Visitor Agreement.
My normal commute is ten miles each way, split evenly between lightly traveled interstate (65-70 mph) and suburban boulevard (45 mph speed limit, maybe six lights). On this run I average 22-23 mpg.
I'm seriously considering switching to an '08 with the four cylinder and a stick. I drove one earlier this week and it feels every bit as quick in real-world conditions, and based on what others are posting here I would expect to be able to gain 15-20% in mpg.
I've always been able to beat the EPA figures when driving a manual transmission Honda. Automatics are another story.
Oh I forgot, if you drive while raining can be obstruction in getting good mpg
I live in AZ it is hot and that may be a difference, however I use high octane gas from Chevron gas station. TAKE CARE
Right now I'm sitting at "half" tank and so far I've gone about 233 miles. Not sure what kind of mileage this will return, but I'm thinking it could bring my average up.
What do you all think based on your experience. High 20s low 30s? I'll have to wait til friday when I fill up again.
Super.
29 mpg doesn't upset me though, especially since before this the highest I'd ever managed was 26.xx. It's getting better, then again I've become a little more conscious of my driving and what I've been doing to waste gas.
I run mine at 34 and I am sure you could go to 35 without any problem depending on how hot it gets where you are. Might just get you that extra .4! Just watch your tire wear.
We recently got 30 with our 2008 V6 Sedan over about 138 miles at 70-75 - right on the button 138/4.6 gallons = 30.
Filled up this am. No one is really happy........looking around the Valero that I use.
Numbers: 1925.9 miles on 67.796 gallons (5/27/08 to 6/27/08).......
Mean=28.4
Median=27.65
Mode=26.65 more or less
Range 20.24 to 32.18
2005 HAV6 6M (coupe)
all the best, ez....
Consistently get 25 mpg driving around Phoenix.
Not Honda - Honda believes in higher RPM - Why? I have no idea. But our '08 V6? 2500 RPM at 75. The engine certainly has the torque necessary to run at lower RPMs and my reason for arguing for a 6 speed atuo with higher overdrive INSTEAD of VCM. :confuse:
Honda's previous V6 ran at close to 2,100 rpm at 75 mph. By gearing higher, the VCM can run more often, saving more fuel. If the RPMs were lower, the engine wouldn't have enough power to run on 3 or 4 cylinders, and would be forced to use all 6 cylinders, which would use more fuel.
The Honda Odyssey with optional VCM is a perfect example - the RPMs run about 300rpm higher at 75 mph in those with VCM than those that don't, for the reason I mentioned.
Your V6 runs at the exact same RPMs as my 2006 4-cylinder (75mph at 2,500 rpm); makes sense seeing that your car runs on 4 cylinders when doing light load driving.
The fact that the car runs at high RPMs isn't because it "only" has 5 forward speeds. Our old 2000 Odyssey ran around 1700-1800rpm at 60 mph. I'm sure the Accord could be tuned to run like that just fine, but you can be sure it would use more fuel than with VCM, or Honda would've just done that.
If you check what has been written about the real world mileage of the V6 Hondas between 2003 and 2007, you'll generally see better mileage than what you see with the 2008s. If you look at a couple of competitors that don't use VCM {the new Camry and Sonata for instance}, you'll see roughly comparable cars getting at least the mileage you see here with the new Honda, and maybe better.
The closest comparison, most likely the fairest comparison, is what the real world mileage of the Acura TL gets. Looking at that thread, it seems either that folks are exagerating their mileage claims, or that the same engine as the VCM V6 without the VCM is getting better highway mileage, in a similar, but slightly heavier car.
Forgive me for not having the links this time, but the Real World MPG threads are in these other forums too........
Vfm HAS to have helped it or economy would be closer to the 17/25 of the non VCM model.
Sorry for any misspelling; I'm on my iPod!
On the other hand, one can make a case that the Acura TL is pretty similar to the Accord. Uses pretty much the same engine, in a slightly heavier car. And the mileage appears to be better in the Acura. The difference seems to be that the Acura still hasn't been saddled with VCM.
I agree with your assessment that adding approx 200lbs could cost roughly 2mpg. But, looking at the other makers, adding .5 liters to the engine, and more torque, also seems to add more mileage. In this case, it really didn't. It appears to me, that in this case, the cost of the VCM isn't worth it.........
