This post is completely speculative. Although GM confirmed that they are dropping body-on-frame mid-size SUVs, Ford never stated this. Just the opposite, Ford will likely continue to offer a body on frame Explorer because while the market is shrinking for this type of vehicle. The number of vehicle choice will shrink also.
Not trying to pick a fight here, mschmal - if you're an insider who knows more than the engineer I know at Ford who told me this, I defer and apologize. I'm actually happy to hear you say that.
Admitted, things may have been reversed by ARM since he took over, like the Panther car demise, the Taurus demise, perhaps he saved the Explorer also.
I bought an 05 Mountaineer about 4 months ago, when I first bought it the EGR Valve had to be replaced and since then it shift really hard and quick, but not all the time. It comes and goes, and it seems to be the worse after sitting in the hot muggy weather all day and if it is below a half a tank. May just be coincidences. Any suggestion would be grateful. Also, I did not get the owners manual with the vehicle and after my brother changed the oil, we did not know how to reset the oil sensor, again, an help wwould be gratfeul. Thanks
You may register on Mercuryvehicles.com as owner and download electronic copy manual
To Reset Merc Oil life.....
Use Reset button on Right of Steering wheel
System check CHANGE OIL SOON/OIL CHANGE REQUIRED. Displayed when the engine oil life remaining is 5 percent or less. When oil life left is between 5% and 0%, the CHANGE OIL SOON message will be displayed. When oil life left reaches 0%, the OIL CHANGE REQUIRED message will be displayed. An oil change is required whenever indicated by the message center. USE ONLY RECOMMENDED ENGINE OILS. To reset the oil monitoring system to 100% after each oil change [approximately 8,000 km (5,000 miles) or 180 days] perform the following: 1. Press the SETUP control to access the System Check function. 2. Press and release the RESET control to display “OIL LIFE XX% HOLD RESET NEW”. 3. Press and hold the RESET control for 2 seconds to display “IF NEW OIL HOLD RESET”. 4. Press and hold the RESET control to display OIL LIFE SET TO 100%. Your oil life is now reset. To reset the oil monitoring system to your personalized oil life %: 1. Press the SETUP control to access the System Check function. 2. Press and release the RESET control to display “OIL LIFE XX% HOLD RESET NEW”. 3. Press and hold the RESET control for 2 seconds to display “IF NEW OIL HOLD RESET”. 4. Release the RESET control momentarily, then press RESET and SETUP controls at the same time to activate a service mode which will display OIL LIFE XX% RESET TO ALTER. 5. Press RESET until you find your personalized OIL LIFE XX%. 6. With your personalized OIL LIFE XX% displayed, press SETUP to continue the system check. Instrumentation
If it's an 05, it has the 5 speed transmission. It sounds like it could stand a reflash. Those rough shifts are usually intermittant, but often a reprogramming will correct them. I'd try that first. You don't want to know what I suggest second....
Just a little info on the Mountaineer's performance in sand. We spent a week in St. Augustine Florida which has approximately 5+ miles of beach available for driving. 4WD is recommended but I did see many cars that were able to drive on the beach in limited locations. The sand was hard packed in some locations but could instantly change to very soft fluffy sand (which many cars found out in a hurry). The Mountaineer seemed to perform flawlessly in any and all soft sand situations we encountered. It was driven in both the "locked" mode and in the normal AWD mode. I was unable to distinguish any differences between the two. If the vehicle began to slow in the soft stuff, slight pressure on the gas got it right back up to speed. Gradual stops and starts were also made with no difficulties. I'm a firm believer that driving in sand is as much the driver as it is the vehicle in most cases. I'm not saying I'd cross the Sahara with no worries but for general beach driving, the Mountaineer feels more than capable. In fact, it fills you with just enough confidence to probably get you in trouble.
Likewise, I've driven several of the Mountaineers we have owned in mud and snow, up and down steep mountain inclines in the same road conditions, and found the AWD system about the best there is. Conversely, I've been stuck in my Escalade AWD on snow, where I could not get up the hills in it. I'm a big fan of the traction system in the Mountaineer.
