Jetta TDI, Civic Hybrid, or Prius?
Things I like about Jetta TDI:
16. Was able to find a used 2002 with 80K miles for $10,500 (I couldn't touch even a higher mileage or older used Prius for that).
17. This overlaps with some of the others, but the excellent handling and braking means better crash avoidance than other cars.
Things I don't like about my Jetta TDI:
5. Very bad sounding stereo. I have the Monsoon and am very disappointed in the sound...very tinny.
6. On the used market the wagon price is $4-5K higher than the sedan (I really wanted a wagon, but for that price difference, I'll just live with the sedan and make two trips if necessary).
7. Poorly placed cup holders block CD player when in use.
Jetta TDI, Civic Hybrid or Prius
Its should be
Jetta TDI & Civic Hybrid & Prius & Escape Hybrid.
At this point of time with high gas prices, we need both Hybrid & Diesel.
Yes, but this only applies to turbo diesels. And even then:
http://www.kraftpower.com/solutions-godwin.html
--- Offering a reliable turbocharged engine is very important as mining operations move ever higher. Power loss on a normally aspirated engine can go as high as three percent per thousand feet of elevation, says Abbott. With a turbo, the loss is less than a half a percent per thousand feet.---
Still, I agree with you that turbos perform well at altitude.
I believe you when you tell that your diesels kept on working in Arctic conditions. If you prepare your diesel well, it will do very well in cold conditions.
However, sometimes "normal" car users do not prepare their diesel or temperatures drop below the cloud point of the type of winter diesel they happen to have in their tank. Then they have a problem that a gas engine will not have in the same conditions. Although it will certainly happen very seldomly, it is still a minus point for the Jetta.
Prius owners complain about running out of battery halfway up a mountain. With the Honda you can shift to a lower gear (2nd or 3rd), but Prius does not have that option. Prius turns into a turtle.
Troy
I've run up 3000' vertical at 25-40 mph with reserve battery power at the end topping at 10,000 ft MSL with snow covered road. But I haven't run up I-70 from Denver to the continental divide, I-80 from Sacramento to Tahoe, or I-17 from Phoenix to Flagstaff. Those are the 5000' climbs I'd like to hear about for anyone who's tried it. If I'm forced to 40mph in turtle mode, I'll just have to join the trucks in the right lane since I've already bought a Prius. However, downshifting in the Civic hybrid to 3rd wouldn't get me much above 40 without red-lining anyway.
My personal favorite would be a diesel hybrid with the utility of an AWD wagon or small SUV.
Their asking price was $17,500 for a 2002 JEtta TDI with 48,000 miles. I walked. The brand new 1.8T GLS/GLI??, on the new lot is marked at $17,800 no haggle price.
Too bad for Jetta, I could have been an owner had they started at a more resonable price for a 3 year old car with almost 50,000 miles. They told me how rare these are, and blah blah. All I could see is a 3 year old car with 50,000 miles, and they are asking the same for it as the new one. If the 1.8T MSRP is $22K, and the selling price now is $17,800, the TDI's selling price, in states where it is sold is probably close to the $18K mark. The used one is not worth more than $10 -$12K to me. Gas savings or not, that is too much money for a used car.
Be aware that the 2004+ TDIs have even more torque and horsepower than the 2002 you drove. 2004+ have 100 hp, 177 ft-lbs tq while 99-03 have 90 hp, 155 ft-lbs tq. That's 11% more hp and almost 15% more torque.
DSZJGL:"I've run up 3000' vertical at 25-40 mph"
25-40 mph? As I said... Prius is a turtle.
I climbed Eisenhower pass in my Insight, 3rd gear, at 60 miles an hour. You can shift down in a Honda or TDI... you can't in the Prius.
Troy
If a car cannot keep up with traffic on any of the Interstate highways or freeways it should be banned. They have laws pertaining to just that issue. Motorcycles have to have a certain HP rating to get on the freeways, the same should apply to cars. Going 25-40 MPH even in the right lane is a hazard. With trucks you can see them from way off and make lane adjustments. Small cars going slow will sneak up on you. The minimum on most Interstates is 45 mph. If a car cannot maintain that up the steepest grades they should be ticketed.
