Hybrids & Diesels - Deals or Duds?
17273757778100
  • kdhspyderkdhspyder Member Posts: 7,160
    It wasnt clear from the short write up but there seems to have been a significant discrepancy between the onboard computer read out of about 50 mpg (?) and the calculated one of miles driven / gas pumped.
    In 18,000 mi I've never had a reading as low as 42 mpg for an entire tank but I can venture a guess how it might occur. The fuel bladder in a Prius has a significant effect on the amount of gas apparently used. There is potentially a significant difference in fuel tank capacity in the fuel bladder if the weather is cool, it's a new Prius, the fillup is done early in the morning and in the filling equipment itself.
    The TDI certainly did well in exceeding the EPA.
    I predict with certainty that John will discredit this test!!
    For sure. They probably did not fill the tank to start with and the tires were not inflated to 90 lbs etc etc. The last cross country test of the Jetta TDI vs the Prius gave almost identical results. Cross country at 75+ MPH, the Jetta TDI will beat the Prius on mileage every time. In stop and go with very slow speeds as in the Vancouver, BC 200 mile run, the Prius will have a better chance.
    To me this was the biggest plus. It beat even the Accord Hybrid for quiet comfort.
    For comfort, quiet and highway handling, drivers found the TDI had significant advantages over every other car in the test. It would have been AutoWeek's choice, in other words, for an easy day trip on the interstates, regardless of fuel economy.
    Anyone that wants one better get it quick. There will be a shortage till they get the next VW diesel ready for the US market. Pretty bad when the best mileage sedan in America is being shoved out by ignorance in Washington DC and CA. Also the only high mileage vehicle capable of using 100% renewable "Made in the USA" fuel.
  • winter2winter2 Member Posts: 1,801
    After reading the article, it points out a couple of things.
    1. Driving technique has much to say when it comes to fuel economy. It has been known for several decades that a light right foot always improves fuel economy, without regard to the type of drivetrain that is in place.
    2. Prius type hybrids always seem to better in stop and go driving, whereas diesels always seem to do better on the open road/highway.
    3. As to greenness, both are green in their own respect. Both are dirty in their own respect. So to say one is cleaner/greener than another is a waste of words and time.
  • logic1logic1 Member Posts: 2,433
    Is the Accord Hybrid quiet?
    The reason I ask is that I am in one of these shared cars organizations. This is a service somewhat like a co-op for cars where a number of people sign up to use cars parked around the city. We reserve use on the web and then pay a modest hourly sum and mileage. You pick up and return the car from its parking spot with a key card. No human interaction necessary.
    Anyway, the car I used over the weekend is a brand new (only 900 miles) Civic Hybrid. After hearing so much about the refined quiet of Hondas, I was somewhat surprised to discover the engine is just a little noisy and even rough.
    I think the stoplight shut down is pretty cool (and oft used in Brooklyn - sheesh!). You sure could tell it was stopping and starting. I am no stop light racer. If you are, you definitely do not want a Civic Hybrid, as there is a brief lag before the engine starts.
    All in all, I had no problem with the car. But it sure was not whisper quiet.
    Now that the ULSD is set to hit the market, I think the VW TDI would be my prefence.
    Too bad about Daimler dropping the diesel from the Liberty. Seems to me a torquey low sulfur diesel in a Wrangler would be a match made in heaven. Perhaps Daimler does not have the drive train to go with the diesel?
    Unfortunately, EPA rules are quashing the diesel in the Liberty. I believe it is getting hit on NOx. Daimler does have the drive train to put behind it.
    I would love to retrofit my CRD with an NOx scrubber but alas such is life.
    As to your experience driving the Civic Hybrid, I had a similar experience driving a Prius this past December. Engine starts were abrupt, it was noisy (mostly road noise) and the steering was really numb.
  • jkinzeljkinzel Member Posts: 735
    zodiac,
    Pretty gutsy call, however, I have great faith in your psychic powers. ;)
    I was going strictly by hearsay on Edmund's concerning the quiet ride of the Accord Hybrid. So it was a surprise. I don't think I would like it if the starting of the engine was noticeable on a hybrid. My GMC is so quiet starting and idling that I have to look at the tach to tell if it is running. When you let off the brake the starting is very quiet and smooth. If you try to slide your foot off the brake onto the gas for a fast start there is a hesitation. Letting off the brake normally and then accelerating is very smooth and seamless. Several passengers were very startled that the engine would shut off and start with no noise inside the cab. Makes for good listening to the classical stations on XM radio through the Bose system.
