed sprint. (sorry, I don't have any magazine test to back this one up. Just basing this on personal experience at stoplight.)
    The tacoma's reliability is far better as well. But you're right about the price issue. The frontier is cheaper, when you look at 4x4's or desert runners, but when comparing reg. cabs, they are almost identical. I bought my '98 reg cab for $12,500. That's a pretty cheap new vehicle no matter which way you look at it.
    I still think both reg. cab models are uglier than anything on the road, of course, and will never buy another reg. cab model.
    I got my info from carpoint.com, by the way.
    Have you actually driven the frontier 4cylinder hard? All 0-60 data I have seen show less than 8tenths 0-60, also eveyrhwere you look the nissan and toyota are rated about the same in quality, I have experience with Nissans and toyotas, they both will last longer than you will probably keep them, have fun with your toyo, nice truck
    CNCMAN, the difference is the weight. Put 400 pounds in the back of your truck and do a timed acceleration test. You'll add anywhere from 3-6 tenths to the time. I don't know what tests you are referring to, but the lowest 0-60 time for the reg. cab. tacoma is 8.4 and I've never seen a Frontier of any model get below the nines. They just weigh so much more. There are no trucks short of the V-6 2wd Tacoma, V-8 powered Dakota, or V-8, 5-speed Silverado's which dip into the 7 second range (Lightning and modified one-off's excluded).
    I'll research and try to find a test of reg. cab frontier so I can give you an accurate number. The 8.4 above for the tacoma either came from Edmund's or a magazine. I'll get that one for you, too.
    By the way, I was commenting on reg. cabs, but I no longer own mine. I traded up for the Prerunner ext. cab. I don't dislike Nissan, don't get me wrong. Good luck with yours and I'll be getting back today or tomorrow if I can find those stats.
    I looked all over the web and could not find any performance tests for the reg. cab model frontiers or tacomas. So until I find some, just disregard any of my babbling.
    webb;
    The 0-60 info I have is for king cabs for both, which should be comparable because they both have the 2.4l 4cylinder.
    9.7 seconds for the tacoma and 10,2 for the frontier. Also I just realized you said you paid $12,500 for your regular cab,
    that's how much I paid for my XE King cab with the VTP 5spd. I also have privacy glass, sliding window, 15" alloys, step bumper, mats, etc. My only point is that you started claiming that there was a world of difference between the two trucks, I really think when you look at all the data, they are pretty much on the same level, and you can't go wrong with either I don't think, just depends on what you like, I am going on vacation today so everyone have a happy holifay! (why is this darn type face so small? I cna barely read it!)
  • akgakg Member Posts: 85
    I am wanting to purchase either a Tacoma or Nissan doublecab 4x4. I have only had 5spds in the past, but am now considering an automatic(which is what the Taco comes in anyway). Here are a few questions: What kind of gas mileage do the two vehicles get? Does it vary between 5spd and auto? I helped a friend recently purchase a 2000 Nissan double cab, and it was nice, but didn't seem as 'quality' as the Toyota. Also, I owned a '96 Tacoma 4x4 xtracab, which felt unstable to be, does the double cab afford more stability?
    One last question, I have found out the the 4runner is going to re-generate in 2002, how about the Tacoma? Does anyone know the next Toyota small truck will be introduced? Thanks!!!!
    I read 2003 in car and driver or motortrend as far as a redesign year for the Tacoma. That sounds about right considering they just released the Double Cab and will take a couple of years to milk that before overhauling the design.
    There is a quality difference between the Nissan and Toyota trucks period, regardless of model. The frontier is cheaper in price because of this.
    As far as gas mileage, I think Autoworld got 18 mpg with theirs (could be wrong on that.) I have a prerunner, which weighs about 400 lbs less than the 01 Double Cab, and I have gotten 18.67 MPG in 29,000 miles (I keep detailed files).
    As far as stability, I haven't owned or driven a '96, so my comments would only be relative to other models I have owned or driven, but my truck is stable considering its height and suspension. You won't mistake it for a 911, but you can take corners with confidence in it.
    Hope some of this helped.
    I'd still like to get some feedback from Tacoma Doublcab 4x4 owners who have owned the truck for more than a month...past the honeymoon phase. What are your likes and dislikes about the truck? Also, I'd like to geta gas quote on owners of the 4x4 who live in a hilly area. I have never bought a new vehicle before and I want to be sure that this is a good move for me. I still am thinking about the Frontier Crewcab too. Happy holidays!!!
    Just trying to figure out where you are getting your info from, first you said the numbers on the toyota blow the frontier away, but they are virtually identicle, then you said the frontier only costs less on the higher models, but I paid the same for my king cab with more equipment as you paid for your regular cab. Now you say there is a price difference because the toyota is so much higher in quality, well just check out msn.com's reliability ratings for toyota pickup and nissan pickup, they actually rate the Nissan higher than the toyota! Also the frontier got JD powers award for highest in inital quality, I can't remember when the tacoma got that last, I am not saying the toyota is unreliable, because it isn't but to say that there is a gap in the quality and reliability between the two is ridiculous, they are both excellent relliable vehicles and any decent site that shows longterm relibility proves this, also you can check out intellichoice.com, shows the frontier has the lowest cost of ownership too, if you have some different data please share with us.
