Toyota Camry Real World MPG
1101113151623
  • phd86phd86 Member Posts: 110
    "I am consistently getting 21/8-22.3 mpg on short 20 min drives back and forth to work. Do you think this is correct?> I see people getting 35 mpgs and I don't undertsand.. Is something wrong with my car. "
    Yes, Timmush - I believe that is correct based on several fairly long test drives of several 2007 4-cylinder AT's of that model and year. I did somewhat better (~25 mpg), but that was pretty much pure freeway, flat as pancake, straight, no wind. In my opinion, a 22 mpg in 20 mile drives, even if freeway, does not indicate a malfunction.
  • dremdrem Member Posts: 24
    Timmush,
    On the other hand my wife drives her 2004 4cyl AT back and forth to work almost exclusively and the fuel mileage is 25-26 mpg everytime. The trip is 7.1 miles one way with 5.2 miles freeway. The time is 15 minutes start to stop with five lights to deal with. It used to be 24-25 mpg when the car was new, but now 25-26 mpg at the 35,000 mile mark. This same car gets 35-36 mpg on road trips at a CC of 72 mph.
    We do not warm the car up at all before driving it, keep the tires at 35 psi and use 5w-30 oil.
    Some things that will affect your mileage are...The ethanol content of the fuel, your wheel alignment, rolling resistance of your tires, the variation in the manufacturing of your engine and transmission, the calibration of the O2 sensor, your driving style, the dragging of your brakes, viscosities of all your fluids, the outside temperature, etc.
    But if I had to prioritize them, the top three would be the total trip length and traffic conditions, the outside temperature and your driving style...in that order.
    Want to have some fun? Try a full tank of gas worth of driving while making it a goal to never use your brakes at all. Of course you can never get to 'never' and you will frustrate a small number of drivers who wonder why you are beginning to slow so far in advance of a red light, but with some practice you can raise your city mpg by 3 mpg. When I have the patience I have raised my 25-26 mpg city driving to 29-30 mpg by trying never to hit a red light and having to re-accelerate from 0mph anymore than absolutely necessary.
    Drem
  • troylikesbikestroylikesbikes Member Posts: 132
    I have an 07 camry 4cyl. I am consistently getting 21/8-22.3 mpg on short 20 min drives back and forth to work. Do you think this is correct?> I see people getting 35 mpgs and I don't undertsand.. Is something wrong with my car. Tires have been checked. THanks
    Timmush, my 07 4cyl Camry consistently gets 24-26 mpg on short trips back and forth to work. My 05 4cyl Camry consistently got 23-25 mpg on those same short trips. I define a short trip as my 3 mile commute to work, never above 45mph.
    Your numbers for short trips appear to be consistent with mine.
    35 mpg is a highway mileage figure. Myself, I've easily gotten that highway number on an 05 Camry automatic 4 cylinder as well as my current 07 Camry 4 cylinder.
  • janderson8janderson8 Member Posts: 30
    We have a 2000 Camry, but would feel fortunate to get 22 mpg for short trips. I drive 5 miles each way to and from work, about the 20 min drive described above, never above 45 and have never done better than 19 and it is usually more like 17-18 mpg, ocassionally even lower in winter. So I don't think you should be concerned. We've never gotten even close to 35 on the highway. I think ONCE we got 29 and since then 26-27.
    We have a 2000 Camry, but would feel fortunate to get 22 mpg for short trips, and have never done better than 19 and it is usually more like 17-18 mpg, ocassionally even lower in winter. So I don't think you should be concerned. We've never gotten even close to 35 on the highway. I think ONCE we got 29 and since then 26-27.
    V6 or 4 cylinder? I had a 1994 V6 LE and it got that sort of mileage around on on short trips. 30-31 mpg on the highway.
    It has been the 4 cylinders which have been quoted as getting some of the exceptional highway mileage, like my 05 LE and 07 CE.
  • caazcaaz Member Posts: 209
    # 7 405.6mi @ 60mph 10.3ga = 40.438 perfect calm conditions
    #8 405.6mi @ 75mph 12.85 = 31.564 <--- last nite 01/27 some rain.