Just my opinion.......
Caught me for a bit on this...... The only "non VCM" option is the stick shift coupe. I don't think we can directly correlate the mileage performance of the stick vs the auto, particularly since the stick in the coupe is likely more for the "performance" crowd than the mileage crowd. Gearing could be a major factor here........Otherwise I can't see why the mileage is so poor for freeway driving. That's V8 fullsize freeway mileage....... Or performance coupe mileage.... and I think that's what is intended for the stick shift couple.
You may be right, but I suspect VCM has a bigger effect on the mileage than you think.
That Acura TL.
And I prefer to look at the "Real World MPG" numbers rather than worry too much about the EPA estimates. Yes, you're going to be dealing with people, and how people interact with their cars, and then turn around and express themselves on the internet..... but....... look at enough samples and it raises some questions for me {more questions}. Why does a heavier car without VCM seem to get better mileage than a car with the latest mileage tech?
I'm not a Honda guy, really..... that's why I prefer to stay within the Honda family on this. I'm not a real believer in the Camry V6 "superiority", I suspect that the warmed over Honda really is close enough today in refinement that we should see similar numbers without VCM. Using the Acura to look at it this way, we do see similar if not better numbers than the Camry, and definitely as good if not better than the VCM Accord.
You don't see this with the I4's. Here, Honda is still an industry leader without question.......
I maintain that a non-VCM V6 Honda would get better highway mileage with a 6 speed overdrive transmission and very tall overdrive permitting 40MPH/1000 RPM than the current V6 VCM.
VCM is WAY too complicated a "solution" to better mileage.
Please explain. GM does it with all its engines. My Trans Am ran 2000 RPM/80 MPH and got 29 MPG. Frankly, it ran great. How is it "harder" on the engine? When the engine comes under load the tranny shifts out of OD and into the next lower gear until the power is no longer needed. I know you should not "lug" and engine, but that generally is when you go below 1000 RPMs in any gear and you certainly feel it with a manual tranny. It is impossible to "lug" and engine with an automatic transmission.
The low rpm Sienna gets better mpg than the VCM Odyssey (Consumer Reports).
I long for taller gears in my Accord. I used to have a 74 hp Passat that only turned 2100 rpm at 60 mph. My Accord ('07 I4 MT) is at about 2380 rpm going 60.
....while I spin at 2000 rpm going 60 ('05 V-6 6M), from time to time (especially with pain at fueling time on the increase) I fantasize about your power train and it's tremendous fuel economy potential.......
I guess that why I stayed in the Naval Reserve (so I could afford to taste to 6M's signal straight line acceleration up the on ramp enroute to the salt mines).
best, ez....
My corvair was a '63 convertable with a 3 speed stick. Had the back end try to pass the front end twice in spirited (but not crazy) driving. Luckily I caught it both times. That thing was a handfull.
Problems from earlier models completely corrected.
Are manuals really geared that much different than autos? I wouldn't know I've only driven one with any real success once, and that was only for 3 miles, no highway speeds. Trying to learn to drive a 5 speed.
I know it's off-topic, but I was curious. I saw it on Modern Marvels. Didn't Chevy finally axe it because they got involved in a bad class-action lawsuit or something. Just curious. I wasn't around when the Corvair was in production, or if I was it wasn't long.
Thanks for humoring me.
Yes... for example the AT Civic actually gets better highway mileage than the MT. Some say Honda keeps the revs higher in the MT so that those who use cruise control don't make the engine lug when going up a hill. I've never had that problem in my 06 EX-L I-4 5 spd manual. I'd get 40 mpg all the time if I had the auto's gear ratios.
......last 3 tank-ups: 756.6 miles on 24.364 gallons of 87.........
....gives circa 31.1 60HWY/40CITY. 6M coupe.
...happy hour is here.
best, ez....
Needless to say, I'm very light on the throttle. The transmission usually upshifts somewhere in the 2000-2600 rpm range and I hardly ever let the engine rev past 3000. I coast as much as I can and I always manipulate the throttle slowly and smoothly when accelerating. In fact, I'm so careful with the throttle that my right ankle often aches during driving from modulating the throttle so precisely. I sometimes wonder why I try so hard when the results aren't really that spectacular. If I were to drive how I wanted to drive (quick acceleration and higher speeds), my mileage would only drop 3 or 4 MPG, I'm sure.