    I have written to a couple Jeep dealers about a Wrangler diesel. That would be a fun machine.
    Unfortunately, you need to move to Europe to get the Wrangler diesel. Maybe, they will be here in 2008 or after.
    I would love to see the CRD in a 300. They have them in Europe and they are very quick. Plus they go very far on a gallon of #2.
    is the 300 heavier or lighter than you Liberty?
    We can hope. It really seems optimal. Have you driven the EU version? If so, what do you think?
    Yes that is what I had expected.
    The Civic had a brief lag when you put the accelerator down. Not enough to be annoying, but I certainly did feel it start up again each time. I will try and be more careful with the brake and acceleration next time and report back. (the Civic happens to be the closest car in the service to my apartment)
    Could be the V8 is just smoother than the 4?
  • gem069gem069 Member Posts: 65
    Diesel Swap: Jeep Drops Liberty CRD in Wake of Grand Cherokee Offering
    Date posted: 06-05-2006
    DETROIT — Only a week after announcing plans to offer a new turbodiesel engine in the 2007 Jeep Grand Cherokee, Chrysler said it will discontinue the diesel edition of the Jeep Liberty after model year 2006.
    Chrysler said the older diesel engine that is offered in the Liberty doesn't meet tougher federal emissions standards that are being phased in for model-year 2007.
    The Liberty offers a 2.8-liter four-cylinder common-rail diesel that delivers 160 horsepower and 295 pound-feet of torque. The EPA city/highway ratings are 21/26 mpg. The engine is made by VM Motori, a DaimlerChrysler subsidiary.
    The Grand Cherokee gets a new Mercedes-Benz 3.0-liter V6 CRD that delivers 215 hp and 376 lb-ft of torque, with projected EPA ratings of 19/23 mpg. In fact, the same engine already is being installed in the Grand Cherokee and Commander in Europe and other overseas markets, as well as in such export models as the Chrysler 300C sedan and wagon.
    The Liberty is slated to get a full redesign for model-year 2008. Chrysler is said to be evaluating several diesel options for the next-generation model.
    What this means to you: Getting diesel into the U.S. is a tricky dance, but the demand appears to be there on a limited basis. If customers want it, someone will figure a way to get it over here.
    I believe the 300 is lighter than the Liberty by a few hundred pounds.
    No, I have not driven the EU version. But if they are using the same 2.8L diesel engine that presently resides in the U.S. Liberty, my guess is that it will be a really good match.
    A Wrangler with a diesel is fascinating to say the least. They are very capable vehicles and with a diesel, that capability will be enhanced.
    My feeling is that with MY 2008, we will see more diesels including one in a Liberty and/or a Wrangler.
  • zodiac2004zodiac2004 Member Posts: 458
    A Civic is way noisier than an Accord V6, especially under acceleration. So I'd imagine the HCH with a smaller ICE would be even more so.
  • bc13bc13 Member Posts: 32
    Its great to hear that they might finally have a diesel in a grand cherokee. But I would be disappointed if it only got 19/23 mpg. Isn't it the same engine that goes into the MB 320 CDI? Isn't that rated at 27/37 mpg? Or has the engine been modified at the cost of fuel efficiency? Weight wise I don't think they are much different (grand cher and the E320).
    Now if only Ford/volvo/chevy would follow suit.
  • john1701ajohn1701a Member Posts: 1,897
    There's simply no need.
    1,200 miles of Road-Rally through Minnesota did that already.
    The two Classic Prius averaged 48.5 MPG. The Civic-Hybrid CVT got 46 MPG. And the Jetta TDI Automatic only got 42 MPG.
    JOHN
    You need to run it with current Vehicles. The older VW auto transmissions were not nearly as efficient as the DSG transmission used today. I would say VW Jetta has advanced while the Prius went somewhat backward. At least by results from recent cross country events using the Prius II. The MPG results were swapped with what you experienced using the Prius Classic and an older Jetta TDI. Did not see what MY VW was chosen for the cross country event. Your response was predicted.