Also, to repeat, the Hondas have the ability to shift to lower gears, so they can climb at 60 mph.
troy
...but you should see what I got going down the other side (engine off = 0 gallons burned = Infinite MPG)!
Overall, I found I could still average 90 mpg going over a mountain. Of course the thin air at 10,000 feet really helped reduce air resistance.
troy
The best mileage I ever got (36 mpg), with my 1978 Honda Accord was going through Colorado. I did not think about the thin air. Just figured it was all the downhill coasting.
Also, the statement about not being "able" to downshift PRIUS makes no sense.
It has a power split device that acts like a variable transmission. Very simple and light, very maintenance free, and very easy and smooth to drive! In a manual car you worry about which gear might be better and whether overreving will hurt your car, and you lose power and get jerked around in the process of shifting. In the PRIUS you just set the cruise and let the computer take car of finding the max power/efficiency for you. There's NO jerky shifting and NO overreving worries.
The 2004-2005 PRIUS will easily keep up with (or pass) any Jetta TDI (1.8or1.9L), Insight, or Civic hybrid. It has more HP (110), Torque (295) and equal or better 0-60 (9.8s Motortrend) than any of those others.
Also, I don't understand all this uninformed PRIUS bashing. I would think hybrid owners would support each other in promoting this great, clean new technology. The only thing I can think of is that the Insight and TDI owners feel threatened by the unprecented popularity, numerous awards, low pollution, and great performance of the PRIUS. Don't be threatened - just enjoy your car and tell others how great it is. But really, there's no need to spread misinformation about other cars.
Guess the rest of the world is wrong and Troy is right. Prius sold over 10,000 units in north america. I'd bet serious money insight didn't sell 1,000 in the last 2 months. I don't even own a prius, I'm considering a liberty diesel to pull a boat with. I think the person who stated we need all was correct. I don't think we'll be seing sustained oil below $40 bbl anytime soon. :P
- Can't use 10W-30 or 5W-40, else the "check engine" light turns on... and might leave you sitting
- Strange fuel bladder that only accepts ~8 gallons... and makes re-fueling difficult & time-consuming
- A gas gauge that would be better called a "guess" gauge because it's not accurate
- If the battery or electrical system dies, you're out-of-luck. Can't move anywhere (with the hondas, the car can still operate as a non-hybrid).
I like how the Prius *looks*... I just don't like how it acts.
The purpose of this thread is to give your honest opinion, and I gave mine.
I'm sorry you don't like it. That's life. (shrug)
troy
1) The Prius will run on any regualr oil and NOT leave you stranded. There have been no reports of this! In my opinion, it's GREAT that the Prius lets you know when the incorrect oil was used. The 5W-30 oil in the Prius is easy to find and cheap. The 0w-20 required for the Insight is not nearly as common.
2) The fuel bladder reduces emissions (the main goal of the Prius is reduced smog emission - the MPG is just a side benefit). That's one of the reasons the Prius (sold in CA) gets a 9.5 out of 10 on the EPA Green Vehicle Guide Air Polltion Score. Troy's manual Insight only got a 3 out of 10 ! However, you can get a CVT Insight which scores a 9 ! By the way, both the Prius and Insight score a 10 on the Greenhouse Gas Emissions. Yes, the Insight get better MPG, but that is to be expected because it's lighter and has about 40% less interior volume than the Prius.
3) Most people now get ~9-10 gallons in their tank. Yes, there was a problem early on with gas gauges (and problems caused by bad high sulfur gas), but that has been fixed. Considering how many hybrid discussion boards you troll, you ought to know that by now.
4) All cars today have electrical systems (and computers), and NONE of them will run without it. However, no "regular" cars will run when you run out of gas, neither will mild hybrids like the Insight. The Prius on the other hand, can get you to a gas station a couple miles away on battery alone !
By the way, the 12V battery which start up the Prius (computer) can be jump started just like in any car.
I demand an apology. I don't lie. And people are STILL complaining about the guess gauge. It has NOT been fixed.
troy
Troy, OK, you're not a liar in the strict definition. SORRY.