We just returned from the OBX today and here are the stats for our '06 Explorer XLT V6 4WD.
- 6 People (4 adults, 2 small children in car seats)
- Luggage for all 6 people and gear for kids all loaded in the cargo area (half of it anyway) and on a hitch mounted carrying rack.
- Tires inflated to 38psi (35 is the mfr recommendation)
- A/C the whole way and CC most of the way
- Sat in traffic for about an hour on the way down (Labor Day weekend)
- 515 miles each way, averaged 22.8 mpg on the highway
- Total trip was 1237 miles, averaged 21.1 mpg for the whole trip.
I was very pleasantly surprised with those numbers as our Escape, that the Explorer replaced, could only get a bit over 23 mpg on the highway at best. Has anyone else seen numbers like that?
My dealer has been working with the flywheel clutch or something like that . It allows the engine and the transmission to communicate. This can be adjusted and if it doesn't stay adjusted it can be replaced. When mine was adjusted the car ran like a dream for 2 weeks...then it went back to it's old habits. They have replaced the clutch thing recently but after three weeks they still haven't given the vehicle back to me yet....still test driving it.This clutch adjustment seemed to really help.
I was wondering if anyone who has experienced the rough shift between 2nd and 1st gears, has had their vehicle fixed without the problem ever coming back? My 2006 Mountaineer V8 started acting up before 8500 miles and now I have 22,000 miles, and Ford has yet to come up with a permanent fix. They have downloaded several "fixes" that work for a few weeks, but the problem comes back. The transmission computer has been replaced, but that also lasted for about 2 weeks. The shift is so harsh, I feel like I have been hit from behind! I've been informed by Ford that a new download will be available sometime later in October or early November. The Ford representative said a replacement for the vehicle is out of the question, but they will give me an extended warranty. That will not help, because it is a leased vehicle and my lease ends at the same time when the warranty ends. Thanks a lot clueless Ford representative. When will Ford admit they have a bad 6 speed transmission? Any ideas or comments?
I think you can be glad you leased it, as opposed to buying it. Couple approaches you can take.
1.) You can just stick it out for what I think might be another year for you, dump it and move quickly to some other manufacturer.
2.) Assuming that the lease is with Ford/Lincoln/Mercury, you can attempt to work with the dealer to let you out of the existing lease and replace it with another Ford product. I personally wouldn't buy another equivalent model (unless you're convinced you just picked up a lemon), but could shift to another model.
The dealership should recognize that in #1 you are walking and will never be back, which means no future revenue....ever. The advantage to them with #2, is that they have the ability to salvage the relationship with you, and lock you in to another 3 year lease with hopefully a much better vehicle. Assuming that vehicle is okay, then there is a reasonable chance they might even get another one.
Your advice is accurate. The dealer has been awesome in working with me on this problem. I know they have their hands tied when it comes to fixing the problem. Ford will not admit that there is a problem with many of their vehicles with this same problem. They only send downloads to temporarily fix it. The dealership has stated they stand behind me and will do whatever it takes to fix or replace the vehicle in the next month if the "new fix" does not work. It is Ford that I am upset with. They talk big about standing behind their quality product, but when it comes down to it, they will not do a thing if the lemon law is not followed to exact expectations. There is a lot more to this, but the bottom line is I'm very dissatisfied with Ford and this particular vehicle, and you are right when you say I'm lucky to have leased it, and I will be out of it in another year one way or another.
I'm following this one. My 2006 V8 Explorer has somewhat inconsistent shifting, the 1-2 is sometimes a little abrupt, and the 2-1 downshift after a highway run is sometimes quite rough. I had the same problem with my previous 2004 VW Touareg with the 6 speed Aisin tranny. When the lockup unlocked when slowing down after a highway run, it would sometimes shake my world. The Explorer upshifts better if I accelerate moderately instead of slowly. The problem is that moderate acceleration in a V8 Explorer is pretty strong and not appropriate in many traffic situations. Mine was reflashed about 5,000 miles ago, and I think it's regressed some. They also did something to the engine management system that makes the car cough and sputter for a few seconds after I put it in drive, first thing in the morning. Clears up after about 100 feet. That was after I complained that it cold idled at 2500 rpm. Kinda wierd. I'll bring it up next oil change.