    How much recycled bio diesel fuel did the Prius and Civic use compared to straight gasoline?
    ..."The two Classic Prius averaged 48.5 MPG. The Civic-Hybrid CVT got 46 MPG. And the Jetta TDI Automatic only got 42 MPG."...
    Again an interesting comparison. Under the same conditions I would swag my TDI 5 speed manual would get closer to 50 mpg. Since the hybrids do not come with manual or DSG transmissions I wonder (however academically) what the fuel mileage would be.
    The real point is those figures would be beyond HOT if I (you or anyone) did not HAVE to prepay for the higher fuel mileage (want is of course a whole different option). This is the real reason why (for me for example in a plain jane commute) chosing a Honda Civic made economic sense, even as if it only gets 38-41 mpg. :) Compared to a Honda Civic, the Prius YEARLY savings would be 54 gals per yr, at 3.20 per gal, my per year savings $172.80/$14.40mo. I of course would have paid 12,500 more for this savings. :(:) A SWAG puts the fuel comparison savings BE at 72.337 years. :( So if this seems like an abnormally long time, lets just say that $12,500 would fuel my commute 160,156 miles. So just the price difference alone pays for 11.23 years of commuting.
    Again this is not to take anything away from the Prius, HCH and/or TDI. The price difference for a Prius/HCH/TDI was 12,500/7,500/5,500 respectively.
    The interesting point of the whole mileage test with a diverse array of vehicles was the fact that the VW Jetta TDI was the one ALL the drivers picked over a Corvette, Accord and Prius as the most comfortable and QUIET. So if you have a long commute each day and are concerned about fossil fuel usage the Jetta TDI with DSG IS the BEST and only logical choice. Also the ONLY one that can run on 100% homegrown fuel. Try that in a Prius. :P
    Interesting observation! I guess if I look at my own behavior, I have the same mileage on both and have had the Jetta 3 years less!! :)
    Sooner or later the Prius/Hybrid folks are still going to have to acknowledge using the one trick pony fuel unleaded regular. :) Unless of course the environmentalists will let the unleaded regular be gotten from the VAST domestic reserves in the USA!!!! ???? NOT !!! :)
    Hybrid Road Rally is discredited.
    The "data" from 2002 is as bogus now as it was in 02. The Hybrid Road Rally is the type of misrepresentative staged event that caused months of non-constructive bickering.
    The 02 TDI obtained higher mpg than the 04 PD unit injector TDI engine and obtaining 50 mpg with an automatic is easily achieved. 42 mpg average too low to be credible.
    JOHN
    Just filled up today from a 584 mile R/T trip (trip was yesterday), 7 hours of driving time to and from San Jose, CA to Santa Barbara, CA. Couldn't go much faster as there were CHP out in force, 13-14 squad cars and or pick up trucks. :(:)
    Fuel was expensive in Santa Barbara (but what else isn't,even Ophra has digs in the vicinity) , (3.39 per gal) so I decided to make it home to fill at the corner store for 3.19 per gal. :) Absolutely no attempt at driving the fuel misers' procedure!!
    In order to get a really clear picture of how well a Prius does against a VW TDI, one would need to look at many different road rallys each running in different circumstances. Only then will you get a real idea of what kind of FE you will get.
    Agreed. Anecdotal evidence from whatever instant source is at best a snapshot.
    A resource such as GreenHybrid or GreenDiesel ;) would go far in eliminating a lot of the need for any press reportage and comparo's. Just look at the databases.
    In the absence of this real data we are left with meaningless comparo's whether structured or best-effort-unbiased.
    Imagine if somehow all the vehicles in the market were somehow required to report fuel/type used and distance driven. If this were somehow monitored by a 'use tax' as proposed in some places then the need for the EPA numbers would be eliminated.
    With these databases each model and fuel-used could be summarized in millions of data points and a 'true' FE value would be known. The City/Hwy distinction would be lost but the 'True-Cost-to-Own',to coin a phrase :surprise: , would be readily available. All this data is available now there just is no incentive to gather it and sythesize it for public use.
    ..."Imagine if somehow all the vehicles in the market were somehow required to report fuel/type used and distance driven."...