    No matter how slow i go, i cant seem to hit 41 mpg, perhaps in the summer...
    Later
    Caaz
    P.s. I'd be glad to take anybody with me who wants to witness my mileage
    During the week last week i had the chance to drive from So Cal to the mexican border and back...Results as follows.
    Went 75 mpg all cruise,m we were having Santana winds, which are about 60 mph if you've never heard of them before....
    203.5 miles 7.2ga = 28.26 mpg
    P.S. Troy??....do the newer 4 cyl have more horsepower than my 03?, Possibly thats why there's an mpg difference. I'm thinking i will rent a new body style camry and try a trip with it just to see.
    I notice that drems mpg @ 72 is 35 - 36 whereas mine @ 70 was 35.2..
    Obviously i'm not the only person that gets high Mpg, or better yet....has Learned how to achieve high Mpg, because you do have to practice. I'd also like to know what some of your prior mpgs are Troylikesbikes
    Later
    Caaz
    I think there is a couple of HP difference between 03's and 07's, but it isn't alot, and didn't seem to effect the EPA stickers I saw at the time. No more than 3 or 5 HP I think. The switch occurred in 05 if I recall correctly.
    I have a complete breakdown on 2 big trips on my 05 auto and 07 manual ( same motors, different body styles ) but I can't get the silly columns to line up right and it makes it terrible to try and read. I'm still working on it.
    Later
    Caaz
    This is a long post, so skip to the bottom for the results if you are interested in the answer and not data and commentary.
    For starters, I began this exercise with the following given: In my opinion, my 05 LE auto and my 07 CE stick get the same highway fuel mileage under the same circumstances. This was my opinion based on general impressions and use of these cars, the 05 I put some 25,000 miles on, I've got about 9,000 on the CE.
    To prove or disprove this idea, I collected all information from two trips from both cars, when they were new ( less than 10,000 miles ).
    The 05 Camry was an LE, stock, 4 cylinder 4AZ-FE motor if I recall correctly, 5 speed automatic transmission. The trip was from Denver to Pennsylvania, to Ocean City, back to Denver, and then back to Ohio, and then back to Denver. The trip was in June, half the time loaded with 2 adults, 2 kids and a full trunk, A/C used a majority of the time. One speed warning collected in Kansas for doing 80. A majority of the trip was interstate, and at 70+ mph.
    The 07 Camry is a CE, stock, 4 cylinder 4AZ-FE motor ( same as the 05 ), 5 speed MANUAL transmission. The trip was from Denver to Pennsylvania, to Florida, to Houston, to Denver, in October. The load was 2 adults and a trunk full of stuff, minimal A/C, 1 or 2 windows down, 70+ all the time.
    Here are the actual tanks, with the data arranged like this,
    Odometer, Differential Mileage, Fuel Used, MPG
    First, for the 05 Camry with automatic.
    2504-Start
    2956 - 452 - 13.84 - 32.66
    3444 - 488 - 14.45 - 33.77
    3823 - 379 - 10.52 - 36.03
    4242 - 419 - 13.27 - 31.57
    4733 - 491 - 15.19 - 32.32
    4856 - 123 - 4.63 - 26.57
    5260 - 404 - 11.04 - 36.59
    5740 - 480 - 15.92 - 30.15
    6229 - 489 - 12.92 - 37.85
    6742 - 513 - 14.82 - 34.62
    7112 - 370 - 12.34 - 29.98
    7315 - 203 - 6.51 - 31.18
    7816 - 501 - 15.09 - 33.20
    8354 - 538 - 15.96 - 33.71
    8828 - 474 - 12.76 - 37.15
    9369 - 541 - 15.91 - 34.00
    9889 - 520 - 16.19 - 32.12
    Now, the 2007 CE Camry with 5 speed stick
    3957 - Start
    4326 - 369 - 11.20 - 32.95
    4754 - 428 - 11.01 - 38.87
    5119 - 365 - 10.54 - 34.63
    5593 - 474 - 12.92 - 36.69
    5907 - 314 - 8.94 - 35.12
    6221 - 314 - 8.05 - 39.01
    6608 - 387 - 12.04 - 32.14
    7012 - 404 - 11.25 - 35.91
    7425 - 413 - 12.68 - 32.57
    7786 - 361 - 10.31 - 35.01
    8115 - 329 - 10.00 - 32.90
    8558 - 443 - 12.49 - 35.47
    8731 - 173 - 4.57 - 37.86
    Now, the statistics.