Now please stop using outdated and out-of-context "information", and we could all get along better and actually discuss the true merits and problems of these cars.
Yes, some people still report gas gauge problems (some of those refuse to get the gas gauge fix because they are worried about the mechanics screwing up), but for me and many other early Prius buyers (late2003, early 2004), the TSB fix solved both the capacity and inaccuracy problems.
Let's all get back on topic:
I think the new 2004-2005 Prius beats the Civic Hybrid and Jetta TDI, but that's just an opinion. ( If you want to compare those to the old Prius, then it's a tossup, but that comparison is a bit outdated. Most Prius on the road are new ones.)
Also, I think we would all be better off if more people drove any of those 3 cars.
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
The complete picture is that the Prius will not run without it's hybrid traction battery. The HCH / HAH / Insight will run on ICE alone. That is what Troy was speaking about. It is not a question of the electrical system failing. It is a question of the main battery depleting (a rare occurance) or or the electrical propulsion system dying due to software failure (an even rarer occurrance, but it does happen - see the "Prius Software Problems" forum).
Actually, it seems to me that software problems are far more common than battery problems. Software problems clearly exist (see discussion board). However, I don't believe there have been any cases of a Prius dying because of the main battery becoming depleted, in part because the computer in the Prius won't let the charge level go below around ~40%. Even when the gas runs out, the Prius computer will shut off the car after a few miles, long before the battery gets totally depleted (although at that point I think it may not let you start the car again -not sure). Toyota stated that (in the 8 years of selling the Prius) they have NEVER had to replace an entire main battery due to it going bad somehow.
Sorry, I should have been more clear. I wasn't saying the battery would no longer hold a charge, just that the Civic is capable of running without any traction battery, which the Prius cannot manage. Different designs.
NEW CRASH TEST RESULTS:
VOLKSWAGEN NEW JETTA ACES SIDE IMPACT TEST;
ALSO EARNS GOOD RATING IN FRONTAL TEST
ARLINGTON, VA — The 2005 Volkswagen Jetta earned good ratings in both frontal offset and side impact crash tests conducted by the Insurance Institute for Highway Safety. Plus the Jetta is the first vehicle to earn the top rating of good in every individual measurement category (injury measures, head protection, and structural design) of the Institute's side impact test. This car is designated a "best pick" for side crash protection, and it's a good performer for frontal crash protection. The performance of the Jetta in these tests plus its acceptable rating for seat/head restraint design in rear impact tests make it the top-rated car overall in the inexpensive midsize class. The redesigned Jetta, which is larger than its predecessor model, was introduced in the 2005 model year, and these results apply to the new larger Jetta.
"The Jetta was the first vehicle to ace our side impact test," says Institute president Brian O'Neill. "It's the best performer among midsize inexpensive cars. Its structural performance was better than the second- and third-best models, the Toyota Camry and Honda Accord. This new Jetta design shows what manufacturers can do to improve occupant protection in serious side impacts when cars are hit by taller and heavier SUVs and pickup trucks."
http://www.hwysafety.org/news_releases/2005/pr042405.htm
Unfortunately, this is mere speculation. And ANY new vehicle is going to have to get the bugs worked out. I wouldn't buy an 05 Corvette just because of the fact that it is a first year model........
Stick with the hybrids folks... you're better off and you'll get twice the mileage
Twice the mileage, eh? I AVERAGE 45mpg in my Jetta TDI, and I AVERAGE 36MPG in my Passat TDI......so you are telling me that the PRIUS and HCH AVERAGE 90MPG? And with that reasoning, I suppose the HAH averages 72MPG since the Passat averages 36?
Truth be told, they are all very good cars. Personally, Hybrid technology still being in it's infancy is why I don't use it....that and the fact that you have to pay such a PREMIUM to own it. What happens when the batteries fail and need to be replaced? Do you replace them at a very high cost percentage of the value of the vehicle? Or does the Hybrid just become a throw-away vehicle at that point?