    This is essentially the crux of the matter on the Prius EPA vs Prius "reality". I think it is the illustration of the classic Shakespearian line: much ado about not much!! :)
    The lab doesn't match the real world!! Yet we poh poh the diesel side when it actually gets better than the lab? Or call it unscientific or anecdotal? Come on folks, get over it. :)
    that we may or may not see here.
    From a European autoblog, Auto Express, today.
    quote:
    Tuesday 30th May 2006
    Prius to be given turbo boost
    Our insiders have blown the cover on a turbocharged prototype which is being tested in Japan. Auto Express was the first magazine to reveal plans for a 100mpg-plus successor to the Prius in issue 904 - and now we can spill the beans on how it will be done. In its efforts to come up with a car that blends economy, low emissions and performance at an affordable price, Toyota has decided to use a lean-burn 1.8-litre turbo engine. Meanwhile, the THS-II hybrid system will be upgraded with efficient lithium ion batteries, which will allow the electric motor to deliver greater performance because the cells recharge quickly and hold more power for longer. To further improve efficiency, it's also thought that Toyota is considering a plug-in system, similar to that used on the Amberjac Projects Prius. The socket will allow owners to top up the battery when it's parked. Insiders at Toyota are excited about the newcomer, and are promising greater performance and super-low emissions for less than £20,000.
    unquote
    Under $24,000 at current rates. YMMV ( your market may vary )
    for less than £20,000. unquote
    20000 UK pounds is over $30000 US.
    YCMV (Your conversion may vary).
    right I was thinking euros at abt 1.20/1.00. Missed the currency sign, tks. E&OE ;)
    Also to further confuse the issue, the article being written in the UK uses Imp Gal. Thus 100 mi/Imp Gal converts to abt 83 mi/US Gal.
    Going back to a topic discussed here earlier, the Jeep web site has the specs for the forthcoming '07 Wrangler.
    Apparently the Toledo factory will make a version of the little Jeep with a 2.8 litre diesel and 5 speed manual tansmission for export only.
    Mileage figures are not available, but I would guess the diesel will significantly outperform the new V6 with the 6 speed manual. And, as mentioned earlier, the little diesel will certainly be able to run on readily available bio-diesel, processed from restaurant waste and other recycled sources.
    This really seems like a case of our regs cutting off the nose to spite the face. I hope Daimler figures out a way to make the 2.8 meet US NOX and particulate standards quickly.
    Zodiac: Do you know off hand if the diesel Wrangler will be available in Canada?
    Or is Daimler making this for export to Europe and elsewhere overseas?
  • easy2t2easy2t2 Member Posts: 31
    I have been thinking the same since I read the news. Other japanese manufacturers have more efficient diesel engines around the world, like nissan & toyota. You want to see a real if shipped to the US? here...
    http://www.worldstyling.com/web/product_detail.php?id=911&PHPSESSID=dc3631bdce6a- 646892e6e466935c3a6e
    GBPUSD=X 20000 Jun 7 1.8613 $37,226.9654 US Dollar 1.8613 1.8616
    VW Ceases Production of Gasoline-Only Models in Brazil; All to Be Flex-Fuel
    6 June 2006
    VW’s flex-fuel sales in Brazil
    Effective this month, Volkswagen Brazil is halting production of gasoline-only models in the country. All vehicles with gasoline engines will now roll off the line flex-fuel-capable.
    While a number of manufacturers offer flex-fuel vehicles in Brazil, VW is the first to switch entirely to the technology across its entire line-up.
    VW introduced its flex-fuel 1.6-liter Goal in March 2003, followed by the 1.0-liter Fox in October 2003 with the Bosch flex-fuel engine management system (earlier post).
    VW has been a leader in the Brazilian flex-fuel market from the beginning, and now has a 35% market share, with aggregate flex-fuel sales of 575,111 units through April 2006. The Goal and the Fox together represent of those 464,087 units.
    More than 75% of all new vehicles sold in Brazil are flex-fuel. Brazil offers E100 (100% ethanol) at its gas stations, as well as E25 (25% ethanol and 75% gasoline). About 20% of Brazil’s transport fuel market is ethanol, compared with about 1% world-wide.
    How many acres per year of rain forest are destroyed to make way for the production of ethanol?
    This is not a good thing.
    ...unless it was an A-plan, X-plan, WXYZ-plan program
    I had not seen this before but in another forum it was pointed out that it's more than the Hollywood glitterati who seem to be making a statement. Corporate incentives?