    05 Camry, 7,385 miles, 221.36 gallons, 33.36 mpg
    07 Camry, 4,774 miles, 136.00 gallons, 35.10 mpg
    05 Camry, 2.88 mpg Standard Deviation, 2.19 mean deviation from mean mpg
    07 Camry, 2.28 mpg Standard Deviation 1.81 mean deviation from mean mpg
    The slightly higher spread on the 05 Camry comes from some use around town during the trip. I could have stripped that data out to be a little more fair, but it wasn't much, so I left it in, and it shows up as a 26 mpg data point.
    Other issues would be fillup error, which runs approx 6.2% of a gallon/fillup the 05 and 4.9% of a gallon/fillup on the 07. The 05 trip had more A/C and a heavier overall load.
    Because I don't keep speed/weather info for each tank, I can't separate out the A/C and load issues and don't really feel like coming up with a general correlation to try and compensate for the difference. So I'm just going to go with the raw data for now, and the raw data tells me I was wrong about the mileage being the same.
    Yeah sure, they both get lower to upper 30's on the highway, but over long trips with consistent types of driving and the same actual driver, the newer car does better. It might only be 1 mpg or 1.5 mpg by the time you factor out the load and A/C factors, but the newer, heavier, and manual tranny Camry does better than the 05 automatic by a decent 1-2mpg.
    Manuals still have an advantage in this case, although there is a difference in body style which I can't compensate for either. Unless someone has a decent Coeff Drag number expressed down to at least hundreths converted to an efficiency increase per mile or gallon which I can use to back out the differences between the two?
    Your mileage may vary of course. I've only owned 3 Camrys to date, and they have been reasonably predictable.
  • Just completed a 2900 mile trip from frozen Indiana (first tank was burned in single digit temps) to sunny Florida and back in a 2004 4WD Highlander Limited with 3.3 liter engine. Average fuel economy was 22.96 mpg. Typical freeway speed was 70-72 mph. Probably had no more than 200 miles of city driving but did have a couple hundred miles at 65 or so due to construction, traffic, etc. The trip computer (which averaged about 1.5 mpg higher than actual) shows a definite improvement at 65 vs 72 mph.
    In my 2005 Camry SE with the same engine, a 2550 mile trip in the summer yielded 27.5 mpg.
    I really enjoyed reading your travel log. I read each tankful, etc. It definitely appears the 5 speed 07 is getting a lil better MPG. You did quite well with several of those tanks.. As i've stated before, i only purchased my 03 Camry ( 39,000 miles) on it the last week of december. But with my Sunday nite to Ca trip and my thurs to Phx return trip, in just 12 months i'll put on 60,000 miles. I'm really enjoying the car, but began to wonder about the newer model. Obviously i'll be trading up in a year or so. But then again, i'm liking this 03 (mint condition) so well, i might to try make it a high mileage 400,000 mi car. Then i'll considser going new. Possibly when the new body comes out in 2012, or 2011. But now i can see with your data that i dont have to wait if i dont want to. That it is indeed a matter of the driver and i appear to drive similar to you, working to get that ultimate mpg...so to speak. My numbers are exact, and when i put it on cruise i truly place it on the 60,65,70,75,80 mph on the money. And the drive is relatively straight, from Cal. to Phx. 405mi to my house, with maybe 12 or so long incline passes totalling 50 miles of that 405, the rest relatively flat and smooth. So i'm really keeping it about the same, other than weather conditions which i obviously cant control...wind...mainly, with occassional rain. Anyway, thanks troy i cant rest assured that purchasing a newer camry will still give me similar mpg results
    Later
    Caaz
    p.s. I'm really wondering if i would ever buy a camry hybrid. A few of us can ahcieve almost the same mpg as they're getting, without factoring in the 3500.00 dollar battery every 150,000 miles, plus the additional cost up front, you'd Never catch up to paying 18,000 for a new Le that i can average 35 mpg or better in.
