~alpha
FWIW, the 2.4L in the RAV4 will be rated at a healthy 165 foot pounds of twist at 4000 RPM. (Essentially, this engine is the current Camry's 154 horse unit outfitted with variable valve timing on BOTH the intake and exhaust valves, I think Toyota calls it Dual VVTi or something like that. The result, vs. the '06 Camry's engine, is increased hp by 12 and torque by 5, and I'd venture the engine is quicker to rev/respond to thottle inputs, since it is "breathing" better).
~alpha
~alpha
The V6 will be more than fine.
3rd row is for bragging rights and resale value. Most people don't actually use them. My friend bought an Aviator and removed it, never used it once. It will help market and sell the RAV4. Packaging looks pretty clever for the small size, if you ask me.
-juice
I am now unsure if I should wait or just by the Outback. The new Rav should be at least as good as its competitors in size but then again Honda's got a new V on the horizon too. Also, they are sure to sell alist at least for a while and now doubt there will be a price increase. Finally I'd be leary about buying a car in its first model year...my 02 Camry is rattle trap....then again so are the 03-05 models. Yes this will be a hard decision.....
If you go with the Outback, get the 5M. The 4A is quite slow, with very soft acceleration from a stop, though passing isnt too bad. Or of course... GET THE XT!!!!
Good luck!
~alpha
Is a FWD RAV4 an SUV? Depends on your definition, but ask a Jeep owner if he/she thinks so, I doubt you'll get a yes.
Recreational, Active Vehicle with 4WD, isn't that what the acronym stands for? They made it look like an SUV but I'd call it more of a crossover, actually.
We agree that it's closer to a Forester, especially the outgoing model because the new one is quite a bit bigger.
-juice
The Rav is taller but I found the space in the Forester and/or Outback is more accomodating. I'd rather have my stuff spread out than piled high so I can not see out the rear window.
My original rant was really with Toyota for not being forthright on the Ravs new release. I mean my own dealer outright lied...assuming a redesigned RAV really hits the streets before next July!
You can not really compare the *new* RAV to anything yet; it does seam to be catching up to others in its class in terms of size. Will it price itself out of the market? Will it be too big for its following? WIll it be too small for Highlander owners who are peaved the new HL is getting bigger to compete with the Pilot? Time will tell. Timing is bad for me right now...I'll let you guys be the guinea pigs this time...I did that with my Camry...never again!
And before any one jumps in, I'll point out that the Aussie Foresters actually do have a low range. Skid plates, too.
-juice
it would be much quieter, and more fuel efficient!!! but NO!!! I like toyotas but when i start looking at what they actually come equipped with other cars such as honda's cr-v become more and more appealing!!!
any suggestions why it might be better to have 4 speed in the new rav4 and not 5? i can't think of any!!!!!
The 2006 Siena uses the same type of seats in the third row and they're great! Now, whereas the Siena's third row will seat three (using a 60/40 split, each section folding flat independently) the Rav4's third row seats two with a 50/50 split, each seat independent of the other, and both seats, when up, providing a much higher and more comfortable seat (with actual depth for the lower legs and feet) than the Highlander's third row. For those who don't like the spare tire on the back of the vehicle, think of the comfort and storage you'd be giving up just to have the spare tire "inside" all nice and cozy and warm? :confuse: I think it makes sense to have the "full size" spare on the outside rather than resort to a "temp" spare, or worse yet, "run flat" tires like the AWD Siena uses. :lemon:
One nifty solution I've seen is a cover that slides over from one side. So it can remain with or without the 3rd row deployed. Pretty nifty.
-juice
-juice
A V6 will be available, but I'm not sure if its going to be at launch.
So it's 1/4 of the price. Plus with a battery I can take it inside to program addresses, and move it from car to car, even without the power cord.
-juice
My HP setup works pretty well, plus I get a PDA with wireless internet access when I head to Panera.
And it goes from my little car to my medium one to my van easily, and its all wireless.
It works, but its best when you have a co-pilot programming it.
One guy in the NAV thread put one in his van, he also plays DVDs for his kids. It's one or the other, though. Obviously.
Though I guess someone could invent picture-in-picture for a laptop.
