with about 75% highway miles
19/28 MT
20/28 AT
Beating these numbers, especially the highway one, should be quite feasible.
27.5 MPG
29 MPG with 85% Highway miles
See the chart below done on an 04 TSX. Look at test 1 and 3. There could be a slight change for MY06 and later because of the different engine.
If you want to see the whole write up go here: http://tsx.acurazine.com/forums/showthread.php?t=23721
BTW, this also shows why the speed limits laws of the 70s are still applicable today - the best mileage is at the old double nickel limit.
And of course this is only a cost comparison - never mind the fact that the manufacturer recommends premium and that you make more power with premium.
Combined mileage 31
Best Tank full 35 Worst Tank 28
Test 1 and Test 3 were both done at 55 MPH, but one had cooler temps and a headwind, and the other had warmer temps and a tailwind.
Test 1 and Test 2 appear to be from the same stretch of road (on the same day even), but Test 2 was done at a slower road speed.
I agree with your thinking though. The only way to compare 87 octane and 91 octane economy is to do it with the same car, on the same road, under the same environmental conditions.
It's meaningless to try and compare a TSX in NJ that gets 41 MPG on 87 octane and a TSX in San Francisco that gets 22 MPG on 91 octane.
If you drive your car closer to its performance envelope (sprints to redline, very spirited driving on mountain switchbacks, full load in the car, etc), then you need 89 or 91 octane to squeeze the max performance from the k24 engine.
I do most of my traveling in New Mexico, Arizona, and Colorado at altitudes from 1100 feet to +11,000 feet. I-70 westbound mountain pass around Clear Creek, west of Denver, is at 11,013 feet. Put 87 octane in your TSX and hit that stretch of road. Run your mileage test in this environment and then you will see a “statistically significant” change in your mpgs/power/performance.
Choose the fuel that best fits for your driving environment/habits.
Mine is an 2008 and just one tank of gas. I'm getting 34 peak highway and 31 +/- on commute (mix Hwy, Local)
Incidentally, the 2008 brochure says 91 Octane REQUIRED and the manual simply says specifies "91 Octane" without any recommended or required language... I followed up with both GM and Service Mgr at the selling dealer and then hadn't noticed the change as yet and admitted it was change to te documentaiton. Then at delivery, I found out that they filled it with 87 octane ! Go Figure !!!
Total City MPG for 1500 miles 24 MPG
Combined Total MPG for 7,000 miles 30.5 MPG
I bought my new 2007 TSX 2 months back and am getting only 18 MPG for about 1500 miles of mainly city driving (75% city/25% highway). I use 89 Octane fuel.
It is summer in DC and so the AC is working overtime but, this appears really low. Anyone else with the same experience? Should I call the dealer?
The TSX really hates city driving. Stop/go traffic in an I-4 pulling +3500 lbs from a dead stop every 300-600 feet(car's mass, gasoline weight, passenger(s), junk in the trunk, A/C, etc). Maybe a longer route with less lights might be better compared to a shorter route with more lights?
Take a drive on the hwy with the cruise set between 70-75 mph, you will see around 30-34 mpgs on average.
I use my TSX for commuter driving which here in greater Boston means congested Highway miles with Urban Stop-n-Go at both ends (80 Hwy/20 City). I am averaging 31.3 - 32.5 for my first few tanks and I can't tell the difference between the 87 Octane the dealer filled it with and the Shell V-Power 93 I have now filled it with 3 Times.
30.0 mpg
Total mpg highway 32 Total mpg city 26
Have used all three grades of gas with premium getting the best mileage by about 5%. What little you save getting another grade of gas (87 or 89) tends to be eaten up in less mpg using the lower grades.
Worst Tank MPG 20.0 for 240 miles of city driving
Total MPG for 12,000 miles is 30.3 with 90% highway 10% Town
Total MPG for 15,000 is 31.0 with 93% Highway 7% City
Has anyone beat this for 15,000 miles?
When I am going downhill, I sometimes drop the tranny to neutral and coast much of the way. Is it bad for the automatic transmission to be popped in/out of neutral and/or left in neutral for extended periods?
Why in the world would you want to shift to neutral and coast? :confuse:
You might want to check your local laws, though. I don't know about California, but it's technically illegal to coast in neutral here.
Thanks to all for the great info on TSX mileage. I've about settled on one as my next ride. I get the feeling that it'll be a lot harder restraining my right foot in an Acura than a Hyundai, though!
I don't get it. I don't floor it, and always shift at around 3k rpm's..75% of my driving is highway, 25% city.
1) The trip miles - reset at each fill - does not total the total mileage accumulated. It is typically 1 to 2 miles lower on each fill than the total mileage being accumulated on the car. Initially I thought this was just me not resetting the mileage in time, but since I have been aware of it, I have deduced that it is the trip computer than can not add up, and not me.
2) The average mileage per gallon that is calculated on the trip computer is over calculated. Typically it reads 2 to 3 MPG over and above what I am calculating. Now I understand that by filling on different pumps that the gas used may be sightly under or over read, but it usually balances out over a few fills. But I am not seeing this. Take for instance, my last few fills. Last one was recorded at 29.9MPG by the car, 27.7MPG by me. The one previous to that was 29.8MPG by the car, 27.5 by me, and the one prior to that was about 27-28MPG by the car and 25.9 by me. I don't remember this last one exactly but it was significantly off and was the point that sparked my interest in the accuracy of the trip computer. It seems to be consistently off.
I am now adjusting my spreadsheet that I use to calculate my gas mileage to track the trip computer totals as well, just to see how bad the trip computer is.
Has anyone else been seeing this?