    "We have a 2000 Camry, but would feel fortunate to get 22 mpg for short trips. I drive 5 miles each way to and from work, about the 20 min drive described above, never above 45 and have never done better than 19 and it is usually more like 17-18 mpg, ocassionally even lower in winter. So I don't think you should be concerned. We've never gotten even close to 35 on the highway. I think ONCE we got 29 and since then 26-27. "
    This sounds exactly like many experiences, including my own, so not to worry:
    To answer the question posed, I recall janderson8 - if memory serves - has a 4 cylinder LE 2000, the first year of that body type - and I think his/her car is one of the originals on my first analysis of mileage (which preceded this subforum).
    There are about a dozen such camrys where I work (out of 900 employees) - including a couple 2007s - I think I've spoken to most of the owners, and the range is about 25-28 mpg - no 30's in there -and not that many 28s, and mostly 26 or so. I've rented several others, in 2006, and 2007, and took them out for a spin too. As for individual tanks, I am over 100 readings of my own, and only two individual tanks reached or exceed 30 mpg, and these were surrounded by lower numbers, so it is possible that error in refueling may have been responsible for it. That low end for pure city driving, 17-18 mpg, with a bit lower in winter, is right on the money with what I get.
    When I got my 07, I took a look at the hybrid Camrys, but I knew I was buying a mostly highway travel car which occasionally has to move the entire family. The hybrid system seems to be mostly an improvement for around town anyway, so I would rather get the better price rather than good around town mileage.
    If I were buying a car only for me to do highway driving, I would choose something just a bit smaller like the Corolla or Civic, to squeeze out another few mpg.
    But considering the size of the Camry, I'm quite happy with its fuel mileage at highway speeds. On my next trip somehere, I'm going to try and slow down and see if I can crack 40mpg like you have.
    The car i replaced with my 03 camry was an 04 Civic hybrid....lol, since you mentioned with all my highway driving thats what you might consider. I enjoyed it alot, but to be honest, the camry is much more comfortable.. 10 times quieter, which was my biggest complaint with the civic. you had to blast the stereo to drowned out the road and wind noise. And at my usuall 80 mph on my phx to ca trips, i averaged 42.3 almost everytime. So i can slow down to 75, get about 36...and really enjoy the comfort. Put on my books on tape, which i do every week now, and can leave it nice and low and still hear it....
    later
    Caaz
    Maybe.. and i have heard that the new corolla is going to be really quiet. If so, i could def keep that posibility open.
    Part of the reason I've stuck with Camrys is because of the quiet factor as well. I find that during a 30 hour drive, any little thing can make the difference between being really uncomfortable, and arriving at your final destination in reasonable shape. Noise is a deal breaker for me, anything I plan on driving across the country in a single shot has to be quiet.
    I agree with the quietness factor.
    Trip#9 405.6 mi 11.45 ga. = 35.42...Constant 75mph. Decent conditions a small amount of side wind. Intersting that 10mph costs me 5mpg.
    Later Caaz
  • "Intersting that 10mph costs me 5mpg."
    I have seen mileage tests at both Car & Driver and Consumer Reports that reported the same results. In my recent trip to Florida, my trip computer (on a Highlander with 3.3 liter engine) showed 2-3 mpg better at a steady 65-66 vs 71-72.
    I knew with the weather there would be no records, so i went 80 mph into a strong head wind. Strong enough to make me nervous as there were times when the wind knocked me 6 to 8 inches from side to side. Yet, there were still idiots going 10 to 15 mph faster. I dont know how they do it without wrecking.