My 2007 Mountaineer still has some of these issues. Rough shift from 1-2 and 2-1 downshift is sometimes abrupt when slowing in a parking lot for example. I did have it reflashed at 5k (for the 2nd time) and it was somewhat better for a week or two, then back to it's old ways. I returned it to the dealer again and was told that Ford would not authorize any further repairs. Found this rediculious since the mechanic and service manager both had said it should shift better than it does. Then the mechanic told me that he had talked to a factory rep that told him if it shifted fine after the flash and then got worse it was my fault. WTF!! He said that it learns driving patterns and if both my wife and I both drive it that we have different patterns and we were confusing it. At this point I rolled up my pants and told the mechanic that if he was going to start throwing that much s..t around I didn't want to get my pants dirty. I then asked the manager if Ford's official position was that the rough shift was my fault. He refused to comment. 10k service next week, we may try again.
As a side note, earlier posts say that replacing the valve body will correct this problem. When I asked about that I was told that all 6 speeds made after July of 06 (mine included) already had the new valve body so other than reflash there was nothing left to do.
I plan on keeping the vehicle for a while so I'm hoping this issue doesn't get worse. Although if it got worse I suppose they would eventually have to do something. I just hoping that the 6 speed doesn't turn out to be a hibitual piece of crap.
Last note, aside from all the above whining, I love this vehicle and enjoy it every time I get in it. Just didn't expect a 35k plus vehicle to not shift smoothly.
I have posted before about my concern over the intermittent harsh and abrubt downshifting of my 2006 Mountaineer. I have had to take the issue to the Better Business Bureau Auto Line. I would like to ask if others are still having the same problem with the transmission. Have any been fixed permanently? If so, could you let me know by responding to this post? I want to be sure both parties involved in this dispute, see that the rough transmission downshifting is not a single incident, but one that involves other Mountaineer's or Explorer's.
I found this on several other Mountaineer forums. Apparently Ford will be comming out with yet another update in mid-November. Let's all hope this one actually does something.
"Special Service Messages
20005 2006-2007 Explorer/Mountaineer/Explorer Sport Trac -- various transmission shift quality symptoms - 6R60 Trans - temporary, do not attempt to repair
Some 2006-2007 Explorer 4DR/Mountaineers and 2007 Explorer Sport Trac vehicles equipped with 6R60 transmissions may exhibit various transmission performance issues. When compared to other transmission, some of the shift characteristics are different that previous models due to the 100% synchronous design of the 6R60. Customer concerns that exceed shift characteristics of like equipped vehicles which may include transmission engagement delay when shifting between P-D, N-D, and R-D, Delayed/Hesitation on 1-2 shift, 2-1 and/or 3-2 decel step in shifts. Hoot noise during cold 1st gear launches from transmission pump. TSB-07-13-08 has been deactivated in PTS. DO NOT ATTEMPT TO REPAIR VEHICLES WITH THESE CONDITIONS. ENGINEERING WILL BE RELEASING A NEW TSB APPROXIMATELY MID-NOVEMBER.
sacmtnr - you beat me to it. I was just about to post this info. After 8 months and about 10K miles, our '07 V-8 Explorer suddenly started downshifting (roughly) when slowing to a stop. We just brought it in last week and got the same info - TSB to be released in a few weeks.
This is our 5th Mountaineer/Explorer and the last 3 have had some form of transmission issue. And exactly why we have leased and not purchased. A real shame too - this last model was possibly going to be a 'keeper' - the best by far over any of the others we have had to date. Let's hope the TSB is more than just a temporary fix for a reoccuring problem.
Thank you both for that important information. I was wondering what other Mountaineer forums have discussed this transmission problem? I would like to collect all the information I can find in order to help my case when it comes to arbritration with myself, the BBB Auto Line and Ford Motor Company. I've had enough of this transmission problem. Thanks again for the information and I look forward to anything else anyone can provide.
