Chevy Silverado and GMC Sierra Real World MPG Numbers
Does anyone have any advice on how I can get better gas mileage without sacrificing power? Thanks!!
I've been experimenting with different grades of gas lately. I'd been using Sam's Club 87 octane (they only offer 87 and 93 at my local Sam's) since I bought the truck back in early October last year. My lowest mileage was mid-13's on the first tank- the dealership filled it then let it idle for a few hours while we completed sales paperwork to recharge the dead battery. Otherwise my real lowest has been mid-16's and my best so far has been around 19.6. During the winter I ranged mainly between mid-17 to mid-18's.
My father also has a 2004 truck, similar to mine (same drivetrain, 16" wheels instead of the 17's I have, slightly different option packages, same drivetrain / body / gearing though) and has sounded frustrated that his truck isn't getting the same mileage mine is. He swears by 93 octane name-brand gas. Which is where my experimenting comes in..
I put a Fold-a-cover tonneau cover on it just over a month ago, about the same time I decided to start the experiment. I fueled up the first tank after the cover with 93, and ran a total of 3 tanks of it. I then switched back to 87 (since I can't compare pre-tonneau 87 with post-tonneau 93 and call it apples to apples). I'm on the third tank of 87 so far. My lowest average for a tank using the 93 was in the low 18's, and my highest was around 19.5. So far the 87 has been consistently in the low 19's (so no real meaningful difference at this point).
Once I finish this tank I'm going to repeat the experiment using 6 tanks from the local Shell station. Shell is one of several brands actually recommended for GM vehicles in a TSB that I've seen recently due to the cleaning agents they add, so there might be more to dad's name brand kick than mileage..
For the record- I do watch the DIC for general comparison's sake as I'm driving, but my actual mileage is manually calculated at the pumps. I record the total mileage, trip (then reset), and gallons of gas to fill up, then calculate the mpg from those numbers. I also try as much as possible to use the same pump. My driving route is mainly home-work-home, ~30 miles each way, 80-85% 65 mph highway, 15-20% rural (2 stoplights, speeds ranging from 30 - 55 mph). For the highway portion I use cruise control to keep speeds as consistent as possible. So hopefully my experiment is controlled well enough that my numbers are relatively reliable.
BTW, kudos to Chevy for building a 5000+lb 4x4 vehicle that can get almost 20mpg (maybe I'll get lucky and actually break 20 at some point! :shades: )
out there knows what my mpg might be on this Z71. Its a 2005 silverado 1500 z71
Regency package with a 4" procomp suspension lift 33" tires and a 4.10
Gear ratio? The sticker says 15 city and 19 hwy and this reading is for the standard Z71 with a 3.42 gear ratio witch seems to be the standard for all these type trucks.
Any info would be appreciated.
I've been considering purchasing the Tornado vortex add on but it seems to be duplication of effort. Any ideas???
GM's new "on demand" 5.3L promises to be even more efficient. GM really does V8's well...
2005 Silverado 1500 2wd, ext cab, 5.3 liter.
1. 4WD components add about 500 lbs to the weight of a full size truck: front differential and axles, transfer case, front driveshaft, skid plates and heavier shocks/springs, and larger tires.
2. 4WD trucks generally have higher ground clearance, which means they sit higher and have less favorable aerodynamics. For example, a stock 4WD Z71 Silverado sits about 2.5 inches higher than a 2WD version of the same truck
3. Most of the time 4WD trucks will have lower gearing to compensate for the added weight, and additional power losses through the drivetrain (when in 4WD)
4. For some compact pickups, 4 WD versions will come with substantially heavier frames, and suspension components. This was the case with my '95 Nissan 4X4 V6 extended cab pickup, which came with much lower gearing, much bigger tires, heavier frame, and heavier springs than the 2WD version of the same truck. Lately manufacturers have been offering 2WD trucks with 4WD chassis clearance on most models. They have the additional clearance, but do not have the 4WD components, which means less weight. Also, they typically will not have the low gears associated with 4WD trucks. My Nissan had something like 4.23:1 differential gears. I could not get better than 17-18 MPG out of this vehicle. This MPG figure was confirmed by many other owners I talked to.
5. In the past, when fuel prices were of little concern some 4WD vehicles came without front end locking hubs. The front differential and axles would turn all the time, even when the vehicle was in the 2WD mode. For example, I drove a 1976 Chevy Blazer (full size) with a 350 engine and it would get about 8 MPG in 2 WD! In 4WD the mileage would not drop much. And it did not even have air conditioning.
Compared to these vehicles, new Chevy 4WD trucks actually get decent fuel economy. New Nissan Titan 4WD gets about 13-14 MPG, new Dodge 4WD with a 5.7 liter Hemi gets about 11-12 MPG. I do not know about Ford F150, but I suspect that the mileage is not that great either.
My weekly driving habits have changed recently, adding more stop-n-go. I used to get ~ 12+ mpg, mostly hyway. Last week, 10.99. The best ever recorded was 16 once at high altitude, 469 mi. on 29.1 gal. ( phenomenal ! ). That was when the truck was new with factory 245's on it. It now has 265's. Can't give much info on towing. Mine's hardly worked a day in its life.
-David
05 Z71 Crew Cab 5.3 L (Black because that is the most fuel efficient color) and with 15k miles on it I've just got the DIC to read 17MPG last week. Otherwise it was stuck at 16.8 for at least 5 months. :shades:
17 is not bad at all in my book. My mother in-law has an 05 Avalanch 5.3 L (because thats what girls drive) and she is getting 17.4 MPG....she drives it like the old lady she is.
Note: 5 MPG in a boat is considered good fuel economy.
I get 19.3 mpg in highway driving which is about one mpg less than I was getting with a Toyota Tacoma 6 cylinder TRD Access cab 4wd in similar driving conditions.
I took the tonneau cover off for the trip; from the #s my scangauge was giving me, I'd say I could have gotten maybe 21 mpg with the cover on the truck... but that's really just a guess.
-m.
That is best for me.
And your experience is ???
How are people getting 18-20mpg in their Silverado?
Am I getting that mileage because it is a 6.0? Actually, I had a 2004 F150 5.4 V8 and it got around 13-14.5mpg, so for a little bigger engine, it's pretty much the same thing.
motohead77@hotmail.com
Got 18.2 mpg overall. Extremely pleased and surprised with the mileage. That is excellent mileage for a full size pickup with gobs of power. The "old" EPA rating of 19 mpg highway looks very achievable (or even exceedable) based on my experience, once the vehicle is broken in, and if speeds are reduced to 65 mph.
Active Fuel Management really works. You can see it toggling back and forth from V-8 to V-4 mode. BUT, you cannot feel it unless your foot is on the accelerator when it happens. And then, just barely. It's a great invention if it stays reliable.
Not the forum for discussing Toyota, but I don't hear of anyone bragging about that kind of mpg in the 5.7L Tundra.
And yeah, I'm bragging.
1offroader