    If you read the post above, I made no assertions to the numbers of the Tacoma blowing those away of the Frontier (that was earlier in this topic and we came to a consensus on that issue already). The only statistical advantage of the Tacoma over the Nissan would be power--acceleration, specifically. They both are rated the same in towing, but even the supercharged Frontier still comes up slower 0-60 than the normally aspirated tacoma 3.4.
    I stated that frontiers are cheaper in price because of the value difference. If you question this, go to Kelly Blue Book and check out the resale value of the Tacoma to get an idea how the buyers and sellers perceive the quality of the two trucks. A comparison between a 1998 regular cab tacoma and frontier with nothing but A/C on either one and 30,000 miles netted $1825 more in resale value for the Tacoma.
    And, actually, the Mazda B-series won the latest J.D. Powers initial quality study. Here's the link: http://www.jdpower.com/auto/jdpaawards/award-au00.html
    The Frontier did win the 1998 initial quality study 2. Here's the link: http://www.jdpower.com/auto/jdpaawards/award-au98.html
    The Tacoma last won in 1997. Here's the link:
    http://www.jdpower.com/auto/jdpaawards/award-au97.html
    If you check out consumer reports magazine, which has the largest pool of respondents to query from, you will find the Tacoma consistently ranks #1 in its segment and does it convincingly.
    Your data from carpoint.com is inconclusive as there are only a handful of people rating those vehicles. For example, in 1998, the frontier was rated 9.1 from 17 respondents and the tacoma was rated 8.7 from 41. If you add 24 more ratings onto the frontier's, you'd probably water down that .4 advantage. But even 41 is not a large enough sampling to represent several hundred thousand owners.
    Both trucks are good choices, better than the so-called domestics, but I, personally, choose the tacoma over the frontier.
    Webb,
    I think you looked at the new truck ratings not the used cars like I said, sorry, the link does not directly post here, go to used trucks, then look at nissan pickup and toyota pickup, it shows data with problem areas and overall dependability ratings for 91-97, these were compiled by an automotive repair consulting service that gets over 20,000 calls a month. Nissan is rated higher.
    Actually you did not state that there was a difference in price because of a value difference, you said,
    "There is a quality difference between the Nissan and Toyota trucks period,
    regardless of model. The frontier is cheaper in price because of this."
    Which it is obvious that the quality/dependability of the two are comparable. If you meant to say there is a value difference, I am even more confused, I think if you can get a king cab with more equipment, bigger bed, larger tires for the same price as a regular cab with less equipment that is a good value, and your resale argument would be valid if the trucks were the same price new,
    but there is actually around a $1500 difference in prices new, so actually resale value between the two is the same also,
    My comparison was between '98 models at carpoint.com. But, from my Consumer Reports reading, I made the comment, "There is a quality difference between the Nissan and Toyota trucks period, regardless of model. The frontier is cheaper in price because of this."
    I looked at the '91-97 reliability boxes at carpoint.com (yellow, red, and green colorings), and, yes, it appears that during those years, Nissan had less problem areas and fewer problems in those problem areas than did Toyota.
    Good job, Cncman.
    I think this just goes to show that reliability is a hard thing to pin down, I know people who have had hyundais for years with no problems and swear by them, and I have known folks that have had alot of trouble out of toyos. The toyo still would be by far my second choice and I would not even consider a ranger/mazda S10 etc. good luck to everyone in the new year.
  • volfyvolfy Member Posts: 274
    Having owned both 4x2 Tacoma and Frontier, I'd have to say that there is little quality difference between the two. If anything, the Tacoma feels spartan compared to a comparable Frontier. My new Frontier is quieter and has a more composed ride. The heavier Frontier does feel less quick than the darty 4cyl Tacoma it replaced, but has plenty power for my needs. I bought the truck for light-duty hauling/commuting, not drag racing.
    Above all else though, the single biggest drawback with the Tacoma that kept me from being a repeat customer is its lack of side notches for setting pieces of 2x4 lumber so I can haul 4x8 plywood sheets flat. It was a pain not being able to do that when I had the Tacoma. I don't know why Toyota doesn't just pay the royalty to whomever holds the patent on it and implement it in the Tacoma. Granted it's a small detail, but a pickup truck is meant for, well, picking up and hauling loads. So a minor oversight in that department becomes a big drawback in my book.