I am experiencing this very same problem on my 2006 ford Explorer Limited. Dealer says check back in Mid Novenber. Otherwise great car-love to drive this high powered and heavy SUV.
I have had my 2007 Ford Explorer V8 in the shop 6 times for the abrupt shifting. They have reprogrammed a few times and replaced the megatronic controller (computer that controls the shifting). Just yesterday I had the new programming (the one they promised mid November) done (it just came out this week). So far, so good. It shifts a lot smoother, but I am not ready to "sign off" on this until I have a few weeks of smooth shifting.
I hope the new programming works on your Explorer. I've had the computer replaced as well and several new programs done over the past year, only to have the problem come back after a few hundred miles. That is the reason I'm working with the Better Business Bureau Auto Line. I'd rather have an arbitration hearing conducted in order to address this annoying issue. Maybe the more people who take Ford to this level, they will get more serious in attempting to find a permanent solution, not just a temporary fix.
Wow...just what I thought might happen. I am sure glad I did not take mine in for the latest "fix". Your post confirms my reason to take this to arbitration with the Better Business Bureau. I am so frustrated with Ford and their denial that this new transmission has a serious problem. They still claim that this abrubt shifting is the way it is suppose to work! I have to take a day from work and drive into a major city during rush hour to attend this arbitration, but now I am sure I am doing the right thing. Thanks so much for your reply. I hope more people with this problem will step forward. Good luck with your Explorer.
Are any of you having problems with acceleration from a rolling stop? For example, you yield to traffic on a highway, letting a car pass, and then apply the throttle to accelerate from the ramp, only to have very little acceleration (as if the vehicle were stuck in a high gear and refuses to down-shift)?
Yes, I have 100% of what you just stated. There are times when the gas pedal is all the way to the floor and the car is barely moving. I have Ford Escorts and Toyota Prius' pass me up.
I spoke with my cousin this weekend. He is a parts manager at a MD Ford dealer. I asked him what the status is on the rough shift issues with the 6 speeds. He told me that his dealership has been unable to provide permant resolutions to the rough shift issues. This includes the new (early November) programing update put out by Ford. He said that Ford is putting very little money into R&D right now and is "cash poor" and will make every effort to NOT have to issue any type of recall on these transmissions. They are still going to try and resolve the issue with further programing. I guess if the first 4 times it doesn't work you might as well try 4 more. After all, the customers time is worthless so what does it matter how much you have to waste with repeated trips to the dealer. My Mountaineer's shifting seems to be somewhat better. Although I'm not positive it's better. I may just be getting use to it now. I have not done the recent November update. Not going to make a special trip to the dealer for it. I'll just wait until the next oil change. Who knows, there may be 3 newer ones by then. Repeating an earlier statement, other than the rough shift, I love this vehicle. Everything else about it is great and with 12k miles, all is still very sound and well.
I have posted before about the harsh and abrubt shifting in my 2006 Mountaineer. Ford claims that how we drive creates this problem. If we roll threw stops or do double footed driving etc then this causes the transmission to shift harshly. This is actually in their own words! By reading other messages related to this it is obvious Ford does not want to acknowledge this is a design flaw for fear of recalls or whatever. Those of us who are having this problem need to banned together and submit complaints. A good place to do this is at http://www.autosafety.org/fileacomplaint.php. I just filed my complaint. I am looking into doing a class action against Ford who only sends the dealership recalibrations that only clear up the problem for a short time. Please let me know if anyone else is interested or experiencing the same problem.
Moutaineer power problems persist now I have gone through arbitration via the BBB and Ford. Now since I have gone through 6 fixes over 1.5 years wait for the next fix etc..... I have been denied because I have too many miles on the vehicle.Do I file a law suit who is a good attorney in Kentucky? What is the next move.What about a class action law suit? Is there any thing like that available to join? I'm sick of this... :lemon:
Depending on your state laws, I believe it is after the first date/mileage of ford's notice of the problem, which includes the service order with your dealership. Did you report this as a problem within the alloted span of the limited warranty?