    Anyway.... the results are...405.6 mi 14.6 ga = 27.78mpg My worst yet. but not surprising with the winds.
    Later
    Caaz
    Trip #10 405.6mi 11.4 ga = 35.57mpg @ 70 mph A bit of cross wind, but not bad
    Later
    Caaz
    trip #11 405.6mi 12.5 ga. = 32.44mpg 75 mph into a slight head wind from phx to ca. and agianst the jetstream.
    Later Caaz
    Keep em coming. Love the updates with different speeds etc. Lots of good data points.
  • shyneeshynee Member Posts: 9
    I have a 2007 Camry SE AT V6. I drive 21 miles one way to work on a free way (from Richardson to Irving ). I consistently get 27MPG which includes bumper to bumper traffic. I fill up once I hit the empty tank signal which is generally occurs @ 15 gallons.
  • chuck28chuck28 Member Posts: 259
    I have never gotten 27 mpg . This winter I have been gettin 15 to 18 and the 18 is when I have some Highway but mostly local.
    I believe that my Gas milage has been affected with each transmission fix.
    When I go th the dealer thay just say it's winter time.
    There has to be a reason why my car is getting 15 to 18 and others are getting high 20"s?
    I need suggestions on how to get toyota to fix this problem.
  • 15 to 18 in city driving in the winter is about right. I'll bet if you did a full tank on the highway, you could get mid- to upper 20s. A quarter tank of city driving is going to drag down the overall mileage even if the rest is highway.
    By transmission fix, are you having that "transmission flare" issue or whatever Toyota is calling it? That problem is really socking Toyota in the chops, if internet boards are to be believed.
    I would think so.
    I would think the first issue is getting Toyota to admit there is actually a problem. Claiming a difference in fuel mileage between yourself and others isn't good enough for Toyota, I would imagine.
  • We read here about significant differences in mileage. In cruise controlled highway driving, I suspect "normal" vehicle to vehicle variation could be +/-10% or so which would be 6 mpg variation if the mean is 30 mpg (just pulling numbers out of the air here.) IOW, the guy who claims he never gets over 27 mpg just has a vehicle at the low end of the bell shaped curve and the guy who get 33 mpg has a vehicle at the other end. Hard for either to understand the other's mileage.
    I'll bet the city variation is quite a bit more. Not only does "city driving" vary greatly from city to city, driver style probably has a much greater effect. I once rode with a colleague whose speed changed constantly just driving stoplight to stoplight. We were almost always accelerating or braking. It almost made me motion sick and I never get motion sick. My guess is that her city mileage was horrible compared to most drivers. She wasn't the type to be concerned about that sort of thing so I doubt she ever checked it. Had she discovered her mileage was horrible, she probably never would have suspected her driving style because I'm sure she thought it was normal.
    I believe the lower Gas milage though can be affected by dribving styles which I'm well aware of and know how to drive conservitive if needed, has to do with the Computer being reprogramed to adjust the trans shifting issues which has been a problem.
    I have noticed my MPG change after each fix.
    Getting Toyota to admit it is another problem.
    I still need help!
    I believe you're all correct to some degree.
    #12 405.6 mi 12.9 ga. = 31.44 80 mph
    #13 405.6 mi 13.89ga = 29.20 80 mph
    interesting how the same drive, same conditions, same temp. but i always get less going against the jetstream from east to west.
    Later
    Caaz
    next time i'll post all 13 trips so you can compare..... Im also noticing im not getting as good of mpg since even though we're not super cold like the rest of the u.s. our temps are dropping.. That makes a difference as well. Im assuming my best mpg will come in the spring... 80's 90's...before i have to start using the a/c
  • You don't use the A/C when it's 80s or 90s? ;)
    A trip to Charlotte this weekend. 393.3 miles, 11.5 gallons for 34.2 mpg. Drove at 70mph on cruise, had two cold starts and about 16 miles of 'city' driving. Winds moderate both ways.