    Having lived with the Tacoma, I now know why MDF comes in oversized 49"x97" sheets. Can you say "shipping damage"? ;-)
  • meetturbomeetturbo Member Posts: 5
    volfy- I have to agree with your comment on the 2X4 notches in the bed! This has been a concern of mine in the past as well, but I usually have a 16 foot trailer behind my Taco so I don't really worry about it so much anymore. However, my past experience with Nissan has been less than perfect(to say the least). My problem consisted mainly of interior trim quality with my truck as well as my NX2000 car. The only reason I still have the car is because it is very fast, beat out every other car in its class in 1991, and I have wanted one since the first time I layed eyes on it. And as much as I like it< I would sell it in a heartbeat if I thought someone else might want it, and then I would go buy another Toy truck for my wife to drive!
    I can only compare the interior trim quality between my '96 Tacoma and '99 Frontier. I had to remove the door panels and other interior trim panels to install speakers and audio/alarm wiring on both trucks. From what I saw, there weren't too much difference in terms of material, fit and finish.
    Incidently, the Tacoma did not come with seat back covers (the yellow foam was in plain view) and cabin backwall liner (just bare painted body panel).
    I do wish both Toyota and Nissan would use better grades of interior trim plastic, as the hard plastics in both trucks are easily scratched.
    My wife did like the spunkier & nimbler Tacoma reg cab better than my current Frontier ext cab, but even she can tell the Frontier rides smoother with better NVH isolation. Compromises, compromises...
  • leon_vleon_v Member Posts: 8
    Good morning.. i am about to start looking for a truck ( i have godd 5-6 month before i can actually buy one) i do want to get a 4x4 and was looking at the tacoma's TRD package.. but i am a bit confused.. with the package the price jumps up about 4000-5000... and if all it is is just flares and shocks.. i am not too crazy about the flares.. so if all it is is just better shocks.. whould it not be cheaper to buy some and have them installed elsewhere?
    it might sound naive but i am not quite sure what the trd package is..
    thanks for your help
  • jayson4jayson4 Member Posts: 5
    the trd is more than the flares and shocks... im pretty sure it includes bigger tires.and better rims. also.
  • allknowingallknowing Member Posts: 866
    If you really believe that that the TRD package is only flares and tires don't buy it. Leave the TRD's for people with the ambition to to do a little research and get a few facts rather than inaccurate here say.
  • toyossantoyossan Member Posts: 1
    I am in the same boat as many. Toyota DC or Nissan CC. Comparing Toyota DC V6 w/ SR5, TRD versus Nissan CC SE-V6 w/ Deluxe Package. Tacoma offers auto(which I really do not want) slightly larger bed and cab. Nissan offers an attractive roof rack, better stereo and a rear slider. Tacoma seems to cost (MSRP) a little more and also looks like it sells near MSRP after researching carsdirect.com. Let me hear you Tacoma and Nissan owners defend your favorite truck.
  • tr1jr2tr1jr2 Member Posts: 2
    Bought the Toy in November after driving the Frontier, there is no possible way that anyone would buy the Nissan after driving them both, believe me I wanted to buy the Nissan in a bad way but that engine SUCKS, while driving with the dealer his only comment was that they are coming out with a supercharger, WELL I DONT BLAME THEM CAUSE THEY ARNT GOING TO SELL MANY OF THESE DOGS IN PA, They shouldn't have to put a supercharger on a truck engine, to think that they rate the Frontier at 5000# towing is JOKE, I dare someone to try it in PA, this thing could hardly pull itself up a hill let alone 5000lbs. Don't believe me? Drive them both (UP A HILL) and punch it. GOOD DAY
  • toyrotatoyrota Member Posts: 66
    I first looked at the Toyota Double Cab SR5, then the Nissan Crew SE. At first glance, the Nissan appeared to be a better deal (roof rack, step rail, cd player etc...). I seriously began to consider the Nissan, even though I have owned Toyotas in the past, and have nothing but praise for toyota. I even looked at the Crew Cab SC, thinking that I could get a 5 spd coupled with the supercharged engine for the same money as the toyota V6-auto combination. And I could have. But after comparing interior space (especially the rear seat and door ingress/egress), level of fit and finish, bed length, engine smoothness and power, and the fact that the 190 horse toyota will run on 87 octane, but the Nissan SC requires premium, I decided to go Toyota. And I have NOT regretted it! My Toyota cost approx. $1000 more than a comparably equipped Nissan, but there are some things, like engine smoothness and more room, that are priceless.
  • tistevetisteve Member Posts: 142
    The TRD package has the following: 31" x 10.5" Goodyear Wranglers on aluminium wheels. Progressive rate springs and Bilstein shocks. Locking rear differential. Fender flares. Maybe a front sway bar(not sure). This package should only add about $1600 to the price of the truck. If your seeing trucks costing 4-5k more, they must have other options like power windows, locks, V-6 vs. 4 cyl, auto vs. stick, etc..
    I have had a Tacoma with out TRD and now with the TRD package. I love the difference, it is a much firmer and tighter ride. Some may not like the harder ride, but I think it handles a lot better and doesn't bottom out as easily off road. But if you want a "car like" ride, the TRD is not for you! It can be too harsh on really bad roads.