Those of us who have been experiencing this problem are all fed up with Ford's inability and/or refusal to acknowlegde this problem. I posted a web site in an earlier post that has lawyers listed by State that deal with class action suits. You can also post a complaint at the same web site. I have already done this. I also checked where it asked if I would be interested in a class action suit. Doesn't seem like the BBB is of much help on this, because they do not get the true information from Ford. Ford has been lying to the BBB in that they claim their Mountaineers and Explorers that have this tendency are working as designed and are caused by the driver's characteristics! As we all know, Ford has posted a bulletin to the dealers stating not to "Attempt any repairs" on this problem and to wait for the next calibration, which was in mid November. It is a programming issue and I'm sure Ford has a problem trying to change it, because they risk screwing up emissions and probably fuel economy that have been set to governmental standards. So the result is Ford is stalling and fears a huge recall. My suggestion would be if we contact each other and give email, we can form some group that could start some type movement towards a class action suit. I'll wait to see what others on here will say.
Help! I just bought a new 2008 Mercury Mountaineer. There is a blinking red light on top of the dashboard facing the hood. I have looked all through the book and I can't find out what that light is for and why it constantly blinks. Can anyone help? :confuse:
Unless you purchased an optional active alarm system, it does only come with a passave (aka - ignition lockout) system that will only let the engine run for a few seconds without the correct key/chip used. The light blinks continuously whenever the key is removed and stops when the key is inserted. Short of removing the bulb, there is no way to turn it off. If it bothers you that much you could always just put a little piece of black tape over the light.
Thank you so much! The light doesn't bother me, only that fact that I thought something was wrong and I should be able to turn it off. You've eased my mind.
We're also interested in whether there's a class action suit against them. We purchased our second mercury mountaineer three years ago and before it hit 60k miles, our transmission went, the racken pinion (sp) and the rotars all went in the same week. Three weeks later something else went. A total of around $4500. As with most people, that loss of funds drained us and Ford Motor Credit wouldn't work with us on payments, so this past Wednesday the repo man paid us a visit and we had to say goodbye to our truck. We were starting to have problems with the transmission and the engine again, so we just let it go. Please let me know if you have come across anyone doing a class action suit against them. These issues certainly should have been a recall.
I am not sure if there are any class action suits against them concerning the transmissions. A good place to check or register a complaint is at the following web site: http://www.autosafety.org/fileacomplaint.php Ford needs to clean up their act in regards to their transmissions. Unfortunately, I will never purchase another Ford because of their attitude and the poor quality of their transmissions. This I feel is a shame, because I like so many things about the Mountaineer.
I own a 2006 Mountaineer V8 AWD and have the problem you describe with the "rear-ending". It does not happen with every stop, but it does happen every time I drive the truck. The dealer said to rotate the tires as the system senses a different wheel speed due to the different diameters caused by wear. It seemed to help a little as the forward jump seemed to be less pronounced and less frequent. It did not go away altogether, unfortunately. My wife did go over a curb rather violently and knocked the alignment off a bit. The dealer said that may cause the problem I am experiencing. I have yet to test that theory by getting an alignment. I do not have any shifting problems (yet)from start as others unfortunately have. It is just that fwd lurch at a stop. Other people have said that it is the traction control re-setting itself. I was curious as to the results and steps taken to correct this problem and if they had any lasting effect? Does the November TSB that eveyone is blogging about relate to this? Thank you 88Domer
Just a quick update on my Mountaineer. I recently took it in for the latest transmission flash update. It does seem to be shifting a little smoother even after a few weeks. Not a big difference, and not perfect, but it is a little better. After one year and 15000 miles I am use to the shifting. This is still also the only minor complaint aboiut the vehicle. Everything else about the vehicle is very solid and as good as the day I drove it home from the dealer. Mileage is consistantly 14 in town and between 20 and 22 on the highway. I did notice a 1 mpg increase when I switched to fully synthetic Amsoil 0W-20 oil. Again I think this is a great vehicle and with a little effort by Ford it could become even better.