    BoA
    Very little. Brasil is a large country. Almost as large as the United States. Just as some parts of the US are forest, some desert, some prairie, so too does Brasil have differing topography.
    The prime sugar cane growing regions are not in the Amazon rain forest, but in the central grass land areas. Now prairie destruction comes with its own issues. But it is not the same as tropical rain forest destruction.
    Most of the rain forest pressures are the result of insatiable global demand for hard wood and cattle grazing.
    That is OK if you like corporate welfare. You think the BofA is doing that out of the goodness of their little ole pea pickin' hearts? It is all being subsidized by the rest of us.
    This is the kind of corporations I want to align myself with. They are doing something about our use of fossil fuels.
    Companies using biodiesel
    I'm not very familiar with DC products here, but I haven't heard anything about the CRD engine going into the TJ.
    It's only available in the Liberty.
  • kneisl1kneisl1 Member Posts: 1,694
    >Insatiable demand for hardwood and cattle grazing<
    Dont you mean an insatiatable BRAZILIAN desire to make money from the global demand? (and I suspect they are selling CHEAP!)
    A national finance magazine is looking to interview current hybrid owners who purchased a hybrid within the past year or two. The reporter is wanting to know if you have been satisfied or not with the gas savings you&#146;ve been receiving. Please send an e-mail to ctalati@edmunds.com no later than Saturday, June 10, 2006 by 5:00 PM PT/8:00 PM ET containing your daytime contact information and the make and model of your hybrid vehicle.
    A national finance magazine is looking to interview consumers who are looking to purchase a hybrid vehicle and are looking at it from a financial standpoint, hoping to save money from the high cost of fuel. Please send an e-mail to ctalati@edmunds.com no later than Saturday, June 10, 2006 by 5:00 PM PT/8:00 PM ET containing your daytime contact information and the hybrid vehicle you are considering.
    Chintan Talati
    Corporate Communications
    Edmunds.com
    Surely no one (the owners included) thinks that owning a hybrid is going to save them money? If anything, its going to cost them more money. Financially, all a hybrid does is give the money you would have given to Exxon to Toyota. I would be interested to see how many people buying a hybrid think its going to save them money.
  • alp8alp8 Member Posts: 656
    probably a lower percentage than the percentage of home mortgage holders that take a fixed interest rate loan, and I don't see you criticizing THAT as a stupid financial decision
    why is it that you guys are so hung up on proving that hybrid buyers made a bad financial decision?
    ANY new car purchase is a stupid financial decision when compared to the alternatives, such as buying that very same car used.
    I know - you want to hold hybrid buyers to a different standard because you think they take a holier than thou approach. Just say it!!!!!
    Actually the "holier than thou" attitude was most frequently expressed by some of the hybrid ownership side.
    In regard to the "used" hybrid market, there are not many who frequent this board who have bought USED hybrids, let alone have experience (time and mileage) with them.
    So again, I have absolutely nothing against anyone whose ideal car is a hybrid and in fact buys it. Just don't tout the "holier than thou types of issues when some to all of the issues has been disproven.
    I only deal in facts, not friction.
    There is no question that it will save me money even at $2.50/gal.
    40,000+ miles annually x 5-6 yrs.
    Camry 4c Fuel usage: 1335 gal / yr x 6 yrs @ 2.50/gal = $18,000 gas cost
    Prius Fuel usage: 800 gal/yr x 6 yrs @ 2.50/gal = $12,000 gas cost
    This ignores any tax incentives. The Prius cost just under $24000 vs a new LE Camry with the same features @$20,000.
    It is an unusual situation but never say never ;)
    Thanks for proving my point...
    you misread my post
    I stated that the attitude was of the hybrid owner (well, what someone thought the hybrid owners' attitude is/was}: "I know - you want to hold hybrid buyers to a different standard because you think they take a holier than thou approach."
    as to new vs used - you are missign my point. EVERY new car purchase is STUPID from a purely financial standpoint, so it's not fair to ONLY criticize hybrid buyers for financial stupidity. Hold Hybrid buyers to the SAME standards that you hold ALL car buyers. A new TDI purchase is STUPID financially compared to buying a one-year old TDI. See what I mean?