I've noticed that my mileage has improved quite a bit in the last few months (warmer weather?). During the winter, it would never rise above 24 MPG no matter how carefully I drove. Most of the time it was between 22 and 23.
I should note that I fill up exclusively with Shell V-Power 93. The J30A5 runs much smoother and stronger on this gas than on regular 87. I quit filling up with 87 within the first 1000 miles because I noticed severe pinging/knocking during acceleration, especially uphill. I could even hear it with the radio at a moderate volume. That's how severe it was. Once I switched to 93, the pinging stopped, and within a few tanks I noticed a considerable increase in torque (especially in the low-end) and better fuel economy (up at least 2 MPG, on average, couldn't do better than 21.X MPG city on 87). At first, I thought the increase in power and efficiency was attributable to the engine breaking in, but after trying a few tanks of 87 every so often, I've found that there is quite a difference between the two. After running 93 for several tanks and then suddenly filling up with 87, I notice a slight drop in power and the mileage for that tank is usually about 2 MPG lower than the previous tank of 93. I've yet to try mid-grade, but I really don't see a reason to. It may not ping like 87, but it likely won't perform like 93.
For all you 2003+ V6 guys out there, I highly recommend using premium gas. Sure, it costs more up front, but in my experience the greater power and efficiency more than makes up for the couple of dollars per tank premium. In fact, since my mileage is around 2 MPG higher on average with 93 versus 87, I'm actually SAVING money in the long run using the more expensive 93 octane.
If you do decide to give 93 a try, have patience. You're not going to notice an increase in performance and mileage right away. It takes a few tank-fulls for the engine's computer to optimize the ignition timing advance for the higher-octane fuel. The difference between regular and premium is far easier to feel when downgrading from 93 to 87, since the engine has to immediately pull the timing advance back to avoid detonation. It takes much longer for the engine to "see what it can get away with", so to speak. It takes time, usually 300-500 miles or up to two tanks of gas.
If you have a 2002 or older V6, stick with 87 octane. Anything higher will actually hurt your performance and gas mileage as their engines can't optimize the ignition timing for higher octane fuel like the newer engines can. On the Accord, that nifty "feature" was added in 2003 with the introduction of the J30A4 (when the 7th gen Accord debuted, a Honda engineer even stated that using 91+ octane in the V6 added 10 HP and 10 FT-LBS for a total of 250 HP and 222 TQ). As far as I know, this applies to the 2008 Accords as well, probably even more so since the J35Z2 has a higher compression ratio than the J30A4/5 (10.5 vs. 10.0).
On a side note, isn't it amazing how far engine management has come in recent years? 10+ years ago, you couldn't have imagined an engine with a 10+:1 compression ratio running safely on regular gas while making decent power. Now, they can...and then some. The new direct-injection 3.6L V6 in the CTS comes to mind. 304 HP on 87 octane. Wow. Heck, even the 06-07 Accord V6's 244 HP on 87 is impressive (though, from my experience the engine doesn't like 87 much at all).
Well, I've gone on long enough, so I'll shut up now :P
Right now your theory holds true - if you get 24 with regular and 26 with premium, regular costs $3.99 here in NJ, and premium $4.27, and you travel 260 miles, you are better off with the premium - 10x$4.27 - $42.70 versus 10.83 regular x$3.99 = $43.22. If the price differential is $.33/gallon or more you are worse off.
I never had any pinging problems with our '04 V6 AT Coupe. Have to wonder about the quality of the gas you are buying, regardless of its being Shell or not. I once got a tank of water from a Sunoco station.
I have only used 87 so far in my 2008 6spd, pretty much following the recommendations from Honda. However, based on your suggestion, I will start using 93 octane in my 6spd to see how much better it performs. This new 3.5 feels significantly more stout than the 3.0, so I'm curious to see how it responds to premium gas.
The one downside to pushing higher octane is whether it will increase the torque steer, which can be noticeable if I floor it without a good grip on the steering wheel. I do run summer tires in the warmer weather, which improves handling and lessens the spinning of the front wheels. Given the greater performance of the 3.5 6spd, I've been pleasantly surprised that torque steer is really not that bad....so far.
Thanks for the tip!
So...you...ride the clutch?
I think you mean your "other left." I had to say SOMETHING.