I have not heard of this abrubt thumb when stopping as being caused by tires. Every person I have spoken to have been told it is a programming issue. I guess Ford will do anything to make people believe the problem with their transmission is anything other than a design flaw. I would suggest you have the newest program downloaded as suggested in other posts. I had my last one done in late November and it has improved slightly, but still has the same problem, but just not as abrubt as before. It still hesitates slightly when starting up from a corner, because it seems confused as to what gear it's suppose to be in. I've given up on this vehicle and will no longer purchase another Ford. When my lease is up next year, I will be happy to walk away from this problem. I recently bought a 1993 Cadillac Fleetwood with 91,000 miles to drive instead of the Mountaineer. It shifts smoothly and runs much better then my Mountaineer and its 13 years older. I'll use the Mountaineer in bad weather or when I need to haul something. The Mountaineer has many great qualities, it's just to bad that Ford is acting the way they are and turning away customers who have enjoyed their products over the years.
Sorry, and surprised, to read of your problems. Our Explorer, a '99 XLT with 104,000 miles, has been very reliable and fairly flawless. We use it somewhat as a truck- to haul construction materials, tow an 18' trailer, drive in deep snow & back roads. It has been good enough that a new Explorer would be the first thing to look at when I decide to replace it. I am careful with maintenance. I am not saying that all Ford products are great; we had a bad experience with a Ford Contour and a great experience with a Ford Taurus SHO. Now we have one German-built sedan and one Japanese-built sedan and have no allegiance to any one particular brand..
My 2006 Explorer V8 has exhibited some slight 1-2 upshift and downshift problems since it was new, but they were too slight for me to bother taking it in for service. I now have 34,600 miles on it, and the problem (occasionally feeling like being hit from behind on some stops, occasional jerky take-off from stops) had worsened, so I took it to Rancho Santa Margarita Ford. I especially appreciate the transmission mechanic's desire to having it right before returning it to me. He worked on it, and it was supposed to be finished at the end of the day Wednesday. However, when I arrived to pick it up, Duane in the service department explained that the mechanic was not statisfied with the way it shifted, so wanted to replace more parts. I picked it up this morning (Friday), and it is very, very smooth.
They did not have the paperwork ready when I picked it up, and I did not care, as it was warranty work, so I do not know what they replaced, although I think they will mail the paperwork.
I see that some of you seem to have the probelms return after the transmission was repaired. Is that correct?
From my own experience I would say yes to your question. It comes down to a computer download that reprograms the transmission. It will shift smooth for a few hundred miles, but eventually comes back. I have had this done several times only to have it reappear. The last one has improved it more than the other downloads, but it still on occasion shifts with the feeling of "being hit from behind." Good luck, and I hope whatever was done will last.
I went thru the same process and had all the problems associated with the transmission. Returned to the dealer three times and the last time they had the new flash code program. The mechanic also replaced something called a valve body and cleaned that area of any gunk and buildup. When I picked my Explorer up the mechanic also said that he wiped out the adaptive learning part of the computer and to give it a couple of days of normal driving. If I had any problems to bring it back. I'm happy to I've been problem free with the tranny. Whatever the dealer did (my mechanical skills are not the best) worked. I think that replacing that valve body with a newly modified version did the trick.
Awesome! How long has it been since you had it repaired? After my last new flash it took a couple months before it began acting up again. I'll keep my fingers crossed that what your mechanic did will continue to work.
If I remember correctly the problem was finally fixed (hope) back in late November of 2007. No problems since..........need to find a piece of wood to knock on when I say that, don't want to jinx anything.
Body-on-frame is necessary for good tow ratings.
BTW My father used to two a largish Gulfstream style trailer (slept 5 people) around Europe behind a 2.5 liter RWD car.
System check
displayed.
following:
HOLD RESET NEW”.
HOLD RESET NEW”.
ALTER.
Instrumentation
Mark
88Domer