-juice
Problem solved.
Although its hard to beat the cool factor of having it built in...
But a lot of times car companies will call AWD systems "4WD" to make it sound real.
The Toyota Highlander's like that. It says 4WD, but its really AWD. Which just adds to the confusion.
I had one of the very first RAV's in my area, and now am on my 3rd one. The have all been 4WD automatics. The last 2 I did the lease thing as I like to have rather new vehicles and it seemed the way to go.
Most of my driving would be considered local..I don't need it for heavy snow or anything like that..I wonder why I keep getting 4WD? One thing I like about the RAV is the way th rar door opens..sideways rather than up/down. Funny, I have had many men comment on the convenience of this when noticing in a parking lot.I don't think I could go back to a sedan..I thought about the Matrix, but have noticed some unfavorable comments about its power!
I would appreciate hearing what you all might come up with for suggestions for me. My lease ends early August...seems like that might be a good time IF I do another RAV...
Thanks...Joan
I think the new V6 will be a detuned 3.5L ~250 HP. WAY more power than the current Highlander except for the HH @ 268 HP.
But after they link the HSD to the 2.4L in the Camry next year it would make sense to add the RAV 2.4 to the HSD lineup.
3.5 V6 is MONEY NOT WELL SPEND.
For the very reasons you mentioned I dont think the 3.5L will be a big seller either. The RAV buyer is not a high performance freak. As a matter of fact 'Yota might get more sales from a 2.4L-HSD combo... But.. for the time being the 3.5L RAV acts as support for the V6 Highlander in the same way that the XLE Camry V6 acts as support for the Avalon series. Nature abhors a vacuum and so does the market.
I think the V6 is a wise choice if you opt for the 3 row model and plan to use that 3rd row. Or if you routinely tow or haul heavy loads.
For most people, though, the 2.4l is fine.
-juice
This first order (what they call Nov and Dec allotments) is only for 4 cylinder versions....6 cylinders to follow.
It seems that Toyota Canada has made things really simple.....just 2 flavours Base 4WD and upper grade 4WD. Pricing is not announced but the upper grade version will be $4000-4400. more than the base.
Automatics only....no 5 speed option! No mention on if it is 4 speed or 5 speed auto.
Here are the highlights:
BASE RAV4 has the following:
Power doors
A/C
Power Windows
Keyless Entry
Cruise Control
Dual front airbags
17" styled steel wheels
Vehicle Stability,Control Traction Control, On demand electronic 4WD
Super Electronically controled Transmission (ECT)
ABS
Electric Power Steering
The Upper Grade Rav4 adds the following for $4000-4400 more:
6 disc CD changer
dual zone A/C
upgraded seat material
power drivers seat with lumbar
leather wrapped steering wheel and shifter
Large capacity storage box under rear deck
footwell lamps
Alloy Wheels
Privacy glass
Chrome grill, moulded spare tire cover
Power moonroof
colored door handles and rear spoiler
Fog lamps
Towing capacity rated at 2000lbs and 60 litre fuel tank.
So there you have it....what REALLY BOTHERED ME:
No side airbags!!!!!!
No mention of a 3'rd row seat (must be a 6 cyl only option)
No Manual Tranny
Don't they notice Kia and Hyundai adding side and curtain airbags to everything!!!
The base unit has decent features if the price is good. My guess Base at $26-27K Canadian with the upper at $30-31K.
I'm sure the US cars will have more options available...likely inc side airbags which is the current situation (2005 Rav no side airbags in Canada but yes in US)
I had high hopes but now I'm feeling bad....wife would like a 3'rd row seat for kids and their friends and I wanted side airbags....have to keep limping along with my 98 Forester S....2007 Mitsubishi Outlander??
i drove Forester...nice, very nice!!! Subaru will have a completely redesign forester for the late 2007. what do you think is it worth the wait? should i pass on 2006 rav?
I also forgot to mention that Base Rav comes with a telescopic steering wheel.
Next Tuesday there should be much more info on the Rav from the US launch.
2000 lbs towing? That's it? Pretty wimpy for a V6. Why have all that power and then not let it do the job it could do?
-juice