    I don't know what my Camry would get at 75 or 80 mph. Can't bring myself to drive that fast. It's against the law 'round here...
    Drem
    I still need help!
    This is mainly a forum for mentioning our fuel mileage and such things, have you tried in a more general toyota forum where people have had similar problems as yours? Considering the issues with the V6 and 6sp auto, I would think others have already tackled this problem and written up their plans, results, ideas and such?
    Here in Colorado the posted limit is 75mph, you can do 80mph without hassle by the revenuers, I once did Las Vegas to Denver via Flagstaff and Albequerque and my radar detector didn't go off once. I drove I95 this past fall from PA to FL and it went off every 10 miles or so. Just different driving worlds.
  • 210delray210delray Member Posts: 4,721
    Yep, I made it: 602.1 miles on one tank of gas in my Camry! A little anxiety-provoking at the end, but success was achieved. This was done on mostly all interstates, most of them posted at 70 mph, in my 2005 Camry, the one that gets lower mpg's than my 2004. Put in 18.53 gallons when I filled up, the capacity of the tank (car was tilted downward to the right at the station, and the pump nozzle was an "easy squeeze" type, making it easy to top up without risk of spillage).
    So, my mpg came to 32.5 -- typical for this car on highway trips, but the first time I risked running out of gas to see if I could make the magic 600-mile mark! Usually when I fill up, I only end up putting 15+ gallons at the most (550 miles driven), when the gauge reads exactly at the "E" mark, so I figured I could go another 50 miles.
    BTW, my GPS indicates my odometer reads 2.3% too low, so if I put in this correction, I actually went 615 miles.
    I will post photos in my CarSpace page soon.
  • mcdawggmcdawgg Member Posts: 1,722
    Congratulations! I've been waiting for someone to do this ultimate test. I am not surprised, though. Glad to hear that this debate is over, the Camry proved itself!
    Good job!
    Excellent!! The only time I ever attempt games like that is when I've got another 5 gallons of emergency gas in the trunk...
    Its nice to see that quite a few of us are able to do exactly whats expected of a solid 30+ mpg car though.
    I'm trying to think up a little Camry stunt myself, if I head west from Denver, doing only 60-65 mph, I should be able to stay free of any major slowdowns for 1050 miles easy ( Reno NV ). Throw 5 gallons in the trunk, and then run the tank to fumes. Drive slow on a non windy day, 37 mpg for 18.5 gal = 680 miles?
    Would I be better off heading east through Nebraska and Iowa to Chicago instead, avoiding that first big climb out of Denver to the Continental Divide? Thats about 1000 miles in distance, so there is plenty of room that way as well, but the scenery isn't near as nice.
    when im in the upper 30's (mpg) i usually fill up at 625 miles. The time i hit 40 mpg i could have gone 725 miles..... I have noticed 1 thing on my camry, when my gas light comes on... i only have 1 1/2 ga left.... i cant go very far at all with the light on... how bout the rest of you??
    later caaz
    p.s...ive missed a few postings... will do them tommorrow a.m.
    Do you have a hybrid? Otherwise, I don't think it is possible to get 40 mpg on a Camry (unless you start at the top of a mountain and only go downhill.) How do you figure your mileage? Admittedly, we have a lemon of a Camry and have never even gotten 30 mpg, but 40 doesn't seem in the realm of possibility.
    caaz,
    That's about my experience as well. About 2.5-2.7 gallons while I am sloshing the tank around in town, but about 1.5-1.6 gallons if I am running smooth and straight on the highway. 2004 model.
    Drem
    Back in Post #636 I listed consecutive strings of tank fillups in my 07. I think there are 3 of them >37 mpg or so, and I had like NO consideration for speed at all when making those runs.
    I think 40mpg is possible, but it requires some things which may be far enough from "normal" driving to perhaps not be advisable. Like driving 62mph on interstates posted at 75mph. Secondary roads have too many towns which require you to slow down, downshift, then accelerate again. So a nice western interstate....with as few big cities and as low traffic as possible....62 mph....non windy day....just steady cruising for 11-12 hours....I think Caz has already done it on a 400 mile run, it ain't easy, but its doable.