Diesel is MATURE proven technology and until Hybrids have a good, strong mature track record, I'll continue to purchase diesels. I know they'll go 300-400K miles without having any engine problems what-so-ever, and still get exceptional mileage while doing so......
-PR-
03 Ford F350 SuperCrew KingRanch 6.0L Powerstroke
04 VW Jetta GLS TDI
05 VW Passat GLS TDI
This is actually another common misconception. There are 5 emissions categories..... Carbon Dioxide (CO2) or the "global warming gas", Carbon Monoxide (CO) which is poisonous, Hydrocarbons, Nitrouos Oxides (SMOG) and particulates.
Diesels emit less Carbon Dioxide, Carbon Monoxide and Hydrocarbons than comparable gasoline engines. The emit relatively the same levels of Nitrous Oxides as comparable gas engines. And they emit MORE particulates than gas engines.
So, that being said, Diesels are BETTER than gasoline engines in 3 out of 5 emissions categories, the same in 1 out of 5, and worse than gasoline engines in 1 out of 5 categories.
well it's outlawed in numerous states
Are you referring to the states that will not allow me (if I lived in them) to purchase an Jetta or Passat TDI (with small 4 cyl diesels), but will allow me to purchase a one-ton truck with a large 8 cylinder diesel? Those states? Which do you think will emit more, a 1.9L TDI engine or a 6.0L Powerstroke diesel? It's a contradiction if you ask me......
All that being said, yes, if hybrids ever came down to a realistic price, they will more than likely outsell diesels. But, with ULSD I expect to see more diesel offerings in the US in the coming years (speculation on my end now).
-PR-
04 VW Jetta GLS TDI
If you only plan to keep a car until the warranty runs out then sell it, how do you think that will affect the resale? I can tell you that Prius that are no longer covered by warranty are not selling close to Blue Book prices. The VW TDI's bring much better True Market prices when they are past their warranty than any of the hybrids. Toyota pretty much says that the life cycle of the Prius is 10 years, 150k miles. To me that is a "throwaway car". I keep cars on average 15 to 20 years. Age will be a problem with the hybrids. Can you show more than 1 or 2 hybrids with over 150k miles that are still going strong? I can post dozens of Jetta TDI owners still very happy after 150k miles.
Actually the diesel car market is about 3 times larger than the hybrid market.
troy
But the Hybrid market is growing FAST (960% since 2000, 81% in 2004) and the Diesel market is merely steady...
That is saying a lot since they were not available in California and 4 other states since January 2004. If diesel was $3 per gallon and gas was $2 per gallon the difference between a gas car and the same size diesel car would be a wash. A 20 to 30 cent per gallon premium is not enough to offset the difference in performance and mileage. I have driven both the gas and diesel versions of the VW wagons. The diesel is far better in real world useful driving from 30-70 MPH. I don't race from stop light to stop light so a gas car is not any advantage for me. If the VW TDI's were available in CA over the last few years, I am not so sure the hybrid would have gotten off the ground. They started limiting diesel car sales in 2000.
Way to go and welcome to the forum. What kind of mileage did you get hauling the trailer? That is another advantage of the VW TDI over any of the high mileage hybrids. I understand you would void the warranty on a Prius also, if you hook up a trailer of any kind. Now you have utility and a 45 + MPG car.
As far as towing, I cannot locate any specs that indicate a USA Golf TDI even "has" a rated towing capacity.....???? Euro Golfs are given a 600KG Tow rating apparently....
Personally, I think towing with a small car is kinda dangerous, thus no rating given...
They do. It's called B100 biodiesel. Clean, domestic, and renewable.
Can't say that about any fuel the Prius can use.
I do like how you can calculate your miles-per-petro-gallon with the TDIs though.
For example, my last tankful in my Jetta TDI was 48.8 mpg, but I used B20 so that's
61.0 mppg. With B50 it would have been almost 100 mppg and with B100 it would have
been infinite.
That is the issue. The hybrids currently will not run on anything but fossil fuel. If they built one for E85 or biodiesel that would be flexibility. Only the Diesels & bi-fuel vehicles offer that flexibility. Hybrids are not offering any solution to getting out from under foreign oil.