    #14 405.6 mi. 13.56 ga. = 29.9 80 mph..plenty of wind... temp 40's
    #15 405.6 mi 13.85ga. = 29.28 80 mph very windy .... temp 40's
    #16 405.6 mi 14.24ga = 28.48 82 mph 60 mph winds temp 60's
    Will be attempting a 65mph run tommorrow, my confidence is slipping after all these 80+mph runs... i need to make sure my car still gets good mpg....lol
    Later
    Caaz
    j...no its not a hybrid...its an 03 4 cyl automatic. And at 75mph or less ALL my tanks are over 30 mpg......
    when im at 60 or 65...with perfect conditions...(no wind)..on 2 tanks i got 40mpg...outside temp when i did that was 70-72 degrees.
    Not in the 40's like now
    Later Caaz
    p.s. How do i calculate my mileage?.... SImple...enter the miles...divided by gallons.= mileage.. i ALWAYS top it off until i see the gas sitting on the lip and it doesnt drop anymore....ultra consistent. takes me an extra minute, but ive always done this my whole life, was taught by my dad. Never in my life have i put the nozzle back in the pump when it clicked off...its not full yet, lol. i can get 2.2 ga. in when it clicks off
    Hope this answers your questions
    #17 My confidence is somewhat returning..... did my trip from So Cal to PHX..this time i left just a lil bit further down the freeway than my usuall 405.6 miles.
    417.5 mi. 11.2 Ga. = 37.27 mpg A bit of side wind which hurt it a bit, but decent. warm...74 degrees. It has restored my confidence. After all those 80+mph runs and in the high 20's..i was begining to wonder
    Later Caaz
  • It's simple physics. Wind resistance goes up as the square of the velocity and most of the hp at highway speeds is used to overcome wind resistance. I think you've proved your point many times over.
    What would be really interesting would be for you to drive one of the Camrys that can't seem to break 30 mpg on freeway trips to see how much is the car and how much the driver. Alas, we'll never solve that mystery.
    I agree that it would be interesting to have the same driver drive a car that is getting good mileage and one getting poor mileage to see how much is the car and how much the driver. We are one of the under 30 and I am quite sure it is the car, not the driver, but it is hard to prove. On other cars we've owned we've gotten rated mileage or even better. Our city mileage (we average 5 mi trips in light city traffic) is now running between 16.5 and 17.5 on our 2000 Camry. In warmer weather we may get close to 19 but never over 20 or even close to the rated 23.
  • If you have gotten the highway ratings on other cars, that's a pretty good data point. My wife's Highlander has never achieved anything close to its 18 mgg city rating. In the winter, it's in the 13-14 range and 15-16 in the summer, also lots of short trips. Best highway mileage has been 23 on a recent 2900 mile trip to Fla and back where we saw temps ranging from low single digits to low 80s (not on the same day of course.) ;)
    So cal to phx.
    trip#18 405.6 mi. 11.65ga. 34.81 mpg @ 75 mph. A bit breezy but not bad.
    I wont bore you with more trips until we warm up a bit, then see if i can pierce 40 mpg again. once its in the 80's
    Later Caaz
    365 miles round trip with one cold start overnight. CC @ 69 mph. 10.0 gallons. 36.5 mpg. 2004 4cyl auto.
    Drem
    nice drem..... i just got in last nite from mt phoenix to So cal trip, but havnt filled up yet so i cant report it yet....lol
    Later
    Caaz
    I'm in the middle of a 1700 miler right now, about 34 mpg on the first tank. Will report the entire trip as a single mileage when I get home Thursday. That 34 mpg was from Denver to Santa Fe, 40F or so, 80mph constantly when not in or near town. 1 adult, 2 kids, 1/2 full trunk, moderate cross winds. I won't get a chance to drive slowly this trip, beyond doodling around the Grand Canyon and such, otherwise its as fast as the law allows.
